With the last system update kernel 5.8 was automatically removed, but while booting my system the old kernel 5.8 still appears in the advanced boot options:
Kernel 5.8 can not be removed because it is not installed…
$ sudo mhwd-kernel -r linux58
Error: Kernel not installed.
Currently running: 5.4.86-1-MANJARO (linux54)
* linux510
* linux54
does anyone have an idea how to solve this problem?
thx
bankman
Hi Bankman
Have you tried to update Grub?
sudo update-grub
Hi Graham,
yes, i tried to update Grub with sudo update-grub but that didn’t work…
Have you ever used Grub Customizer? I have read that it can cause ghost entries.
can you report
sudo ls /etc/mkinitcpio.d/*.preset
sudo ls /boot/*
@ Graham: No, i never used Grub Customizer
@ stephane:
$ sudo ls /etc/mkinitcpio.d/*.preset
/etc/mkinitcpio.d/linux510.preset /etc/mkinitcpio.d/linux58.preset
/etc/mkinitcpio.d/linux54.preset
$ sudo ls /boot/*
/boot/initramfs-5.10-x86_64-fallback.img /boot/intel-ucode.img
/boot/initramfs-5.10-x86_64.img /boot/linux510-x86_64.kver
/boot/initramfs-5.4-x86_64-fallback.img /boot/linux54-x86_64.kver
/boot/initramfs-5.4-x86_64.img /boot/vmlinuz-5.10-x86_64
/boot/initramfs-5.8-x86_64-fallback.img /boot/vmlinuz-5.4-x86_64
/boot/initramfs-5.8-x86_64.img /boot/vmlinuz-5.8-x86_64
/boot/grub:
fonts grub.cfg grubenv i386-pc locale themes
/boot/memtest86+:
memtest.bin
then remove
sudo rm /boot/initramfs-5.8-x86_64-fallback.img
sudo rm /boot/initramfs-5.8-x86_64.img
sudo rm /boot/vmlinuz-5.8-x86_64
sudo rm /etc/mkinitcpio.d/linux58.preset
sudo pacman -Qs linux58-
sudo mkinitcpio -P
removed as described but the entry in the advanced boot options is still there
Hagen
2 January 2021 19:20
9
sudo update-grub
thank you guys!
The ghost has gone
system
Closed
17 January 2021 20:11
11
