Audio not working after upgrade to 5.8.6-1 Linux kernel
Dear Manjaro community,
Yesterday I upgraded my kernel to 5.8.6-1 version from 5.7.19-2 and the sound stopped working. In the system tray it says “No input or output devices are found”, and only the dummy output volume can be configured in the audio settings.
Here is the output of inxi -F
  Host: ravil-pc Kernel: 5.8.6-1-MANJARO x86_64 bits: 64
  Desktop: KDE Plasma 5.19.5 Distro: Manjaro Linux
  Type: Convertible System: LENOVO product: 81C4
  v: Lenovo YOGA C930-13IKB serial: <superuser/root required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
  serial: <superuser/root required> UEFI: LENOVO v: 8GCN30WW
  date: 07/13/2018
  ID-1: BAT1 charge: 46.7 Wh condition: 46.7/60.0 Wh (78%)
  Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  L2 cache: 8192 KiB
  Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800
  3: 799 4: 800 5: 800 6: 800 7: 800 8: 800
  Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
  Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
  s-res: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
  v: 4.6 Mesa 20.1.7
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_soc_skl
  Sound Server: ALSA v: k5.8.6-1-MANJARO
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi
  IF: wlp107s0 state: up mac: 48:a4:72:d0:cc:94
  Device-2: Intel Wireless-AC 9260 Bluetooth Adapter type: USB
  driver: btusb
  Local Storage: total: 238.47 GiB used: 66.68 GiB (28.0%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS256GD9TNG-62A0A
  ID-1: / size: 34.20 GiB used: 10.93 GiB (31.9%) fs: ext4
  dev: /dev/nvme0n1p6
  ID-2: /home size: 69.99 GiB used: 55.72 GiB (79.6%) fs: ext4
  dev: /dev/nvme0n1p7
  ID-1: swap-1 type: partition size: 12.00 GiB used: 0 KiB (0.0%)
  dev: /dev/nvme0n1p5
  System Temperatures: cpu: 39.5 C mobo: 29.8 C
  Processes: 240 Uptime: 2m Memory: 11.46 GiB used: 1.49 GiB (13.0%)
  Shell: Bash inxi: 3.1.05
please post more information
sudo dmesg | grep -E 'ALSA|HDA|snd|sound|hda'
I suspect if audio was working on v5.7 kernel, system has a modprobe option added to disable the internal microphone array - options snd-hda-intel dmic_detect=0
if so, data from dmesg will confirm that this option has been deprecated, and advise the new option to use
Like this post from the old forum:
archived.forum.manjaro - Bad audio quality from earphones
replace options snd-hda-intel dmic_detect=0 with options snd-intel-dspcfg.dsp_driver=1
Lenovo YOGA C930 is still awaiting support for internal digital microphone from sof-firmware
Microphone on Lenovo Yoga C930 not working
see this
People think the latest kernel is always the greatest, and that is not true.
If 5.7 works and 5.8 doesn’t, stay with 5.7 and file a bug for 5.8.
The “best” kernels are the LTS kernels (Long Time Support) and all the other ones should only be used if you have hardware that is not supported by your current kernel…
:innocent:
I am sorry for a late reply. Here is the output:
[    2.336820] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    2.336824] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SST driver
[    2.473695] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[    2.473703] snd_soc_skl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SST driver
[    2.476422] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    2.527984] HDMI HDA Codec ehdaudio0D2: Max dais supported: 3
Also, following the instructions in the post you provided, I couldn’t find any files inside the directory “/etc/modprobe.d”
Yes, I totally agree with you! I do not see a lot of advantages to always trying to get the newest kernel.
Thanks for referring me to this thread.
I tried the proposed solution, i.e. creating a file named “alsa-fix.conf” with the line “options snd-hda-intel dmic_detect=0” in the directory “/etc/modprobe.d”, but after rebooting the issue was still there.
Please run pa-info and provide its output. Could you go back to the kernel where it was working, and run inxi -Fazy and pa-info and sudo dmesg | grep -Ei 'alsa|snd|sound|hda' there as well?
