Bluetooth error with blueman-manager: Theme parsing error: gtk.css
So I got the next error while trying to restart blueman-manager (I had no problems yesterday with bluetooth)
blueman-manager
(blueman-manager:133443): Gtk-WARNING **: 10:54:48.897: Theme parsing error: gtk.css:73:10: 'overflow' is not a valid property name
(blueman-manager:133443): Gtk-WARNING **: 10:54:48.921: Theme parsing error: gtk.css:4091:13: negative values are not allowed.
(blueman-manager:133443): Gtk-WARNING **: 10:54:48.934: Theme parsing error: gtk.css:7855:13: negative values are not allowed.
(blueman-manager:133443): Gtk-WARNING **: 10:54:48.935: Theme parsing error: gtk.css:8039:19: negative values are not allowed.
(blueman-manager:133443): Gtk-WARNING **: 10:54:48.936: Theme parsing error: gtk.css:8317:21: negative values are not allowed.
(blueman-manager:133443): Gtk-WARNING **: 10:54:48.936: Theme parsing error: gtk.css:8318:24: negative values are not allowed.
blueman-manager 10.54.49 ERROR    Manager:147 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 10.54.49 ERROR    Manager:151 on_dbus_name_appeared: No adapter(s) found, exiting
I tried to change to other theme as suggested on this solution: Theme parsing error: gtk.css:--after installing code-oss
And tried to restart blueman-manager, that’s when I got:
blueman-manager
(blueman-manager:115306): Gtk-WARNING **: 10:48:27.194: Theme parsing error: gtk.css:73:10: 'overflow' is not a valid property name
blueman-manager 10.48.27 ERROR    Manager:147 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 10.48.27 ERROR    Manager:151 on_dbus_name_appeared: No adapter(s) found, exiting
Do you need any more information from my end? Please let me know
journalctl --boot 0 --dmesg --no-hostname --no-pager --grep "bluetooth"
See this:
Ok so this is the output of the commands you mentioned:
journalctl --boot 0 --dmesg --no-hostname --grep "bluetooth"
Jul 14 09:36:47 kernel: usb 2-7: Product: Bluetooth Radio
Jul 14 09:37:03 kernel: Bluetooth: Core ver 2.22
Jul 14 09:37:03 kernel: NET: Registered PF_BLUETOOTH protocol family
Jul 14 09:37:03 kernel: Bluetooth: HCI device and connection manager initialized
Jul 14 09:37:03 kernel: Bluetooth: HCI socket layer initialized
Jul 14 09:37:03 kernel: Bluetooth: L2CAP socket layer initialized
Jul 14 09:37:03 kernel: Bluetooth: SCO socket layer initialized
Jul 14 09:37:03 kernel: Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
Jul 14 09:37:03 kernel: Bluetooth: hci0: RTL: rom_version status=0 version=1
Jul 14 09:37:03 kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
Jul 14 09:37:03 kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
Jul 14 09:37:03 kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with er>
lines 1-12
Let me check the solution to that old bug
The output of the second terminal is the following:
[ 7474.522848] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
[ 7502.152965] usbcore: deregistering interface driver btusb
[ 7512.607204] usbcore: registered new interface driver btusb
[ 7512.829802] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 7512.830789] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 7512.830793] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 7512.840508] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 7512.840628] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 7512.840645] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 7513.276813] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 7513.386322] Bluetooth: MGMT ver 1.22
[ 7513.419154] NET: Registered PF_ALG protocol family
[ 7513.548277] Bluetooth: RFCOMM TTY layer initialized
[ 7513.548292] Bluetooth: RFCOMM socket layer initialized
[ 7513.548297] Bluetooth: RFCOMM ver 1.11
[ 7600.477616] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
[ 7648.315458] input: Bose SLIII (AVRCP) as /devices/virtual/input/input13
[ 7726.531669] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
[ 7852.489637] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
[ 7978.540534] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
[ 8104.596414] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
[ 8230.549554] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:28:3a:4d:9b:13:46:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 PROTO=2
Yes, after trying to execute blueman-manager it actually did the work. However the error regarding GTK with the theme parsing persist (in my despair I went back to my previous theme), should I change it?
 blueman-manager
(blueman-manager:227554): Gtk-WARNING **: 11:43:33.431: Theme parsing error: gtk.css:73:10: 'overflow' is not a valid property name
(blueman-manager:227554): Gtk-WARNING **: 11:43:33.454: Theme parsing error: gtk.css:4091:13: negative values are not allowed.
(blueman-manager:227554): Gtk-WARNING **: 11:43:33.472: Theme parsing error: gtk.css:7855:13: negative values are not allowed.
(blueman-manager:227554): Gtk-WARNING **: 11:43:33.472: Theme parsing error: gtk.css:8039:19: negative values are not allowed.
(blueman-manager:227554): Gtk-WARNING **: 11:43:33.473: Theme parsing error: gtk.css:8317:21: negative values are not allowed.
(blueman-manager:227554): Gtk-WARNING **: 11:43:33.473: Theme parsing error: gtk.css:8318:24: negative values are not allowed.
Otherwise, as you said, I think the solution was reloading the driver
