Battery drain during suspend mode
Hi guys, I need your help because I’m not figuring out which is the problem. I have a laptop bought a couple of months ago, with the specifics defined at the end of the post.
What happens is that if I put my laptop in sleep mode it appears to work, the LEDs and the fans turn off, but the battery drains. Sometimes during night it goes to zero. I noticed that casually the fans turn on for one or two seconds and then turn off again. I’ve tried three kernel versions, but nothing changed. Any help would be appreciated
  Host: pc-daniele Kernel: 5.16.11-2-MANJARO x86_64 bits: 64
    Desktop: GNOME 41.4 Distro: Manjaro Linux
  Type: Laptop System: SAMSUNG product: 750XDA v: P16CFD
    serial: <superuser required>
  Mobo: SAMSUNG model: NP750XDA-KDCIT v: SAMSUNG_SW_REVISION_12345+0.0.0000
    serial: <superuser required> UEFI: American Megatrends LLC.
    v: P16CFD.040.211223.HQ date: 12/23/2021
  ID-1: BAT1 charge: 37.6 Wh (67.1%) condition: 56.0/54.4 Wh (103.0%)
  Info: quad core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    cache: L2: 5 MiB
  Speed (MHz): avg: 2200 min/max: 400/4700 cores: 1: 2289 2: 2358 3: 2042
    4: 1998 5: 3300 6: 1607 7: 2162 8: 1844
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
  Device-2: IMC Networks HD Camera type: USB driver: uvcvideo
  Display: wayland server: X.Org v: 1.22.1 with: Xwayland v: 22.1.0
    compositor: gnome-shell driver: X: loaded: intel gpu: i915
    resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.7
  Device-1: Intel Tiger Lake-LP Smart Sound Audio
    driver: sof-audio-pci-intel-tgl
  Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: yes
  Sound Server-3: PipeWire v: 0.3.47 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
  IF: wlo1 state: up mac: 28:11:a8:46:47:f9
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb
  Local Storage: total: 506.49 GiB used: 144.22 GiB (28.5%)
  ID-1: /dev/nvme0n1 vendor: SSSTC model: CL1-8D512 size: 476.94 GiB
  ID-2: /dev/sda type: USB model: Multiple Card Reader size: 29.55 GiB
  ID-1: / size: 231.08 GiB used: 122.28 GiB (52.9%) fs: ext4
    dev: /dev/nvme0n1p7
  ID-2: /boot/efi size: 551.9 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p8
  ID-1: swap-1 type: zram size: 491.3 MiB used: 0 KiB (0.0%) dev: /dev/zram0
  ID-2: swap-2 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram1
  ID-3: swap-3 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram2
  ID-4: swap-4 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram3
  ID-5: swap-5 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram4
  ID-6: swap-6 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram5
  ID-7: swap-7 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram6
  ID-8: swap-8 type: zram size: 491.3 MiB used: 0 KiB (0.0%)
    dev: /dev/zram7
  ID-9: swap-9 type: file size: 256 MiB used: 0 KiB (0.0%)
    file: /var/lib/systemd-swap/swapfc/1
  System Temperatures: cpu: 39.0 C mobo: N/A
  Processes: 318 Uptime: 51m Memory: 15.35 GiB used: 7.34 GiB (47.8%)
  Shell: Zsh inxi: 3.3.13
If i remember right there has been a similar post a few weeks ago
You may find a solution when you search the forum for the right key-word like:
battery, sleep, laptop, suspend, hibernate, closed lid …
Suspend mode keeps the RAM powered on - so it can keep it’s contents and enable the wakeup as you left it.
That will eventually drain your battery - this is normal.
There are other modes, like hybrid sleep or hibernation - where the RAM contents are saved to disk (swap).
The first behaves like suspend, but in case the battery runs out, it can still wake up by reading from the saved to disk data
and the second does only the save to disk and then shuts down.
None of these will work without either a dedicated swap file or a swap partition.
systemd-swap (which is what you have) provides you a swap file, but this cannot be used to suspend to disk
I already knew that, but the problem is that the battery drains to 0 % during one night. I’ve tried by creating a swap partition and the problem persists. Here the journalctl log:
mar 10 00:08:55 pc-daniele gnome-shell[1724]: Power state changed: discharging
mar 10 00:09:00 pc-daniele systemd-logind[497]: Lid closed.
mar 10 00:09:00 pc-daniele systemd-logind[497]: Suspending...
mar 10 00:09:00 pc-daniele NetworkManager[493]: <info>  [1646867340.9762] manager: sleep: sleep requested (sleeping: no  enabled: yes)
mar 10 00:09:00 pc-daniele NetworkManager[493]: <info>  [1646867340.9763] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:09:00 pc-daniele ModemManager[565]: <info>  [sleep-monitor] system is about to suspend
mar 10 00:09:00 pc-daniele NetworkManager[493]: <info>  [1646867340.9765] manager: NetworkManager state is now ASLEEP
mar 10 00:09:00 pc-daniele NetworkManager[493]: <info>  [1646867340.9767] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:09:00 pc-daniele kernel: wlo1: deauthenticating from a4:91:b1:e1:bd:05 by local choice (Reason: 3=DEAUTH_LEAVING)
mar 10 00:09:01 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-DISCONNECTED bssid=a4:91:b1:e1:bd:05 reason=3 locally_generated=1
mar 10 00:09:01 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1067] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1295] dhcp4 (wlo1): canceled DHCP transaction
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1295] dhcp4 (wlo1): state changed bound -> terminated
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1296] dhcp6 (wlo1): canceled DHCP transaction
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1296] dhcp6 (wlo1): state changed bound -> terminated
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1319] device (wlo1): set-hw-addr: set MAC address to C6:92:65:FF:55:3E (scanning)
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1348] device (wlo1): supplicant interface state: completed -> disconnected
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1349] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:09:01 pc-daniele NetworkManager[493]: <info>  [1646867341.1369] device (wlo1): set-hw-addr: reset MAC address to 28:11:A8:46:47:F9 (unmanage)
mar 10 00:09:01 pc-daniele systemd[1674]: Stopping gnome-user-share WebDAV server...
mar 10 00:09:01 pc-daniele wpa_supplicant[670]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 10 00:09:01 pc-daniele wpa_supplicant[670]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
mar 10 00:09:01 pc-daniele wpa_supplicant[670]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
mar 10 00:09:01 pc-daniele dropbox[2071]: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
mar 10 00:09:01 pc-daniele gnome-shell[1724]: An active wireless connection, in infrastructure mode, involves no access point?
mar 10 00:09:01 pc-daniele gnome-shell[1724]: DING: GNOME nautilus 41.2
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Timelines with detached actors are not supported
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 64 with keysym 64 (keycode 28).