Inxi -Fazy from the old kernel:
  Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=6e35e8d4-c2ea-4d27-9916-517fe043d37c rw quiet udev.log_priority=3
  Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
  Type: Convertible System: LENOVO product: 81C4 v: Lenovo YOGA C930-13IKB
  serial: <filter> Chassis: type: 31 v: Lenovo YOGA C930-13IKB
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
  UEFI: LENOVO v: 8GCN30WW date: 07/13/2018
  ID-1: BAT1 charge: 44.9 Wh condition: 46.7/60.0 Wh (78%) volts: 8.4/7.7
  model: Celxpert BASE-BAT type: Li-poly serial: <filter> status: Unknown
  arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: D6
  L2 cache: 8192 KiB
  bogomips: 32012
  Speed: 900 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
  4: 901 5: 900 6: 900 7: 900 8: 900
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5917
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-1:2
  chip ID: 04f2:b61e serial: <filter>
  Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.7
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.7.19-2-MANJARO
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3040
  bus ID: 6b:00.0 chip ID: 8086:2526
  IF: wlp107s0 state: up mac: <filter>
  Device-2: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
  bus ID: 1-8:5 chip ID: 8087:0025
  Local Storage: total: 238.47 GiB used: 66.75 GiB (28.0%)
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 80001E00 scheme: GPT
  ID-1: / raw size: 35.00 GiB size: 34.20 GiB (97.72%) used: 10.95 GiB (32.0%)
  fs: ext4 dev: /dev/nvme0n1p6
  ID-2: /home raw size: 71.62 GiB size: 69.99 GiB (97.73%)
  used: 55.77 GiB (79.7%) fs: ext4 dev: /dev/nvme0n1p7
  ID-1: swap-1 type: partition size: 12.00 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p5
  System Temperatures: cpu: 35.0 C mobo: 29.8 C
  Processes: 245 Uptime: 1m Memory: 11.46 GiB used: 1.40 GiB (12.2%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1156 lib: 329
  Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
sudo dmesg | grep -Ei 'alsa|snd|sound|hda' from the old kernel:
[    2.054470] snd_hda_intel 0000:00:1f.3: dmic_detect option is deprecated, pass snd-intel-dspcfg.dsp_driver=1 option instead
[    2.429519] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    2.485571] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC298: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    2.485574] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.485575] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    2.485576] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    2.485577] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    2.485579] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[    2.580804] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    2.587202] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[    2.587286] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    2.587338] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    2.587375] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[    2.587412] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[    2.587449] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[    2.587481] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
pa-info from the old kernel:
________________
> pulseaudio_ps_do
ravil       1120  1.2  0.1 423640 13036 ?        S<sl 10:50   0:00 /usr/bin/pulseaudio --daemonize=no
ravil       1459  0.0  0.0   3076   788 pts/1    S+   10:51   0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1120
________________
> pulseaudio --version
pulseaudio 13.0
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 33
Server Protocol Version: 33
Is Local: yes
Client Index: 5
Tile Size: 65472
User Name: ravil
Host Name: ravil-pc
Server Name: pulseaudio
Server Version: 13.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Cookie: 7226:5e9c
________________
> pactl list
Module #0
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Lennart Poettering"
		module.description = "Automatically restore the volume/mute state of devices"
		module.version = "13.0"
Module #1
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore profile of cards"
Module #3
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Augment the property sets of streams with additional static information"
Module #4
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "David Henningsson"
		module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect available audio hardware and load matching drivers"
Module #6
	Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Usage counter: 0
	Properties:
		module.description = "ALSA Card"
Module #7
	Argument: channels=2
	Usage counter: n/a
	Properties:
		module.description = "Adds JACK sink/source ports when JACK is started"
Module #8
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Frédéric Dalleau, Pali Rohár"
		module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #9
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "João Paulo Rechi Vita"
		module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #10
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #11
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Tanu Kaskinen"
		module.description = "D-Bus interface"
Module #12
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Native protocol (UNIX sockets)"
Module #13
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Sylvain Baubeau"
		module.description = "GSettings Adapter"
Module #14
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically restore the default sink and source"
Module #15
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #16
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Colin Guthrie"
		module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #17
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Automatically set device of streams based on intended roles of devices"
Module #18
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "When a sink/source is idle for too long, suspend it"
Module #19
