Airpods Pro Not Connecting
I am trying to listen to my music on my Manjaro (KDE Plasma, Stable) using my Airpods Pro.
I could pair them I believe after following the steps here Bluetooth Questions - Airpods - #5 by zzp1012
Now I see my Airpods Pro in bluetooth, I tried to press the connect button but I got a message saying "Connection to the device failed "
I disabled bluetooth, enabled, rebooted… etc. Still not connecting.
I did my homework and searched the forum and found Automatic Bluetooth Pairing - Headphones - #3 by A4orce84
But this is about auto connecting Airpods AND suggested using something from AUR (which I won’t like to try)
What can I do to get my Airpods automatically connects to my system when I put them on.
I see it “Paired” and “Trusted”.
Update:
In settings I get “br-connection-canceled”
Thanks.
The key is to trust the device first, otherwise the Device connection will be refused.
Trust>Pair>connect
I see it is already trusted. Though I don’t remember I saw something on the screen asking me to trust it.
Where to reach this?
This doesn’t mean much… it must be set in the correct order.
You can find a Search function, right click on the bluetooth icon in your taskbar.
When you see your device in the GUI, you can right click on it.
I just deleted, repeated from the beginning till I got "The device ‘xxx’s AirPods Pro’ has been set up and can now be used. "
Now I see it is connected but no sound coming to it! (surprisingly not even in headphones or speakers! - they were working)
That seems odd. On mate I always pair then trust.
I also get a popup notification (several actually) asking for permission to connect, with 3 options, Allow, Always Allow, and Cancel. For auto connection Always Allow has to be selected. This is with some cheap bluetooth headphones.
That’s what happens if I don’t allow.
I didn’t get any of these.
Now, clicking the speaker button in the toolbar I get like a menu with 3 options: 1- Speakers 2 - Headphones (with the name of my Airpods), 3 - Internal Microphone.
with an option to select any of them.
Selecting the first one I get sound now in speakers and on headphones (when plugged 3.5 mm) Selecting the second option which is my Airpods I get nothing.
WOW.
I disconnected the Airpods (from the blutooth icon) then connected again and it just worked.
So, it is OK now.
@Kobold, you really helped when you mentioned the order to be done.
Thank you for your help.
I know it is odd :wink:
I was thinking the same, as i bought a brand new Bluetooth stick and a Brandnew XBox One X/s wireless gamepad, 3 year’s ago and i was ripping my hair off but only Trust>Pair>Connect was working… otherwise Gandalf will tell your device “You shall not pass!” :man_mage:
I have no idea about the logic behind this, not to pair your device first… and set “trusted” after it… but it is as it is.
Im glad i could help :slight_smile:
All distros I tried before I had to be clicking accept, yes, ok, … etc
This is a good thing it just did it on its own.
Maybe once I am connecting it myself this means it should be automatically as well trusted.
The thing I found weird really was that it got connected automatically but no sound till I disconnected and connected again.
The next time or after a restart, it should connect automatically without doing anything special.
At least this is how it works with my xbox bluetooth gamepad.
