Hello there,
I recently installed Manjaro KDE (had XFCE before) and everythings works fine besides blueetoth. Basically it doesnβt find any devices, it only worked once. How do I fix this?
No one know how to fix unless you give some information about your system.
Thank you for your reply. What kind of information should I send?
Howdy!
Can you try the following command, please?
sudo systemctl restart bluetooth
Have a wonderful day!
Welpz
That was quite easy I guess. It worked thank you very much
Youβre very welcome, friend!
I am sorry,
the problem is back again after turning off my pc. I tried to launch the same command with no luck this time
Everything is described in link. You should send at least inxi and journalctl output.
-- Logs begin at Fri 2020-10-02 14:58:29 CEST, end at Mon 2020-10-12 20:48:24 CEST. --
ott 02 14:58:29 HOST kernel: dw_dmac INTL9C60:00: Missing DT data
ott 02 14:58:30 HOST kernel: snd_hda_intel 0000:04:00.1: no codecs found!
ott 02 14:58:31 HOST kernel: sd 3:0:0:0: [sdc] No Caching mode page found
ott 02 14:58:31 HOST kernel: sd 3:0:0:0: [sdc] Assuming drive cache: write through
ott 02 14:58:33 HOST sddm-greeter[876]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
ott 02 14:58:33 HOST systemd-coredump[926]: Process 876 (sddm-greeter) of user 967 dumped core.
Stack trace of thread 876:
#0 0x00007f4d5f2ac615 raise (libc.so.6 + 0x3d615)
#1 0x00007f4d5f295862 abort (libc.so.6 + 0x26862)
#2 0x00007f4d5f6be9ac _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x8f9ac)
#3 0x00007f4d5fcaf546 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x131546)
#4 0x00007f4d5fcaf9e1 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x1319e1)
#5 0x00007f4d5f8e73e6 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2b83e6)
#6 0x00007f4d5fcb2a20 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x134a20)
#7 0x00007f4d5fcb3988 _ZN15QGuiApplicationC1ERiPPci (libQt5Gui.so.5 + 0x135988)
#8 0x0000564ce4643927 main (sddm-greeter + 0x19927)
#9 0x00007f4d5f297152 __libc_start_main (libc.so.6 + 0x28152)
#10 0x0000564ce4643f1e _start (sddm-greeter + 0x19f1e)
ββ Subject: Process 876 (sddm-greeter) dumped core
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ Documentation: man:core(5)
ββ
ββ Process 876 (sddm-greeter) crashed and dumped core.
ββ
ββ This usually indicates a programming error in the crashing program and
ββ should be reported to its vendor as a bug.
ott 02 14:58:33 HOST systemd-coredump[928]: Process 631 (Xorg) of user 0 dumped core.
Stack trace of thread 631:
#0 0x00007f8dc7c64615 raise (libc.so.6 + 0x3d615)
#1 0x00007f8dc7c4d862 abort (libc.so.6 + 0x26862)
#2 0x000055af1640924a OsAbort (Xorg + 0x14a24a)
#3 0x000055af1640ad11 FatalError (Xorg + 0x14bd11)
#4 0x000055af16410969 n/a (Xorg + 0x151969)
#5 0x00007f8dc7c646a0 __restore_rt (libc.so.6 + 0x3d6a0)
#6 0x00007f8dc7c64615 raise (libc.so.6 + 0x3d615)
#7 0x00007f8dc7c4d862 abort (libc.so.6 + 0x26862)
#8 0x00007f8dc7c4d747 __assert_fail_base.cold (libc.so.6 + 0x26747)
#9 0x00007f8dc7c5cbf6 __assert_fail (libc.so.6 + 0x35bf6)
#10 0x000055af16354960 n/a (Xorg + 0x95960)
#11 0x00007f8dc41cefb9 glamor_init (libglamoregl.so + 0xcfb9)
#12 0x00007f8dc433503d n/a (modesetting_drv.so + 0x1403d)
#13 0x000055af1633843e AddGPUScreen (Xorg + 0x7943e)
#14 0x000055af16444749 n/a (Xorg + 0x185749)
#15 0x000055af16479a68 n/a (Xorg + 0x1baa68)
#16 0x000055af1647a2f2 n/a (Xorg + 0x1bb2f2)
#17 0x000055af16408e91 n/a (Xorg + 0x149e91)
#18 0x000055af16404760 WaitForSomething (Xorg + 0x145760)
#19 0x000055af162f8914 n/a (Xorg + 0x39914)
#20 0x00007f8dc7c4f152 __libc_start_main (libc.so.6 + 0x28152)
#21 0x000055af162f95de _start (Xorg + 0x3a5de)
Stack trace of thread 758:
#0 0x00007f8dc77ce6a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x00007f8dc6b92e60 n/a (intel_drv.so + 0xb4e60)
#2 0x00007f8dc77c83e9 start_thread (libpthread.so.0 + 0x93e9)
#3 0x00007f8dc7d27293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 913:
#1 0x00007f8dbdd41e3c n/a (nouveau_dri.so + 0x4b0e3c)
#2 0x00007f8dbdd40838 n/a (nouveau_dri.so + 0x4af838)
#3 0x00007f8dc77c83e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007f8dc7d27293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 761:
#1 0x00007f8dc58aaa6c n/a (i965_dri.so + 0x51fa6c)
#2 0x00007f8dc58a9d88 n/a (i965_dri.so + 0x51ed88)
Stack trace of thread 915:
Stack trace of thread 760:
Stack trace of thread 916:
Stack trace of thread 762:
Stack trace of thread 763:
Stack trace of thread 914:
ββ Subject: Process 631 (Xorg) dumped core
ββ
ββ Process 631 (Xorg) crashed and dumped core.
