pactl list cards returns
Card #0
Driver: module-alsa-card.c
Owner Module: 6
Properties:
alsa.card = "2"
alsa.card_name = "Steinberg UR22C"
alsa.long_card_name = "Yamaha Corporation Steinberg UR22C at usb-0000:03:00.0-2, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:03:00.0-usb-0:2:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-2/1-2:1.0/sound/card2"
udev.id = "usb-Yamaha_Corporation_Steinberg_UR22C-00"
device.bus = "usb"
device.vendor.id = "0499"
device.vendor.name = "Yamaha Corp."
device.product.id = "172f"
device.product.name = "Steinberg UR22C"
device.serial = "Yamaha_Corporation_Steinberg_UR22C"
device.string = "2"
device.description = "Steinberg UR22C"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 6555, available: yes)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: output:iec958-stereo+input:iec958-stereo
Ports:
analog-input: Analog Input (type: Analog, priority: 10000, latency offset: 0 usec, availability unknown)
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:iec958-stereo+input:analog-stereo
iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo
analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #1
Owner Module: 7
Properties:
alsa.card = "3"
alsa.card_name = "USB Device 0x46d:0x825"
alsa.long_card_name = "USB Device 0x46d:0x825 at usb-0000:03:00.0-9, high speed"
device.bus_path = "pci-0000:03:00.0-usb-0:9:1.2"
sysfs.path = "/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.2/sound/card3"
udev.id = "usb-046d_0825_F55095D0-02"
device.bus = "usb"
device.vendor.id = "046d"
device.vendor.name = "Logitech, Inc."
device.product.id = "0825"
device.product.name = "Webcam C270"
device.serial = "046d_0825_F55095D0"
device.form_factor = "webcam"
device.string = "3"
device.description = "Webcam C270"
device.icon_name = "camera-web-usb"
Profiles:
input:mono-fallback: Mono Input (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: input:mono-fallback
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): input:mono-fallback
Card #2
Owner Module: 8
Properties:
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xf7080000 irq 131"
device.bus_path = "pci-0000:26:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0fb0"
device.product.name = "GM200 High Definition Audio"
device.string = "0"
device.description = "GM200 High Definition Audio"
device.icon_name = "audio-card-pci"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 38468, available: yes)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (sinks: 1, sources: 0, priority: 600, available: no)
Active Profile: output:hdmi-stereo-extra2
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, available)
Properties:
device.product.name = "Q27P2W
Part of profile(s): output:hdmi-stereo-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
hdmi-output-5: HDMI / DisplayPort 6 (type: HDMI, priority: 5400, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
hdmi-output-6: HDMI / DisplayPort 7 (type: HDMI, priority: 5300, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra6, output:hdmi-surround-extra6, output:hdmi-surround71-extra6
Card #3
Owner Module: 9
Properties:
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xf7800000 irq 133"
device.bus_path = "pci-0000:28:00.4"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:28:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.string = "1"
device.description = "Starship/Matisse HD Audio Controller"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 38268, available: yes)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: no)
Active Profile: output:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
Properties:
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, not available)
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, available)
Properties:
