javi12
17 December 2023 07:19
1
This issue was reported in another topic:
Black screen with mouse pointer after login after screen lock
It is now closed, that is way I am opening this one.
There, I informed that solved the issue by re-installing Manjaro.
I installed the latest version available 23.0.4 with xfce, but as soon as updated to 23.1.0 the issue re-appeared.
To confirm that, I installed version 23.0.4 in another disk, check everything worked fine, then upgraded to 23.1.0 and boom the issue was there again.
Any help would be highly appreciated, thanks
Hi @javi12 ,
I won’t be able to help, aside from making sure you have no unmerged .pacnew files?
Check with:
sudo pacdiff -o
It should return blank.
More:
https://wiki.archlinux.org/title/Pacman/Pacnew_and_Pacsave#.pacnew
Hope this helps!
javi12
17 December 2023 08:40
3
Thanks for your reply @Mirdarthos
No, there are no .pacnew files.
Then I’m going to suggest all I know further. Maybe it helps, maybe it doesn’t
Check if there are any error or warning log entries:
journalctl --priority=warning..err --boot=-1 --no-pager
Where:
The --priority=warning..err argument limits the output to warning s and err ors only;
the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
--no-pager formats the output nicely for use here, on the forum.
javi12
17 December 2023 10:58
5
Hi, here the requested output…
$ journalctl --priority=warning..err --boot=-1 --no-pager
Dez 17 11:49:13 pegasus kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230331/tbfadt-615)
Dez 17 11:49:13 pegasus kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Dez 17 11:49:13 pegasus kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Dez 17 11:49:13 pegasus kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Dez 17 11:49:13 pegasus kernel: ata1.00: supports DRM functions and may not be fully accessible
Dez 17 11:49:14 pegasus kernel: ata7: failed to resume link (SControl 0)
Dez 17 11:49:14 pegasus kernel: ata8: failed to resume link (SControl 0)
Dez 17 11:49:14 pegasus kernel: usb: port power management may be unreliable
Dez 17 11:49:13 pegasus systemd-vconsole-setup[348]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Dez 17 11:49:13 pegasus systemd-vconsole-setup[348]: Fonts will not be copied to remaining consoles
Dez 17 11:49:14 pegasus kernel: wmi_bus wmi_bus-PNP0C14:01: WQAA data block query control method not found
Dez 17 11:49:14 pegasus systemd-vconsole-setup[604]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Dez 17 11:49:14 pegasus systemd-vconsole-setup[604]: Fonts will not be copied to remaining consoles
Dez 17 11:49:14 pegasus kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 15
Dez 17 11:49:14 pegasus kernel: nvidia: loading out-of-tree module taints kernel.
Dez 17 11:49:14 pegasus kernel: nvidia: module license 'NVIDIA' taints kernel.
Dez 17 11:49:14 pegasus kernel: Disabling lock debugging due to kernel taint
Dez 17 11:49:14 pegasus kernel: nvidia: module license taints kernel.
Dez 17 11:49:15 pegasus kernel:
Dez 17 11:49:15 pegasus kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 0
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 1
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 2
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 3
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 4
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 6
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 8
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 9
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 10
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 11
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 15
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 16
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 18
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 19
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 20
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 21
Dez 17 11:49:15 pegasus kernel: iwlwifi 0000:05:00.0: WRT: Overriding region id 28
Dez 17 11:49:15 pegasus kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Dez 17 11:49:15 pegasus kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dez 17 11:49:16 pegasus systemd[1]: snapd.service: Got notification message from PID 1046, but reception only permitted for main PID 1003
Dez 17 11:49:16 pegasus systemd[1]: snapd.service: Got notification message from PID 1047, but reception only permitted for main PID 1003
Dez 17 11:49:16 pegasus systemd[1]: snapd.service: Got notification message from PID 1116, but reception only permitted for main PID 1003
Dez 17 11:49:16 pegasus kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Dez 17 11:49:16 pegasus bluetoothd[1123]: src/plugin.c:plugin_init() System does not support csip plugin
Dez 17 11:49:16 pegasus bluetoothd[1123]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dez 17 11:49:16 pegasus bluetoothd[1123]: src/plugin.c:plugin_init() System does not support micp plugin
Dez 17 11:49:16 pegasus bluetoothd[1123]: src/plugin.c:plugin_init() System does not support vcp plugin
Dez 17 11:49:16 pegasus bluetoothd[1123]: src/plugin.c:plugin_init() System does not support mcp plugin
Dez 17 11:49:16 pegasus bluetoothd[1123]: src/plugin.c:plugin_init() System does not support bass plugin
Dez 17 11:49:16 pegasus bluetoothd[1123]: src/plugin.c:plugin_init() System does not support bap plugin
Dez 17 11:49:16 pegasus kernel: ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
Dez 17 11:49:17 pegasus colord[1153]: failed to get edid data: EDID length is too small
Dez 17 11:49:22 pegasus kernel: Xorg[1189]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Dez 17 11:49:33 pegasus lightdm[1438]: gkr-pam: unable to locate daemon control file
Dez 17 11:49:33 pegasus systemd-xdg-autostart-generator[1463]: Configuration file /home/javi/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dez 17 11:49:35 pegasus tumblerd[1622]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: No skeleton to export
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.FileChooser as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.AppChooser as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Print as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Notification as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Inhibit as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Access as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Account as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.Email as a last-resort fallback
Dez 17 11:49:35 pegasus xdg-desktop-por[1706]: Choosing gtk.portal for org.freedesktop.impl.portal.DynamicLauncher as a last-resort fallback
Dez 17 11:51:50 pegasus lightdm[2500]: gkr-pam: unable to locate daemon control file
Dez 17 11:52:37 pegasus kernel: pcieport 0000:02:03.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
Dez 17 11:52:37 pegasus kernel: pcieport 0000:02:03.0: device [1022:43c7] error status/mask=00000001/00002000
Dez 17 11:52:37 pegasus kernel: pcieport 0000:02:03.0: [ 0] RxErr (First)
Dez 17 11:52:58 pegasus pulseaudio[1559]: ICE I/O error handler called
Dez 17 11:52:58 pegasus systemd[1457]: xfce4-notifyd.service: Failed with result 'exit-code'.
Dez 17 11:52:58 pegasus systemd[1457]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Dez 17 11:52:58 pegasus tumblerd[1622]: Name org.freedesktop.thumbnails.Cache1 lost on the message dbus, exiting.
Dez 17 11:52:58 pegasus tumblerd[1622]: Name org.freedesktop.thumbnails.Manager1 lost on the message dbus, exiting.
Dez 17 11:52:58 pegasus tumblerd[1622]: Name org.freedesktop.thumbnails.Thumbnailer1 lost on the message dbus, exiting.
Dez 17 11:52:58 pegasus xdg-desktop-por[1706]: Caught PipeWire error: connection error
Dez 17 11:52:58 pegasus systemd[1457]: xdg-permission-store.service: Failed with result 'exit-code'.
Dez 17 11:52:59 pegasus NetworkManager[1044]: <warn> [1702810379.6677] dispatcher: (11) failed (after 0.000 sec): Refusing activation, D-Bus is shutting down.
javi12
17 December 2023 11:02
6
an here updated inxi…
$ inxi --full --admin --filter --width
Kernel: 6.5.13-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=1ca0dc0c-5bbc-4280-bf10-756aaec7054c rw quiet splash apparmor=1
security=apparmor resume=UUID=28428da1-f5a9-40b0-a525-497c2408787d
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: X470 AORUS GAMING 5 WIFI v: N/A
serial: <superuser required>
Mobo: Gigabyte model: X470 AORUS GAMING 5 WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F3 date: 08/08/2018
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2260 high: 3200 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2167 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 3200 15: 2200 16: 2200 bogomips: 118441
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 09:00.0 chip-ID: 10de:1f07
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0
note: <missing: xdpyinfo/xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
memory: 7.81 GiB
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 09:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.5.13-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 4.53 TiB used: 32.56 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40EZRZ-00GXCB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Intenso model: SATA III SSD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BA.3 scheme: GPT
ID-1: / raw-size: 431.34 GiB size: 423.49 GiB (98.18%) used: 32.56 GiB (7.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 41.6 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 328 Uptime: 7m wakeups: 0 Memory: total: 32 GiB
available: 31.29 GiB used: 2.41 GiB (7.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1178 libs: 333 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.2.21 running-in: xfce4-terminal inxi: 3.3.31
I now went thorough that journalctl output you gave…and, well, nothing jumps out at me. So I don’t know. But someone more knowledgeable that me might know… Sorry!
javi12
17 December 2023 11:23
8
Thank you very much @Mirdarthos in any case, it give me hope to continue looking for a solution
you connect with TTY ( Ctrl + Alt + F2 to F7 )
and you restart lightdm.service
sudo systemctl restart lightdm.service
and wait next update version nvidia
javi12
17 December 2023 11:58
10
I have the idea to downgrade the nvidia driver 545.29.06 to a previous one.
I found your instructions for that in this post
But, I do not know how to find the nvidia driver version used in manjaro 23.0.4
mhwd -l -d --pci
gives:
video-nvidia
video-nvidia-470xx
video-linux
video-modesetting
video-vesa
video-nvidia looks like a pointer to the most current.
video-nvidia-470xx looks old for my card.
A list of installed nvidia related packages…
pamac list -i | grep -i nvidia
lib32-nvidia-utils 545.29.06-1 multilib 208,4 MB
linux61-nvidia 545.29.06-8 extra 54,8 MB
linux65-nvidia 545.29.06-10 extra 59,2 MB
mhwd-nvidia 545.29.06-1 extra 1,7 kB
mhwd-nvidia-390xx 390.157-9 extra 1,9 kB
mhwd-nvidia-470xx 470.223.02-1 extra 1,8 kB
nvidia-settings 545.29.06-1 extra 1,6 MB
nvidia-utils 545.29.06-1 extra 670,8 MB
Is it possible to install a version like 535 ? thanks!
bedna
17 December 2023 12:05
11
My advice, stay away from even trying.
But you do you.
