Black Screen after LUKS prompt
This started happening since last few updates. After I entered my LUKS password in the Plymouth prompt the system goes into black screen, can’t even switch to any TTY. However, if I press Esc immediately after entering the disk password, the system boots normally. This is so strange I don’t even know how to debug this. Any help will be appreciated.
I noticed this issue with Kernel 5.10, 5.11 & 5.12. I hybrid intel-nvidia graphics. I am using latest nvidia-prime driver from mhwd.
I had something similar recently. I noticed that if I unplug my second monitor, SDDM loads fine and I can proceed and plug it in back.
However, this is not necessarily the same issue.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. The relevant part of a journalctl --boot=0 --system when:
    • you do get they system booted
    • it doesn’t (use boot=-1 to get the previous boot)
    would be helpful as well
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Output of inxi is below. I have updated my profile as well.
  Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/vmlinuz-5.12-x86_64
  root=/dev/mapper/CryptVolumeGroup-Root rw
  cryptdevice=UUID=d0c7eb55-9338-41ed-b28c-496ddc99365b:CryptLVM quiet splash
  sysrq_always_enabled=1 net.ifnames=0 apparmor=1 intel_iommu=1
  security=apparmor ec_sys.write_support=1 udev.log_priority=3
  resume=/dev/disk/by-uuid/97897af4-a7ea-47b6-8db1-4745590b229e
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: System76 product: Adder WS v: addw1 serial: <filter>
  Mobo: System76 model: Adder WS v: addw1 serial: <filter> UEFI: INSYDE
  v: 1.07.11-0 date: 06/20/2019
  ID-1: BAT0 charge: 58.5 Wh (100.0%) condition: 58.5/62.1 Wh (94.2%)
  volts: 12.4 min: 10.9 model: Notebook BAT type: Li-ion serial: <filter>
  status: Full
  RAM: total: 31.07 GiB used: 3.21 GiB (10.3%)
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: DE cache: L2: 12 MiB bogomips: 62431
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 4048
  3: 3427 4: 2391 5: 1791 6: 1032 7: 857 8: 800 9: 1315 10: 800 11: 800
  12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: CLEVO/KAPOK
  driver: nvidia v: 465.27 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f10 class-ID: 0300
  Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-9:4
  chip-ID: 5986:9102 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 192 s-size: 508x285mm (20.0x11.2")
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 3840x2160 hz: 60 dpi: 284 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
  bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
  Sound Server-3: JACK v: 0.125.0 running: no
  Sound Server-4: PulseAudio v: 14.2 running: yes
  Sound Server-5: PipeWire v: 0.3.26 running: no
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 72:00.0
  IF: eth0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: down
  bt-service: enabled,running rfk-block: hardware: no software: no
  address: <filter>
  Message: Unable to run lvs. Root privileges required.
  Device-1: CryptLVM maj-min: 254:0 type: LUKS dm: dm-0 size: 464.76 GiB
  Components:
  p-1: nvme1n1p3 maj-min: 259:4 size: 464.76 GiB
  Device-2: Data_Drive maj-min: 254:5 type: LUKS dm: dm-5 size: 465.75 GiB
  Components:
  p-1: nvme0n1p1 maj-min: 259:5 size: 465.76 GiB
  Device-3: Web_Drive maj-min: 254:4 type: LUKS dm: dm-4 size: 465.75 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:6 size: 465.75 GiB
  Local Storage: total: 1.82 TiB used: 467.5 GiB (25.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
  model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
  logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
  rev: 2B2QEXM7 scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
  model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
  rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-1: / raw-size: 160 GiB size: 160 GiB (100.00%) used: 46.67 GiB (29.2%)
  fs: btrfs dev: /dev/dm-1 maj-min: 254:1 mapped: CryptVolumeGroup-Root
  label: N/A uuid: N/A
  ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%) used: 265 MiB (51.9%)
  fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A uuid: D740-2464
  ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
  used: 416 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2 label: N/A
  uuid: D7CE-89F5
  ID-4: /home raw-size: 272.76 GiB size: 272.76 GiB (100.00%)
  used: 237.47 GiB (87.1%) fs: btrfs dev: /dev/dm-2 maj-min: 254:2
  mapped: CryptVolumeGroup-Home label: N/A uuid: N/A
  ID-5: /home/<filter>/data_drive raw-size: 465.75 GiB
  size: 465.75 GiB (100.00%) used: 173.9 GiB (37.3%) fs: btrfs dev: /dev/dm-5
  maj-min: 254:5 mapped: Data_Drive label: N/A uuid: N/A
  ID-6: /home/<filter>/web_drive raw-size: 465.75 GiB
  size: 465.75 GiB (100.00%) used: 9.21 GiB (2.0%) fs: btrfs dev: /dev/dm-4
  maj-min: 254:4 mapped: Web_Drive label: N/A uuid: N/A
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/dm-3 maj-min: 254:3 mapped: CryptVolumeGroup-SWAP label: N/A
  uuid: 97897af4-a7ea-47b6-8db1-4745590b229e
  ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
  uuid: 2C58BB5058BB1792
  ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
  uuid: 38BB-55B2
  ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
  ID-4: /dev/sda4 maj-min: 8:4 size: 128 GiB fs: bitlocker label: N/A
  uuid: N/A
  ID-5: /dev/sda5 maj-min: 8:5 size: 337.13 GiB fs: <superuser required>
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-6:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-7:3 info: Synaptics type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00c7
  class-ID: ff00 serial: <filter>
  Device-3: 1-9:4 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
  class-ID: 0e02
  Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 61.0 C mobo: N/A
  Processes: 392 Uptime: 6m wakeups: 2 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 alt: 4.9/4.9.4/8 clang: 11.1.0 Packages: 2526
  pacman: 2507 lib: 563 flatpak: 10 snap: 9 Shell: Bash v: 5.1.4
  running-in: yakuake inxi: 3.3.04
The journal log: Journal - Pastebin.com
You missed these bits:
  • Once when
  • And another one
If you don’t know which the relevant part is, please give me the time (up to a second) when the issue happens / doesn’t happen.
:thinking:
Thanks @Fabby , I will keep them in mind. Currently the problem seems to be resolved after after latest update.
