Good morning everyone
For the last two boots, this baloo_file_extractor has been hitting my CPU rather hard for quite some time. htop shows between 90 - 98% CPU usage on baloo_file_extractor. The fans ramp up and stay up there for maybe 5 - 10 minutes, but eventually this behavior only lasts for few minutes. I was just installing Manjaro KDE from Manjaro GNOME using Architect iso.
I noticed this first after uninstalling amd-ucode and rebooting (I have Intel CPU).
I have not experienced this behavior on Manjaro before on any DE, so I am wondering what I can do about this.
Journalctl -S today
CRTC: 63
Pos: QPoint(0,0)
Mode: 70 KScreen::Mode(Id: "70" , Size: QSize(1920, 1080) @ 60.0297 )
Rotation: 1
okt 29 08:04:41 HP kscreen_backend_launcher[7264]: kscreen.xrandr: Result: 0
okt 29 08:04:41 HP kscreen_backend_launcher[7264]: kscreen.xrandr: XRandROutput 66 update
m_connected: 0
m_crtc XRandRCrtc(0x5613ead95eb0)
CRTC: 63
MODE: 70
Connection: 0
Primary: true
okt 29 08:04:41 HP kscreen_backend_launcher[7264]: kscreen.xrandr: XRandR::setConfig done!
okt 29 08:04:41 HP dbus-daemon[870]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.62' (uid=1000 pid=7156 comm="/usr/bin/pulseaudio --daemonize=no --log-target>
okt 29 08:04:41 HP systemd[1]: Starting RealtimeKit Scheduling Policy Service...
okt 29 08:04:41 HP dbus-daemon[870]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
okt 29 08:04:41 HP rtkit-daemon[7343]: Successfully called chroot.
okt 29 08:04:41 HP rtkit-daemon[7343]: Successfully dropped privileges.
okt 29 08:04:41 HP systemd[1]: Started RealtimeKit Scheduling Policy Service.
okt 29 08:04:41 HP rtkit-daemon[7343]: Successfully limited resources.
okt 29 08:04:41 HP rtkit-daemon[7343]: Running.
okt 29 08:04:41 HP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:41 HP rtkit-daemon[7343]: Watchdog thread running.
okt 29 08:04:41 HP rtkit-daemon[7343]: Canary thread running.
okt 29 08:04:41 HP rtkit-daemon[7343]: Successfully made thread 7156 of process 7156 owned by '1000' high priority at nice level -11.
okt 29 08:04:41 HP rtkit-daemon[7343]: Supervising 1 threads of 1 processes of 1 users.
okt 29 08:04:41 HP org_kde_powerdevil[7165]: org.kde.powerdevil: Handle button events action could not check for screen configuration
okt 29 08:04:41 HP org_kde_powerdevil[7165]: Warning from helper: Failed to open "/sys/class/power_supply/BAT1/charge_start_threshold" for reading
okt 29 08:04:41 HP org_kde_powerdevil[7165]: Warning from helper: Failed to open "/sys/class/power_supply/BAT1/charge_stop_threshold" for reading
okt 29 08:04:41 HP org_kde_powerdevil[7165]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
okt 29 08:04:41 HP plasmashell[7120]: kf.plasma.quick: Applet preload policy set to 1
okt 29 08:04:41 HP rtkit-daemon[7343]: Successfully made thread 7560 of process 7156 owned by '1000' RT at priority 5.
okt 29 08:04:41 HP rtkit-daemon[7343]: Supervising 2 threads of 1 processes of 1 users.
okt 29 08:04:41 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:04:41 HP rtkit-daemon[7343]: Successfully made thread 7566 of process 7156 owned by '1000' RT at priority 5.
okt 29 08:04:41 HP rtkit-daemon[7343]: Supervising 3 threads of 1 processes of 1 users.
okt 29 08:04:41 HP systemd[6693]: Started Sound Service.
okt 29 08:04:41 HP bluetoothd[868]: Endpoint registered: sender=:1.201 path=/MediaEndpoint/A2DPSink/sbc
okt 29 08:04:41 HP bluetoothd[868]: Endpoint registered: sender=:1.201 path=/MediaEndpoint/A2DPSource/sbc
okt 29 08:04:41 HP plasmashell[7120]: kf.package: No metadata file in the package, expected it at: "/home/olividir/.local/share/wallpapers/"
okt 29 08:04:41 HP kded5[6953]: bluedevil: ObexManager operational changed true
okt 29 08:04:41 HP kded5[6953]: bluedevil: ObexAgent registered
okt 29 08:04:41 HP plasmashell[7120]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/U>
okt 29 08:04:41 HP plasmashell[7120]: trying to show an empty dialog
okt 29 08:04:41 HP plasmashell[7120]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
okt 29 08:04:41 HP plasmashell[7120]: kf.package: No metadata file in the package, expected it at: "/usr/share/backgrounds/"
okt 29 08:04:41 HP plasmashell[7120]: kf.package: No metadata file in the package, expected it at: "/usr/share/backgrounds/manjaro-wallpapers-18.0/"
okt 29 08:04:41 HP plasmashell[7120]: kf.package: No metadata file in the package, expected it at: "/usr/share/backgrounds/wallpapers-2018/"
okt 29 08:04:41 HP plasmashell[7120]: kf.package: No metadata file in the package, expected it at: "/usr/share/backgrounds/wallpapers-juhraya/"
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Autumn" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Breath2" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/BytheWater" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Canopee" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cascade" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Cluster" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColdRipple" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/ColorfulCups" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/DarkestHour" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Elarun" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/EveningGlow" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FallenLeaf" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Flow" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/FlyingKonqui" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Grey" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/IceCold" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kite" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Kokkini" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/OneStandsOut" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Opal" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/PastelHills" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Path" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/SafeLanding" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/summer_1am" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Volna" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/manjaro-wallpapers-18.0" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-2018" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: kf.coreaddons: KDirWatch: "/usr/share/backgrounds/wallpapers-juhraya" is a directory. Use addDir!
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
okt 29 08:04:41 HP plasmashell[7120]: Plasma Shell startup completed
okt 29 08:04:41 HP kwin_x11[6976]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1726, resource id: 4194342, major code: 18 (ChangeProperty), minor code: 0
okt 29 08:04:42 HP udisksd[3232]: Mounted /dev/sda1 at /run/media/olividir/500 Gaming on behalf of uid 1000
okt 29 08:04:42 HP kernel: EXT4-fs (sda1): recovery complete
okt 29 08:04:42 HP kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
okt 29 08:04:42 HP plasmashell[7120]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
okt 29 08:04:42 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:04:42 HP plasmashell[7120]: Both point size and pixel size set. Using pixel size.
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:524:9: QML Label: Binding loop detected for property "height"
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:483:13: QML Label: Binding loop detected for property "height"
okt 29 08:04:42 HP plasmashell[7120]: trying to show an empty dialog
okt 29 08:04:42 HP plasmashell[7120]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:544:5: QML Label: Binding loop detected for property "height"
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.2950] policy: auto-activating connection 'Hringdu-5G-c5S5' (56c7e123-dcea-40c5-b7b1-4c81647f018f)
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.2959] device (wlo1): Activation: starting connection 'Hringdu-5G-c5S5' (56c7e123-dcea-40c5-b7b1-4c81647f018f)
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.2960] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.2962] manager: NetworkManager state is now CONNECTING
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.2968] device (wlo1): set-hw-addr: reset MAC address to 74:40:BB:9E:6F:F3 (preserve)
okt 29 08:04:42 HP kernel: rtw_8822be 0000:02:00.0: stop vif ce:49:8d:75:c4:16 on port 0
okt 29 08:04:42 HP plasmashell[7120]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notificati>
okt 29 08:04:42 HP dbus-daemon[6770]: [session uid=1000 pid=6770] Successfully activated service 'org.freedesktop.Notifications'
okt 29 08:04:42 HP kernel: rtw_8822be 0000:02:00.0: start vif 74:40:bb:9e:6f:f3 on port 0
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7772] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7774] device (wlo1): Activation: (wifi) access point 'Hringdu-5G-c5S5' has security, but secrets are required.
