Hi All -
I’ve had automounts via samba from my unraid server working for quite some time. Latest updates borked it all. Trying to see if anyone has suggestions on how to resolve. Happy to provide whatever logs might help.
→ [root tip] [How To] systemd mount unit samples
→ [root tip] [How To] Basic Samba Setup and Troubleshooting
→ Search results for '#contributions:tutorials samba' - Manjaro Linux Forum
Yes I know all of these things…I just don’t know why the update borked it all…
I suppose that would of been nice to provide with your post! ![]()
What is the unit configuration?
Can you manually mount -t cifs it?
The above may throw the same errors in journalctl you are getting with your mount unit. No one knows.
Sorry - I’m terrible with knowing how to pull logs (thus why I didn’t post them up front). But, I ended up “fixing” it by going into my .automounts, I modified them, then reverted and saved again. Now, all is working again.
In this case, to troubleshoot… I would have run (in a separate window/tab/whatever): journalctl -f
This sees every new log entry, so I was suggesting try a manual mount, while watching the logs.
But you can filter by unit/service name too, how many boots(restarts) ago, simple ‘YYYY-MM-DD’ date ranges, etc. man journalctl
But when you say “automounts”, I had assumed a systemd mount unit (that happens to automatically mount). This is the way I do it anyway.
