Hi all.
I’m dualbooting Manjaro XFCE and Windows 10.
If I choose “Hibernate” in Manjaro, then I’m left with a black screen when I turn on my machine again.
Suspend works fine. I’m not quite sure what information to provide you with, here is what I thought was useful:
inxi -Fazy output:
Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=3b798255-8020-4d88-b513-a3263f25f75a rw quiet apparmor=1
security=apparmor resume=UUID=bb591d97-7e19-4ec5-bb90-de555a1e6f54
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
serial: <filter> UEFI: American Megatrends v: 2.60 date: 12/30/2019
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
L2 cache: 3072 KiB
bogomips: 86424
Speed: 2199 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2199 2: 2200 3: 2192 4: 2191 5: 2198 6: 2200 7: 2196 8: 2197 9: 2200
10: 2199 11: 2192 12: 2200
conditional, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: Gigabyte
driver: nouveau v: kernel bus ID: 26:00.0 chip ID: 10de:2187
Display: x11 server: X.Org 1.20.8 driver: modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DP-1 res: 1920x1080 hz: 120 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: llvmpipe (LLVM 10.0.1 256 bits) v: 3.3 Mesa 20.1.6
compat-v: 3.1 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 26:00.1 chip ID: 10de:1aeb
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 28:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.4.60-2-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 22:00.0
chip ID: 10ec:8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 465.76 GiB used: 10.32 GiB (2.2%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 023 scheme: GPT
ID-1: / raw size: 97.16 GiB size: 95.13 GiB (97.91%) used: 10.32 GiB (10.8%)
fs: ext4 dev: /dev/sda6
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 21 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1606
Processes: 386 Uptime: 4h 27m Memory: 15.65 GiB used: 1.49 GiB (9.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1097 lib: 314
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
sudo dmesg -l emerg,alert,crit,err,warn output:
[ 0.029999] tsc: Unable to calibrate against PIT
[ 0.641841] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.752289] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.757769] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 1.360884] ata1.00: supports DRM functions and may not be fully accessible
[ 1.361594] ata1.00: supports DRM functions and may not be fully accessible
[ 3.016624] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 3.305834] nouveau 0000:26:00.0: DRM: failed to create kernel channel, -22
[ 4.463350] nvidia-gpu 0000:26:00.3: i2c timeout error e0000000
[ 4.463355] ucsi_ccg 3-0008: i2c_transfer failed -110
[ 4.463358] ucsi_ccg 3-0008: ucsi_ccg_init failed - -110
[ 4.463365] ucsi_ccg: probe of 3-0008 failed with error -110
[ 8.916012] kauditd_printk_skb: 36 callbacks suppressed
[ 13.980181] kauditd_printk_skb: 12 callbacks suppressed
[ 3567.240803] kauditd_printk_skb: 1 callbacks suppressed
[ 4415.350373] kauditd_printk_skb: 3 callbacks suppressed
[ 4906.562323] ata1.00: supports DRM functions and may not be fully accessible
[ 4906.563062] ata1.00: supports DRM functions and may not be fully accessible
[ 8805.964321] kauditd_printk_skb: 1 callbacks suppressed
[12142.851913] ata1.00: supports DRM functions and may not be fully accessible
[12142.852599] ata1.00: supports DRM functions and may not be fully accessible
Snatch of a journalctl output I found related:
PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
PM: hibernation: Registered nosave memory: [mem 0x09d82000-0x09ffffff]
PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20bfff]
PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
PM: hibernation: Registered nosave memory: [mem 0xd6d84000-0xd6de0fff]
PM: hibernation: Registered nosave memory: [mem 0xd6eaf000-0xd6eaffff]
PM: hibernation: Registered nosave memory: [mem 0xdb5e6000-0xdb72ffff]
PM: hibernation: Registered nosave memory: [mem 0xdb8b1000-0xdbcc2fff]
PM: hibernation: Registered nosave memory: [mem 0xdbcc3000-0xdc9e3fff]
PM: hibernation: Registered nosave memory: [mem 0xdc9e4000-0xdca89fff]
PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfcffffff]
hibernation: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[mem 0xe0000000-0xf7ffffff] available for PCI devices
Booting paravirtualized kernel on bare hardware
Any advice? ![]()
. I’ve updated my post with what I thought might be relevant.