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7775] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:42 HP kded5[6953]: plasma-nm: Unhandled active connection state change: 1
okt 29 08:04:42 HP kded5[6953]: plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)
okt 29 08:04:42 HP kded5[6953]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/2"
okt 29 08:04:42 HP kded5[6953]: plasma-nm: Setting name: "802-11-wireless-security"
okt 29 08:04:42 HP kded5[6953]: plasma-nm: Hints: ()
okt 29 08:04:42 HP kded5[6953]: plasma-nm: Flags: 1
okt 29 08:04:42 HP kded5[6953]: plasma-nm: bool SecretAgent::processGetSecrets(SecretsRequest&) const Waiting for the wallet to open
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7911] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7913] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7915] device (wlo1): Activation: (wifi) connection 'Hringdu-5G-c5S5' has security, and secrets exist. No new secrets needed.
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7915] Config: added 'ssid' value 'Hringdu-5G-c5S5'
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7915] Config: added 'scan_ssid' value '1'
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7915] Config: added 'bgscan' value 'simple:30:-70:86400'
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7916] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7916] Config: added 'auth_alg' value 'OPEN'
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.7916] Config: added 'psk' value '<hidden>'
okt 29 08:04:42 HP NetworkManager[871]: <info> [1603958682.8173] device (wlo1): supplicant interface state: disconnected -> inactive
okt 29 08:04:42 HP kded5[6953]: Registering "org.kde.StatusNotifierHost-7120" as system tray
okt 29 08:04:42 HP udisksd[3232]: udisks_state_check_mounted_fs_entry: block device /dev/sda1 is busy, skipping cleanup
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:59:9: Unable to assign [undefined] to int
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
okt 29 08:04:42 HP plasmashell[7120]: KAStatsFavoritesModel::setFavorites is ignored
okt 29 08:04:42 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/FullRepresentation.qml:356: ReferenceError: headerSeparator is not defined
okt 29 08:04:43 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:171: TypeError: Cannot read property 'added' of undefined
okt 29 08:04:43 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/devicenotifier.qml:171: TypeError: Value is undefined and could not be converted to an object
okt 29 08:04:43 HP NetworkManager[871]: <info> [1603958683.3011] device (wlo1): supplicant interface state: inactive -> scanning
okt 29 08:04:44 HP plasmashell[7120]: file:///usr/lib/qt/qml/org/kde/plasma/components/ModelContextMenu.qml:38:1: QML ModelContextMenu: Accessible must be attached to an Item
okt 29 08:04:44 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:04:45 HP plasmashell[7120]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:59:9: Unable to assign [undefined] to int
okt 29 08:04:45 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:04:45 HP baloo_file[7114]: replace called with invalid arguments, docId: 1103806595125 url: "/home/olividir/"
okt 29 08:04:46 HP plasmashell[7120]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ComboBox.qml:138:13: Unable to assign [undefined] to QQmlComponent*
okt 29 08:04:46 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: SME: Trying to authenticate with cc:64:a6:27:e8:64 (SSID='Hringdu-5G-c5S5' freq=5180 MHz)
okt 29 08:04:47 HP kernel: wlo1: authenticate with cc:64:a6:27:e8:64
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.6333] device (wlo1): supplicant interface state: scanning -> authenticating
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: Trying to associate with cc:64:a6:27:e8:64 (SSID='Hringdu-5G-c5S5' freq=5180 MHz)
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.6350] device (wlo1): supplicant interface state: authenticating -> associating
okt 29 08:04:47 HP kernel: wlo1: send auth to cc:64:a6:27:e8:64 (try 1/3)
okt 29 08:04:47 HP kernel: wlo1: authenticated
okt 29 08:04:47 HP kernel: wlo1: associate with cc:64:a6:27:e8:64 (try 1/3)
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: Associated with cc:64:a6:27:e8:64
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=IS
okt 29 08:04:47 HP kernel: wlo1: RX AssocResp from cc:64:a6:27:e8:64 (capab=0x1411 status=0 aid=5)
okt 29 08:04:47 HP kernel: rtw_8822be 0000:02:00.0: sta cc:64:a6:27:e8:64 joined with macid 0
okt 29 08:04:47 HP kernel: wlo1: associated
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.6468] device (wlo1): supplicant interface state: associating -> associated
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.6724] device (wlo1): supplicant interface state: associated -> 4way_handshake
okt 29 08:04:47 HP kernel: wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by cc:64:a6:27:e8:64
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: WPA: Key negotiation completed with cc:64:a6:27:e8:64 [PTK=CCMP GTK=TKIP]
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: CTRL-EVENT-CONNECTED - Connection to cc:64:a6:27:e8:64 completed [id=0 id_str=]
okt 29 08:04:47 HP kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.7112] device (wlo1): supplicant interface state: 4way_handshake -> completed
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.7113] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Hringdu-5G-c5S5"
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.7114] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:47 HP NetworkManager[871]: <info> [1603958687.7116] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
okt 29 08:04:47 HP avahi-daemon[867]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::9d1f:1f77:da11:5aac.
