Hi there, after an update some weeks ago, my bluetooth stopped working (I couldn’t even scan anything), but I uninstalled everything and reinstalled it, and now my issue is totally different.
Simply put, when I scan for devices, nothing is found. I’ve tried systemctl restart bluetooth, bluetoothctl power on, rfkill unblock all and reinstalling everything again, but nothing works. Any ideas ?
I do not have any errors when I do scan on in bluetoothctl, but I do have one when I do scan off: Failed to stop discovery: org.bluez.Error.InProgress
Output of inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6411a68e-60d6-4014-8a05-25982b9d7998 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Laptop System: LENOVO product: 82UH v: Legion 7 16ARHA7
serial: <superuser required> Chassis: type: 10 v: Legion 7 16ARHA7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> UEFI: LENOVO v: K9CN34WW date: 07/22/2022
ID-1: BAT0 charge: 65.4 Wh (69.0%) condition: 94.8/99.9 Wh (94.9%)
volts: 15.7 min: 15.5 model: SMP L21M4PC5 type: Li-poly serial: <filter>
status: discharging cycles: 147
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/235/317
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: available: 30.55 GiB used: 10.77 GiB (35.2%)
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1979 high: 3300 min/max: 1600/4934 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1437 2: 2432
3: 1678 4: 1807 5: 1986 6: 3300 7: 1930 8: 1913 9: 1881 10: 1621 11: 1723
12: 1585 13: 1594 14: 1680 15: 2631 16: 2468 bogomips: 105453
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1, DP-2, HDMI-A-1, eDP-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-9,eDP-2
empty: DP-10, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8 bus-ID: 36:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 50.0 C
Device-3: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 30c9:0056 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu,amdgpu d-rect: 2560x3040 display-ID: 0
Monitor-1: DP-9 pos: primary,top res: 2560x1440 size: N/A modes: N/A
Monitor-2: eDP-2 pos: bottom res: 2560x1600 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (rembrandt
LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 36:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 36:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: wireplumber
status: active tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Lenovo driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0489:e0d8
Local Storage: total: 953.87 GiB used: 249.89 GiB (26.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CL1QGXA7 temp: 50.9 C
scheme: GPT
ID-1: / raw-size: 463.36 GiB size: 455.02 GiB (98.20%)
used: 249.81 GiB (54.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 6411a68e-60d6-4014-8a05-25982b9d7998
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 72.6 MiB (28.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 3E6E-7F4A
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 488.28 GiB fs: ntfs
label: Windows-SSD uuid: 7AC46F5CC46F1A21
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
label: WINRE_DRV uuid: D8506FC5506FA948
Device-1: 1-3:2 info: Luxvisions Innotech Integrated RGB Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 30c9:0056 class-ID: fe01 serial: <filter>
Device-2: 1-4:3 info: Integrated Express ITE Device(8258) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c978 class-ID: 0301
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Hub-4: 3-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 3-2.1:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-2.4:5 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:550a class-ID: ff00
Device-3: 3-3:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-2:2 info: Realtek Hub ports: 3 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Lenovo Hydra Force Sensor
type: abstract (modem),CDC-data,keyboard,HID
driver: cdc_acm,hid-generic,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 20mA
chip-ID: 17ef:6131 class-ID: 0300
Hub-8: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 7-1:2 info: Realtek 4-Port USB 2.1 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5423
Device-1: 7-1.2:3 info: Dell MS116 Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:301a class-ID: 0301
Device-2: 7-1.3:4 info: Dell KB216 Wired Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:2113 class-ID: 0300
Hub-11: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-12: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-13: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 58.9 C mobo: N/A
GPU: device: amdgpu temp: 50.0 C device: amdgpu temp: 51.0 C mem: 50.0 C
fan: 0 watts: 7.00
Processes: 390 Uptime: 38m wakeups: 14 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1398 libs: 378 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27```
