Downgrade nvidia to 470
Hi,
i’m on majaro-gnome i installed nvidia drivers via mhwd is there anyway to downgrade to 470
Hi @bgyiregb12, and welcome!
I think it’s as easy as uninstalling the current one:
Identify which one you’re using by running:
mhwd --listinstalled
It’ll return the list of installed driver. For example, mine is:
$ mhwd --listinstalled
> Installed PCI configs:
video-nvidia            2021.12.18               false            PCI
Showing my current driver is video-nvidia. The next step is to remove it.
sudo mhwd --remove <driverToRemove>
Where <driverToRemove> is the driver you no longer want. video-nvidia In this case.
Followed by installing the desired one:
sudo mhwd --install video-nvidia-470xx
Hope this helps!
worked thanks
Hi @bgyiregb12
Can you please check the Solution Box to let other know which process solved your issue ?