okt 29 08:04:47 HP avahi-daemon[867]: New relevant interface wlo1.IPv6 for mDNS.
okt 29 08:04:47 HP avahi-daemon[867]: Registering new address record for fe80::9d1f:1f77:da11:5aac on wlo1.*.
okt 29 08:04:47 HP wpa_supplicant[1605]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-74 noise=9999 txrate=780000
okt 29 08:04:49 HP NetworkManager[871]: <info> [1603958689.0077] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
okt 29 08:04:50 HP systemd[1]: Stopping User Manager for UID 967...
okt 29 08:04:50 HP systemd[2903]: Stopped target Main User Target.
okt 29 08:04:50 HP systemd[2903]: Stopping D-Bus User Message Bus...
okt 29 08:04:50 HP systemd[2903]: dbus.service: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Stopped D-Bus User Message Bus.
okt 29 08:04:50 HP systemd[2903]: Stopped target Basic System.
okt 29 08:04:50 HP systemd[2903]: Stopped target Paths.
okt 29 08:04:50 HP systemd[2903]: Stopped target Sockets.
okt 29 08:04:50 HP systemd[2903]: Stopped target Timers.
okt 29 08:04:50 HP systemd[2903]: dbus.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed D-Bus User Message Bus Socket.
okt 29 08:04:50 HP systemd[2903]: dirmngr.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed GnuPG network certificate management daemon.
okt 29 08:04:50 HP systemd[2903]: gpg-agent-browser.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
okt 29 08:04:50 HP systemd[2903]: gpg-agent-extra.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
okt 29 08:04:50 HP systemd[2903]: gpg-agent-ssh.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed GnuPG cryptographic agent (ssh-agent emulation).
okt 29 08:04:50 HP systemd[2903]: gpg-agent.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed GnuPG cryptographic agent and passphrase cache.
okt 29 08:04:50 HP systemd[2903]: p11-kit-server.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed p11-kit server.
okt 29 08:04:50 HP systemd[2903]: pipewire.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed Multimedia System.
okt 29 08:04:50 HP systemd[2903]: pulseaudio.socket: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Closed Sound System.
okt 29 08:04:50 HP systemd[2903]: Reached target Shutdown.
okt 29 08:04:50 HP systemd[2903]: systemd-exit.service: Succeeded.
okt 29 08:04:50 HP systemd[2903]: Finished Exit the Session.
okt 29 08:04:50 HP systemd[2903]: Reached target Exit the Session.
okt 29 08:04:50 HP systemd[2909]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
okt 29 08:04:50 HP systemd[1]: user@967.service: Succeeded.
okt 29 08:04:50 HP systemd[1]: Stopped User Manager for UID 967.
okt 29 08:04:50 HP systemd[1]: Stopping User Runtime Directory /run/user/967...
okt 29 08:04:50 HP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:50 HP kernel: kauditd_printk_skb: 7 callbacks suppressed
okt 29 08:04:50 HP kernel: audit: type=1131 audit(1603958690.196:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:50 HP systemd[6693]: run-user-967.mount: Succeeded.
okt 29 08:04:50 HP systemd[1]: run-user-967.mount: Succeeded.
okt 29 08:04:50 HP systemd[1]: user-runtime-dir@967.service: Succeeded.
okt 29 08:04:50 HP systemd[1]: Stopped User Runtime Directory /run/user/967.
okt 29 08:04:50 HP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:50 HP kernel: audit: type=1131 audit(1603958690.202:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:50 HP systemd[1]: Removed slice User Slice of UID 967.
okt 29 08:04:50 HP dbus-daemon[870]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.4' (uid=0 pid=871 comm="/usr/bin/NetworkManager --no-daemon ")
okt 29 08:04:50 HP dbus-daemon[870]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
okt 29 08:04:50 HP dbus-daemon[870]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=871 comm="/usr/bin/NetworkManager --no->
okt 29 08:04:50 HP systemd[1]: Starting Network Manager Script Dispatcher Service...
okt 29 08:04:50 HP dbus-daemon[870]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
okt 29 08:04:50 HP systemd[1]: Started Network Manager Script Dispatcher Service.
okt 29 08:04:50 HP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:50 HP kernel: audit: type=1130 audit(1603958690.806:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9893] dhcp6 (wlo1): state changed unknown -> bound
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9899] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9916] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9918] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9921] manager: NetworkManager state is now CONNECTED_LOCAL
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9934] device (wlo1): Activation: successful, device activated.
okt 29 08:04:51 HP NetworkManager[871]: <info> [1603958691.9938] manager: startup complete
okt 29 08:04:51 HP dbus-daemon[870]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.4' (uid=0 pid=871 comm="/usr/bin/NetworkManager --no-daemon ")
okt 29 08:04:51 HP dbus-daemon[870]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
okt 29 08:04:51 HP systemd[1]: Finished Network Manager Wait Online.
okt 29 08:04:51 HP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:51 HP systemd[1]: Reached target Network is Online.
okt 29 08:04:51 HP systemd[1]: Starting CUPS Scheduler...
okt 29 08:04:51 HP kernel: audit: type=1130 audit(1603958691.992:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes>
okt 29 08:04:52 HP systemd[1]: Starting pkgfile database update...
okt 29 08:04:52 HP pkgfile[12412]: error: unable to write to /var/cache/pkgfile: No such file or directory
okt 29 08:04:52 HP systemd[1]: pkgfile-update.service: Main process exited, code=exited, status=1/FAILURE
okt 29 08:04:52 HP systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
okt 29 08:04:52 HP systemd[1]: Failed to start pkgfile database update.
okt 29 08:04:52 HP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
okt 29 08:04:52 HP kernel: audit: type=1130 audit(1603958692.002:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pkgfile-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
okt 29 08:04:52 HP dbus-daemon[870]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service' requested by ':1.209' (uid=0 pid=12409 comm="/usr/bin/cupsd -l ")
okt 29 08:04:52 HP systemd[1]: Starting Manage, Install and Generate Color Profiles...
okt 29 08:04:52 HP dbus-daemon[870]: [system] Successfully activated service 'org.freedesktop.ColorManager'
okt 29 08:04:52 HP systemd[1]: Started Manage, Install and Generate Color Profiles.
okt 29 08:04:52 HP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:52 HP kernel: audit: type=1130 audit(1603958692.019:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:52 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
okt 29 08:04:52 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:04:52 HP systemd[1]: Started CUPS Scheduler.
okt 29 08:04:52 HP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:52 HP systemd[1]: Reached target Printer.
okt 29 08:04:52 HP plasmashell[7120]: libkcups: CUPS-Get-Printers last error: 0 successful-ok
okt 29 08:04:52 HP plasmashell[7120]: libkcups: Get-Jobs last error: 0 successful-ok
okt 29 08:04:52 HP plasmashell[7120]: libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
okt 29 08:04:52 HP kernel: audit: type=1130 audit(1603958692.092:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:52 HP kernel: usblp1: removed
okt 29 08:04:52 HP kernel: usblp 1-2.2:1.1: usblp1: USB Bidirectional printer dev 6 if 1 alt 0 proto 2 vid 0x03F0 pid 0xD711
okt 29 08:04:52 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PopupDialog.qml:91:17: Unable to assign [undefined] to QString
okt 29 08:04:52 HP plasmashell[7120]: libkcups: 3 "ENVY-4520-series"
okt 29 08:04:52 HP plasmashell[7120]: libkcups: 0
okt 29 08:04:52 HP plasmashell[7120]: libkcups: "Scheduler started on demand."
okt 29 08:04:52 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/printmanager.qml:64:34: QML PopupDialog: Binding loop detected for property "scrollBarVisible"
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option dhcp_lease_time => '86400'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option domain_name_servers => '192.168.1.1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option expiry => '1604045092'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option ip_address => '192.168.1.2'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_broadcast_address => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_domain_name => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_domain_name_servers => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_domain_search => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_host_name => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_interface_mtu => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_ms_classless_static_routes => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_nis_domain => '1'
okt 29 08:04:52 HP avahi-daemon[867]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.1.2.