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Create a client for each ConsoleKit session of this user"
Module #20
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Create a client for each login session of this user"
Module #21
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #22
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Mute & cork streams with certain roles while others exist"
Module #23
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Detect when various filters are desirable"
Module #24
	Argument:
	Usage counter: n/a
	Properties:
		module.description = "Load filter sinks automatically when needed"
Module #25
	Argument: display=:0
	Usage counter: n/a
	Properties:
		module.description = "X11 credential publisher"
Module #26
	Argument: display=:0 session_manager=local/ravil-pc:@/tmp/.ICE-unix/1070,unix/ravil-pc:/tmp/.ICE-unix/1070
	Usage counter: n/a
	Properties:
		module.description = "X11 session management"
Sink #0
	State: SUSPENDED
	Description: Built-in Audio Analog Stereo
	Driver: module-alsa-card.c
	Owner Module: 6
	Mute: no
	Volume: front-left: 45514 /  69% / -9.50 dB,   front-right: 45514 /  69% / -9.50 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC298 Analog"
		alsa.id = "ALC298 Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0x2ffb018000 irq 147"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "9d71"
		device.product.name = "Sunrise Point-LP HD Audio"
		device.string = "front:0"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Built-in Audio Analog Stereo"
		alsa.mixer_name = "Realtek ALC298"
		alsa.components = "HDA:10ec0298,17aa3812,00100103 HDA:8086280b,80860101,00100000"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Ports:
		analog-output-speaker: Speakers (priority: 10000)
		analog-output-headphones: Headphones (priority: 9900, not available)
	Active Port: analog-output-speaker
	Formats:
		pcm
Source #0
	State: SUSPENDED
	Description: Monitor of Built-in Audio Analog Stereo
	Owner Module: 6
	Mute: no
	Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		device.description = "Monitor of Built-in Audio Analog Stereo"
		device.class = "monitor"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Formats:
		pcm
Client #0
	Driver: module-systemd-login.c
	Owner Module: 20
	Properties:
		application.name = "Login Session 2"
		systemd-login.session = "2"
Client #3
	Driver: module-x11-xsmp.c
	Owner Module: 26
	Properties:
		application.name = "XSMP Session on KDE as 10de8ee6cc000160071064800000010700004"
		xsmp.vendor = "KDE"
		xsmp.client.id = "10de8ee6cc000160071064800000010700004"
Client #4
	Driver: protocol-native.c
	Owner Module: 12
	Properties:
		application.name = "QPulse"
		native-protocol.peer = "UNIX socket client"
		native-protocol.version = "33"
		application.process.id = "1088"
		application.process.user = "ravil"
		application.process.host = "ravil-pc"
		application.process.binary = "plasmashell"
		application.language = "en_US.UTF-8"
		window.x11.display = ":0"
		application.process.machine_id = "ddafba75ad0e4bb895e5568f62ce59b9"
		application.process.session_id = "2"
Client #6
	Owner Module: 12
	Properties:
		application.name = "pactl"
		application.process.id = "1464"
		application.process.binary = "pactl"
		application.language = "C"
Card #0
	Owner Module: 6
	Properties:
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
		device.description = "Built-in Audio"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: no)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: no)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: no)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
		output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
		output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
		output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: output:analog-stereo
	Ports:
		analog-input-mic: Microphone (priority: 8700, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4+input:analog-stereo
		analog-output-speaker: Speakers (priority: 10000, latency offset: 0 usec)
			Properties:
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (priority: 9900, latency offset: 0 usec, not available)
			Properties:
		hdmi-output-0: HDMI / DisplayPort (priority: 5900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
		hdmi-output-1: HDMI / DisplayPort 2 (priority: 5800, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
		hdmi-output-2: HDMI / DisplayPort 3 (priority: 5700, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
		hdmi-output-3: HDMI / DisplayPort 4 (priority: 5600, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
		hdmi-output-4: HDMI / DisplayPort 5 (priority: 5500, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4, output:hdmi-surround71-extra4+input:analog-stereo
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out.  Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
flat-volumes = no
; flat-volumes = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Automatically move streams to the default sink if the sink they are
### connected to dies, similar for sources
load-module module-rescue-streams
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116,  1 Sep 21 10:50 /dev/snd/seq
crw-rw----+ 1 root audio 116,  3 Sep 21 10:50 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116,  8 Sep 21 10:50 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116,  7 Sep 21 10:50 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116,  6 Sep 21 10:50 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116,  5 Sep 21 10:50 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116,  4 Sep 21 10:50 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  2 Sep 21 10:50 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 11 Sep 21 10:50 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  9 Sep 21 10:50 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 10 Sep 21 10:50 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116, 33 Sep 21 10:50 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Sep 21 10:50 .
drwxr-xr-x 3 root root 300 Sep 21 10:50 ..