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
mar 10 00:09:01 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
mar 10 00:09:02 pc-daniele systemd[1674]: Stopped gnome-user-share WebDAV server.
mar 10 00:09:02 pc-daniele systemd[1]: Reached target Sleep.
mar 10 00:09:02 pc-daniele systemd[1]: Starting System Suspend...
mar 10 00:09:02 pc-daniele systemd-sleep[52454]: Entering sleep state 'suspend'...
mar 10 00:09:02 pc-daniele kernel: PM: suspend entry (s2idle)
mar 10 00:09:02 pc-daniele kernel: Filesystems sync: 0.023 seconds
mar 10 00:10:22 pc-daniele kernel: Bluetooth: hci0: Timed out waiting for suspend events
mar 10 00:10:22 pc-daniele kernel: Bluetooth: hci0: Suspend timeout bit: 9
mar 10 00:10:22 pc-daniele kernel: Bluetooth: hci0: Suspend notifier action (3) failed: -110
mar 10 00:10:22 pc-daniele kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
mar 10 00:10:22 pc-daniele kernel: OOM killer disabled.
mar 10 00:10:22 pc-daniele kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
mar 10 00:10:22 pc-daniele kernel: printk: Suspending console(s) (use no_console_suspend to debug)
mar 10 00:10:22 pc-daniele kernel: ACPI: EC: interrupt blocked
mar 10 00:10:22 pc-daniele kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^PC00.LPCB.HEC.ECNT], AE_NOT_FOUND (20210930/psargs-330)
mar 10 00:10:22 pc-daniele kernel: ACPI Error: Aborting method \_SB.PEPD._DSM due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:10:22 pc-daniele kernel: ------------[ cut here ]------------
mar 10 00:10:22 pc-daniele kernel: WARNING: CPU: 2 PID: 0 at kernel/time/timekeeping.c:824 ktime_get+0x97/0xa0
mar 10 00:10:22 pc-daniele kernel: Modules linked in: ntfs3 rfcomm ccm cmac algif_hash algif_skcipher af_alg bnep uas btusb uvcvideo btrtl videobuf2_vmalloc btbcm videobuf2_memops videobuf2_v4l2 btintel videobu>
mar 10 00:10:22 pc-daniele kernel:  snd_hwdep kvm iwlmvm snd_pcm irqbypass mei_hdcp crct10dif_pclmul intel_rapl_msr wmi_bmof mac80211 crc32_pclmul ghash_clmulni_intel snd_timer intel_spi_pci snd aesni_intel int>
mar 10 00:10:22 pc-daniele kernel: CPU: 2 PID: 0 Comm: swapper/2 Tainted: G           OE     5.16.11-2-MANJARO #1 e89f672376849709dca6940989168cdc5105b505
mar 10 00:10:22 pc-daniele kernel: Hardware name: SAMSUNG ELECTRONICS CO., LTD. 750XDA/NP750XDA-KDCIT, BIOS P16CFD.040.211223.HQ 12/23/2021
mar 10 00:10:22 pc-daniele kernel: RIP: 0010:ktime_get+0x97/0xa0
mar 10 00:10:22 pc-daniele kernel: Code: 8b 35 fd 30 56 02 41 39 f4 75 a1 48 0f af d0 48 8d 04 3a 48 d3 e8 48 01 d8 5b 5d 41 5c 31 d2 89 d1 89 d6 89 d7 c3 f3 90 eb 82 <0f> 0b e9 79 ff ff ff 66 90 0f 1f 44 00 00>
mar 10 00:10:22 pc-daniele kernel: RSP: 0018:ffffb7310015bd80 EFLAGS: 00010002
mar 10 00:10:22 pc-daniele kernel: RAX: 0000000000000001 RBX: ffff9abb40b74d00 RCX: 0000000000000000
mar 10 00:10:22 pc-daniele kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
mar 10 00:10:22 pc-daniele kernel: RBP: ffff9abee0431800 R08: 0000000000000000 R09: 0000000000000000
mar 10 00:10:22 pc-daniele kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9abee0431800
mar 10 00:10:22 pc-daniele kernel: R13: ffff9abee0431800 R14: ffff9abee04320f0 R15: ffff9abb40b74e80
mar 10 00:10:22 pc-daniele kernel: FS:  0000000000000000(0000) GS:ffff9abee0480000(0000) knlGS:0000000000000000
mar 10 00:10:22 pc-daniele kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
mar 10 00:10:22 pc-daniele kernel: CR2: 000055fe1a56b9a0 CR3: 00000003e4e10003 CR4: 0000000000770ee0
mar 10 00:10:22 pc-daniele kernel: PKRU: 55555554
mar 10 00:10:22 pc-daniele kernel: Call Trace:
mar 10 00:10:22 pc-daniele kernel:  <TASK>
mar 10 00:10:22 pc-daniele kernel:  enqueue_task_rt+0x34f/0x3c0
mar 10 00:10:22 pc-daniele kernel:  enqueue_task+0x4e/0x190
mar 10 00:10:22 pc-daniele kernel:  ttwu_do_activate+0x4c/0xc0
mar 10 00:10:22 pc-daniele kernel:  try_to_wake_up+0x200/0x590
mar 10 00:10:22 pc-daniele kernel:  swake_up_one+0x2e/0x60
mar 10 00:10:22 pc-daniele kernel:  rcu_eqs_enter.constprop.0+0x57/0xb0
mar 10 00:10:22 pc-daniele kernel:  cpuidle_enter_s2idle+0x14c/0x180
mar 10 00:10:22 pc-daniele kernel:  do_idle+0x22f/0x270
mar 10 00:10:22 pc-daniele kernel:  cpu_startup_entry+0x19/0x20
mar 10 00:10:22 pc-daniele kernel:  secondary_startup_64_no_verify+0xc2/0xcb
mar 10 00:10:22 pc-daniele kernel:  </TASK>
mar 10 00:10:22 pc-daniele kernel: ---[ end trace 53ec3b755f954574 ]---
mar 10 00:10:22 pc-daniele kernel: ACPI: EC: interrupt unblocked
mar 10 00:10:22 pc-daniele kernel: nvme nvme0: 8/0/0 default/read/poll queues
mar 10 00:10:22 pc-daniele kernel: ACPI: EC: 0 stale EC events cleared
mar 10 00:10:22 pc-daniele kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.HEC.ECAV], AE_NOT_FOUND (20210930/psargs-330)
mar 10 00:10:22 pc-daniele kernel: ACPI Error: Aborting method \_TZ.FNCL due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:10:22 pc-daniele kernel: ACPI Error: Aborting method \_TZ.FN04._ON due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:10:22 pc-daniele kernel: acpi-fan PNP0C0B:04: Error updating fan power state
mar 10 00:10:22 pc-daniele kernel: PM: dpm_run_callback(): platform_pm_resume+0x0/0x40 returns -19
mar 10 00:10:22 pc-daniele kernel: acpi-fan PNP0C0B:04: PM: failed to resume: error -19
mar 10 00:10:22 pc-daniele kernel: OOM killer enabled.