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_nis_servers => '1'
okt 29 08:04:52 HP avahi-daemon[867]: New relevant interface wlo1.IPv4 for mDNS.
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6886] dhcp4 (wlo1): option requested_ntp_servers => '1'
okt 29 08:04:52 HP avahi-daemon[867]: Registering new address record for 192.168.1.2 on wlo1.IPv4.
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_rfc3442_classless_static_routes => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_root_path => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_routers => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_static_routes => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_subnet_mask => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_time_offset => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option requested_wpad => '1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option routers => '192.168.1.1'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): option subnet_mask => '255.255.255.0'
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6887] dhcp4 (wlo1): state changed unknown -> bound
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6894] manager: NetworkManager state is now CONNECTED_SITE
okt 29 08:04:52 HP NetworkManager[871]: <info> [1603958692.6895] policy: set 'Hringdu-5G-c5S5' (wlo1) as default for IPv4 routing and DNS
okt 29 08:04:52 HP dbus-daemon[870]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.4' (uid=0 pid=871 comm="/usr/bin/NetworkManager --no-daemon ")
okt 29 08:04:52 HP dbus-daemon[870]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
okt 29 08:04:52 HP baloo_file_extractor[11358]: QIODevice::read (QProcess): device not open
okt 29 08:04:52 HP plasmashell[7120]: trying to show an empty dialog
okt 29 08:04:54 HP udev-configure-printer[995]: SERN fields match
okt 29 08:04:54 HP udev-configure-printer[995]: URI match: hp:/usb/ENVY_4520_series?serial=TH76J4B0JK0660
okt 29 08:04:54 HP udev-configure-printer[995]: URI match: usb://HP/ENVY%204520%20series?serial=TH76J4B0JK0660&interface=1
okt 29 08:04:54 HP udev-configure-printer[995]: URI of detected printer: hp:/usb/ENVY_4520_series?serial=TH76J4B0JK0660, normalized: envy 4520 series serial th76j4b0jk0660
okt 29 08:04:54 HP udev-configure-printer[995]: URI of print queue: hp:/usb/ENVY_4520_series?serial=TH76J4B0JK0660, normalized: envy 4520 series serial th76j4b0jk0660
okt 29 08:04:54 HP udev-configure-printer[995]: Queue ipp://localhost/printers/ENVY-4520-series has matching device URI
okt 29 08:04:54 HP udev-configure-printer[995]: URI of detected printer: usb://HP/ENVY%204520%20series?serial=TH76J4B0JK0660&interface=1, normalized: envy 4520 series serial th76j4b0jk0660 interface 1
okt 29 08:04:54 HP systemd[1]: configure-printer@usb-001-006.service: Succeeded.
okt 29 08:04:54 HP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=configure-printer@usb-001-006 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:54 HP kernel: audit: type=1131 audit(1603958694.102:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=configure-printer@usb-001-006 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc>
okt 29 08:04:54 HP NetworkManager[871]: <info> [1603958694.1661] manager: NetworkManager state is now CONNECTED_GLOBAL
okt 29 08:04:55 HP colord-sane[12454]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
okt 29 08:04:57 HP kwin_x11[6976]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6887, resource id: 35651730, major code: 15 (QueryTree), minor code: 0
okt 29 08:04:58 HP systemd[1]: systemd-hostnamed.service: Succeeded.
okt 29 08:04:58 HP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:58 HP kernel: audit: type=1131 audit(1603958698.186:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:04:58 HP audit: BPF prog-id=10 op=UNLOAD
okt 29 08:04:58 HP audit: BPF prog-id=9 op=UNLOAD
okt 29 08:04:58 HP kernel: audit: type=1334 audit(1603958698.246:86): prog-id=10 op=UNLOAD
okt 29 08:04:58 HP kernel: audit: type=1334 audit(1603958698.246:87): prog-id=9 op=UNLOAD
okt 29 08:04:59 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:05:00 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:05:00 HP systemd[1]: NetworkManager-dispatcher.service: Succeeded.
okt 29 08:05:00 HP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:05:00 HP kernel: audit: type=1131 audit(1603958700.902:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
okt 29 08:05:01 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
okt 29 08:05:01 HP systemd[6693]: Created slice app.slice.