What does pacman -Qs xdg-desktop return?
javi12
17 December 2023 12:14
12
thanks @bedna
here the output
$ pacman -Qs xdg-desktop
local/xdg-desktop-portal 1.18.2-1
Desktop integration portals for sandboxed apps
local/xdg-desktop-portal-gtk 1.15.1-1
A backend implementation for xdg-desktop-portal using GTK
I’ll follow your advice not to try to downgrade nvidia driver.
That’s probably right. So, in theory you could try:
sudo downgrade video-nvidia
But I think that needs manjaro-downgrade from the extra repository:
pamac install manjaro-downgrade
I have never done this, nor have I ever used the downgrade utility, so I’m not talking from experience.
bedna
17 December 2023 12:25
14
I don’t use Xfce so I thought there could be more xdg-desktop stuff.
But something is going wrong when the login manager (lightdm) is trying to load.
Sorry that I can not be more helpful about that.
As for the nvidia stuff. The kernel taint thing could be because you just put the early loading in, I have seen nvidia complain for the first boot. I think you can safely ignore it.
Just make sure you have secure boot turned off.
Check your grub line.
Make sure you load the nvidia modules early in mkinitcpio.conf.
https://wiki.archlinux.org/title/NVIDIA#DRM_kernel_mode_setting
javi12
17 December 2023 12:32
15
This brings to the login screen again. After login, get a working desktop environment, but the applications (windows) are gone.
I mean before locking the screen I left some apps open, and after locking, login, black screen, ctrl-f3, login, sudo systemctl restart lightdm.service, there are no apps’ windows open.
AHA!
That’s good news. It gives us another place to look. Please provide the output of:
journalctl --boot=-1 --priority=warning..err --unit=lightdm.service --no-pager
Where:
--no-pager formats the output nicely for use here, on the forum;
the --boot=0 argument limits the messages to be from the current boot. This can be adjusted to -1 for the previous boot, -2 to the boot before that , and so on and so forth;
the --unit=lightdm.service argument narrows in to why the login screen unit only , allowing for more details.
javi12
17 December 2023 12:51
17
here the output…
$ journalctl --boot=-1 --priority=warning..err --unit=lightdm.service --no-pager
Dez 17 13:46:56 pegasus lightdm[1434]: gkr-pam: unable to locate daemon control file
Dez 17 13:48:02 pegasus lightdm[2163]: gkr-pam: unable to locate daemon control file
All I can find is:
So while reading these logs I found an error saying that my Xauthority file can not be written cause of permission denied, and then I remembered that I was doing somethings with .Xresources file so I thought that this should be the problem then i run the command chmod 777 .Xauthority and enter my password to the locking GUI and voila it is working again as it should be.
Now I am worried that my way of fixing the problem will cause some problems in the future. Can someone give me some advice reg…
My question, now, is what is causing it to die. Let’s look a bit more at the logs, but this time don’t limit it to warnings and errors:
journalctl --boot=-1 --unit=lightdm.service --no-pager
Also, please provide the output of the following from a re-logged in blank session , as described above:
ps aux | grep --ignore-case light
javi12
17 December 2023 13:43
19
Here the journal…
Dez 17 13:46:45 pegasus systemd[1]: Starting Light Display Manager...
Dez 17 13:46:45 pegasus systemd[1]: Started Light Display Manager.
Dez 17 13:46:47 pegasus lightdm[1380]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=963) by (uid=0)
Dez 17 13:46:56 pegasus lightdm[1434]: gkr-pam: stashed password to try later in open session
Dez 17 13:46:56 pegasus lightdm[1434]: pam_unix(lightdm:session): session opened for user javi(uid=1000) by javi(uid=0)
Dez 17 13:46:56 pegasus lightdm[1434]: gkr-pam: unlocked login keyring
Dez 17 13:47:40 pegasus lightdm[2093]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=963) by (uid=0)
Dez 17 13:48:02 pegasus lightdm[2163]: gkr-pam: stashed password to try later in open session
Dez 17 13:48:50 pegasus systemd[1]: Stopping Light Display Manager...
Dez 17 13:48:51 pegasus systemd[1]: lightdm.service: Deactivated successfully.
Dez 17 13:48:51 pegasus systemd[1]: Stopped Light Display Manager.
Dez 17 13:48:51 pegasus systemd[1]: lightdm.service: Consumed 5.663s CPU time.
and the ps output…
root 1172 0.0 0.0 378916 6584 ? SLsl 14:30 0:00 /usr/bin/lightdm
root 1181 1.4 0.8 25622488 291344 tty7 Ssl+ 14:30 0:08 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
root 1430 0.0 0.0 236132 10868 ? Sl 14:30 0:00 lightdm --session-child 13 20
javi 1623 0.0 0.1 606040 41500 ? Sl 14:30 0:00 light-locker
javi 2887 0.0 0.0 6904 2544 tty3 S+ 14:39 0:00 grep --colour=auto light
bedna
17 December 2023 13:54
20
A search on this lead me to this: https://bbs.archlinux.org/viewtopic.php?id=261156
Seems it might have to do with PAM.
Out of curiosity, if you do a lock > unlock > no windows and checks the sessions, would the old still exist?
loginctl list-sessions