mar 10 00:10:22 pc-daniele kernel: Restarting tasks ...
mar 10 00:10:22 pc-daniele kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
mar 10 00:10:22 pc-daniele kernel: done.
mar 10 00:10:22 pc-daniele kernel: acpi PNP0C0B:04: Cannot transition from (unknown) to D3hot
mar 10 00:10:22 pc-daniele kernel: audit: type=1131 audit(1646867422.095:262): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/system>
mar 10 00:10:22 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? >
mar 10 00:10:22 pc-daniele systemd-logind[497]: Lid opened.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: The canary thread is apparently starving. Taking action.
mar 10 00:10:22 pc-daniele systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Demoting known real-time threads.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 51789 of process 51638.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 2669 of process 2668.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 2670 of process 2667.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 2667 of process 2667.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1925 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1924 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1923 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1922 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1921 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1920 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1806 of process 1806.
mar 10 00:10:22 pc-daniele rtkit-daemon[1074]: Demoted 11 threads.
mar 10 00:10:22 pc-daniele systemd-sleep[52454]: System returned from sleep state.
mar 10 00:10:22 pc-daniele bluetoothd[887]: Controller resume with wake event 0x0
mar 10 00:10:22 pc-daniele kernel: PM: suspend exit
mar 10 00:10:22 pc-daniele systemd[1]: systemd-suspend.service: Deactivated successfully.
mar 10 00:10:22 pc-daniele systemd[1]: Finished System Suspend.
mar 10 00:10:22 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
mar 10 00:10:22 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
mar 10 00:10:22 pc-daniele systemd[1]: systemd-suspend.service: Consumed 10.740s CPU time.
mar 10 00:10:22 pc-daniele systemd[1]: Stopped target Sleep.
mar 10 00:10:22 pc-daniele systemd[1]: Reached target Suspend.
mar 10 00:10:22 pc-daniele systemd[1]: Stopped target Suspend.
mar 10 00:10:22 pc-daniele kernel: audit: type=1130 audit(1646867422.578:263): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd">
mar 10 00:10:22 pc-daniele kernel: audit: type=1131 audit(1646867422.578:264): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd">
mar 10 00:10:22 pc-daniele systemd-logind[497]: Operation 'sleep' finished.
mar 10 00:10:22 pc-daniele ModemManager[565]: <info>  [sleep-monitor] system is resuming
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.5835] manager: sleep: wake requested (sleeping: yes  enabled: yes)
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.5835] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.5843] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.5846] manager: NetworkManager state is now DISCONNECTED
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6113] device (wlo1): supplicant interface state: internal-starting -> disconnected
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6113] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6116] Wi-Fi P2P device controlled by interface wlo1 created
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6118] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/6)
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6119] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6122] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
mar 10 00:10:22 pc-daniele NetworkManager[493]: <info>  [1646867422.6127] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:22 pc-daniele gnome-shell[1724]: Removing a network device that was not added
mar 10 00:10:23 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.86' (uid=1000 pid=1724 comm="/usr/bin/gnome-shell ")
mar 10 00:10:23 pc-daniele audit: BPF prog-id=67 op=LOAD
mar 10 00:10:23 pc-daniele systemd[1]: Starting Fingerprint Authentication Daemon...
mar 10 00:10:23 pc-daniele kernel: audit: type=1334 audit(1646867423.228:265): prog-id=67 op=LOAD
mar 10 00:10:23 pc-daniele dbus-daemon[492]: [system] Successfully activated service 'net.reactivated.Fprint'
mar 10 00:10:23 pc-daniele systemd[1]: Started Fingerprint Authentication Daemon.
mar 10 00:10:23 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
mar 10 00:10:23 pc-daniele kernel: audit: type=1130 audit(1646867423.261:266): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostnam>
mar 10 00:10:23 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.366' (uid=0 pid=52838 comm="gdm-sess>
mar 10 00:10:23 pc-daniele dbus-daemon[492]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
mar 10 00:10:23 pc-daniele gdm-password][52838]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
mar 10 00:10:25 pc-daniele ModemManager[565]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=IT
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7272] policy: auto-activating connection 'DANIELITO<3' (014a3c23-a0de-452e-a4ff-ef4e6da58cab)
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7274] device (wlo1): Activation: starting connection 'DANIELITO<3' (014a3c23-a0de-452e-a4ff-ef4e6da58cab)
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7275] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7276] manager: NetworkManager state is now CONNECTING
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7277] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7278] device (wlo1): Activation: (wifi) access point 'DANIELITO<3' has security, but secrets are required.
