Audio Output is not automatically switching to Bluetooth Headsets
Hi, I am new to manjaro and linux also. So I have bluetooth headsets, Oneplus Bullet Wireless Z. My problem is that when I connect my headphones to pc, my audio output does not automatically switches to headphones, I have to open volume bar and manually change to headphones, I searched many times but didn,t find any solution. Any help will be much appreciated.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. Have you checked whether the line
    load-module module-switch-on-connect
    is present in /etc/pulse/default.pa
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
There is no line of load-module module-switch-on-connect in /etc/pulse/default.pa
Here’s the output of inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a42f529d-0c9d-4796-a2a6-b8d3b21a783b rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Desktop Mobo: Standard model: X50-V2 serial: <filter>
  BIOS: American Megatrends v: 1.03 date: 08/27/2010
  RAM: total: 3.83 GiB used: 1.23 GiB (32.1%)
  Info: Dual Core model: Intel Atom D525 bits: 64 type: MT MCP arch: Bonnell
  family: 6 model-id: 1C (28) stepping: A (10) microcode: 107 cache:
  L2: 512 KiB bogomips: 14370
  Speed: 1795 MHz min/max: N/A Core speeds (MHz): 1: 1795 2: 1796 3: 1796
  4: 1796
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
  cx16 cx8 de ds_cpl dtes64 dtherm dts fpu fxsr ht lahf_lm lm mca mce mmx
  monitor movbe msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
  rep_good sep ss sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
  Type: spec_store_bypass status: Not affected
  Type: spectre_v1 status: Not affected
  Type: spectre_v2 status: Not affected
  Device-1: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics
  vendor: Holco Enterprise Co /Shuttle driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:a001 class-ID: 0300
  Device-2: Chicony USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 1-2:2
  chip-ID: 04f2:b1f1 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0
  screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa DRI Intel Pineview v: 1.4 Mesa 21.1.5
  direct render: Yes
  Device-1: Intel NM10/ICH7 Family High Definition Audio
  vendor: Holco Enterprise Co /Shuttle driver: snd_hda_intel v: kernel
  bus-ID: 00:1b.0 chip-ID: 8086:27d8 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: no
  Device-1: JMicron JMC260 PCI Express Fast Ethernet
  vendor: Holco Enterprise Co /Shuttle driver: jme v: 1.0.8 port: d800
  bus-ID: 01:00.5 chip-ID: 197b:0260 class-ID: 0200
  IF: enp1s0f5 state: down mac: <filter>
  Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
  v: kernel port: e800 bus-ID: 02:00.0 chip-ID: 10ec:8176 class-ID: 0280
  driver: btusb v: 0.8 bus-ID: 4-2:3 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 232.89 GiB used: 69.86 GiB (30.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK2576GSX
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
  type: HDD rpm: 5400 serial: <filter> rev: 2N scheme: MBR
  ID-1: / raw-size: 232.88 GiB size: 228.23 GiB (98.00%)
  used: 69.86 GiB (30.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: a42f529d-0c9d-4796-a2a6-b8d3b21a783b
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
  Device-1: 1-2:2 info: Chicony USB 2.0 Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 320mA chip-ID: 04f2:b1f1
  class-ID: 0e02
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  chip-ID: 1d6b:0001 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Device-1: 3-2:2 info: CASUE USB KB type: Keyboard,HID
  power: 100mA chip-ID: 2a7a:938f class-ID: 0300
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Device-1: 4-1:2 info: Logitech Wireless Receiver type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
  chip-ID: 046d:c542 class-ID: 0301
  Device-2: 4-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  System Temperatures: cpu: 64.0 C mobo: N/A
  Processes: 225 Uptime: 15m wakeups: 2 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1276 apt: 0 pacman: 1269 lib: 371
  flatpak: 7 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06```
Please add that first
Look if there is a BIOS update and apply that too.
Please read this:
:crossed_fingers:
I added load-module module-switch-on-connect in /etc/pulse/default.pa restarted my pc and It worked, Thank you very very much.
