Bluetooth is not working (AX210)
I’m with the latest version of manjaro Minimal and with kernel 5.14 installed, the Wifi is working normal but the bluetooth is not working, even with the modules loaded, I have tested the test updates in archlinux with the latest kernel, it didn’t work either.
i already tried to remove the file “iwlwifi-ty-a0-gf-a0” and nothing changed. in other distros (fedora 34,slackware Current,zorinOS 16) it works fine
my inxi output:
  Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
  root=UUID=a22a02e0-13d9-4cb9-a707-198bcab554f2 rw rootflags=subvol=@ quiet
  resume=UUID=91f96fe3-d150-4dec-b85f-100f1c80475f udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K/BR v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 5603 date: 07/28/2020
  RAM: total: 15.56 GiB used: 2.16 GiB (13.9%)
  Info: 6-Core model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 3 MiB
  bogomips: 86258
  Speed: 2954 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 2954 2: 2503 3: 2169 4: 1845 5: 1863 6: 1862 7: 1996 8: 1920 9: 2562
  10: 2143 11: 1827 12: 2517
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep
  ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  disabled, RSB filling
  Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: eVga.com. driver: nvidia
  v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
  chip-ID: 10de:1e89 class-ID: 0300
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5")
  s-diag: 590mm (23.2")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
  diag: 584mm (23")
  OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
  Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
  v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.35 running: no
  vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
  bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
  port: f000 bus-ID: 07:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:3
  chip-ID: 8087:0032 class-ID: e001
  Local Storage: total: 1.58 TiB used: 13.79 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVME SSD 512GB size: 476.94 GiB
  block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  type: SSD serial: <filter> rev: T0707A0L temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDA240G
  size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 70RL scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD502HJ size: 465.76 GiB
  block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD
  rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Maxtor model: STM3160215AS
  size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
  type: N/A serial: <filter> rev: B scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST320LM001 HN-M320MBB
  size: 298.09 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  type: HDD rpm: 5400 serial: <filter> rev: 0002 scheme: GPT
  ID-1: / raw-size: 288.99 GiB size: 288.99 GiB (100.00%)
  used: 13.79 GiB (4.8%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50 label: N/A
  uuid: a22a02e0-13d9-4cb9-a707-198bcab554f2
  used: 568 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: NO_LABEL
  uuid: 812C-583D
  ID-3: /home raw-size: 288.99 GiB size: 288.99 GiB (100.00%)
  ID-4: /run/timeshift/backup raw-size: 288.99 GiB size: 288.99 GiB (100.00%)
  ID-5: /var/cache raw-size: 288.99 GiB size: 288.99 GiB (100.00%)
  ID-6: /var/log raw-size: 288.99 GiB size: 288.99 GiB (100.00%)
  dev: /dev/sdd3 maj-min: 8:51 label: swap
  uuid: 91f96fe3-d150-4dec-b85f-100f1c80475f
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 600 MiB fs: vfat label: N/A
  uuid: 6102-DD98
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 1024 MiB fs: ext4 label: N/A
  uuid: ebe3f1c0-b652-44e8-82b1-d374aeadcf21
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 475.35 GiB fs: btrfs
  label: fedora_localhost-live uuid: 71b47d82-9424-4354-a376-7c6f3c5bf426
  ID-4: /dev/sda1 maj-min: 8:1 size: 500 MiB fs: vfat label: N/A
  uuid: 367A-01CE
  ID-5: /dev/sda2 maj-min: 8:2 size: 8 GiB fs: swap label: N/A
  uuid: bb30301f-6c6e-4aca-9510-20749533d277
  ID-6: /dev/sda3 maj-min: 8:3 size: 215.08 GiB fs: btrfs label: N/A
  uuid: 9d7cb455-f31a-4780-a0d2-cc9bd54c6062
  ID-7: /dev/sdc1 maj-min: 8:33 size: 149.05 GiB fs: btrfs label: N/A
  uuid: 175f793b-df1b-417c-a43c-04f68c98945b
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
  Device-1: 1-5:3 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Microdia USB DEVICE type: Keyboard,Mouse
  power: 100mA chip-ID: 0c45:7697 class-ID: 0301
  Device-2: 5-4:3 info: Sunplus Innovation Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 36.1 C mobo: N/A gpu: nvidia temp: 35 C
  Processes: 347 Uptime: 25m wakeups: 0 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1093 lib: 406 Shell: Bash v: 5.1.8
  running-in: xfce4-terminal inxi: 3.3.06
using the command “dmesg | grep iwlwifi”…
[    9.915626] iwlwifi 0000:07:00.0: enabling device (0000 -> 0002)
[    9.917397] iwlwifi 0000:07:00.0: Direct firmware load for iwlwifi-ty-a0-gf-a0-64.ucode failed with error -2
[   10.003704] iwlwifi 0000:07:00.0: api flags index 2 larger than supported by driver
[   10.003722] iwlwifi 0000:07:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.25
[   10.003973] iwlwifi 0000:07:00.0: loaded firmware version 63.c04f3485.0 ty-a0-gf-a0-63.ucode op_mode iwlmvm
[   10.715480] iwlwifi 0000:07:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   10.864371] iwlwifi 0000:07:00.0: Detected RF GF, rfid=0x10d000
[   10.865350] iwlwifi 0000:07:00.0: Microcode SW error detected. Restarting 0x0.
[   10.865451] iwlwifi 0000:07:00.0: Start IWL Error Log Dump:
[   10.865453] iwlwifi 0000:07:00.0: Transport status: 0x0000004A, valid: 6
[   10.865455] iwlwifi 0000:07:00.0: Loaded firmware version: 63.c04f3485.0 ty-a0-gf-a0-63.ucode
[   10.865456] iwlwifi 0000:07:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[   10.865458] iwlwifi 0000:07:00.0: 0x002002F0 | trm_hw_status0
[   10.865459] iwlwifi 0000:07:00.0: 0x00000000 | trm_hw_status1
[   10.865460] iwlwifi 0000:07:00.0: 0x004DA004 | branchlink2
[   10.865462] iwlwifi 0000:07:00.0: 0x004D07EA | interruptlink1
[   10.865463] iwlwifi 0000:07:00.0: 0x004D07EA | interruptlink2
[   10.865464] iwlwifi 0000:07:00.0: 0x004D8DEA | data1
[   10.865464] iwlwifi 0000:07:00.0: 0x00000010 | data2
[   10.865465] iwlwifi 0000:07:00.0: 0x00000000 | data3
[   10.865466] iwlwifi 0000:07:00.0: 0x00000000 | beacon time
[   10.865467] iwlwifi 0000:07:00.0: 0x00011401 | tsf low
[   10.865468] iwlwifi 0000:07:00.0: 0x00000000 | tsf hi
[   10.865469] iwlwifi 0000:07:00.0: 0x00000000 | time gp1
[   10.865470] iwlwifi 0000:07:00.0: 0x0002261A | time gp2
[   10.865471] iwlwifi 0000:07:00.0: 0x00000001 | uCode revision type
[   10.865472] iwlwifi 0000:07:00.0: 0x0000003F | uCode version major
[   10.865473] iwlwifi 0000:07:00.0: 0xC04F3485 | uCode version minor
[   10.865474] iwlwifi 0000:07:00.0: 0x00000420 | hw version
[   10.865475] iwlwifi 0000:07:00.0: 0x18C89002 | board version
[   10.865476] iwlwifi 0000:07:00.0: 0x8008FF00 | hcmd
[   10.865477] iwlwifi 0000:07:00.0: 0x00020000 | isr0
[   10.865478] iwlwifi 0000:07:00.0: 0x60000000 | isr1
[   10.865479] iwlwifi 0000:07:00.0: 0x58F00002 | isr2
[   10.865480] iwlwifi 0000:07:00.0: 0x00C0000C | isr3
[   10.865481] iwlwifi 0000:07:00.0: 0x00000000 | isr4
[   10.865482] iwlwifi 0000:07:00.0: 0x00000000 | last cmd Id
[   10.865483] iwlwifi 0000:07:00.0: 0x004D8DEA | wait_event
[   10.865484] iwlwifi 0000:07:00.0: 0x00000000 | l2p_control
[   10.865485] iwlwifi 0000:07:00.0: 0x00000000 | l2p_duration
[   10.865486] iwlwifi 0000:07:00.0: 0x00000000 | l2p_mhvalid
[   10.865486] iwlwifi 0000:07:00.0: 0x00000000 | l2p_addr_match
[   10.865487] iwlwifi 0000:07:00.0: 0x00000009 | lmpm_pmg_sel
[   10.865488] iwlwifi 0000:07:00.0: 0x00000000 | timestamp
[   10.865489] iwlwifi 0000:07:00.0: 0x00000024 | flow_handler
[   10.865528] iwlwifi 0000:07:00.0: Start IWL Error Log Dump:
[   10.865529] iwlwifi 0000:07:00.0: Transport status: 0x0000004A, valid: 7
[   10.865530] iwlwifi 0000:07:00.0: 0x2010070D | ADVANCED_SYSASSERT
[   10.865532] iwlwifi 0000:07:00.0: 0x00000000 | umac branchlink1
[   10.865533] iwlwifi 0000:07:00.0: 0x8045CF40 | umac branchlink2
[   10.865534] iwlwifi 0000:07:00.0: 0x0108E0B2 | umac interruptlink1
[   10.865535] iwlwifi 0000:07:00.0: 0x00000000 | umac interruptlink2
[   10.865536] iwlwifi 0000:07:00.0: 0x00000005 | umac data1
[   10.865536] iwlwifi 0000:07:00.0: 0xDEADBEEF | umac data2
[   10.865537] iwlwifi 0000:07:00.0: 0xDEADBEEF | umac data3
[   10.865538] iwlwifi 0000:07:00.0: 0x0000003F | umac major
[   10.865539] iwlwifi 0000:07:00.0: 0xC04F3485 | umac minor
[   10.865540] iwlwifi 0000:07:00.0: 0x00022612 | frame pointer
[   10.865541] iwlwifi 0000:07:00.0: 0xC0885E90 | stack pointer
[   10.865542] iwlwifi 0000:07:00.0: 0x00010C00 | last host cmd
[   10.865543] iwlwifi 0000:07:00.0: 0x00000000 | isr status reg
[   10.865555] iwlwifi 0000:07:00.0: IML/ROM dump:
[   10.865556] iwlwifi 0000:07:00.0: 0x00000B03 | IML/ROM error/state
[   10.865567] iwlwifi 0000:07:00.0: 0x00007193 | IML/ROM data1
[   10.865579] iwlwifi 0000:07:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[   10.865587] iwlwifi 0000:07:00.0: Fseq Registers:
[   10.865590] iwlwifi 0000:07:00.0: 0x60000100 | FSEQ_ERROR_CODE
[   10.865594] iwlwifi 0000:07:00.0: 0x00440003 | FSEQ_TOP_INIT_VERSION