lrwxrwxrwx 1 root root  12 Sep 21 10:50 pci-0000:00:1f.3 -> ../controlC0
________________
> lsof /dev/snd/*
________________
> jacks_do
card=0
numid=45,iface=CARD,name='HDMI/DP,pcm=10 Jack'
  ; type=BOOLEAN,access=r-------,values=1
  : values=off
numid=21,iface=CARD,name='HDMI/DP,pcm=3 Jack'
  : values=off
numid=27,iface=CARD,name='HDMI/DP,pcm=7 Jack'
  : values=off
numid=33,iface=CARD,name='HDMI/DP,pcm=8 Jack'
  : values=off
numid=39,iface=CARD,name='HDMI/DP,pcm=9 Jack'
  : values=off
numid=17,iface=CARD,name='Headphone Jack'
  : values=off
numid=16,iface=CARD,name='Mic Jack'
  : values=off
numid=18,iface=CARD,name='Speaker Phantom Jack'
  : values=on
________________
> aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
    HDA Intel PCH, ALC298 Analog
    Default Audio Device
front:CARD=PCH,DEV=0
    Front output / input
surround21:CARD=PCH,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
hdmi:CARD=PCH,DEV=3
    HDA Intel PCH, HDMI 3
    HDMI Audio Output
hdmi:CARD=PCH,DEV=4
    HDA Intel PCH, HDMI 4
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
    Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
________________
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Mon Sep 21 17:51:23 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      LENOVO
Product Name:      81C4
Product Version:   Lenovo YOGA C930-13IKB
Firmware Version:  8GCN30WW
Board Vendor:      LENOVO
Board Name:        LNVNB161216
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/IDEA0100:00/status 	 15
/sys/bus/acpi/devices/INT0E0C:00/status 	 15
/sys/bus/acpi/devices/INT33A1:00/status 	 15
/sys/bus/acpi/devices/INT33D0:00/status 	 15
/sys/bus/acpi/devices/INT33D3:00/status 	 15
/sys/bus/acpi/devices/INT3400:00/status 	 15
/sys/bus/acpi/devices/INT3403:01/status 	 15
/sys/bus/acpi/devices/INT340E:00/status 	 15
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/ITE8353:00/status 	 15
/sys/bus/acpi/devices/LIC0001:00/status 	 15
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:00/status 	 3
/sys/bus/acpi/devices/PNP0C02:05/status 	 3
/sys/bus/acpi/devices/PNP0C09:00/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PNP0C0C:00/status 	 15
/sys/bus/acpi/devices/PNP0C0D:00/status 	 15
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/SYNA2B31:00/status 	 15
/sys/bus/acpi/devices/USBC000:00/status 	 15
/sys/bus/acpi/devices/VPC2004:00/status 	 15
/sys/bus/acpi/devices/WCOM5196:00/status 	 15
/sys/bus/acpi/devices/YMC2017:00/status 	 15
/sys/bus/acpi/devices/device:17/status 	 15
/sys/bus/acpi/devices/device:20/status 	 15
/sys/bus/acpi/devices/device:32/status 	 15
!!Kernel Information
Kernel release:    5.7.19-2-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.7.19-2-MANJARO
Library version:    1.2.3.2
Utilities version:  1.2.3
!!Loaded ALSA modules
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21)
	Subsystem: Lenovo Device [17aa:3831]
!!Modprobe options (Sound related)
snd_hda_intel: dmic_detect=0
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	dmic_detect : N
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC298
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0298
Subsystem Id: 0x17aa3812
Revision Id: 0x100103
No Modem Function Group found
Default PCM:
    rates [0x60]: 44100 48000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 D3cold CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=8, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[7]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC298 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x7f, nsteps=0x7f, stepsize=0x01, mute=0
  Amp-Out vals:  [0x00 0x00]
  Converter: stream=1, channel=0
  PCM:
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Speaker Playback Volume", index=0, device=0
  Amp-Out vals:  [0x6c 0x6c]
  PCM:
    formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
  Converter: stream=0, channel=0
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x43, nsteps=0x7f, stepsize=0x01, mute=1
  Amp-In vals:  [0x5b 0x5b]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In vals:  [0xc3 0xc3]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
  SDI-Select: 0
  Digital:
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x560]: 44100 48000 96000 192000
    formats [0x1]: PCM
  Connection: 1
     0x25
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Mic Playback Volume", index=0, device=0
  Control: name="Mic Playback Switch", index=0, device=0
  Control: name="Beep Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=4, ofs=0
  Control: name="Beep Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 4
     0x18 0x19 0x1a 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 1
     0x03
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x24
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00000020: IN
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Pin Default 0x40000000: [N/A] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40050d: Stereo Amp-Out
  Control: name="Speaker Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Pincap 0x00010010: OUT EAPD
  EAPD 0x2: EAPD
  Pin Default 0x90170140: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Unknown
    DefAssociation = 0x4, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 2
     0x0c 0x0d*
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Unsolicited: tag=00, enabled=0
  Connection: 3
     0x0c* 0x0d 0x06
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Control: name="Mic Boost Volume", index=0, device=0
  Pincap 0x00003724: IN Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x04a11020: [Jack] Mic at Ext Right
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
    Misc = NO_PRESENCE
  Pin-ctls: 0x00: VREF_HIZ
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Pincap 0x0001373c: IN OUT HP EAPD Detect
  EAPD 0x2: EAPD
    Misc = NO_PRESENCE
  Connection: 2
     0x0c* 0x0d
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x40700001: [N/A] Modem Hand at Ext N/A
    DefAssociation = 0x0, Sequence = 0x1
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400701: Stereo Digital
  Pincap 0x00000014: OUT Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
  Connection: 1
