Bluetooth and USB Panel randomly do not turn on/work at boot
Hello,
I am dealing with an issue where sometimes on boot my usb 2.0 ports and bluetooth card don’t activate. This issue only happens on boot into linux and I have to reboot my computer until both devices turn on.
In my tests, I found that when looking at the bios both devices work correctly, however when exiting bios and starting manjaro, the devices could “turn off”. I observed the mouse light and it would turn off during to booting of linux itself.
I am currently on the unstable branch and kernel 6.9, but I encountered this issue on kernel 6.6, 6.8 and while on the stable branch.
My best guess this is an issue with the linux kernel with my computer, is there a grub boot command that can guarantee the usb ports and bluetooth will turn on when manjaro boots up?
Below are the journalctl errors I encounter during a broken boot, and a working boot.
Broken boot
journalctl --boot=-1 --priority=3 --no-pager         ✔
Jun 01 08:21:08 jacob-b650mprorswifi kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 01 08:21:13 jacob-b650mprorswifi wpa_supplicant[714]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 08:21:14 jacob-b650mprorswifi kernel: Bluetooth: hci0: Failed to get device id (-110)
Jun 01 08:21:16 jacob-b650mprorswifi wpa_supplicant[714]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 08:21:21 jacob-b650mprorswifi kernel: usb 1-8: Failed to suspend device, error -110
Jun 01 08:21:32 jacob-b650mprorswifi kernel: usbhid 1-7.3:1.1: can't add hid device: -110
Jun 01 08:21:32 jacob-b650mprorswifi kernel: usbhid 1-7.3:1.1: probe with driver usbhid failed with error -110
Jun 01 08:21:37 jacob-b650mprorswifi kernel: hub 1-7:1.0: hub_ext_port_status failed (err = -110)
Jun 01 08:21:41 jacob-b650mprorswifi dbus-broker-launch[633]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jun 01 08:21:41 jacob-b650mprorswifi systemd[1]: Failed unmounting /var/cache.
Working boot
journalctl --boot=0 --priority=3 --no-pager         ✔
Jun 01 08:22:11 jacob-b650mprorswifi kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 01 08:22:16 jacob-b650mprorswifi wpa_supplicant[742]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 08:22:19 jacob-b650mprorswifi wpa_supplicant[742]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 08:22:30 jacob-b650mprorswifi systemd[860]: /run/user/1000/systemd/generator.late/app-ciopfs\x20external@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Jun 01 08:22:31 jacob-b650mprorswifi org_kde_powerdevil[1090]: busno=5, sleep-multiplier =  1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
inxi
  Kernel: 6.9.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.9-x86_64
    root=UUID=16a5b737-4ccf-47f6-bd98-93a3431cce43 rw rootflags=subvol=@ quiet
    splash udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: ASRock model: B650M Pro RS WiFi serial: N/A
    uuid: 3e006b9c-db03-0000-0000-000000000000 UEFI: American Megatrends LLC.
    v: 2.08 date: 03/01/2024
  System RAM: total: 32 GiB available: 30.47 GiB used: 2 GiB (6.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 6000 MT/s actual: 5200 MT/s volts:
    curr: 1.1 min: 1.1 max: 1.1 width (bits): data: 64 total: 64
    manufacturer: N/A part-no: UD5-6000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Message: No PCI Slot data found.
