Black Screen with cursor after waking up from sleep
nvidia 1050Ti
kernel 5.10
nvidia driver 460.67
sometimes i wake up my pc from sleep, i get a black screen with a cursor.
The cursor was moving fine.
I can still switch to alternate terminals with CTRL+ALT+F2,my only option is to reboot,Is there another solution?
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. What’s the output of:
    journalctl --system --boot=-1 |tail --lines=35
    after your reboot through REISUB or sudo reboot?
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
hi! Have you resolved this? I have same issue.
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.4.150-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=f03a99b3-8753-47be-a685-ef1b6a432e9b rw quiet
  resume=UUID=7dc4c251-fe04-4b4d-9cc1-b11c968ffb08
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Micro-Star product: GT72S 6QF v: REV:1.0
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Micro-Star model: MS-1783 v: REV:1.0 serial: <filter>
  UEFI: American Megatrends v: E1783IMS.11D date: 10/14/2016
  ID-1: BAT1 charge: 6.7 Wh (77.9%) condition: 8.6/86.6 Wh (10.0%) volts: 12.2
  min: 11.1 model: MSI BIF0_9 type: Li-ion serial: N/A status: Charging
  RAM: total: 31.32 GiB used: 2.27 GiB (7.2%)
  Info: Quad Core model: Intel Core i7-6820HK bits: 64 type: MT MCP
  arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache:
  L2: 8 MiB bogomips: 43214
  Speed: 802 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 802 2: 800 3: 800
  4: 801 5: 800 6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: NVIDIA GM204M [GeForce GTX 980 Mobile] vendor: Micro-Star MSI
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:161a class-ID: 0300
  Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-2.3:6 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
  s-diag: 583mm (23")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
  diag: 598mm (23.5")
  OpenGL: renderer: NVIDIA GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
  direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fbb
  class-ID: 0403
  Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.4.150-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.38 running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Rivet Networks driver: ath10k_pci v: kernel bus-ID: 03:00.0
  chip-ID: 168c:003e class-ID: 0280
  Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
  vendor: Micro-Star MSI driver: alx v: kernel port: c000 bus-ID: 05:00.0
  chip-ID: 1969:e0a1 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
  v: 0.8 bus-ID: 1-10:5 chip-ID: 0cf3:e300 class-ID: e001
  Local Storage: total: 1.14 TiB used: 464.07 GiB (39.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVPV128HDGM-00000
  size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: BXW7300Q scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: MZVPV128HDGM-00000
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
  type: SSD serial: <filter> rev: 4B6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BU20N rev: 1.00
  dev-links: cdrom
  ID-1: / raw-size: 112.88 GiB size: 110.61 GiB (97.99%)
  used: 65.73 GiB (59.4%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:4
  label: N/A uuid: f03a99b3-8753-47be-a685-ef1b6a432e9b
  used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3 label: N/A
  uuid: A6BA-85CA
  ID-3: /mnt/drive_d raw-size: 673.18 GiB size: 673.18 GiB (100.00%)
  used: 353.9 GiB (52.6%) fs: ntfs dev: /dev/sda5 maj-min: 8:5 label: DATA2
  uuid: 3C9263A95FF7EC53
  ID-4: /mnt/ssd2 raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
  used: 44.44 GiB (37.3%) fs: ntfs dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SSD2 uuid: 7DB9C20A1176736A
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme1n1p3 maj-min: 259:5 label: N/A
  uuid: 7dc4c251-fe04-4b4d-9cc1-b11c968ffb08
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 300 MiB fs: vfat label: SYSTEM
  uuid: 76E9-4C21
  ID-3: /dev/sda3 maj-min: 8:3 size: 237.18 GiB fs: ntfs label: OS_Install
  uuid: 4ED85E1BCBD7F987
  ID-4: /dev/sda4 maj-min: 8:4 size: 900 MiB fs: ntfs label: WinRE tools
  uuid: 39A9C41A8F60D8B6
  ID-5: /dev/sda6 maj-min: 8:6 size: 19.85 GiB fs: ntfs label: BIOS_RVY
  uuid: 7FA52BEB1EBA3F15
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 1-2.2:4 info: Logitech M-U0007 [Corded Mouse M500] type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 98mA chip-ID: 046d:c069 class-ID: 0301
  Device-2: 1-2.3:6 info: Logitech Webcam C270 type: Video,Audio
  power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Device-3: 1-2.4:7 info: SiGma Micro Keyboard type: Keyboard,HID
  power: 98mA chip-ID: 1c4f:0026 class-ID: 0300
  Device-4: 1-7:3 info: MSI steel series rgb keyboard type: HID
  driver: gt683r_led,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 2mA
  chip-ID: 1770:ff00 class-ID: 0300 serial: <filter>
  Device-5: 1-10:5 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 0cf3:e300 class-ID: e001
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
  Hub-4: 2-1:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 0bda:0411 class-ID: 0900
  System Temperatures: cpu: 61.0 C mobo: N/A gpu: nvidia temp: 38 C
  Processes: 274 Uptime: 3m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1460 lib: 429
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
$ journalctl --system --boot=-1 |tail --lines=35
Oct 19 18:51:10 sergey-pc systemd[1]: mnt-ssd2.mount: Deactivated successfully.