ββ
ott 02 15:04:22 HOST bluetoothd[918]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
ott 02 15:04:22 HOST bluetoothd[918]: RFCOMM server failed for :1.691/Profile/HSPHS/00001108-0000-1000-8000-00805F9B34FB: rfcomm_bind: Address already in use (98)
ott 02 15:23:57 HOST systemd-coredump[13070]: Failed to send coredump datagram: Connection reset by peer
ott 02 15:23:59 HOST kernel: watchdog: watchdog0: watchdog did not stop!
ott 12 20:38:53 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
ott 12 20:39:04 HOST wpa_supplicant[1372]: wlp3s0: WPA: Group rekeying completed with b8:d5:26:49:fd:ac [GTK=CCMP]
ott 12 20:39:20 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:39:58 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:40:12 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:40:16 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:40:16 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25783, resource id: 73400327, major code: 15 (QueryTree), minor
code: 0
ott 12 20:40:16 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25788, resource id: 73400327, major code: 18 (ChangeProperty),
minor code: 0
ott 12 20:40:16 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 25956, resource id: 73400418, major code: 18 (ChangeProperty),
minor code: 0
ott 12 20:40:16 HOST systemd[1355]: app-org.kde.konsole-e620338057a44e89afdb7dbb9a7db553.scope: Succeeded.
ott 12 20:40:18 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:40:19 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo
ott 12 20:40:19 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly define
d onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
ott 12 20:40:19 HOST systemd[1355]: Started app-org.kde.konsole-59bf4653e3154e8da8beb08aaebba1c0.scope.
ott 12 20:40:20 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly define
ott 12 20:40:20 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:40:20 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:40:37 HOST kernel: [UFW BLOCK] IN=wlp3s0 OUT= MAC=44:1c:a8:29:f9:11:b8:d5:26:49:fd:aa:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1
ID=0 DF PROTO=2
ott 12 20:41:02 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:41:59 HOST kdeconnectd[1573]: QMetaObject::invokeMethod: No such method KIO::StoredTransferJob::slotDataReqFromDevice()
ott 12 20:41:59 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:41:59 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo pr
ott 12 20:41:59 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Im
plicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
ott 12 20:41:59 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:01 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:06 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:06 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo pr
ott 12 20:42:06 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Im
ott 12 20:42:06 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:08 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:12 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 50873, resource id: 44040519, major code: 73 (GetImage), mino
r code: 0
ott 12 20:42:12 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 50874, resource id: 44040519, major code: 73 (GetImage), mino
r code: 0
ott 12 20:42:12 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 50875, resource id: 44040519, major code: 73 (GetImage), mino
r code: 0
ott 12 20:42:12 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:16 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly define
ott 12 20:42:16 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:22 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:22 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:23 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:23 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo pr
ott 12 20:42:23 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Im
ott 12 20:42:23 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:25 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58596, resource id: 44040536, major code: 15 (QueryTree), minor
code: 0
ott 12 20:42:25 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:42 HOST kernel: [UFW BLOCK] IN=wlp3s0 OUT= MAC=44:1c:a8:29:f9:11:b8:d5:26:49:fd:aa:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1
ID=0 DF PROTO=2
ott 12 20:42:44 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:44 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo pr
ott 12 20:42:44 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Im
ott 12 20:42:44 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:46 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61296, resource id: 44040557, major code: 15 (QueryTree), minor
code: 0
ott 12 20:42:46 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:42:56 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:42:58 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:43:35 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:43:45 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:44:04 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:44:22 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:44:47 HOST kernel: [UFW BLOCK] IN=wlp3s0 OUT= MAC=44:1c:a8:29:f9:11:b8:d5:26:49:fd:aa:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1
ID=0 DF PROTO=2
ott 12 20:45:24 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:45:24 HOST systemd[1]: Starting Cleanup of Temporary Directories...