  Info: model: AMD Ryzen 5 7600 socket: AM5 bits: 64 type: MT MCP arch: Zen 4
    gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 400 min/max: 400/5170 base/boost: 3800/5150 scaling:
    driver: amd-pstate-epp governor: powersave volts: 1.3 V ext-clock: 100 MHz
    cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
    10: 400 11: 400 12: 400 bogomips: 91069
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1
    xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e class-ID: 0300
  Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2
    bus-ID: 10:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 40.0 C
  Display: server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Beyond TV serial: <filter>
    built: 2020 res: 3840x2160 hz: 60 dpi: 81 gamma: 1.2 chroma: red: x: 0.678
    y: 0.310 green: x: 0.271 y: 0.659 blue: x: 0.153 y: 0.055 white: x: 0.314
    y: 0.329 size: 1209x680mm (47.6x26.77") diag: 1387mm (54.6") ratio: 16:9
    modes: 3840x2160, 4096x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x960, 1280x800, 1280x720,
    1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93 6: parse_edid:
    unhandled CEA mode 118
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
    drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 17.0.6 DRM 3.57 6.9.3-1-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 24.0.8-manjaro1.1
    device-ID: 1002:747e surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 24.0.8-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
  Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30
    class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.9.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.7 status: n/a (root, process) with:
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
  IF: enp8s0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 0e8d:0616
  Local Storage: total: 7.36 TiB used: 5.54 TiB (75.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD FX900 Pro 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.J.CR temp: 37.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 9d 18h cycles: 186
    read-units: 38,842,108 [19.8 TB] written-units: 11,414,286 [5.84 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 4TB
    family: based SSDs size: 3.64 TiB block-size: physical: 512 B logical: 512 B
    type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 sata: 3.2
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0209 drive-rev: RVT04B6Q
    temp: 24 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 276d 20h cycles: 1860
    written: 27.51 TiB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BU40N rev: A101
    dev-links: cdrom
  ID-1: / raw-size: 3.73 TiB size: 3.73 TiB (100.00%) used: 2.17 TiB (58.2%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 16a5b737-4ccf-47f6-bd98-93a3431cce43
    used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 5A4A-F91D
  ID-3: /home raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
    used: 2.17 TiB (58.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 16a5b737-4ccf-47f6-bd98-93a3431cce43
  ID-4: /mnt/sda1 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 3.37 TiB (92.7%) fs: btrfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: 4TB SATA uuid: 9abeced5-7707-44b8-8e84-4a5242acb8b6
  ID-5: /swap raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
  ID-6: /var/cache raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
  ID-7: /var/log raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 20.4 MiB (4.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-4:2 info: Logitech Media Keyboard K200 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31d class-ID: 0300
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.3:5 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3000 class-ID: 0301
  Device-2: 1-7.4:6 info: Logitech Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-3: 1-8:4 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Device-1: 2-6:2 info: JMicron / USA JMS578 SATA 6Gb/s type: mass storage
    driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 152d:0578 class-ID: 0806
    serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 7-1:2 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-9: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 44.5 C mobo: 30.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 41.0 C device: amdgpu temp: 35.0 C mem: 50.0 C
    fan: 0 watts: 11.00
  Packages: pm: pacman pkgs: 1433 libs: 435 tools: pamac
    1: https://uvermont.mm.fcix.net/manjaro/unstable/$repo/$arch
    2: https://forksystems.mm.fcix.net/manjaro/unstable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/unstable/$repo/$arch
    5: http://mirror.fcix.net/manjaro/unstable/$repo/$arch
    6: https://mirror.ibakerserver.pt/manjaro/unstable/$repo/$arch
    7: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 342
  1: cpu: 2.3% command: konsole pid: 3081 mem: 148.9 MiB (0.4%)
  2: cpu: 1.0% command: zsh pid: 3108 mem: 9.07 MiB (0.0%)
  3: cpu: 0.8% command: Xorg pid: 747 mem: 77.9 MiB (0.2%)
  4: cpu: 0.8% command: baloo_file pid: 914 mem: 23.5 MiB (0.0%)
  5: cpu: 0.6% command: kwin_x11 pid: 962 mem: 180.3 MiB (0.5%)
  Memory top: 5 of 342
  1: mem: 259.5 MiB (0.8%) command: plasmashell pid: 1020 cpu: 0.1%
  2: mem: 180.3 MiB (0.5%) command: kwin_x11 pid: 962 cpu: 0.6%
  3: mem: 148.9 MiB (0.4%) command: konsole pid: 3081 cpu: 2.3%
  4: mem: 111.9 MiB (0.3%) command: polkit-kde-authentication-agent-1
    pid: 1089 cpu: 0.0%
  5: mem: 87.6 MiB (0.2%) command: kded6 pid: 961 cpu: 0.0%
  Processes: 342 Power: uptime: 20m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
Hi @Mechani-Happy,
If it’s really random and it being USB devices, it makes me think it’s a USB cable/port(s)/controller. Maybe as if they don’t get enough power? Sounds like a possibility. Make sure that’s good first.