okt 29 08:05:01 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
okt 29 08:05:01 HP systemd[6693]: Started Firefox - Web Browser.
okt 29 08:05:01 HP kwin_x11[6976]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7505, resource id: 35651779, major code: 18 (ChangeProperty), minor code: 0
okt 29 08:05:01 HP kwin_x11[6976]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7520, resource id: 35651780, major code: 18 (ChangeProperty), minor code: 0
okt 29 08:05:01 HP dbus-daemon[6770]: [session uid=1000 pid=6770] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.44' (uid=1000 pid=16373 comm="/usr/lib/firefox/firefox ")
okt 29 08:05:01 HP systemd[6693]: Starting Accessibility services bus...
okt 29 08:05:01 HP dbus-daemon[6770]: [session uid=1000 pid=6770] Successfully activated service 'org.a11y.Bus'
okt 29 08:05:01 HP systemd[6693]: Started Accessibility services bus.
okt 29 08:05:01 HP at-spi-bus-launcher[16597]: dbus-daemon[16597]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=7147 comm="/usr/bin/gmenudbusmenuproxy ")
okt 29 08:05:01 HP at-spi-bus-launcher[16597]: dbus-daemon[16597]: Successfully activated service 'org.a11y.atspi.Registry'
okt 29 08:05:01 HP at-spi-bus-launcher[16600]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
okt 29 08:05:01 HP baloo_file_extractor[11358]: "Error (2419571): Unexpected end of file in flate stream"
okt 29 08:05:01 HP baloo_file_extractor[11358]: "Error: Leftover args in content stream"
okt 29 08:05:01 HP rtkit-daemon[7343]: Supervising 3 threads of 1 processes of 1 users.
okt 29 08:05:01 HP rtkit-daemon[7343]: Successfully made thread 16748 of process 16373 owned by '1000' RT at priority 10.
okt 29 08:05:01 HP rtkit-daemon[7343]: Supervising 4 threads of 2 processes of 1 users.
okt 29 08:05:02 HP rtkit-daemon[7343]: Supervising 4 threads of 2 processes of 1 users.
okt 29 08:05:02 HP baloo_file_extractor[11358]: "Error (7643133): Unexpected end of file in flate stream"
okt 29 08:05:03 HP baloo_file_extractor[11358]: "Error (13891780): Unexpected end of file in flate stream"
okt 29 08:05:03 HP baloo_file_extractor[11358]: "Error: Leftover args in content stream"
okt 29 08:05:03 HP rtkit-daemon[7343]: Supervising 4 threads of 2 processes of 1 users.
okt 29 08:05:06 HP baloo_file_extractor[11358]: "Error (31491627): Unexpected end of file in flate stream"
okt 29 08:05:06 HP rtkit-daemon[7343]: Supervising 4 threads of 2 processes of 1 users.
okt 29 08:05:06 HP baloo_file_extractor[11358]: "Error (31707830): Unexpected end of file in flate stream"
okt 29 08:05:06 HP baloo_file_extractor[11358]: "Error: Leftover args in content stream"
okt 29 08:05:07 HP rtkit-daemon[7343]: Supervising 4 threads of 2 processes of 1 users.
okt 29 08:05:13 HP rtkit-daemon[7343]: Supervising 4 threads of 2 processes of 1 users.
okt 29 08:05:13 HP rtkit-daemon[7343]: Successfully made thread 21107 of process 18797 owned by '1000' RT at priority 10.
okt 29 08:05:13 HP rtkit-daemon[7343]: Supervising 5 threads of 3 processes of 1 users.
okt 29 08:05:17 HP baloo_file_extractor[11358]: Invalid document structure (docProps is missing)
okt 29 08:05:18 HP baloo_file_extractor[11358]: QIODevice::read (QProcess): device not open
okt 29 08:05:19 HP baloo_file_extractor[11358]: "Error: Invalid least number of objects reading page offset hints table"
okt 29 08:05:22 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Önn 5/Töluleg greining/skekkja.m"
okt 29 08:05:23 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Latex möppur/skyrsla1forritun/skyrsla3.tex"
okt 29 08:05:23 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Latex möppur/skyrsla1forritun/skyrsla.tex"
okt 29 08:05:23 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Latex möppur/skyrsla1forritun/mcode.sty"
okt 29 08:05:23 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Latex möppur/skyrsla1forritun/skyrsla2.tex"
okt 29 08:05:24 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Latex möppur/Hooke/Hooke.tex"
okt 29 08:05:24 HP baloo_file_extractor[11358]: Invalid encoding. Ignoring "/home/olividir/Skjöl/Háskóli/Latex möppur/Hooke/mcode.sty"
okt 29 08:05:49 HP rtkit-daemon[7343]: Supervising 5 threads of 3 processes of 1 users.
okt 29 08:05:55 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:05:55 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:460: TypeError: Cannot read property 'length' of undefined
okt 29 08:05:55 HP systemd[6693]: Started Thunderbird - Mail Client.
okt 29 08:05:55 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:379: Unable to assign [undefined] to QString
okt 29 08:06:05 HP kdeconnectd[7152]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
okt 29 08:06:05 HP plasmashell[7120]: file:///usr/lib/qt/qml/QtQuick/Controls/TableViewColumn.qml:66:1: QML TableViewColumn: Accessible must be attached to an Item
okt 29 08:06:05 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:60:23: QML DeviceDelegate: Binding loop detected for property "height"
okt 29 08:06:05 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:06:11 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
okt 29 08:06:11 HP plasmashell[7120]: kf.plasma.core: findInCache with a lastModified timestamp of 0 is deprecated
okt 29 08:06:18 HP baloo_file_extractor[11358]: "Error (44284790): Dictionary key must be a name object"
okt 29 08:06:18 HP baloo_file_extractor[11358]: "Error (44284943): Dictionary key must be a name object"
okt 29 08:06:23 HP baloo_file_extractor[11358]: "Error: Bad BBox in shading dictionary"
okt 29 08:06:26 HP baloo_file_extractor[11358]: "Error (21769109): Dictionary key must be a name object"
okt 29 08:06:26 HP baloo_file_extractor[11358]: "Error (21769266): Dictionary key must be a name object"
okt 29 08:06:32 HP baloo_file_extractor[11358]: "Error: Couldn't find trailer dictionary"
okt 29 08:06:36 HP baloo_file_extractor[11358]: "Error (15409722): Bad FCHECK in flate stream"
okt 29 08:06:37 HP rtkit-daemon[7343]: Supervising 5 threads of 3 processes of 1 users.
okt 29 08:06:47 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/DeviceDelegate.qml:84:17: Unable to assign [undefined] to QString
okt 29 08:06:47 HP plasmashell[7120]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:60:23: QML DeviceDelegate: Binding loop detected for property "width"
okt 29 08:06:50 HP baloo_file_extractor[11358]: "Error (14038769): Unknown compression method in flate stream"
okt 29 08:06:50 HP baloo_file_extractor[11358]: "Error: Embedded font file may be invalid"
inxi -Fazy
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.8-x86_64
root=UUID=10a7e7a7-da03-41b9-b65c-942b75a7ad97 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
date: 04/21/2020
ID-1: BAT1 charge: 34.9 Wh condition: 34.9/52.8 Wh (66%) volts: 12.9/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Full
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 8192 KiB
bogomips: 36812
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus ID: 1-5:5 chip ID: 05c8:03bc
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 4000 bus ID: 02:00.0 chip ID: 10ec:b822
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
chip ID: 10ec:8168
Local Storage: total: 1.60 TiB used: 276.77 GiB (16.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: CXB73H1Q scheme: GPT
ID-2: /dev/sda type: USB vendor: Western Digital model: WD My Passport 0740
size: 465.73 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1007 scheme: GPT
ID-3: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0
size: 931.51 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 5438 scheme: MBR
ID-1: / raw size: 237.97 GiB size: 237.97 GiB (100.00%)
used: 38.37 GiB (16.1%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /home raw size: 237.97 GiB size: 237.97 GiB (100.00%)
System Temperatures: cpu: 53.0 C mobo: 29.8 C
Processes: 265 Uptime: 28m Memory: 15.53 GiB used: 2.16 GiB (13.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1303
pacman: 1296 lib: 360 flatpak: 0 snap: 7 Shell: Zsh v: 5.8
running in: konsole inxi: 3.1.08
With many thanks in advanced
