Hello please help me, I have problem my gpd pocket have a black screen after hibernation
swap connected
journalctl | grep offset not have error
my mkinitcpio.conf
# vim:set ft=sh# MODULES# The following modules are loaded before any boot hooks are# run. Advanced users may wish to specify all system modules# in this array. For instance:# MODULES=(piix ide_disk reiserfs)MODULES=""
# BINARIES# This setting includes any additional binaries a given user may# wish into the CPIO image. This is run last, so it may be used to# override the actual binaries included by a given hook# BINARIES are dependency parsed, so you may safely ignore librariesBINARIES=()
# FILES# This setting is similar to BINARIES above, however, files are added# as-is and are not parsed in any way. This is useful for config files.FILES=""
# HOOKS# This is the most important setting in this file. The HOOKS control the# modules and scripts added to the image, and what happens at boot time.# Order is important, and it is recommended that you do not change the# order in which HOOKS are added. Run 'mkinitcpio -H ' for# help on a given hook.# 'base' is _required_ unless you know precisely what you are doing.# 'udev' is _required_ in order to automatically load modules# 'filesystems' is _required_ unless you specify your fs modules in MODULES# Examples:## This setup specifies all modules in the MODULES setting above.## No raid, lvm2, or encrypted root is needed.# HOOKS=(base)### This setup will autodetect all modules for your system and should## work as a sane default# HOOKS=(base udev autodetect block filesystems)### This setup will generate a 'full' image which supports most systems.## No autodetection is done.# HOOKS=(base udev block filesystems)### This setup assembles a pata mdadm array with an encrypted root FS.## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.# HOOKS=(base udev block mdadm encrypt filesystems)### This setup loads an lvm2 volume group on a usb device.# HOOKS=(base udev block lvm2 filesystems)### NOTE: If you have /usr on a separate partition, you MUST include the# usr, fsck and shutdown hooks.
HOOKS=«base udev autodetect modconf block keyboard keymap resume filesystems»
# COMPRESSION# Use this to compress the initramfs image. By default, gzip compression# is used. Use 'cat' to create an uncompressed image.COMPRESSION=«gzip»COMPRESSION=«bzip2»COMPRESSION=«lzma»COMPRESSION=«xz»COMPRESSION=«lzop»COMPRESSION=«lz4»COMPRESSION=«zstd»
# COMPRESSION_OPTIONS# Additional options for the compressorCOMPRESSION_OPTIONS=()
my grub config
GRUB_DEFAULT=savedGRUB_TIMEOUT=5GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR=«Manjaro»
GRUB_CMDLINE_LINUX_DEFAULT=«resume=/dev/mmcblk0p6 quiet splash fbcon=rotate:1 quiet apparmor=1 security=apparmor udev.log_priority=3 „GRUB_CMDLINE_LINUX=“fbcon=rotate:1»
# If you want to enable the save default function, uncomment the following# line, and set GRUB_DEFAULT to saved.GRUB_SAVEDEFAULT=true
# Preload both GPT and MBR modules so that they are not missedGRUB_PRELOAD_MODULES=«part_gpt part_msdos»
# Uncomment to enable booting from LUKS encrypted devicesGRUB_ENABLE_CRYPTODISK=y
# Uncomment to use basic consoleGRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminalGRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal# note that you can use only modes which your graphic card supports via VBE# you can see them in real GRUB with the command 'videoinfo'GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grubGRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter# format «root=/dev/xxx» instead of «root=/dev/disk/by-uuid/xxx»GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entriesGRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper# modes only. Entries specified as foreground/background.GRUB_COLOR_NORMAL=«light-gray/black»GRUB_COLOR_HIGHLIGHT=«green/black»
# Uncomment one of them for the gfx desired, a image background or a gfxthemeGRUB_BACKGROUND="/usr/share/grub/background.png"GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
# Uncomment to get a beep at GRUB startGRUB_INIT_TUNE=«480 440 1»
# Uncomment to ensure that the root filesystem is mounted read-only so that# systemd-fsck can run the check automaticallyGRUB_ROOT_FS_RO=true
Welcome to Manjaro!