ott 12 20:45:25 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28102, resource id: 73402245, major code: 18 (ChangeProperty),
minor code: 0
ott 12 20:45:25 HOST systemd[1355]: app-org.kde.konsole-59bf4653e3154e8da8beb08aaebba1c0.scope: Succeeded.
ott 12 20:45:25 HOST systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
ott 12 20:45:25 HOST systemd[1]: Finished Cleanup of Temporary Directories.
ott 12 20:45:25 HOST audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/l
ib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ott 12 20:45:25 HOST audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/li
ott 12 20:45:25 HOST kernel: audit: type=1130 audit(1602528325.053:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean
comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ott 12 20:45:25 HOST kernel: audit: type=1131 audit(1602528325.053:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean
ott 12 20:45:25 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28136, resource id: 50331872, major code: 18 (ChangeProperty),
minor code: 0
ott 12 20:45:27 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29430, resource id: 12597232, major code: 3 (GetWindowAttribute
s), minor code: 0
ott 12 20:45:27 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29431, resource id: 12597232, major code: 14 (GetGeometry), m
inor code: 0
ott 12 20:46:52 HOST kernel: [UFW BLOCK] IN=wlp3s0 OUT= MAC=44:1c:a8:29:f9:11:b8:d5:26:49:fd:aa:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1
ID=0 DF PROTO=2
ott 12 20:47:10 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo
ott 12 20:47:10 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly define
ott 12 20:47:10 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63229, resource id: 50331884, major code: 18 (ChangeProperty),
minor code: 0
ott 12 20:47:10 HOST systemd[1355]: Started app-org.kde.konsole-51dee45bbaf94a268457c46903a6bb83.scope.
ott 12 20:47:10 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63880, resource id: 12602392, major code: 3 (GetWindowAttribute
s), minor code: 0
ott 12 20:47:10 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 63881, resource id: 12602392, major code: 14 (GetGeometry), m
inor code: 0
ott 12 20:47:10 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:47:10 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:47:11 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:47:14 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:47:18 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:47:19 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:47:20 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:47:20 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2868, resource id: 73400376, major code: 18 (ChangeProperty), m
inor code: 0
ott 12 20:47:20 HOST systemd[1355]: app-org.kde.konsole-51dee45bbaf94a268457c46903a6bb83.scope: Succeeded.
ott 12 20:47:50 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13608, resource id: 12602495, major code: 3 (GetWindowAttribute
s), minor code: 0
ott 12 20:47:50 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 13609, resource id: 12602495, major code: 14 (GetGeometry), m
inor code: 0
ott 12 20:47:53 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo
ott 12 20:47:53 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly define
ott 12 20:47:53 HOST systemd[1355]: Started app-org.kde.konsole-7066de00164c42218500679d4d03997f.scope.
ott 12 20:47:54 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16066, resource id: 12603820, major code: 3 (GetWindowAttribute
s), minor code: 0
ott 12 20:47:54 HOST kwin_x11[1467]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 16067, resource id: 12603820, major code: 14 (GetGeometry), m
inor code: 0
ott 12 20:47:54 HOST plasmashell[1561]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly define
ott 12 20:47:54 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:47:54 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:47:58 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:47:59 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:48:00 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:48:00 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:48:01 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:48:15 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:48:23 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:48:24 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:48:53 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:48:56 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:48:56 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:48:57 HOST kernel: [UFW BLOCK] IN=wlp3s0 OUT= MAC=44:1c:a8:29:f9:11:b8:d5:26:49:fd:aa:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1
ID=0 DF PROTO=2
ott 12 20:49:27 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:49:35 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:49:55 HOST plasmashell[1561]: qml: OpenWeatherMap.fetchDailyWeatherForecast
ott 12 20:49:55 HOST plasmashell[1561]: qml: OpenWeatherMap.fetchHourlyWeatherForecast
ott 12 20:49:55 HOST plasmashell[1561]: file:///home/USER/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/AgendaEventItem.qml:24:2: QML Conne
ctions: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
ott 12 20:49:56 HOST plasmashell[1561]: file:///home/USER/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/AgendaEventItem.qml:24:2: QML Conne
ott 12 20:50:53 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:50:53 HOST plasmashell[1561]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo
ott 12 20:51:01 HOST kwin_x11[1467]: qml: loadLayout TileLayout [TileLayout]
ott 12 20:51:02 HOST kernel: [UFW BLOCK] IN=wlp3s0 OUT= MAC=44:1c:a8:29:f9:11:b8:d5:26:49:fd:aa:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1
ID=0 DF PROTO=2
Is this correct?
