"Authentication Required" prompt after every boot
  Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A serial: <filter>
  Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <filter>
  UEFI: American Megatrends v: F21 date: 02/08/2018
  RAM: total: 15.64 GiB used: 2.6 GiB (16.6%)
  Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 1 stepping: 1 microcode: 8001129 cache: L2: 3 MiB
  bogomips: 76673
  Speed: 1428 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
  1: 1428 2: 1385 3: 1375 4: 1374 5: 3340 6: 3199 7: 1394 8: 1475 9: 1375
  10: 1368 11: 1375 12: 1373
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm lbrv lm mca mce
  nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
  sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
  tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
  chip-ID: 10de:1c02 class-ID: 0300
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: nvidia resolution: <missing: xdpyinfo>
  OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
  Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f1
  class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 03:00.0
  Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
  v: kernel modules: bcma port: f000 bus-ID: 07:00.0 chip-ID: 14e4:43a0
  class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Local Storage: total: 698.65 GiB used: 120.16 GiB (17.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: HDD rpm: 5900 serial: <filter> rev: CA12 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
  dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
  used: 120.16 GiB (52.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 40809886-d17c-433b-876f-89a03d053b64
  used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: E832-7B45
  ID-1: /dev/sdb1 maj-min: 8:17 size: 31.25 GiB fs: swap label: N/A
  uuid: 14863704-322a-453c-b7a5-87bba34bb094
  ID-2: /dev/sdb2 maj-min: 8:18 size: 434.51 GiB fs: ext4 label: N/A
  uuid: 1e982ebe-e75b-431f-b88e-9cd8f14fc425
  Device-1: 1-5:2 info: Corsair Gaming K70 LUX RGB Keyboard type: Keyboard,HID
  power: 500mA chip-ID: 1b1c:1b33 class-ID: 0300 serial: <filter>
  Device-2: 1-6:3 info: Logitech G502 Proteus Spectrum Optical Mouse
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
  serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 28.9 C mobo: N/A gpu: nvidia temp: 37 C
  Processes: 334 Uptime: 2m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1399 pacman: 1395 lib: 428
  flatpak: 0 snap: 4 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
I’m not exactly sure when this started happening but for the past day or two when I boot up Manjaro and arrive at the desktop the “Authentication Required” dialog and input box pops up and I put in my password to make it go away. I currently don’t have my computer set to require a password on bootup. Anyone know how I can figure out what the problem might be and to solve it? It might be an issue since the latest major update but I’m not sure.
Thank you.
First: If you do not know, what you are authorizing: don’t do it.
There must be some program autostarting which is querying you for authorziation. Check autostarts.
@freggel.doe
I did not think of that, thank you.
How do I check for what automatically starts?
https://help.gnome.org/users/gnome-help/stable/shell-apps-auto-start.html.en
and also have a look at the .desktop files in /etc/xdg/autostart/.
I’m not sure if those are the only places.
@freggel.doe
Nothing seems out of ordinary in Tweaks, although I did notice that caffeine-ng is set to autostart but doesn’t seem to do so. I hadn’t noticed that in a long time. I just tried starting it and it works but doesn’t autostart. I don’t know if that is related, just something I noticed
Here’s some screenshots of all of the applications in xdg. What should I be looking for?
The first screenshot showing the “Authentication required” messge already shows the culprit:
The login keyring did not get unlogged ..
So it seems to be a problem with (failing) automatic unlocking of the keyring when logging in.
I’m assuming that means you activated automatic login.
I’m not using gnome but found this:
Okay thank you, I think that should be the solution, I’ll try it out for the next day or two and see how things go. Thanks for all the help.
