bearcat
February 19, 2021, 4:52pm
#1
I noticed references to kernel 5.6 when updating. I looked for it, and it’s there:
[dmn@Sydney boot]$ ls | grep 5.6
initramfs-5.6-x86_64-fallback.img
initramfs-5.6-x86_64.img
vmlinuz-5.6-x86_64
But, checking installed kernels with mhwd-kernel -li, only the 5.10 kernel is seen as installed:
[dmn@Sydney boot]$ mhwd-kernel -li
Currently running: 5.10.15-1-MANJARO (linux510)
What is the best way to remove the 5.6 packages? It’s not shown in the Manjaro Settings Manager, Kernel Section.
Bankman
February 19, 2021, 6:24pm
#2
I had the same problem. It was solved here but please ensure twice that that kernel is not installed with the mhwd-kernel --listinstalled
command before you delete a kernel that way or you’ll end up with an unbootable system!
bearcat
February 19, 2021, 7:24pm
#3
Thanks. That validates what I was considering. I removed the three files shown in the original post from /boot, then updated grub.
Note to others: Don’t do this if the kernel is still shown as installed in the manager.
system
closed
March 6, 2021, 7:24pm
#4
