Battery consumption problem
Hello friends
I asked a question a few days ago but no one answered!
About freezing and regenerating manjaro
But now I have another problem!
High battery consumption!?! But I do not know if the battery is weak and does not have the performance of the first day or there is another problem and the battery is healthy !!?
As I write this, my laptop battery was about 18% charged, but suddenly it was 3%
Please help me to understand where the problem is so that the situation does not get worse
thank you.
Information laptop :
ASUS
CPU : Intel® Core™ i7-6700HQ CPU @ 2.60GHz
Memory : 8.0 GB
Disk : TOSHIBA MQ02ABD100H
Wi-Fi : Intel® Dual Band Wireless-AC 7265
GPU 0 : Intel® HD Graphics 530
GPU 1 : NVIDIA GeForce GTX 960M
Screen : 4k
or
Generated on 2020-09-02 10:33:1599026582
#################### inxi -Fxzc0 ########################
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.36.5
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: N552VW v: 1.0 serial:
Mobo: ASUSTeK model: N552VW v: 1.0 serial: UEFI: American Megatrends
v: N552VW.300 date: 08/31/2016
ID-1: BAT0 charge: 6.3 Wh condition: 33.0/48.2 Wh (68%) model: ASUSTeK ASUS Battery
status: Discharging
Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
rev: 3 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41621
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
5: 800 6: 801 7: 800 8: 801
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nouveau v: kernel
bus ID: 01:00.0
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-4:3
Display: x11 server: X org 1.20.8 driver: intel,nouveau unloaded: modesetting
resolution:
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.7.17-2-MANJARO
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
IF: wlp2s0 state: up mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: d000 bus ID: 03:00.1
IF: enp3s0f1 state: down mac:
Local Storage: total: 931.51 GiB used: 19.40 GiB (2.1%)
ID-1: /dev/sda vendor: Toshiba model: MQ02ABD100H size: 931.51 GiB
ID-1: / size: 414.87 GiB used: 12.02 GiB (2.9%) fs: ext4 dev: /dev/sda4
ID-2: /home size: 491.15 GiB used: 7.37 GiB (1.5%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) dev: /dev/sda3
Sensors: System Temperatures: cpu: 42.5 C mobo: N/A gpu: nouveau temp: 35 C
Fan Speeds (RPM): cpu: 2000
Processes: 296 Uptime: 18m Memory: 7.67 GiB used: 1.93 GiB (25.1%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1234 Client: shell wrapper v: 5.0.18-release
inxi: 3.1.05
Hi!
I use slimbookbattery to know the health and other parameters of the battery, also let you configure various modes of power management depending of ac/bat, your performance needs and other stuff.
I don’t recommend you let the battery discharging so much, you should plug in the ac power when it reach 20%/30% and unplug in when it reach 90%, your battery live would be appreciated.
Thank you for your feedback
So do you recommend me to use slimbookbattery or TLP?
I turn on the power whenever it reaches 20% or 15%, but today, when it was still 18% charged, it suddenly lost a lot of charge and became 3%.
Your inxi printout shows a battery health of 68%, that is quite low, so you could consider replacing your battery.
So I have to think about buying a new battery
I have another question
Why is manjaro frozen?
It has happened to me many times!
what’s the solution ?
Can a graphics card be a maker?
Hi!
Slimbookbattery use TLP so you can use whatever you want. I had some problems with tlp in the past, maybe because I didn’t configure it right, so I changed to SBB.
Thank you for your help, dear friend
I also had problems with TLP on my AMD thinkpad. Switched to laptop-mode-tools, no problems since.
One subject per topic, please.
It will definitely be done
I tried to ask everyone in one place so that no other topics would be created
But I will not do it again
Thank you for your remark, dear friend
