So, I recently switched from Windows to manjaro+kde an I’m quite happy with that decision. The only problem are my bluetooth headphones (Marshall Monitor II). On windows they work perfect and also on Manjaro I have no pairing problems, but every few seconds I the Audio cuts out and I have no idea why. The bluetooth settings seem right to me (A2DP), I repaired them multiple times and also reinstalled pulseaudio… I’m not an expert on this topic so from now on I don’t know what to do. I need help
Welcome to Manjaro!
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Hey, Thanks for your answer (and sorry for my late response). The output is the following:
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=52e43711-b494-4752-a0a6-ef39024d104f rw quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1130 serial: <filter>
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1130 serial: <filter> UEFI: HUAWEI
v: 1.06 date: 09/14/2020
ID-1: BAT0 charge: 52.7 Wh (100.0%) condition: 52.7/54.9 Wh (95.9%)
volts: 8.7 min: 7.6 model: Desay HB4593R1ECW-22T0 type: Li-ion
serial: <filter> status: Full cycles: 99
RAM: total: 15.08 GiB used: 6.01 GiB (39.9%)
Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600104 cache: L2: 3 MiB bogomips: 71864
Speed: 1549 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz):
1: 1549 2: 1790 3: 3813 4: 3782 5: 1825 6: 2065 7: 1640 8: 1788 9: 1716
10: 2105 11: 1838 12: 2314
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:56db class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.5x15.0")
s-diag: 686mm (27")
Monitor-1: eDP res: 2160x1440 hz: 60 dpi: 185 size: 296x197mm (11.7x7.8")
diag: 356mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.32-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel v: kernel
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 1358:c123 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 3 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 476.94 GiB used: 147.82 GiB (31.0%)
model: PC SN730 SDBPNTY-512G-1027 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 11120000 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 175.78 GiB size: 171.96 GiB (97.83%)
used: 147.45 GiB (85.7%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: 52e43711-b494-4752-a0a6-ef39024d104f
ID-2: /boot/efi raw-size: 512 MiB size: 508 MiB (99.22%)
used: 375.3 MiB (73.9%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
label: WINPE uuid: 5A28-CA57
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: SYSTEM
uuid: FC27-587A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 120 GiB fs: ntfs label: Windows
uuid: 529E28719E284FB1
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 116.71 GiB fs: ntfs label: Data
uuid: 38EC28E8EC28A1DC
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 14 GiB fs: ntfs label: Onekey
uuid: 32B22B13B22ADB5D
ID-6: /dev/nvme0n1p7 maj-min: 259:7 size: 1024 MiB fs: ntfs label: WinRE
uuid: E8B22D0FB22CE432
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-2:2 info: MosArt 2.4G Keyboard Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:5918 class-ID: 0301
Device-2: 1-4:3 info: Shenzhen Goodix Goodix Fingerprint Device
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5110 class-ID: 0a00
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 1358:c123
Device-2: 3-4:3 info: IMC Networks HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:56db
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.2 C mobo: 0 C gpu: amdgpu temp: 41.0 C
Processes: 266 Uptime: 2h 17m wakeups: 15 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 alt: 8 clang: 11.1.0 Packages: 1403
pacman: 1389 lib: 372 flatpak: 5 snap: 9 Shell: Bash v: 5.1.0
running-in: konsole inxi: 3.3.04```
Is this helpful?
I know these are $hit and have their own Windows driver, but no specific Bluetooth Linux driver.
Can you try both 5.11 and 5.12 kernels and see if they resolve anything?
If not: how old is your machine?
Oh my god, thank you! it’s finally working! switched to 5.12.
Thanks for your help!