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7278] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7279] sup-iface[d93650280a02e57a,2,wlo1]: wps: type pbc start...
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7283] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7284] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7285] device (wlo1): Activation: (wifi) connection 'DANIELITO<3' has security, and secrets exist.  No new secrets needed.
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7285] Config: added 'ssid' value 'DANIELITO<3'
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7285] Config: added 'scan_ssid' value '1'
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7285] Config: added 'bgscan' value 'simple:30:-70:86400'
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7285] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7285] Config: added 'psk' value '<hidden>'
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: WPS-CANCEL
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: SME: Trying to authenticate with a4:91:b1:e1:bd:05 (SSID='DANIELITO<3' freq=2412 MHz)
mar 10 00:10:25 pc-daniele kernel: wlo1: authenticate with a4:91:b1:e1:bd:05
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7436] device (wlo1): supplicant interface state: disconnected -> authenticating
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7436] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> authenticating
mar 10 00:10:25 pc-daniele kernel: wlo1: send auth to a4:91:b1:e1:bd:05 (try 1/3)
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: Trying to associate with a4:91:b1:e1:bd:05 (SSID='DANIELITO<3' freq=2412 MHz)
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7703] device (wlo1): supplicant interface state: authenticating -> associating
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.7704] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
mar 10 00:10:25 pc-daniele kernel: wlo1: authenticated
mar 10 00:10:25 pc-daniele kernel: wlo1: associate with a4:91:b1:e1:bd:05 (try 1/3)
mar 10 00:10:25 pc-daniele kernel: wlo1: RX AssocResp from a4:91:b1:e1:bd:05 (capab=0x1411 status=0 aid=2)
mar 10 00:10:25 pc-daniele kernel: wlo1: associated
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: Associated with a4:91:b1:e1:bd:05
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8053] device (wlo1): supplicant interface state: associating -> 4way_handshake
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8053] device (p2p-dev-wlo1): supplicant management interface state: associating -> 4way_handshake
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: WPA: Key negotiation completed with a4:91:b1:e1:bd:05 [PTK=CCMP GTK=CCMP]
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-CONNECTED - Connection to a4:91:b1:e1:bd:05 completed [id=0 id_str=]
mar 10 00:10:25 pc-daniele kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8760] device (wlo1): supplicant interface state: 4way_handshake -> completed
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8761] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "DANIELITO<3"
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8761] device (p2p-dev-wlo1): supplicant management interface state: 4way_handshake -> completed
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8762] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-50 noise=9999 txrate=1000
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8772] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8868] dhcp4 (wlo1): state changed unknown -> bound, address=192.168.1.115
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8886] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8895] policy: set 'DANIELITO<3' (wlo1) as default for IPv4 routing and DNS
mar 10 00:10:25 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=493 co>
mar 10 00:10:25 pc-daniele systemd[1]: Starting Network Manager Script Dispatcher Service...
mar 10 00:10:25 pc-daniele systemd[1674]: Starting gnome-user-share WebDAV server...
mar 10 00:10:25 pc-daniele dbus-daemon[492]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
mar 10 00:10:25 pc-daniele systemd[1]: Started Network Manager Script Dispatcher Service.
mar 10 00:10:25 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=?>
mar 10 00:10:25 pc-daniele systemd[1674]: Started gnome-user-share WebDAV server.
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8957] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8958] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
mar 10 00:10:25 pc-daniele kernel: audit: type=1130 audit(1646867425.891:267): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/system>
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.8961] manager: NetworkManager state is now CONNECTED_SITE
mar 10 00:10:25 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-54 noise=9999 txrate=52000
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.9002] device (wlo1): Activation: successful, device activated.
mar 10 00:10:25 pc-daniele gnome-user-share-webdav[52890]: AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to supp>
mar 10 00:10:25 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.369' (uid=1000 pid=52897 comm="/usr/>
mar 10 00:10:25 pc-daniele dbus-daemon[492]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
mar 10 00:10:25 pc-daniele NetworkManager[493]: <info>  [1646867425.9646] manager: NetworkManager state is now CONNECTED_GLOBAL
mar 10 00:10:26 pc-daniele gdm-password][52838]: gkr-pam: unlocked login keyring
mar 10 00:10:26 pc-daniele audit[52838]: USER_AUTH pid=52838 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="da>
mar 10 00:10:26 pc-daniele audit[52838]: USER_ACCT pid=52838 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="daniele" exe="/usr/lib/gdm-sessi>
mar 10 00:10:26 pc-daniele kernel: audit: type=1100 audit(1646867426.538:268): pid=52838 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_failloc>
mar 10 00:10:26 pc-daniele kernel: audit: type=1101 audit(1646867426.538:269): pid=52838 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="dani>
mar 10 00:10:26 pc-daniele audit[52838]: CRED_REFR pid=52838 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="daniele" >
mar 10 00:10:26 pc-daniele kernel: audit: type=1110 audit(1646867426.541:270): pid=52838 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_g>
mar 10 00:10:26 pc-daniele dbus-daemon[1694]: [session uid=1000 pid=1694] Activating service name='org.freedesktop.FileManager1' requested by ':1.15' (uid=1000 pid=1724 comm="/usr/bin/gnome-shell ")
mar 10 00:10:26 pc-daniele dbus-daemon[52907]: writing oom_score_adj error: Permission denied
