Hi, this is my actual config:
Last Manjaro release - GNOME 3.38.2 - X11
I’ve installed caffeine-ng and set its in autostart settings.
Caffeine-ng doesn’t start after login and there isn’t sysbar icon
Hoe can I fix it?
Thank you regards
Hoe can I fix it?
Thank you regards
Hi. Is it there it’s autostart .desktop file at ls /etc/xdg/autostart/caffeine.desktop
If it is there, check if there is another .desktop
file for caffeine at ~/.config/autostart/
and delete it or even better, move it from there to another directory, just in case. Then restart and cross your fingers
Ok, I’ve deleted ‘~/.config/autostart/caffeine.desktop’
Than I’ve fixed and caffeine is strarting after login.
Then If I have /etc/xdg/autostart/
and ~/.config/autostart/
duplicetes I’ve to remove one?
Thank you @Signalrunner
No problem mate. Mark the thread as solved if you like.
It depends I guess. Ones are system wide, the others are user wide. You can override one with the other. That particular one it’s faulty it seems, I can’t remember exactly why, because I delete it long time ago.
But you shouldn’t worry otherwise. Check the ones existing already and look if you really need them. Personally, I deleted all of the default distro ones located at ~/.config/autostart/