Thanks for the suggestion, but I already examined the connections on the motherboard and its secure. As for getting enough power, my psu had more than enough power to power all devices on the motherboard and when Im on the bios uefi screen of my computer, the usb ports always work. The mouse is on and I can move the cursor around. However, its only when linux starts the mouse/usb ports can turn off.
Well, if it’s really random, as your title says, I’ve got no idea. However, this might give you a clue. check if there are any errors in the logs:
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
Let’s try to keep your threads on this topic together:
Here are the results
Broken boot
journalctl --priority=warning..crit --no-pager --boot=-1                                                        ✔
Jun 01 10:32:59 jacob-b650mprorswifi kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 01 10:32:59 jacob-b650mprorswifi kernel: sd 6:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
Jun 01 10:32:59 jacob-b650mprorswifi kernel: amdgpu 0000:03:00.0: amdgpu: DF poison setting is inconsistent(1:0:0:0)!
Jun 01 10:32:59 jacob-b650mprorswifi kernel: amdgpu 0000:03:00.0: amdgpu: Poison setting is inconsistent in DF/UMC(0:1)!
Jun 01 10:32:59 jacob-b650mprorswifi systemd-vconsole-setup[404]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Jun 01 10:32:59 jacob-b650mprorswifi systemd-vconsole-setup[404]: Fonts will not be copied to remaining consoles
Jun 01 10:32:59 jacob-b650mprorswifi systemd-vconsole-setup[547]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Jun 01 10:32:59 jacob-b650mprorswifi systemd-vconsole-setup[547]: Fonts will not be copied to remaining consoles
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support bap plugin
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support bass plugin
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support mcp plugin
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support vcp plugin
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support micp plugin
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support ccp plugin
Jun 01 10:33:00 jacob-b650mprorswifi bluetoothd[707]: src/plugin.c:init_plugin() System does not support csip plugin
Jun 01 10:33:05 jacob-b650mprorswifi dbus-broker-launch[640]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jun 01 10:33:05 jacob-b650mprorswifi dbus-broker-launch[770]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 01 10:33:05 jacob-b650mprorswifi dbus-broker-launch[770]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 01 10:33:05 jacob-b650mprorswifi dbus-broker-launch[770]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 01 10:33:05 jacob-b650mprorswifi kernel: Bluetooth: hci0: Failed to get device id (-110)
Jun 01 10:33:05 jacob-b650mprorswifi kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Jun 01 10:33:05 jacob-b650mprorswifi wpa_supplicant[719]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 10:33:05 jacob-b650mprorswifi udisksd[793]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sda': Unexpected sense data returned:
                                                   0000: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
                                                   0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
                                                    (g-io-error-quark, 0)
Jun 01 10:33:06 jacob-b650mprorswifi dbus-broker-launch[640]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jun 01 10:33:06 jacob-b650mprorswifi sddm-greeter-qt6[766]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.17'
Jun 01 10:33:06 jacob-b650mprorswifi sddm-greeter-qt6[766]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.18'
Jun 01 10:33:13 jacob-b650mprorswifi kernel: usb 1-8: Failed to suspend device, error -110
Jun 01 10:33:16 jacob-b650mprorswifi sddm-greeter-qt6[766]: Signal received: SIGTERM
Jun 01 10:33:16 jacob-b650mprorswifi sddm-helper[752]: Signal received: SIGTERM
Jun 01 10:33:16 jacob-b650mprorswifi sddm[722]: Error from greeter session: "Process crashed"
Jun 01 10:33:16 jacob-b650mprorswifi sddm[722]: Auth: sddm-helper (--socket /tmp/sddm-auth-09960c98-986c-479f-994e-09fd40b99992 --id 2 --start /usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-OWxBmM --theme /usr/share/sddm/themes/breeze --user sddm --greeter) crashed (exit code 1)
Jun 01 10:33:16 jacob-b650mprorswifi sddm[722]: Auth: sddm-helper exited with 1
Jun 01 10:33:16 jacob-b650mprorswifi sddm[722]: Signal received: SIGTERM
Jun 01 10:33:16 jacob-b650mprorswifi dbus-broker-launch[640]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jun 01 10:33:16 jacob-b650mprorswifi NetworkManager[642]: <warn>  [1717252396.9636] dispatcher: (10) failed (after 0.001 sec): Could not activate remote peer 'org.freedesktop.nm_dispatcher': activation request failed: unit is invalid
Jun 01 10:33:17 jacob-b650mprorswifi dbus-broker-launch[640]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jun 01 10:33:17 jacob-b650mprorswifi systemd[1]: Failed unmounting /var/cache.