mar 10 00:10:26 pc-daniele gnome-shell[1724]: loading user theme: /usr/share/themes/Matcha-light-azul/gnome-shell/gnome-shell.css
mar 10 00:10:26 pc-daniele gnome-shell[52928]: Installed
mar 10 00:10:26 pc-daniele NetworkManager[493]: <info>  [1646867426.9207] agent-manager: agent[15207c33021ad40c,:1.86/org.gnome.Shell.NetworkAgent/1000]: agent registered
mar 10 00:10:26 pc-daniele appindicatorsupport@rgcjonas.gmail.com[1724]: unable to update icon for dropbox-client-2071
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Loaded old settings: { minVal: 50, maxVal: 100, isTurboBoostActive: true, isAutoSwitchActive: false }
mar 10 00:10:27 pc-daniele pkexec[52963]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
mar 10 00:10:27 pc-daniele audit[52963]: USER_START pid=52963 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bi>
mar 10 00:10:27 pc-daniele kernel: audit: type=1105 audit(1646867427.035:271): pid=52963 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_perm>
mar 10 00:10:27 pc-daniele pkexec[52963]: daniele: Executing command [USER=root] [TTY=unknown] [CWD=/home/daniele/.local/share/gnome-shell/extensions/cpupower@mko-sl.de] [COMMAND=/usr/local/bin/cpufreqctl-danie>
mar 10 00:10:27 pc-daniele pkexec[52966]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
mar 10 00:10:27 pc-daniele audit[52966]: USER_START pid=52966 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bi>
mar 10 00:10:27 pc-daniele pkexec[52966]: daniele: Executing command [USER=root] [TTY=unknown] [CWD=/home/daniele/.local/share/gnome-shell/extensions/cpupower@mko-sl.de] [COMMAND=/usr/local/bin/cpufreqctl-danie>
mar 10 00:10:27 pc-daniele pkexec[52969]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
mar 10 00:10:27 pc-daniele audit[52969]: USER_START pid=52969 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bi>
mar 10 00:10:27 pc-daniele pkexec[52969]: daniele: Executing command [USER=root] [TTY=unknown] [CWD=/home/daniele/.local/share/gnome-shell/extensions/cpupower@mko-sl.de] [COMMAND=/usr/local/bin/cpufreqctl-danie>
mar 10 00:10:27 pc-daniele pkexec[52972]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
mar 10 00:10:27 pc-daniele audit[52972]: USER_START pid=52972 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bi>
mar 10 00:10:27 pc-daniele pkexec[52972]: daniele: Executing command [USER=root] [TTY=unknown] [CWD=/home/daniele/.local/share/gnome-shell/extensions/cpupower@mko-sl.de] [COMMAND=/usr/local/bin/cpufreqctl-danie>
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Power state changed: charging
mar 10 00:10:27 pc-daniele pkexec[52987]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
mar 10 00:10:27 pc-daniele kernel: kauditd_printk_skb: 3 callbacks suppressed
mar 10 00:10:27 pc-daniele kernel: audit: type=1105 audit(1646867427.155:275): pid=52987 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_perm>
mar 10 00:10:27 pc-daniele audit[52987]: USER_START pid=52987 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bi>
mar 10 00:10:27 pc-daniele pkexec[52987]: daniele: Executing command [USER=root] [TTY=unknown] [CWD=/home/daniele/.local/share/gnome-shell/extensions/cpupower@mko-sl.de] [COMMAND=/usr/local/bin/cpufreqctl-danie>
mar 10 00:10:27 pc-daniele pkexec[52990]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
mar 10 00:10:27 pc-daniele audit[52990]: USER_START pid=52990 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bi>
mar 10 00:10:27 pc-daniele pkexec[52990]: daniele: Executing command [USER=root] [TTY=unknown] [CWD=/home/daniele/.local/share/gnome-shell/extensions/cpupower@mko-sl.de] [COMMAND=/usr/local/bin/cpufreqctl-danie>
mar 10 00:10:27 pc-daniele kernel: audit: type=1105 audit(1646867427.165:276): pid=52990 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_perm>
mar 10 00:10:27 pc-daniele dbus-daemon[1694]: [session uid=1000 pid=1694] Activating service name='org.gnome.NautilusPreviewer' requested by ':1.477' (uid=1000 pid=52914 comm="gjs /usr/share/gnome-shell/extensi>
mar 10 00:10:27 pc-daniele dbus-daemon[53001]: writing oom_score_adj error: Permission denied
mar 10 00:10:27 pc-daniele dbus-daemon[1694]: [session uid=1000 pid=1694] Activating service name='org.gnome.ArchiveManager1' requested by ':1.477' (uid=1000 pid=52914 comm="gjs /usr/share/gnome-shell/extension>
mar 10 00:10:27 pc-daniele dbus-daemon[53003]: writing oom_score_adj error: Permission denied
mar 10 00:10:27 pc-daniele org.freedesktop.FileManager1[52907]: Initializing nautilus-dropbox 2020.03.04
mar 10 00:10:27 pc-daniele dbus-daemon[1694]: [session uid=1000 pid=1694] Successfully activated service 'org.freedesktop.FileManager1'
mar 10 00:10:27 pc-daniele dbus-daemon[1694]: [session uid=1000 pid=1694] Successfully activated service 'org.gnome.ArchiveManager1'
mar 10 00:10:27 pc-daniele dbus-daemon[1694]: [session uid=1000 pid=1694] Successfully activated service 'org.gnome.NautilusPreviewer'
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 30 with keysym 30 (keycode 13).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 64 with keysym 64 (keycode 28).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
mar 10 00:10:27 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
mar 10 00:10:27 pc-daniele NetworkManager[493]: <info>  [1646867427.6417] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
mar 10 00:10:27 pc-daniele NetworkManager[493]: <info>  [1646867427.6421] policy: set 'DANIELITO<3' (wlo1) as default for IPv6 routing and DNS
mar 10 00:10:27 pc-daniele NetworkManager[493]: <info>  [1646867427.7055] dhcp6 (wlo1): state changed unknown -> bound
mar 10 00:10:29 pc-daniele systemd[1674]: Started Application launched by gnome-shell.
mar 10 00:10:30 pc-daniele org.qgis.qgis.desktop[53069]: Info: Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
mar 10 00:10:30 pc-daniele gnome-shell[1724]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x1000008 specified for 0x1000006.
mar 10 00:10:30 pc-daniele gnome-shell[1724]: Source ID 126058 was not found when attempting to remove it
mar 10 00:10:37 pc-daniele nautilus[52907]: Could not delete '.meta.isrunning': File o directory non esistente
mar 10 00:10:37 pc-daniele systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mar 10 00:10:37 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? >
mar 10 00:10:37 pc-daniele kernel: audit: type=1131 audit(1646867437.732:277): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/system>
mar 10 00:10:39 pc-daniele org.qgis.qgis.desktop[53069]: Warning 4: Failed to open /usr/share/qgis/resources/data/world_map.gpkg: Permesso negato.
mar 10 00:10:40 pc-daniele gnome-shell[1724]: Could not load a pixbuf from icon theme.
