My bluetooth adapter keeps getting disabled immediately after connecting to any device. It is an Intel 7260HMW, running in a thinkpad t420. Log attached at bottom.
I will provide any additional information upon request.
Attempting to connect to F8:DF:15:[REDACTED]
[CHG] Device F8:DF:15:[REDACTED] Connected: yes
Connection successful
[CHG] Device F8:DF:15:[REDACTED] ServicesResolved: yes
[CHG] Controller AC:FD:CE:[REDACTED] Class: 0x00000000
[CHG] Device F8:DF:15:[REDACTED] ServicesResolved: no
[CHG] Device F8:DF:15:[REDACTED] Connected: no
[CHG] Controller AC:FD:CE:[REDACTED] Powered: no
[CHG] Controller AC:FD:CE:[REDACTED] Discovering: no
[DEL] Device F8:DF:15:[REDACTED] SRS-XB22
[DEL] Controller AC:FD:CE:[REDACTED] alei-t420 #2 [default]
[NEW] Controller AC:FD:CE:[REDACTED] alei-t420 #2 [default]
[NEW] Device F8:DF:15:[REDACTED] SRS-XB22
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001133-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001105-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001132-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001200-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001104-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00005005-0000-1000-8000-0002ee000001
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001108-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001801-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000112f-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000180a-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001800-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000111f-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 0000110a-0000-1000-8000-00805f9b34fb
[CHG] Controller AC:FD:CE:[REDACTED] UUIDs: 00001106-0000-1000-8000-00805f9b34fb```
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\intel-ucode.img initrd=\initramfs-5.13-x86_64.img
root=UUID=eac7dc6d-6c36-43e2-99aa-b637cb1ca1ed rw
Console: pty pts/2 DM: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 4238AY6 v: ThinkPad T420
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 4238AY6 serial: <filter> UEFI: LENOVO
v: 83ET76WW (1.46 ) date: 07/05/2013
ID-1: BAT0 charge: 33.2 Wh (99.7%) condition: 33.3/56.2 Wh (59.3%)
volts: 12.4 min: 10.8 model: SANYO 42T4763 type: Li-ion serial: <filter>
status: N/A
RAM: total: 7.65 GiB used: 3.96 GiB (51.8%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
part-no: M471B5273DH0-CH9 serial: <filter>
Device-2: ChannelB-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3
Info: model: Intel Core i5-2520M bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1156 high: 1854 min/max: 800/3200 base/boost: 2500/2500
scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V
ext-clock: 100 MHz cores: 1: 1089 2: 832 3: 1854 4: 851 bogomips: 19947
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep smx
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo ThinkPad T420 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0126 class-ID: 0300
Display: server: X.org 1.21.1.2 driver: loaded: modesetting
alternate: fbdev,vesa tty: 317x86
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:08b1 class-ID: 0280
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:3 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Device-2: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 2-1.3:7 chip-ID: 8087:07dc class-ID: e001
Report: ID: hci1 rfk-id: 7 state: up address: N/A
Local Storage: total: 232.89 GiB used: 149.36 GiB (64.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7710H rev: 1.S0
dev-links: cdrom
ID-1: / raw-size: 52.3 GiB size: 51.17 GiB (97.85%) used: 24.87 GiB (48.6%)
fs: ext4 block-size: 4096 B dev: /dev/sda6 maj-min: 8:6 label: m-root
uuid: eac7dc6d-6c36-43e2-99aa-b637cb1ca1ed
ID-2: /run/media/alei/e839af4b-da72-4508-8dcb-48a00f732c11
raw-size: 130.29 GiB size: 127.24 GiB (97.66%) used: 124.49 GiB (97.8%)
fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: e839af4b-da72-4508-8dcb-48a00f732c11
ID-1: swap-1 type: partition size: 4 GiB used: 1024 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 46719606-7d4a-4e70-9c87-0b4d73e986cb
ID-1: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
uuid: 14C3-280C
ID-2: /dev/sda2 maj-min: 8:2 size: 34.97 GiB fs: ext4 label: arch_os
uuid: abf8a7b5-4534-4bd6-a136-688c853c00d0
ID-3: /dev/sda5 maj-min: 8:5 size: 10.83 GiB fs: ext4 label: N/A
uuid: d3cee219-8223-4ad8-b1fa-543a92e1de44
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Broadcom BCM2045B (BDC-2.1) type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:217f
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.3:7 info: Intel Bluetooth wireless interface type: Bluetooth
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1992
Processes: 237 Uptime: 1d 5h 49m wakeups: 2 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1116 lib: 290
flatpak: 0 Shell: Bash (sudo) v: 5.1.12 running-in: pty pts/2 (SSH)```
I ended up setting a persistent command to power on bluetooth that executes every 10 seconds. Not elegant, but the alternative is having nonfunctional bluetooth.
system
closed
January 17, 2022, 10:35pm
#5
