Bad sound with xfce/manjaro
Hi,
I have a dual boot Manjaro/Windows 10. In Windows, My sound is good but it’s not the case with Manjaro and I don’t understand why. I read other topics on the forum without find a solution for me.
This is my actual /etc/pulse/daemon.conf:
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out.  Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
default-sample-format = s24le
default-sample-rate = 19200
alternate-sample-rate = 96000
default-sample-channels = 2
default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
and the result of the command “sudo alsa-info.sh --upload”:
http://alsa-project.org/db/?f=c62b814e548a6323243991f00ef842ae70c716c1
I guess there is a problem with my conf file but I’m not sure
Hello, I don’t know much about sound, but…
Try 192000 → this is either kbps or Hz . You are missing a zero 0.
Just saying…
Thanks for that, I guess it’s better but the sound still saturates
and not enough bass maybe … It’s pretty hard to describe x)
I don’t know if it can help, but I found a youtube video with different frequencies:
the sound saturates between ~~480 and ~~630 Hz
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
If PulseAudio is configured to resample audio up to 192kHz or 96kHz the resample-method should also be adjusted
I suggest you add either
resample-method = speex-float-4
or this
resample-method = soxr-hq
to PulseAudio configuration daemon.conf
(sox resampler allegedly has better audio quality than speex but can add about 20mS latency to audio stream)
Manjaro does not have any of the tweaks and audio enhancements that may have been added to the Realtek driver in Windows
IMO audio quality is uncomfortably flat for general audio use and needs (at least) an equalizer to adjust the frequency response – pulseaudio-equalizer-ladspa
I tried your ideas and I have the same result. For the equalizer, I have no change when I modify the parameters.
Maybe can I post you a video/audio rec to show you what it happens ?
  Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a018d76c-d703-413d-8016-17bd27255828 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: ASUSTeK product: ROG Strix G533QS_G533QS v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: G533QS v: 1.0 serial: <filter>
  UEFI: American Megatrends LLC. v: G533QS.320 date: 06/27/2021
  ID-1: BAT0 charge: 45.2 Wh (55.0%) condition: 82.2/90.0 Wh (91.3%)
  volts: 14.6 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
  serial: <filter> status: Discharging
  RAM: total: 30.79 GiB used: 2.51 GiB (8.2%)
  Info: 8-Core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
  microcode: A50000B cache: L2: 4 MiB bogomips: 105444
  Speed: 1197 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz):
  1: 1197 2: 2701 3: 1397 4: 2008 5: 1197 6: 1197 7: 1197 8: 1197 9: 1227
  10: 1273 11: 1390 12: 1847 13: 1197 14: 1558 15: 3653 16: 3634
  cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
  flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
  invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
  movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
  overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
  perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
  rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
  sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
  topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
  vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: always-on, RSB filling
  Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
  vendor: ASUSTeK driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm
  bus-ID: 01:00.0 chip-ID: 10de:249c class-ID: 0300
  Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
  bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 300 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.12-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
  driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
  bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 195.83 GiB (20.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 236.14 GiB size: 231.37 GiB (97.98%)
  used: 195.8 GiB (84.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: a018d76c-d703-413d-8016-17bd27255828
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 25.2 MiB (9.8%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
  uuid: 00E6-E906
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 697.33 GiB fs: ntfs label: OS
  uuid: 12301F96301F8041
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 650 MiB fs: ntfs label: RECOVERY
  uuid: B4A4F540A4F50620
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 19.5 GiB fs: ntfs label: RESTORE
  uuid: 727C97877C97452F
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-3:2 info: ASUSTek N-KEY Device type: Keyboard
  driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 0b05:1866 class-ID: 0301
  Device-2: 1-4:3 info: ASUSTek N-KEY Device type: Keyboard
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 0b05:18c6 class-ID: 0301
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Logitech M105 Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 67.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
  Fan Speeds (RPM): cpu: 2300
  Processes: 363 Uptime: 2m wakeups: 4 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 alt: 10 Packages: pacman: 1219 lib: 342 flatpak: 0
  Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
You’re on a Stable Development kernel. First port of call should be to try an LTS kernel, so please read this:
(At a minimum the section Linux has multiple kernels and then install both 5.10 and 5.4 and see if the problem goes away automagically.
Not directly related to your problem, but please read this
:crossed_fingers:
I tried 5.10 (same behavior) and 5.4, I can’t boot with 5.4 (black screen with an white underscore at the top left). So I’m back on 5.13.
I tried to create a swapfile but I have the same behavior with sound
  ID-1: swap-1 type: file size: 7.82 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
I forgot to say the sound is normal with my headphones, the problem is here only with speakers. So maybe there is a specific driver for my speakers ?
Hello,
Q: Have you tried lowering the values ??
If not, try something like 128000 and 64000 or 48000, see if something changes.
These are my values:
; default-sample-rate = 44100
; alternate-sample-rate = 48000
Also you can try commenting the lines by putting ; if front and see if that helps.
This laptop has similar size main speakers to a Lenovo system discussed recently
Poor Audio from internal speaker - #6 by nikgnomic
Document ROG Strix SCAR 15 G533QS - Customer self repair guide has internal pictures to show the downward facing speakers are similar size to the Lenovo
The audio benchmark for this system has much better results than the Lenovo system
https://www.notebookcheck.net/Asus-ROG-Strix-Scar-15-G533QS-Laptop-Review-AMD-Zen-3-and-165-Hz-1440p-Sweet-Spot.551441.0.html
This system is using twice as much power and has additional upward facing tweeters. But a lot of the extra audio performance may be from driver enhancements, Smart Amp Technology and Dolby Atmos processing.
If a Windows user could turn off all the extra software and driver enhancements that would give a comparable audio quality to a default Linux installation with no processing
Considering the small size of the laptop speakers you need more than just an equalizer
I suggest you replace pulseaudio-equalizer-ladspa with Viper4Linux
There are no alternative drivers for this device
Headphones and speakers use a shared output device on the ALC285 audio codec
using the ‘snd_hda_intel’ driver
HW probe of ASUSTek ROG Strix G533QS_G53QS #98271924ba: aplay
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: Generic_1 [HD-Audio Generic], device 0: ALC285 Analog [ALC285 Analog]
  Subdevices: 1/1
With only one analog audio device for playback there is no option to separate audio outputs for headphones and speakers
The main factor causing a difference in audio quality is the audio transducer converting electronic analog audio to audible sound
I installed kde manjaro because I had a other issue with xfce. I’ll try your suggestion tomorrow, sorry for the time I took to answer, I was busy this week end. Thanks for the suggestion :slight_smile:
