Hello all,
since the last updates, I am experiencing stuttering audio when trying to play any video on YouTube using Chromium from the official repo.
Even more strange: When I stop the video or even close Chromium altogether, the last bits of audio played are still echoed for a few seconds to minutes. To stop this, I have to killall pipewire
Interestingly, this only happens with Chromium - Firefox Nightly is not affected by that problem.
$ inxi -F
Host: gerd-desktop Kernel: 5.19.0-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.16.0 Distro: Manjaro Linux
Type: Desktop System: LENOVO product: 7034W12 v: ThinkCentre M91p
serial: <superuser required>
Mobo: LENOVO model: N/A serial: <superuser required> BIOS: LENOVO
v: 9HKT58AUS date: 06/10/2014
Info: quad core model: Intel Core i5-2400 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 3193 min/max: 1600/3400 cores: 1: 3193 2: 3193 3: 3193
4: 3193
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] driver: nvidia v: 515.57
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57
driver: snd_hda_intel
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
Sound Server-1: ALSA v: k5.19.0-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.54 running: yes
Device-1: Intel 82579LM Gigabit Network driver: e1000e
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 70:f3:95:1b:23:83
Local Storage: total: 1.64 TiB used: 1.05 TiB (64.2%)
ID-1: /dev/sda vendor: Intenso model: SSD SATAIII size: 447.13 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD3200AAKS-00L9A0
ID-3: /dev/sdc vendor: Seagate model: ST31000333AS size: 931.51 GiB
ID-1: / size: 430.59 GiB used: 271.84 GiB (63.1%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 899.56 GiB used: 803.97 GiB (89.4%) fs: ext4
dev: /dev/sdc1
ID-1: swap-1 type: partition size: 8.59 GiB used: 145.2 MiB (1.7%)
dev: /dev/sda2
System Temperatures: cpu: 76.0 C mobo: N/A
Processes: 251 Uptime: 1h 40m Memory: 7.72 GiB used: 5.03 GiB (65.2%)
Shell: Bash inxi: 3.3.19
DAC324:
5.19.0-1-MANJARO
Hello,
Does the issue happen on a more stable kernel too? I understand the urge to test the latest things, but 5.19 kernel is still experimental … Also, check the Chromium browser settings and what flags you are using. For example i use this in ~/.config/chromium-flags.conf
--enable-accelerated-2d-canvas
--enable-accelerated-video-decode
--enable-accelerated-mjpeg-decode
--enable-drdc
--enable-features=ParallelDownloading,UnexpireFlagsM90,VaapiVideoEncoder,VaapiVideoDecoder,CanvasOopRasterization
--enable-gpu-compositing
--enable-native-gpu-memory-buffers
--enable-gpu-rasterization
--enable-oop-rasterization
--enable-raw-draw
--enable-zero-copy
--ignore-gpu-blocklist
--disable-features=UseChromeOSDirectVideoDecoder
--use-gl=desktop
DAC324
July 11, 2022, 10:28am
3
bogdancovaciu:
--enable-drdc
Happens on 5.18 , too, but fortunately, to a lesser extent.
bogdancovaciu:
--enable-drdc
Direct Rendering Display Compositor is not (yet) supported on Linux.
Doesn’t do any harm on my end, probably a leftover from when i was doing some tests …
DAC324
July 11, 2022, 10:37am
5
Of course, it is currently simply ignored.
Tested now with kernel 5.15 (recommended as per Manjaro Settings tools). With this kernel, I do not observe significant stuttering anymore.
Looks like there is some glitch with pipewire
and kernels >= 5.18 , at least on snd_hda_intel
, at least for me.
My chromium
flags:
--enable-accelerated-vpx-decode=3
#--enable-accelerated-video-decode #deprecated in favor of --enable-features=VaapiVideoDecoder
--enable-display-list-2d-canvas
--enable-experimental-web-platform-features
--enable-fast-unload
--enable-font-antialiasing
--enable-gpu-async-worker-context
--enable-hardware-overlays
--enable-zero-copy
--new-canvas-2d-api
--disable-software-rasterizer
--disable-gpu-driver-bug-workarounds
--disable-gpu-driver-workarounds
--disable-gpu-vsync
--enable-features=VaapiVideoDecoder,ParallelDownloading,UnexpireFlagsM90,VaapiVideoEncoder,CanvasOopRasterization,RawDraw,VaapiIgnoreDriverChecks
--use-vulkan
--use-gl=desktop
--num-raster-threads=6
--ozone-platform=x11
--ozone-platform-hint=x11
DAC324
July 29, 2022, 1:55pm
6
Update:
As I have two audio devices
I have now switched from the onboard audio to my graphics card - problems solved
Apparently, my onboard sound is somehow faulty.
