BCM43142A0 Bluetooth module does not detect any devices
The system installed the Bluetooth drivers itself. In the system settings, the device shows as turned on, but the search wheel is spinning all the time and does not find any turned on devices within range.
inxi --admin --verbosity=7 --filter --no-host --width            ✔
  Kernel: 5.15.72-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=8ce5fb83-4fc9-4ac1-95e9-27e0b9f16360 rw quiet splash apparmor=1
    security=apparmor resume=UUID=c37b4737-4448-4b91-b00a-0f818485b606
    udev.log_priority=3
  Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: LENOVO product: 20238 v: Lenovo G510
    serial: <superuser required> Chassis: type: 10 v: Lenovo G510
  Mobo: LENOVO model: INVALID v: 31900058Std serial: <superuser required>
    UEFI: LENOVO v: 79CN46WW(V3.05) date: 12/23/2013
  RAM: total: 7.68 GiB used: 2.11 GiB (27.5%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i5-4200M bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2264 high: 2480 min/max: 800/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2405 2: 1912 3: 2260
    4: 2480 bogomips: 19963
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid xsave xsaveopt xtopology xtpr
    vulnerable
    prctl and seccomp
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
    driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
    active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0416 class-ID: 0300
  Device-2: AMD Jet PRO [Radeon R5 M230 / R7 M260DX Radeon 520 Mobile]
    vendor: Lenovo driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:6665 class-ID: 0380
    temp: 44.0 C
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: X: loaded: modesetting,radeon
    alternate: fbdev,vesa dri: crocus,radeonsi gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Samsung built: 2011
    res: 1366x768 hz: 60 dpi: 217 gamma: 1.2 size: 160x90mm (6.3x3.54")
    diag: 801mm (31.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
  Monitor-2: eDP-1 note: disabled model: Samsung 0x4752 built: 2012
    res: 1366x768 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
  OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2) v: 4.6 Mesa 22.1.7
    direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Sound API: ALSA v: k5.15.72-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: yes
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: wl v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 14e4:4365
    class-ID: 0280
  IF: wlp8s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 09:00.0 chip-ID: 1969:10a0 class-ID: 0200
  IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.14 TiB used: 22.95 GiB (2.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSDPR-CX400-256
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 61.3 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
    type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.27 GiB (9.5%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 8ce5fb83-4fc9-4ac1-95e9-27e0b9f16360
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: CBC7-F791
  ID-3: /home raw-size: 121.97 GiB size: 119.49 GiB (97.97%) used: 13.68 GiB
    (11.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 55f3191a-5393-4e39-8b92-60b843f868aa
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: c37b4737-4448-4b91-b00a-0f818485b606
  ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ext4 label: home
    uuid: a5bba619-ab0e-4260-a0ec-330974d42ce2
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 3-6:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
  Device-2: 3-8:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 55.0 C mobo: N/A gpu: radeon temp: 44.0 C
  Processes: 228 Uptime: 2h 52m wakeups: 3 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1262 libs: 333 tools: gnome-software,pamac,yay
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.22
Ten tekst zostanie ukryty
Hi @Maciek,
Please provide the output for:
lsusb
And
rfkill
Thing is, I don’t see any controllers adapters with or without drivers in your inxi output, so we’ll have to find it. So while you’re at it, please also provide the output for:
lspci
And then, just to be thorough, I have to ask, if you use a laptop, have you made sure it’s not toggled off VIA a hardware key?
Also, I’m asking for the same reason, have you double and/or triple-checked your BIOS/UEFI, that it’s not disabled there?
command results lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 003 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
command results rfkill
ID TYPE DEVICE             SOFT       HARD
 0 wlan ideapad_wlan nieaktywna nieaktywna
 1 wlan phy0         nieaktywna nieaktywna
I come from Poland and I don’t know how to translate the output from the terminal into English
To have things translated to English in the terminal, prefix the command with LC_ALL=C:
LC_ALL=C <command>
Where <command> is the command you wish to run and have translated.
lspci                                                            ✔
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.1 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #2 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM86 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520 Mobile]
08:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
09:00.0 Ethernet controller: Qualcomm Atheros QCA8172 Fast Ethernet (rev 10)
before installing manjaro, I had Zorin OS installed and the bluetooth adapter was working fine
 0 wlan ideapad_wlan unblocked unblocked
 1 wlan phy0         unblocked unblocked
From what I can see, everything is fine. That bluetooth controller is fine, is detected, and I don’t see any issues.
So lets see what happens if you:
bluetoothctl
Followed by:
[bluetooth]# scan on
and:
[bluetooth]# help
    ~  bluetoothctl                                                     ✔
The application bluetoothctl is not installed. It may be found in the following packages:
  extra/bluez-utils 5.65-3	/usr/bin/bluetoothctl
Do you want to Install package bluez-utils? (y/N)
OK, install it then. I’m guessing it can’t do any harm, if nothing else.
    ~  bluetoothctl                                                   1 ✘
Agent registered
[bluetooth]#
:smile:
Agent registered
Discovery started
[bluetooth]#
no reaction
In the bluetoothctl context, try:
[bluetooth]# pairable on
And then reboot and seeing if anything changed.
after reboot
Agent registered
Discovery started
[bluetooth]# help
Also, just remembered this. What’s the output of:
systemctl status bluetooth.service
    ~  systemctl status bluetooth.service                               ✔
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset>
     Active: active (running) since Fri 2022-10-14 11:12:59 CEST; 5min ago
       Docs: man:bluetoothd(8)
   Main PID: 465 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 9400)
     Memory: 2.7M
        CPU: 61ms
     CGroup: /system.slice/bluetooth.service
             └─465 /usr/lib/bluetooth/bluetoothd
paź 14 11:13:18 maciek-20238 bluetoothd[465]: Endpoint registered: sender=:1.81>
lines 1-22/22 (END)
Can you use it now, or not yet?
Try the following:
bluetoothctl
And there:
scan on
An example from my computer, just now:
$ [bluetooth]# scan on
Discovery started
[CHG] Controller 00:19:86:00:12:EB Discovering: yes
[NEW] Device DD:CF:F2:7C:30:4B Philips S7960
[bluetooth]#
after all, something is wrong. I turned off the computer and turned it on again, the message “no bluetooth adapter” appeared only after restarting the computer, the adapter was detected. Still no search results for the device
Agent registered
Discovery started
[bluetooth]#
analyzing the results from your terminal, I conclude that I do not see the bluethooth module
even though the command shows that the module is active
Agent registered
Discovery started
[bluetooth]# exit
    ~  systemctl status bluetooth.service                    ✔  2m 47s 
     Active: active (running) since Fri 2022-10-14 11:29:25 CEST; 10min ago
   Main PID: 446 (bluetoothd)
     Status: "Running"
     Memory: 2.7M
        CPU: 86ms
             └─446 /usr/lib/bluetooth/bluetoothd
paź 14 11:29:39 maciek-20238 bluetoothd[446]: Endpoint registered: sender=:1.81>
lines 1-22/22 (END)