Oct 19 18:51:10 sergey-pc systemd[1]: Unmounted /mnt/ssd2.
Oct 19 18:51:10 sergey-pc systemd[1]: mnt-ssd2.mount: Consumed 25.374s CPU time.
Oct 19 18:51:10 sergey-pc systemd[1]: mnt-drive_d.mount: Deactivated successfully.
Oct 19 18:51:10 sergey-pc systemd[1]: Unmounted /mnt/drive_d.
Oct 19 18:51:10 sergey-pc systemd[1]: mnt-drive_d.mount: Consumed 1min 21.181s CPU time.
Oct 19 18:51:10 sergey-pc systemd[1]: Stopped target Preparation for Local File Systems.
Oct 19 18:51:10 sergey-pc systemd[1]: Reached target Unmount All Filesystems.
Oct 19 18:51:10 sergey-pc systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Oct 19 18:51:10 sergey-pc systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Oct 19 18:51:10 sergey-pc systemd[1]: Stopped Create Static Device Nodes in /dev.
Oct 19 18:51:10 sergey-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 18:51:10 sergey-pc systemd[1]: systemd-sysusers.service: Deactivated successfully.
Oct 19 18:51:10 sergey-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 18:51:10 sergey-pc systemd[1]: Stopped Create System Users.
Oct 19 18:51:10 sergey-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 18:51:10 sergey-pc systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Oct 19 18:51:10 sergey-pc systemd[1]: Stopped Remount Root and Kernel File Systems.
Oct 19 18:51:10 sergey-pc systemd[1]: lvm2-monitor.service: Deactivated successfully.
Oct 19 18:51:10 sergey-pc systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Oct 19 18:51:10 sergey-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 18:51:10 sergey-pc systemd[1]: Reached target System Shutdown.
Oct 19 18:51:10 sergey-pc systemd[1]: Reached target Late Shutdown Services.
Oct 19 18:51:10 sergey-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 18:51:10 sergey-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 18:51:10 sergey-pc systemd[1]: systemd-reboot.service: Deactivated successfully.
Oct 19 18:51:10 sergey-pc systemd[1]: Finished System Reboot.
Oct 19 18:51:10 sergey-pc systemd[1]: Reached target System Reboot.
Oct 19 18:51:10 sergey-pc systemd[1]: Shutting down.
Oct 19 18:51:10 sergey-pc systemd[1]: Using hardware watchdog 'iTCO_wdt', version 0, device /dev/watchdog
Oct 19 18:51:10 sergey-pc systemd[1]: Set hardware watchdog to 10min.
Oct 19 18:51:10 sergey-pc kernel: watchdog: watchdog0: watchdog did not stop!
Oct 19 18:51:10 sergey-pc systemd-shutdown[1]: Syncing filesystems and block devices.
Oct 19 18:51:10 sergey-pc systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Oct 19 18:51:10 sergey-pc systemd-journald[272]: Journal stopped
p.s. after continued googling I came across a suggestion to disable TLP. I’ve installed tlpui and did so. I cannot confirm that this fixes the issue right now, but just recording it.
--lines=100 please as that does not contain enough information…
Have you tried kernel 5.10 LTS already?
:sob:
Thanks for the bug info…
@skarpushin @susanooxyz please subscribe to the bug and try again after it gets resolved.
:sob:
Therefore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
https://forum.manjaro.org/t/black-screen-with-cursor-after-waking-up-from-sleep/63451/5?u=fabby
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
