Hi community,
I made some customization to my kde desktop environment, after that when the system feels for it the screen turn black and only mouse cursor. i have a Radeon RX550 GPU.
I also have noticed that Timeshift is not working, it let me to add the partition and the process completes, but i don’t see any backup in the list. its simply empty.
Also noticed that my pci-e paralel card is not installed.
i belive all this happened after the update, what have i done wrong?
can you please help me?
can you boot into TTY, in the black screen press ctrl+alt+f2
- if f2 doesnt work, try with f1-f6 keys
thank you for your reply,
System seems to be fine, i can press ctl+F2 to search the console to type in command reboot, so my conclusion is that everything on desktop and its environment . Sigh forgot to add that the system take ages to restart or shutdown. micro seconds before shutdown, a post shows and disperses. so it seems that something is wrong with the shut down and reboot process to!
so can you boot into TTY?
You are freaking awesome, thank you!
Seems to not work when CTL+ALT+F2 is pressed!
