Automatic microphone input adjustment problem with discord
So, as the title says, I’m having some trouble that my microphone is auto adjusting it’s volume, I tried most of the soliutions, but most of them end before they even start, due to me not having zoom, steam.
All I could think of is that discord is doing something, but I tried looking into it, couldn’t find anything.
Anyone else having this issue ?
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
What software are you trying to use the microphone with?
  Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
    root=UUID=9e3cea86-3b07-4d0f-9f34-3c3e4b21c50e rw quiet
    resume=UUID=647630c9-8f7b-4c50-8c5a-1ebeff5dffd7 udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASRock model: B450M Steel Legend
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P2.90
    date: 11/27/2019
  RAM: total: 15.55 GiB used: 5.71 GiB (36.7%)
  RAM Report:
  Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
    family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2405 high: 3767 min/max: 2200/3700 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2765 2: 2141
    3: 2034 4: 2136 5: 2137 6: 2138 7: 3640 8: 2135 9: 2879 10: 2135 11: 2041
    12: 2131 13: 2135 14: 2136 15: 3767 16: 2136 bogomips: 118223
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
    smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
  Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: ASUSTeK driver: nvidia
    v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 07:00.0 chip-ID: 10de:1e89 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 89 s-size: 731x430mm (28.78x16.93")
    s-diag: 848mm (33.39")
  Monitor-1: DP-0 res: 2560x1440 dpi: 90 size: 725x428mm (28.54x16.85")
    diag: 842mm (33.15") modes: N/A
  OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
    v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
  Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
    chip-ID: 10de:10f8 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
I’m using PulseAudio, other then that just what comes with Manjaro
In which situation does the volume of the microphone adjust automatically ?
Anytime that I use discord, it just automaticlly adjusts it self, my friends said that my voice becomes more bassy, and unclear.
A quick search for discord in the forum may give you some more information:
Ahhh ok, thank you, will look into it.
Have a wonderful day
I‘m pretty sure I’m not telling you anything new here, but discord has a audio setting under microphone, responsible for auto adjustment, this setting can be disabled and manually moved to a desirable value.
