I have KDE. The tool it has, no temp or I couldn’t find it.
Plasma System monitor has the ability to monitor temps and fans.
You may need to add “+ Add a new page” and configure the sensors yourself though.
To check system sensors (temperatures & fan speeds) in terminal:
sensors
To show system temperatures (and may more things) on desktop:
Conky: Light-weight system monitor for X, Wayland (sort of), and other things, too
How do I config the sensors? That stopped responding so I got Psensors.
As stated above, Conky also fastfetch, neofetch etc.
Best is a matter of opinion. What works for you may not work for everybody else.
