Bought new battery and the power management is still horrible.
20W consumption as you see in a picture, the 12:40 point was when I took out the AC and started using the battery.
I am using tlp and slimbookbatt
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=78b70369-e442-499b-81d2-9a3d1520dec0 rw quiet apparmor=1
security=apparmor resume=UUID=dc6fbfe2-ed60-4875-9979-d3282441e598
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N552VX v: 1.0 serial:
Mobo: ASUSTeK model: N552VX v: 1.0 serial:
UEFI: American Megatrends v: N552VX.206 date: 11/13/2015
ID-1: BAT0 charge: 47.0 Wh condition: 47.5/51.0 Wh (93%) volts: 15.0/15.0
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging
cycles: 6
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: charge: 55% (should be ignored) rechargeable: yes
status: Discharging
Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: D6
L2 cache: 6144 KiB
bogomips: 41621
Speed: 1211 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1222 2: 1236
3: 1203 4: 1232 5: 1198 6: 1214 7: 1209 8: 1216
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:139a
Device-3: Chicony HD WebCam (Asus N-series) type: USB driver: uvcvideo
bus ID: 1-4:3 chip ID: 04f2:b3fd serial:
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: intel,modesetting alternate: fbdev,nouveau,nv,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel port: e000 bus ID: 02:00.0 chip ID: 168c:0034
IF: wlp2s0 state: up mac:
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.1
chip ID: 10ec:8168
IF: enp3s0f1 state: down mac:
Local Storage: total: 931.51 GiB used: 24.35 GiB (2.6%)
ID-1: /dev/sda vendor: Toshiba model: MQ02ABD100H size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: rev: 1J scheme: GPT
ID-1: / raw size: 922.42 GiB size: 906.94 GiB (98.32%)
used: 24.35 GiB (2.7%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nouveau temp: 42 C
Fan Speeds (RPM): cpu: 2000
Processes: 248 Uptime: 3h 22m Memory: 7.67 GiB used: 3.57 GiB (46.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1269 lib: 352
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
