Trying to run Minecraft Beta 1.7.3 through MultiMC. When it runs, it just shows a white screen. I’m assuming I’m missing a package?
Java HotSpot(TM) Server VM warning: You have loaded library /home/cthulu805/.local/share/multimc/instances/Beta/natives/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Exception in thread "Minecraft main thread" java.lang.UnsatisfiedLinkError: /home/cthulu805/.local/share/multimc/instances/Beta/natives/liblwjgl.so: libXcursor.so.1: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1937)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1853)
at java.lang.Runtime.loadLibrary0(Runtime.java:843)
at java.lang.System.loadLibrary(System.java:1134)
at org.lwjgl.Sys$1.run(Sys.java:72)
at java.security.AccessController.doPrivileged(Native Method)
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
at org.lwjgl.Sys.loadLibrary(Sys.java:96)
at org.lwjgl.Sys.<clinit>(Sys.java:117)
at org.lwjgl.opengl.Display.<clinit>(Display.java:135)
at net.minecraft.client.Minecraft.a(SourceFile:244)
at net.minecraft.client.Minecraft.run(SourceFile:716)
at java.lang.Thread.run(Thread.java:750)
