i was using the AUR in kde normally before
now i switched to xfce and i enabled the AUR , but it doesn’t work
i dont find any AUR packages in the “add/remove software” GUI app
and even in the CLI i can’t find AUR packages
( btw there is no # before the EnableAUR in the pamac.conf file , so it is enabled)
what i wanted to download is scheme48 package but i can’t find any AUR packages anyway and i can’t download them
So you actually have a problem with pamac. No idea there, but until you find what is broken, you can use another helper. Install yay, if you need a gui also octopi. I assume you already have base-devel.
p.s. i edited the title and tags. AUR of course works with xfce. It does not work on your machine
How did you switch to Xfce? Switching desktop environments isn’t as easy and straightforward anymore as it used to be, and therefore, it is most likely that you’ve done some damage to your pamac configuration in the process.
I am on xfce, no problem in pamac with AUR that proposes scheme48.
Check in Preferences, 3d tab that AUR is enabled (and updates is not), then update databases (in menu).
A fair point. I hope switching means reinstalling. Otherwise you can run into problems. Especially if you did not made a new user with the new DE, the breakage is a matter of time.
If you deleted the config, it defaulted to AUR being turned off. Check the settings.
However, if I understand you correctly, a test user with vanilla settings also have non-working AUR in pamac, which would mean a deeper problem, unless you have the AUR support disabled there which is the default.
it says “Failed to read AUR data from /var/tmp/pamac/dbs/sync/packages-meta-ext-v1.json.gz : Error opening file /var/tmp/pamac/dbs/sync/packages-meta-ext-v1.json.gz: No such file or directory”
then it lists non AUR packages