Working boot
journalctl --priority=warning..crit --no-pager --boot=0                                                         ✔
Jun 01 10:33:52 jacob-b650mprorswifi kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 01 10:33:52 jacob-b650mprorswifi kernel: sd 6:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
Jun 01 10:33:52 jacob-b650mprorswifi kernel: amdgpu 0000:03:00.0: amdgpu: DF poison setting is inconsistent(1:0:0:0)!
Jun 01 10:33:52 jacob-b650mprorswifi kernel: amdgpu 0000:03:00.0: amdgpu: Poison setting is inconsistent in DF/UMC(0:1)!
Jun 01 10:33:52 jacob-b650mprorswifi systemd-vconsole-setup[402]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Jun 01 10:33:52 jacob-b650mprorswifi systemd-vconsole-setup[402]: Fonts will not be copied to remaining consoles
Jun 01 10:33:52 jacob-b650mprorswifi systemd-vconsole-setup[572]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Jun 01 10:33:52 jacob-b650mprorswifi systemd-vconsole-setup[572]: Fonts will not be copied to remaining consoles
Jun 01 10:33:52 jacob-b650mprorswifi kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support bap plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support bass plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support mcp plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support vcp plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support micp plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support ccp plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/plugin.c:init_plugin() System does not support csip plugin
Jun 01 10:33:53 jacob-b650mprorswifi bluetoothd[669]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Jun 01 10:33:57 jacob-b650mprorswifi wpa_supplicant[754]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 10:33:57 jacob-b650mprorswifi dbus-broker-launch[664]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jun 01 10:33:58 jacob-b650mprorswifi dbus-broker-launch[664]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jun 01 10:33:58 jacob-b650mprorswifi dbus-broker-launch[813]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 01 10:33:58 jacob-b650mprorswifi dbus-broker-launch[813]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 01 10:33:58 jacob-b650mprorswifi dbus-broker-launch[813]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 01 10:33:58 jacob-b650mprorswifi udisksd[826]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sda': Unexpected sense data returned:
Jun 01 10:33:59 jacob-b650mprorswifi sddm-greeter-qt6[809]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.17'
Jun 01 10:33:59 jacob-b650mprorswifi sddm-greeter-qt6[809]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.18'
Jun 01 10:34:04 jacob-b650mprorswifi wpa_supplicant[754]: bgscan simple: Failed to enable signal strength monitoring
Jun 01 10:34:07 jacob-b650mprorswifi sddm-greeter-qt6[809]: file:///usr/share/sddm/themes/breeze/Main.qml:241:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Jun 01 10:34:07 jacob-b650mprorswifi dbus-broker-launch[902]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 01 10:34:07 jacob-b650mprorswifi dbus-broker-launch[902]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Jun 01 10:34:07 jacob-b650mprorswifi dbus-broker-launch[902]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 01 10:34:07 jacob-b650mprorswifi systemd[878]: /run/user/1000/systemd/generator.late/app-ciopfs\x20external@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Jun 01 10:34:07 jacob-b650mprorswifi ksplashqml[906]: Texture 0x63c1259ec8e0 () used with different accesses within the same pass, this is not allowed.
Jun 01 10:34:07 jacob-b650mprorswifi ksmserver[977]: Failed to write ice auth file entry
Jun 01 10:34:07 jacob-b650mprorswifi ksmserver[977]: Failed to write xsmp ice auth file entry
Jun 01 10:34:08 jacob-b650mprorswifi plasmashell[1040]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:08 jacob-b650mprorswifi kded6[979]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Jun 01 10:34:08 jacob-b650mprorswifi kded6[979]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Jun 01 10:34:08 jacob-b650mprorswifi kded6[979]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi kconf_update[1095]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Jun 01 10:34:08 jacob-b650mprorswifi plasmashell[1040]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 01 10:34:08 jacob-b650mprorswifi plasmashell[1040]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 01 10:34:08 jacob-b650mprorswifi gmenudbusmenuproxy[1101]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:08 jacob-b650mprorswifi xembedsniproxy[1105]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:08 jacob-b650mprorswifi kded6[979]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Jun 01 10:34:08 jacob-b650mprorswifi kded6[979]: kscreen.kded: PowerDevil SuspendSession action not available!
Jun 01 10:34:08 jacob-b650mprorswifi polkit-kde-authentication-agent-1[1102]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:08 jacob-b650mprorswifi plasmashell[1040]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 01 10:34:08 jacob-b650mprorswifi xdg-desktop-por[936]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Jun 01 10:34:08 jacob-b650mprorswifi xdg-desktop-por[936]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Jun 01 10:34:08 jacob-b650mprorswifi backlighthelper[1234]: org.kde.powerdevil: no kernel backlight interface found
Jun 01 10:34:08 jacob-b650mprorswifi org_kde_powerdevil[1103]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jun 01 10:34:08 jacob-b650mprorswifi org_kde_powerdevil[1103]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Jun 01 10:34:08 jacob-b650mprorswifi plasmashell[1040]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Jun 01 10:34:08 jacob-b650mprorswifi plasmashell[1040]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Jun 01 10:34:08 jacob-b650mprorswifi org_kde_powerdevil[1103]: busno=5, sleep-multiplier =  1.30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Jun 01 10:34:08 jacob-b650mprorswifi org_kde_powerdevil[1103]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 01 10:34:09 jacob-b650mprorswifi kdeconnectd[1300]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:09 jacob-b650mprorswifi kdeconnectd[1289]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:09 jacob-b650mprorswifi kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Jun 01 10:34:09 jacob-b650mprorswifi msm_kde_notifier[1298]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:09 jacob-b650mprorswifi pamac-tray-plasma[1327]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:09 jacob-b650mprorswifi sc-controller[1307]: expected enumeration type void, but got PyGLibOptionArg instead
Jun 01 10:34:09 jacob-b650mprorswifi plasmashell[1040]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1717252449275: Unsupported image format
Jun 01 10:34:09 jacob-b650mprorswifi plasmashell[1040]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 01 10:34:09 jacob-b650mprorswifi plasmashell[1040]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:62:17: Unable to assign [undefined] to int
Jun 01 10:34:14 jacob-b650mprorswifi konsole[1522]: Qt: Session management error: None of the authentication protocols specified are supported
Jun 01 10:34:14 jacob-b650mprorswifi kwin_x11[980]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jun 01 10:34:29 jacob-b650mprorswifi baloo_file_extractor[1639]: kf.idletime: Could not find any system poller plugin
Jun 01 10:34:29 jacob-b650mprorswifi baloo_file_extractor[1639]: qt.core.qobject.connect: QObject::connect(KAbstractIdleTimePoller, KIdleTime): invalid nullptr parameter
Jun 01 10:34:47 jacob-b650mprorswifi konsole[1668]: Qt: Session management error: None of the authentication protocols specified are supported
Typing “config failed, hub doesn’t have any ports! (err -19)” into a search engine finds a lot of results on various distros. It seems to be a issue on Zen 4 systems.
I didn’t see any obvious solution but the first I’d try is updating BIOS to latest.
Updated to the latest bios, still encountering the issue unfortunately
I am still encountering this issue. It would be much appreciated if someone could help me.
