I Have A Boat Rockerz 400 Im Trying tO Connect To My System But it Does Not Connect It Says Setup Has Failed Any Help Would Be Apprecated
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. - What are the exact steps you’re taking to connect this headset?
- Arrête De Mettre Des Majustcules A Chaque Mot STP ?
Kernel: 5.12.14-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=f61b9720-362c-4610-be2c-6adcc5d3b48e rw rootflags=subvol=@ quiet
loglevel=3 audit=0
Desktop: KDE Plasma 5.22.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
dm: SDDM Distro: Aravalli Linux 6
Type: Laptop System: Dell product: OptiPlex 790 v: 01 serial: <filter>
Chassis: type: 16 serial: <filter>
Mobo: Dell model: 0NKW6Y v: A00 serial: <filter> BIOS: Dell v: A05
date: 05/28/2011
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
RAM: total: 7.65 GiB used: 1.73 GiB (22.7%)
RAM Report:
missing: Required tool dmidecode not installed. Check --recommends
Info: Quad Core model: Intel Core i5-2500 bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 14
cache: L2: 6 MiB bogomips: 26348
Speed: 1650 MHz min/max: 1600/3700 MHz Core speeds (MHz): 1: 1650 2: 3592
3: 2944 4: 1753
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority fpu fxsr ht ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt
pse pse36 pti pts rdtscp rep_good sep smx sse sse2 sse4_1 sse4_2 ssse3
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0102
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: fbdev,modesetting,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: VGA1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8")
diag: 609mm (24")
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.12.14-arch1-1 running: yes
Sound Server-4: PipeWire v: 0.3.31 running: no
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 2-1.2:4 chip-ID: 0bda:8179 class-ID: 0000
serial: <filter>
IF: wlp0s29u1u2 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 2-1.1:3 chip-ID: 0a12:0001 class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 447.13 GiB used: 17.91 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650 size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 4c18 scheme: MBR
Optical-1: /dev/sr0 vendor: TEAC model: DV-28S-W rev: U.2A dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: none
state: running
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 17.91 GiB (35.8%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: f61b9720-362c-4610-be2c-6adcc5d3b48e
ID-2: /home raw-size: 50 GiB size: 50 GiB (100.00%) used: 17.91 GiB (35.8%)
ID-3: /var/cache raw-size: 50 GiB size: 50 GiB (100.00%)
used: 17.91 GiB (35.8%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: /dev/sda1 maj-min: 8:1 size: 148.36 GiB fs: ntfs
label: System Reserved uuid: DCE4038AE40365DC
ID-2: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-3: /dev/sda5 maj-min: 8:5 size: 148.41 GiB fs: ntfs label: NAZIYA3
uuid: 01D73BFDA5F85900
ID-4: /dev/sda6 maj-min: 8:6 size: 100.36 GiB fs: ntfs label: Win10
uuid: 01D73BFE1C8D4030
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 2-1.2:4 info: Realtek RTL8188EUS 802.11n Wireless Network Adapter
type: Network driver: r8188eu interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
Device-3: 2-1.4:5 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-4: 2-1.5:6 info: Brother Industries DCP-L2520D type: Printer
driver: usblp interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04f9:0324 class-ID: 0701 serial: <filter>
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 209 Uptime: 8m wakeups: 5 Init: systemd v: 248
target: graphical.target tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 797 lib: 195 Shell: fish v: 3.2.2 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.04
Désolé d’être en retard
I’m afraid you won’t get support from the Manjaro community since you’re running an Arch derivative.
That being said, your best bet is to follow the guidelines for Bluetooth Headsets on Arch Wiki.
Hope the above helps. I’ll go ahead closing this topic.
