Hello everyone. What is the best choice for mirror? Should I leave the default option (international) or move to a local one (Greece in my case). Thanks.
Both are good.
Use pacman-mirrors or shiny-mirrors to determine the best (fastest) mirror for your location.
Usually, the closer to your location, the faster it is.
What was wrong with the answers you received the last two times you asked a similar question?
