Bluetooth doesn't work on AX200
This is on Kernel 6.1 but this actually started a while back on 5.15.
The System Settings GUI says “Bluetooth is disabled” and there’s an “Enable” button that does nothing. I can’t pair new devices. But, I’ve had KDE Connect linking my phone & desktop since I was using 5.4.
It still works I can send files over KDE Connect no problem. At no point did it stop working. Clearly bluetooth is working to some degree. I don’t understand it, and I’m still to green to know where to start fixing this in bash.
Any ideas?
Can you provide system information and report the result of the following command please?
systemctl status bluetooth
KDE connect uses the local network by default, not Bluetooth.
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Thu 2023-04-27 19:32:48 EDT; 1h 30min ago
       Docs: man:bluetoothd(8)
   Main PID: 907 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 96438)
     Memory: 2.2M
        CPU: 18ms
     CGroup: /system.slice/bluetooth.service
             └─907 /usr/lib/bluetooth/bluetoothd
Apr 27 19:32:48 cyrano-station bluetoothd[907]: Bluetooth daemon 5.66
Apr 27 19:32:48 cyrano-station bluetoothd[907]: Starting SDP server
Apr 27 19:32:48 cyrano-station bluetoothd[907]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Apr 27 19:32:48 cyrano-station bluetoothd[907]: src/plugin.c:plugin_init() Failed to init vcp plugin
Apr 27 19:32:48 cyrano-station bluetoothd[907]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Apr 27 19:32:48 cyrano-station bluetoothd[907]: src/plugin.c:plugin_init() Failed to init mcp plugin
Apr 27 19:32:48 cyrano-station bluetoothd[907]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Apr 27 19:32:48 cyrano-station bluetoothd[907]: src/plugin.c:plugin_init() Failed to init bap plugin
Apr 27 19:32:48 cyrano-station systemd[1]: Started Bluetooth service.
Apr 27 19:32:48 cyrano-station bluetoothd[907]: Bluetooth management interface 1.22 initialized
Please also post system info.
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=a9e31dae-9c1d-43e5-8b4c-5cd1ca90b685 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.30
    date: 07/19/2019
  RAM: total: 78.5 GiB used: 4.85 GiB (6.2%)
  Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 4101 high: 4223 min/max: N/A cores: 1: 4205 2: 4200
    3: 4223 4: 3800 5: 4191 6: 4200 7: 4200 8: 4200 9: 4199 10: 3800 11: 3800
    12: 4198 bogomips: 91245
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdt_a rdtscp
    rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:13c2 class-ID: 0300
  Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2e:00.0 chip-ID: 10de:13c2
    class-ID: 0300
  Display: x11 server: `X.Org` v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
    s-diag: 693mm (27.28")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
    970/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 1-1:2 chip-ID: 0c76:161e pcie: gen: 3
    class-ID: 0300 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 2d:00.1
    chip-ID: 10de:0fbb class-ID: 0403
  Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2e:00.1 chip-ID: 10de:0fbb
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 30:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: JMTek LLC. USB PnP Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: pulseaudio-jack
    type: module tools: pacat,pactl
  Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter
    driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 25:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 26:00.0
  IF: enp38s0 state: down mac: <filter>
  Device-3: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 27:00.0
  IF: enp39s0 state: down mac: <filter>
  Device-4: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
  Local Storage: total: 3.18 TiB used: 338.68 GiB (10.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    type: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD30PURX-64P6ZY0 size: 2.73 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A80 scheme: GPT
  Optical-1: /dev/sr0 vendor: ATAPI model: iHDS118 7 rev: VL08
    dev-links: cdrom
  Features: speed: 48 multisession: yes audio: yes dvd: yes rw: none
    state: running
  ID-1: / raw-size: 465.47 GiB size: 457.09 GiB (98.20%)
    used: 338.68 GiB (74.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: a9e31dae-9c1d-43e5-8b4c-5cd1ca90b685
    used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 04CF-40D0
  ID-1: /dev/sdb1 maj-min: 8:17 size: 878.91 GiB fs: ext4 label: Games
    uuid: b19deb6f-0fcf-4f7b-a180-48100d8192d3
  ID-2: /dev/sdb2 maj-min: 8:18 size: 878.91 GiB fs: ext4 label: Video
    uuid: 639d9573-a859-4496-b550-bd4dbd2ba0d2
  ID-3: /dev/sdb3 maj-min: 8:19 size: 1.01 TiB fs: ext4 label: Backups
    uuid: b65ec042-f176-4e09-bb2a-eef2c45adbdf
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-1:2 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0c76:161e class-ID: 0300
  Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Micro Star MEG X570 ACE type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA
    chip-ID: 1462:7c35 class-ID: 0300 serial: <filter>
  Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Corsair Gaming SCIMITAR RGB Mouse type: Mouse,HID
    driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
    chip-ID: 1b1c:1b1e class-ID: 0300 serial: <filter>
  Device-2: 5-2:3 info: Corsair STRAFE RGB Gaming Keyboard type: Keyboard,HID
    driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
    chip-ID: 1b1c:1b20 class-ID: 0300 serial: <filter>
  Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 51.1 C mobo: N/A
  Processes: 298 Uptime: 23h 10m wakeups: 0 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1654 pm: pacman pkgs: 1642 libs: 437 tools: pamac pm: flatpak
  pkgs: 12 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.26
Please format your output, as shown in the guide.
Sorry, I edited it. Let me know if there are any other problems.
Does anyone know how I might fix this issue?
Sorry, it seems this thread slipped my notice. What about the output of the following?
sudo dmesg | grep -i blue
No worries
[    5.070452] Bluetooth: Core ver 2.22
[    5.070508] NET: Registered PF_BLUETOOTH protocol family
[    5.070509] Bluetooth: HCI device and connection manager initialized
[    5.070520] Bluetooth: HCI socket layer initialized
[    5.070524] Bluetooth: L2CAP socket layer initialized
[    5.070531] Bluetooth: SCO socket layer initialized
[    5.907565] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.907569] Bluetooth: BNEP filters: protocol multicast
[    5.907572] Bluetooth: BNEP socket layer initialized
[    7.283347] Bluetooth: hci0: command 0xfc05 tx timeout
[    7.283353] Bluetooth: hci0: Reading Intel version command failed (-110)```
Some research suggests that this is a bug in the kernel affecting various bluetooth cards, including yours (AX200), for Kernels 5.15+
https://bugzilla.kernel.org/show_bug.cgi?id=215167
What happens if you try 5.10?
That fixed it! I was on 6.2 before switching to 5.10.
What, if anything, does this mean for newer kernel versions? Is this a bug that’s libel to get taken care of eventually, or is this a case of hardware being so prickly or unsupported that it’s going to be an ongoing problem?
You can periodically check other/newer kernels … possibly in connection with some configuration or extra package(s) … until then you will miss out on some of the new ‘shiny’ things in more recent kernel releases … but that rarely matters for much if you dont have newer hardware.
And for some peace of mind … 5.10 should be alive for some time still … with a projected EOL (end-of-life) set at December 2026.
Some commenters on the issue claimed to have solved it with a minor patch. If you’re down to compile your own kernel, you could try applying it now. In theory, this should mean that it can be solved in the future. However, I don’t know enough about kernel development to say what will happen.
If you make an account on bugzilla.kernel.org you should be able to add yourself to the CC list to stay updated on what happens.