[   10.865597] iwlwifi 0000:07:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[   10.865601] iwlwifi 0000:07:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[   10.865605] iwlwifi 0000:07:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[   10.865608] iwlwifi 0000:07:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[   10.865612] iwlwifi 0000:07:00.0: 0x00400410 | FSEQ_CNVI_ID
[   10.865616] iwlwifi 0000:07:00.0: 0x00400410 | FSEQ_CNVR_ID
[   10.865619] iwlwifi 0000:07:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[   10.865625] iwlwifi 0000:07:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[   10.865631] iwlwifi 0000:07:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   10.865637] iwlwifi 0000:07:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   10.865665] iwlwifi 0000:07:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   11.722769] iwlwifi 0000:07:00.0: Failed to run INIT ucode: -5
Welcome to the forum! :wave:
Have you searched the forum? :wink:
Tip: When pasting terminal output on Discourse forums, one can either…
  • Highlight it and use the Preformatted text </> toolbar button.
  • Add three backticks ` above and below the text (Markdown):
    text
  • Use HTML:
    <pre><code>
    text
    </pre></code>
Please also post your system info as outlined here:
So for AX200 & AX201, there is a regression issue with linux-firmware for bluetooth. WiFi would work 100% fine, but bluetooth does not. It either does not connect, or it keeps constantly disconnect. From a really quick online search, AX210 has the same issue.
Though for some people using the AX210, they fixed it by using different kernels.
You might want to try the linux-firmware-git package from the AUR.
A new firmware file for that bluetooth chip has been added 4 days ago:
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/commit/?id=087753f61e17ac978c97bc9e838bd64837675c44
After installing the firmware package, make sure to do a cold boot (full shutdown, not just reboot).
I had a look, and couldn’t find a solution
strange, I have dualboot with fedora 34, and it is running normal with the latest updates
In my tests, every time I change the firmware the bluetooth is working normally, but after I restart the bluetooth it’s back to trouble.
I installed the last available firmware and now it is working again but I am sure that if I restart it the bluetooth will have a problem.
so please read this:
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”. :grin:
:crossed_fingers:
I’m having the exact same issues as @EduardoFox3 - the bluetooth is not working unless I switch the firmware. Then it works until the next reboot and stops working again until firmware change. I tried all the kernels from 5.10 LTS to 5.15 RC with the same result.
Do you have the same chipset?
What are you doing exactly?
:thinking:
Yes, I have the same Intel AX210 chipset.
Reg. firmware I’m downgrading (or upgrading) linux-firmware to lower (or higher) version. The strange behavior is that the bluetooth always works after up/down grade once rebooted, and it always stops working after the next reboot. Kernel change seems to have no impact on that whatsoever (as long as the version is above 5.10 - probably this chipset was not included before that).
Does it work if you do a cold boot (shutdown) instead?
What if you unload and load the module again?
sudo modprobe -r iwlmvm iwlwifi && sudo modprobe iwlwifi
No, it doesn’t change anything.
Also doesn’t affect the issue.
Hmm, ok. I assumed it was the same issue as mentioned here in the bug-report below:
Apparently not though.
https://bugzilla.kernel.org/show_bug.cgi?id=213829
btw. There was yet another firmware update for AX210, 12 days ago.
I’d give that one a try. Maybe it’s fixing it:
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/commit/?id=da9bbff78d2bb838ec9f14139cc02a064743def2
any success? is it working after a reboot?
No, after a reboot the bluetooth is still not available.(Intel AX210)