                                              This may indicate that pixbuf loaders or the mime database could not be found.
mar 10 00:10:49 pc-daniele systemd-logind[497]: Lid closed.
mar 10 00:10:49 pc-daniele systemd-logind[497]: Suspending...
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.3351] manager: sleep: sleep requested (sleeping: no  enabled: yes)
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.3352] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:10:49 pc-daniele ModemManager[565]: <info>  [sleep-monitor] system is about to suspend
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.3355] manager: NetworkManager state is now ASLEEP
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.3355] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:10:49 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=493 co>
mar 10 00:10:49 pc-daniele systemd[1]: Starting Network Manager Script Dispatcher Service...
mar 10 00:10:49 pc-daniele dbus-daemon[492]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
mar 10 00:10:49 pc-daniele systemd[1]: Started Network Manager Script Dispatcher Service.
mar 10 00:10:49 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=?>
mar 10 00:10:49 pc-daniele kernel: audit: type=1130 audit(1646867449.342:278): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/system>
mar 10 00:10:49 pc-daniele kernel: wlo1: deauthenticating from a4:91:b1:e1:bd:05 by local choice (Reason: 3=DEAUTH_LEAVING)
mar 10 00:10:49 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-DISCONNECTED bssid=a4:91:b1:e1:bd:05 reason=3 locally_generated=1
mar 10 00:10:49 pc-daniele wpa_supplicant[670]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4565] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4761] dhcp4 (wlo1): canceled DHCP transaction
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4761] dhcp4 (wlo1): state changed bound -> terminated
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4763] dhcp6 (wlo1): canceled DHCP transaction
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4763] dhcp6 (wlo1): state changed bound -> terminated
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4785] device (wlo1): set-hw-addr: set MAC address to BA:B4:C0:AC:AA:05 (scanning)
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4807] device (wlo1): supplicant interface state: completed -> disconnected
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4807] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
mar 10 00:10:49 pc-daniele NetworkManager[493]: <info>  [1646867449.4826] device (wlo1): set-hw-addr: reset MAC address to 28:11:A8:46:47:F9 (unmanage)
mar 10 00:10:49 pc-daniele systemd[1674]: Stopping gnome-user-share WebDAV server...
mar 10 00:10:49 pc-daniele wpa_supplicant[670]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
mar 10 00:10:49 pc-daniele wpa_supplicant[670]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
mar 10 00:10:49 pc-daniele wpa_supplicant[670]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
mar 10 00:10:49 pc-daniele dropbox[2071]: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
mar 10 00:10:49 pc-daniele gnome-shell[1724]: An active wireless connection, in infrastructure mode, involves no access point?
mar 10 00:10:49 pc-daniele gnome-shell[1724]: DING: GNOME nautilus 41.2
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Timelines with detached actors are not supported
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 61 with keysym 61 (keycode 26).
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 64 with keysym 64 (keycode 28).
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
mar 10 00:10:49 pc-daniele gnome-shell[1724]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
mar 10 00:10:50 pc-daniele systemd[1674]: Stopped gnome-user-share WebDAV server.
mar 10 00:10:50 pc-daniele systemd[1]: Reached target Sleep.
mar 10 00:10:50 pc-daniele systemd[1]: Starting System Suspend...
mar 10 00:10:50 pc-daniele systemd-sleep[53551]: Entering sleep state 'suspend'...
mar 10 00:10:50 pc-daniele kernel: PM: suspend entry (s2idle)
mar 10 00:10:50 pc-daniele kernel: Filesystems sync: 0.016 seconds
mar 10 00:38:37 pc-daniele kernel: Bluetooth: hci0: Timed out waiting for suspend events
mar 10 00:38:37 pc-daniele kernel: Bluetooth: hci0: Suspend timeout bit: 9
mar 10 00:38:37 pc-daniele kernel: Bluetooth: hci0: Suspend notifier action (3) failed: -110
mar 10 00:38:37 pc-daniele kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
mar 10 00:38:37 pc-daniele kernel: OOM killer disabled.
mar 10 00:38:37 pc-daniele kernel: Freezing remaining freezable tasks ... (elapsed 0.000 seconds) done.
mar 10 00:38:37 pc-daniele kernel: printk: Suspending console(s) (use no_console_suspend to debug)
mar 10 00:38:37 pc-daniele kernel: ACPI: EC: interrupt blocked
mar 10 00:38:37 pc-daniele kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^PC00.LPCB.HEC.ECNT], AE_NOT_FOUND (20210930/psargs-330)
mar 10 00:38:37 pc-daniele kernel: ACPI Error: Aborting method \_SB.PEPD._DSM due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:38:37 pc-daniele kernel: ACPI: EC: interrupt unblocked
mar 10 00:38:37 pc-daniele kernel: nvme nvme0: 8/0/0 default/read/poll queues
mar 10 00:38:37 pc-daniele kernel: ACPI: EC: 0 stale EC events cleared
mar 10 00:38:37 pc-daniele kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.HEC.ECAV], AE_NOT_FOUND (20210930/psargs-330)
mar 10 00:38:37 pc-daniele kernel: ACPI Error: Aborting method \_TZ.FNCL due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:38:37 pc-daniele kernel: ACPI Error: Aborting method \_TZ.FN04._ON due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:38:37 pc-daniele kernel: acpi-fan PNP0C0B:04: Error updating fan power state
mar 10 00:38:37 pc-daniele kernel: PM: dpm_run_callback(): platform_pm_resume+0x0/0x40 returns -19
mar 10 00:38:37 pc-daniele kernel: acpi-fan PNP0C0B:04: PM: failed to resume: error -19
mar 10 00:38:37 pc-daniele kernel: i2c_hid_acpi i2c-SPPT2600:00: i2c_hid_get_input: incomplete report (31/261)
mar 10 00:38:37 pc-daniele kernel: OOM killer enabled.
