my apologies because of my work i only get a limited amount of time to work on the issues on my computer and the ntfs drives became a more pressing matter then the controller.
here is all the information my computer showed.
Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=b1fe8657-97e8-4713-8e28-42122a027b55 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: Micro-Star product: MS-7C37 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: A.C0 date: 01/25/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 13.55 GiB used: 3.54 GiB (26.1%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: BL8G32C16U4RL.M8FE serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
microcode: 0xA500011
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1400 min/max: 1400/3800 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 121428
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
Writeback-1 bus-ID: 12:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none empty: HDMI-A-2
bus-ID: 30:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 33.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-3 mapped: DisplayPort-2 model: Acer XF250Q serial: <filter>
built: 2020 res: N/A dpi: 90 gamma: 1.2 chroma: red: x: 0.655 y: 0.329 green:
x: 0.322 y: 0.627 blue: x: 0.153 y: 0.071 white: x: 0.314 y: 0.329
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480,
720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
navi31 LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638 surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 12:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1
chip-ID: 1002:1637 class-ID: 0403
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp41s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6.3:5 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 6.37 TiB used: 4.64 TiB (72.8%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000BX500SSD1
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 030 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT4000MX500SSD1
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-1: / raw-size: 465.86 GiB size: 457.48 GiB (98.20%)
used: 210.63 GiB (46.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: b1fe8657-97e8-4713-8e28-42122a027b55
used: 25.6 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4EF3-82CB
ID-3: /run/media/razzancar/Storage raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 2.95 TiB (81.1%) fs: ntfs dev: /dev/sdb2
maj-min: 8:18 label: Storage uuid: 70BA42DBBA429E0A
ID-4: /run/media/razzancar/Storage1 raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.48 TiB (81.2%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: Storage uuid: 60F2C5BDF2C597A4
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 465.04 GiB fs: ntfs label: N/A
uuid: 882AF4362AF422BC
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 1E2207F92207D525
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
Device-1: 1-6:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c37 class-ID: 0300
serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-6.2:4 info: Cooler Master AMD SR4 lamplight Control
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 2516:0051 class-ID: 0300
Device-2: 3-6.3:5 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 37.6 C mobo: 32.2 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 48.0 C mem: 54.0 C fan: 55 watts: 21.00
device: amdgpu temp: 33.0 C
Packages: 1487 pm: pacman pkgs: 1478 libs: 479 tools: pamac pm: flatpak
pkgs: 9
1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
2: http://mirror.fcix.net/manjaro/stable/$repo/$arch
3: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
4: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
5: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
6: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
7: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
8: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
Processes:
CPU top: 5 of 338
1: cpu: 24.2% command: steam pid: 2089 mem: 442.8 MiB (3.1%)
2: cpu: 7.2% command: steamwebhelper pid: 2433 mem: 493.9 MiB (3.5%)
3: cpu: 5.5% command: sdb2 started-by: mount.lowntfs-3g pid: 719
mem: 1.95 MiB (0.0%)
4: cpu: 4.8% command: steamwebhelper pid: 2361 mem: 255.3 MiB (1.8%)
5: cpu: 3.6% command: firefox pid: 5032 mem: 499.1 MiB (3.5%)
Memory top: 5 of 338
1: mem: 499.1 MiB (3.5%) command: firefox pid: 5032 cpu: 3.6%
2: mem: 493.9 MiB (3.5%) command: steamwebhelper pid: 2433 cpu: 7.2%
3: mem: 442.8 MiB (3.1%) command: steam pid: 2089 cpu: 24.2%
4: mem: 397.1 MiB (2.8%) command: plasmashell pid: 1027 cpu: 0.0%
5: mem: 394.6 MiB (2.8%) command: ./steamwebhelper pid: 2338 cpu: 1.3%
Processes: 338 Power: uptime: 2h 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.4 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
