my laptop bluetooth not show any nearby devices. it search endless.
my bluetooth device is 802.11b/g/n (1x1) and Bluetooth® 4.0 Combo
How to fix it.
I have tried all the solutions of Linux hint but my problem is not solved.
post output of lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f2:b56c Chicony Electronics Co., Ltd HP TrueVision HD
Bus 001 Device 002: ID 0a5c:216d Broadcom Corp. BCM43142A0 Bluetooth 4.0
I had the exact bluetooth card and it didnt detect devices
This worked for me.
basically you have to clone it using: git clone https://github.com/winterheart/broadcom-bt-firmware.git
Then cd broadcom-bt-firmware/brcm
Then sudo cp BCM43142A0-0a5c-216d.hcd /lib/firmware/brcm
Then reboot
not working…
Did you follow the steps and reboot?
yes i follow step.
Do you get any error?
no. i am not get any error.
post output of : dmesg | grep -i bluetooth | grep -i firmware
bluetooth is connected but not working properly. I have connected my device but the sound is coming intermittently
What bluetooth device are you connected to?
I have copied all the files.
how to solve this problem?
Is that bluetooth headphonses?
yes. it’s my headphone.