mar 10 00:38:37 pc-daniele kernel: Restarting tasks ...
mar 10 00:38:37 pc-daniele kernel: Core dump to |/usr/lib/systemd/systemd-coredump pipe failed
mar 10 00:38:37 pc-daniele kernel: audit: type=1701 audit(1646869117.577:279): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=292 comm="systemd-journal" exe="/usr/lib/systemd/systemd-journald" >
mar 10 00:38:37 pc-daniele kernel: done.
mar 10 00:38:37 pc-daniele kernel: ACPI Error: Aborting method \_TZ.FN03._ON due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
mar 10 00:38:37 pc-daniele kernel: acpi PNP0C0B:03: Failed to change power state to D0
mar 10 00:38:37 pc-daniele kernel: acpi PNP0C0B:04: Failed to change power state to D0
mar 10 00:38:37 pc-daniele kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
mar 10 00:38:37 pc-daniele systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mar 10 00:38:37 pc-daniele kernel: audit: type=1131 audit(1646869117.591:280): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/system>
mar 10 00:38:37 pc-daniele systemd[1]: systemd-journald.service: Main process exited, code=killed, status=6/ABRT
mar 10 00:38:37 pc-daniele systemd[1]: systemd-journald.service: Failed with result 'watchdog'.
mar 10 00:38:37 pc-daniele systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
mar 10 00:38:37 pc-daniele systemd[1]: Stopped Journal Service.
mar 10 00:38:37 pc-daniele systemd[1]: Starting Journal Service...
mar 10 00:38:37 pc-daniele kernel: audit: type=1131 audit(1646869117.601:281): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd>
mar 10 00:38:37 pc-daniele kernel: audit: type=1130 audit(1646869117.601:282): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd>
mar 10 00:38:37 pc-daniele kernel: audit: type=1131 audit(1646869117.601:283): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd>
mar 10 00:38:37 pc-daniele kernel: audit: type=1334 audit(1646869117.601:284): prog-id=68 op=LOAD
mar 10 00:38:37 pc-daniele kernel: audit: type=1334 audit(1646869117.601:285): prog-id=69 op=LOAD
mar 10 00:38:37 pc-daniele kernel: audit: type=1334 audit(1646869117.601:286): prog-id=70 op=LOAD
mar 10 00:38:37 pc-daniele systemd[1]: fprintd.service: Deactivated successfully.
mar 10 00:38:37 pc-daniele kernel: audit: type=1131 audit(1646869117.604:287): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostnam>
mar 10 00:38:37 pc-daniele kernel: audit: type=1305 audit(1646869117.614:288): op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 subj==unconfined res=1
mar 10 00:38:37 pc-daniele systemd-journald[53683]: File /var/log/journal/4f593fbe38ea4c7d88ce9514859f8e75/system.journal corrupted or uncleanly shut down, renaming and replacing.
mar 10 00:38:37 pc-daniele systemd-journald[53683]: Journal started
mar 10 00:38:37 pc-daniele systemd-journald[53683]: System Journal (/var/log/journal/4f593fbe38ea4c7d88ce9514859f8e75) is 1.1G, max 4.0G, 2.8G free.
mar 10 00:38:37 pc-daniele audit[292]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=292 comm="systemd-journal" exe="/usr/lib/systemd/systemd-journald" sig=6 res=1
mar 10 00:38:37 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? >
mar 10 00:38:37 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
mar 10 00:38:37 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal>
mar 10 00:38:37 pc-daniele audit: BPF prog-id=68 op=LOAD
mar 10 00:38:37 pc-daniele audit: BPF prog-id=69 op=LOAD
mar 10 00:38:37 pc-daniele audit: BPF prog-id=70 op=LOAD
mar 10 00:38:37 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
mar 10 00:38:37 pc-daniele audit: CONFIG_CHANGE op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 subj==unconfined res=1
mar 10 00:38:37 pc-daniele audit[53683]: SYSCALL arch=c000003e syscall=46 success=yes exit=60 a0=3 a1=7fff2a7e8e10 a2=4000 a3=7fff2a7e8e9c items=0 ppid=1 pid=53683 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsui>
mar 10 00:38:37 pc-daniele audit: PROCTITLE proctitle="/usr/lib/systemd/systemd-journald"
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: The canary thread is apparently starving. Taking action.
mar 10 00:38:37 pc-daniele org.qgis.qgis.desktop[53069]: Warning: QIODevice::read (QNetworkReplyHttpImpl): device not open
mar 10 00:38:37 pc-daniele systemd[1]: Started Journal Service.
mar 10 00:38:37 pc-daniele systemd-journald[53683]: File /var/log/journal/4f593fbe38ea4c7d88ce9514859f8e75/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
mar 10 00:38:37 pc-daniele systemd-logind[497]: Lid opened.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Demoting known real-time threads.
mar 10 00:38:37 pc-daniele systemd[1]: systemd-journald.service: Watchdog timeout (limit 3min)!
