the “possible” breakage of grub in some of the updates this year is giving me anxiety and it is also very annoying*.
So I was wondering, which is the best, i.e. hassle free boot loader for manjaro?
I have just manjaro installed.
Thx and happy holidays.
* During the 2025-08-11 update, I thought I did everything right, it still broke. Then I changed some UEFI settings and I could boot into manjaro again. Didn’t touch grub since, but it definitely doesn’t feel safe.
There is no such thing as best and easiest - it depends on your system and your skills.
If your system is BIOS/MBR then there is very few alternatives - syslinux is one - but I don’t regard that one as easy - perhaps because I never used it.
If your system is modern UEFI based system.
In my personal opinion - using a unified kernel - and fairly easy to convert.
But if you want to change as little as possible
the system has bios mode disabled (CSM or compatibility mode)
the system is NOT encrypted
rEFInd can boot the kernel directly
it also handles booting different EFI based operating systems
I can personally vouch for rEFInd, having used it for well over a decade. Once installed, it becomes the initial UEFI boot manager and effectively chainloads Grub. Grub remains managed by the OS itself, but as @ManjaroDevOps suggests, there is also an option offerred which bypasses Grub completely, and boots via the kernel stub.
rEFInd is configured from one file – the defaults are quite sane.
In fact, it’s likely all that you might want to change is the timeout and the theme. The file is well documented behind # comments.
sudo nano /boot/efi/EFI/refind/refind.conf
You will find links to some rEFInd themes toward the end of this related tutorial:
