Black screen after logging in
Last time I was on I tried to install
yay -S opencl-amd-polaris
But was unable to due to it conflicting with some amd ROCm
Things I already tried
Searching for solution
Restarting
yay -R opencl-amd-polaris Its output “error: target not found: opencl-amd-polaris”
inxi -Fxz
 Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
 Desktop: KDE Plasma 5.21.3 Distro: Manjaro Linux base: Arch Linux
 Type: Desktop System: MSI product: Z1-7641 v: 4.0 serial: <filter>
 Mobo: MSI model: 760GM-P34(FX) (MS-7641) v: 4.0 serial: <filter>
 BIOS: American Megatrends v: 17.18B3 date: 03/13/2014
 Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
 charge: 55% (should be ignored) status: Discharging
 Info: 8-Core model: AMD FX-8320 bits: 64 type: MCP arch: Bulldozer
 rev: 0 cache: L2: 2 MiB
 flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
 bogomips: 56017
 Speed: 2068 MHz min/max: 1400/3500 MHz boost: enabled
 Core speeds (MHz): 1: 2068 2: 2119 3: 1399 4: 1394 5: 1400 6: 1399
 7: 1399 8: 1400
 Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
 vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 01:00.0
 Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
 unloaded: modesetting,radeon resolution: 1920x1080~60Hz
 OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0
 5.10.23-1-MANJARO LLVM 11.1.0)
 v: 4.6 Mesa 20.3.4 direct render: Yes
 Device-1: AMD SBx00 Azalia vendor: Micro-Star MSI
 driver: snd_hda_intel v: kernel bus-ID: 00:14.2
 Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
 vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
 Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
 Sound Server-4: PipeWire v: 0.3.23 running: no
 vendor: Micro-Star MSI driver: r8169 v: kernel port: e800
 bus-ID: 02:00.0
 IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
 Device-2: Ralink RT2561/RT61 802.11g PCI vendor: Linksys WMP54G v4.1
 driver: rt61pci v: 2.3.0 port: e800 bus-ID: 03:02.0
 IF: wlp3s2 state: down mac: <filter>
 Local Storage: total: 2.73 TiB used: 26.55 GiB (1.0%)
 ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
 ID-2: /dev/sdb vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
 ID-1: / size: 907.23 GiB used: 26.55 GiB (2.9%) fs: ext4
 dev: /dev/sda1
 ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
 dev: /dev/sda2
 System Temperatures: cpu: 19.8 C mobo: N/A gpu: amdgpu temp: 23.0 C
 Fan Speeds (RPM): N/A gpu: amdgpu fan: 1296
 Processes: 236 Uptime: 33m Memory: 15.63 GiB used: 2.29 GiB (14.6%)
 Init: systemd Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1430
 Shell: Bash v: 5.1.0 inxi: 3.3.03 ```
I assume you checked these for help…
https://forum.manjaro.org/search?q=Black%20screen%20after%20log
The problem is not that I cannot login it’s that When I login its just a black screen
I can get access to the terminal and firefox But all my gui and everything is gone it seem like it has nothing to do with the ROCm or opencl
I have the exact same problem. It happened after some update but i don’t know which because i didn’t reboot for a week or so.
Odd This just happened to me today. It was working fine yesterday and the day before
maybe that’s a problem with plasmashell because when i try to launch it through terminal it segfaults. Or is it normal?
Hi all,
Please, read the comments on the AUR package repository in order to find an answer.
AUR (en) - opencl-amd-polaris
You can search in the forum with the words POLARIS10 DRM 3.4.0 in order to find more help.
For example, this post: ‘eGPU issues with external monitor - #28 by pobrn
Hope this help, regards
the thing is, in my case i didn’t do anything with this package and i have the same problem, black screen after logging in, no desktop, no bottom panel. ctrl+alt+t works and brings up my terminal. Animations are working so i suppose that kwin is running. Is that something to do with plasmashell? where can i find the logs to check that?
when i run startx in TTY2 I get: Couldn’t exec startkde: No such file or directory. Not sure if that’s something to do with my problem
I managed to solve the issue! Yay! the problem was with the “eventcalendar” plasma extention. The solution was to delete line: “plugin=org.kde.plasma.eventcalendar” in the ~/.config/plasma-org.kde.plasma.desktop-appletsrc file. I hope this solves your issue too @EmynFuin
Great to hear! I just reinstalled as I was to impatient so sadly i cannot test to see if this will work
form now on I’m going to try to backup with Timeshift