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 51789 of process 51638.
mar 10 00:38:37 pc-daniele systemd[1]: systemd-journald.service: Killing process 292 (systemd-journal) with signal SIGABRT.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 2669 of process 2668.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 2670 of process 2667.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 2667 of process 2667.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1925 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1924 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1923 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1922 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1921 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1920 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Successfully demoted thread 1806 of process 1806.
mar 10 00:38:37 pc-daniele rtkit-daemon[1074]: Demoted 11 threads.
mar 10 00:38:37 pc-daniele nmbd[661]: [2022/03/10 00:38:37.580974,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
mar 10 00:38:37 pc-daniele nmbd[661]:   Packet send failed to 192.168.1.255(138) ERRNO=La rete non è raggiungibile
mar 10 00:38:37 pc-daniele nmbd[661]: [2022/03/10 00:38:37.581069,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
mar 10 00:38:37 pc-daniele audit: BPF prog-id=0 op=UNLOAD
mar 10 00:38:37 pc-daniele nmbd[661]: [2022/03/10 00:38:37.581293,  0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
mar 10 00:38:37 pc-daniele nmbd[661]:   reload_interfaces: No subnets to listen to. Waiting..
mar 10 00:38:37 pc-daniele systemd-sleep[53551]: System returned from sleep state.
mar 10 00:38:37 pc-daniele bluetoothd[887]: Controller resume with wake event 0x0
mar 10 00:38:37 pc-daniele kernel: PM: suspend exit
mar 10 00:38:37 pc-daniele systemd[1]: systemd-suspend.service: Deactivated successfully.
mar 10 00:38:37 pc-daniele systemd[1]: Finished System Suspend.
mar 10 00:38:37 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
mar 10 00:38:37 pc-daniele audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
mar 10 00:38:37 pc-daniele systemd[1]: systemd-suspend.service: Consumed 21min 51.797s CPU time.
mar 10 00:38:37 pc-daniele systemd[1]: Stopped target Sleep.
mar 10 00:38:37 pc-daniele systemd[1]: Reached target Suspend.
mar 10 00:38:37 pc-daniele systemd[1]: Stopped target Suspend.
mar 10 00:38:37 pc-daniele systemd-logind[497]: Operation 'sleep' finished.
mar 10 00:38:37 pc-daniele ModemManager[565]: <info>  [sleep-monitor] system is resuming
mar 10 00:38:37 pc-daniele NetworkManager[493]: <info>  [1646869117.8873] manager: sleep: wake requested (sleeping: yes  enabled: yes)
mar 10 00:38:37 pc-daniele NetworkManager[493]: <info>  [1646869117.8873] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 10 00:38:37 pc-daniele NetworkManager[493]: <info>  [1646869117.9038] device (wlo1): set-hw-addr: set MAC address to EE:09:5F:9B:0A:2C (scanning)
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.0968] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.0972] manager: NetworkManager state is now DISCONNECTED
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1239] device (wlo1): supplicant interface state: internal-starting -> disconnected
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1239] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1242] Wi-Fi P2P device controlled by interface wlo1 created
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1243] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/7)
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1244] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1247] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
mar 10 00:38:38 pc-daniele NetworkManager[493]: <info>  [1646869118.1251] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
mar 10 00:38:38 pc-daniele gnome-shell[1724]: Removing a network device that was not added
mar 10 00:38:38 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.86' (uid=1000 pid=1724 comm="/usr/bin/gnome-shell ")
mar 10 00:38:38 pc-daniele audit: BPF prog-id=71 op=LOAD
mar 10 00:38:38 pc-daniele systemd[1]: Starting Fingerprint Authentication Daemon...
mar 10 00:38:38 pc-daniele dbus-daemon[492]: [system] Successfully activated service 'net.reactivated.Fprint'
mar 10 00:38:38 pc-daniele systemd[1]: Started Fingerprint Authentication Daemon.
mar 10 00:38:38 pc-daniele audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
mar 10 00:38:38 pc-daniele dbus-daemon[492]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.388' (uid=0 pid=53871 comm="gdm-sess>
mar 10 00:38:38 pc-daniele dbus-daemon[492]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
mar 10 00:38:38 pc-daniele gdm-password][53871]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
mar 10 00:38:40 pc-daniele ModemManager[565]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
I see something crashed - don’t know what it is.
Bluetooth perhaps?
And ACPI errors - which may or may not be relevant.
I can only speculate - and would myself tinker a little, if it where my machine.
But I cannot be helpful here.
Firmware/Bios update may help, if available.
It may be related to the bios because before the last update of it I’m pretty sure I had no problem with the sleep mode. But I’ve already checked and there are no updates. Thanks for the help!
Not sure if this will help you but on my lenovo, a bios update set sleep to something called “windows plus linux” (or something like that). Once I set it back to “linux S3” the system sleeps with very small (normal) battery drain.
Do you see the same behaviour with another kernel?
Yes, I tried 3 different kernels, same results
I think here is the point, the last bios update did something to the settings. The problem is that in samsung laptop the bios doesn’t have advanced settings. It has only boot order settings, something related to TMP and secure boot settings. I read somewhere that there are also hidden settings, but to reach them you have to press the correct shortcut key during startup.
Anyway, thanks guys. I hope that next updates fix this issue…
Known bug from upstream kernel development. It’s been fixed in 5.17-rc7. This “change” in s2idle (suspend to RAM) was backported to 5.15 and 5.16. Hence, even 5.15 and 5.16 kernels are hit with this nasty bug.
Luckily for Arch Linux users, they will get the fix sooner than Manjaro users, due to their rapid-release package updates.
For us on Manjaro, we’ll have to wait until the fix is backported to 5.15 and 5.16, or when 5.17 reaches a “stable” release in the next Manjaro Stable Update.
EDIT: I’ll keep being a thorn on these message boards until I get banned, to be honest. You’ll notice I had a hiatus for over four months. (Intentionally.)
It takes frustration and annoyance to really bring attention to severe issues on desktop Linux. If it comes off as “negative” and against community rules, so be it. I mostly helped other users on here, so losing my account is not a loss against me.
And frankly, such a major change being backported to an “LTS” kernel is inappropriate. The whole point of using LTS kernels is to avoid such drastic changes and bugs, which might arise in newer kernels. This bug is so bad that is drains and stresses laptop batteries, as well as causes heat damage, if not caught early. (Risk to internal components and CPU.) Never should have happened in mainline kernel development / backporting to LTS 5.15.
Isn’t the bug on AMD systems and isn’t the OP’s machine intel???
Yes, it is Intel