     0x06
Node 0x1f [Pin Complex] wcaps 0x400601: Stereo Digital
  Pincap 0x00000024: IN Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x00:
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=150
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0000001c: OUT HP Detect
  Pin Default 0x04211010: [Jack] HP Out at Ext Right
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP
  Unsolicited: tag=01, enabled=1
  Connection: 2
     0x0c* 0x0d
Node 0x22 [Audio Selector] wcaps 0x300101: Stereo
  Connection: 6
     0x18* 0x19 0x1a 0x1d 0x0b 0x12
Node 0x23 [Audio Selector] wcaps 0x300101: Stereo
  Connection: 6
     0x18* 0x19 0x1a 0x1d 0x0b 0x13
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
  Connection: 2
     0x12* 0x13
Node 0x25 [Audio Selector] wcaps 0x300101: Stereo
  Connection: 1
     0x1f
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled KAE
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pincap 0x0b000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC298 Analog [ALC298 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0x2ffb018000 irq 147'
  Mixer name	: 'Realtek ALC298'
  Components	: 'HDA:10ec0298,17aa3812,00100103 HDA:8086280b,80860101,00100000'
  Controls      : 56
  Simple ctrls  : 15
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 127
  Mono: Playback 108 [85%] [-9.50dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 0 [0%] [-63.50dB] [off]
  Front Right: Playback 0 [0%] [-63.50dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 127 [100%] [0.00dB] [on]
  Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Mono:
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 127
  Front Left: Capture 91 [72%] [12.00dB] [on]
  Front Right: Capture 91 [72%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 127'
			dbmin -6350
			dbmax 0
			dbvalue.0 -6350
			dbvalue.1 -6350
	control.2 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Speaker Playback Volume'
		value.0 127
		value.1 127
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 127'
			dbmin -6350
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Speaker Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.6 {
		iface MIXER
		name 'Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.7 {
		iface MIXER
		name 'Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.8 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.9 {
		iface MIXER
		name 'Capture Volume'
		value.0 91
		value.1 91
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 127'
			dbmin -3350
			dbmax 3000
			dbvalue.0 1200
			dbvalue.1 1200
	control.10 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.11 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.12 {
		iface MIXER
		name 'Beep Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.13 {
		iface MIXER
		name 'Beep Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.14 {
		iface MIXER
		name 'Master Playback Volume'
		value 108
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 127'
			dbmin -6350
			dbmax 0
			dbvalue.0 -950
	control.15 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.16 {
		iface CARD
		name 'Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.17 {
		iface CARD
		name 'Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.18 {
		iface CARD
		name 'Speaker Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.19 {
		iface PCM
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.20 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.21 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.22 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.23 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.24 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.25 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.26 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.27 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.28 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.30 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.31 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.32 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.33 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.34 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.36 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.37 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.38 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.39 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.40 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.41 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.42 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.43 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.44 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.45 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.46 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.47 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.48 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.49 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.50 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.51 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.52 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.53 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.54 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.55 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.56 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
--endcollapse--
!!All Loaded Modules
8250_dw
ac
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
hid_sensor_accel_3d
hid_sensor_als
hid_sensor_hub
hid_sensor_iio_common
hid_sensor_trigger
i2c_algo_bit
i2c_hid
i2c_i801
i8042
i915
iTCO_vendor_support
iTCO_wdt
ideapad_laptop
idma64
industrialio
industrialio_triggered_buffer
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
intel_wmi_thunderbolt
intel_xhci_usb_role_switch
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
nls_cp437
nls_iso8859_1
pcspkr
processor_thermal_device
rapl
rc_core
rfcomm
rfkill
rng_core
roles
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wacom
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x411111f0
0x13 0x40000000
0x14 0x90170140
0x17 0x411111f0
0x18 0x04a11020
0x19 0x411111f0
0x1a 0x411111f0
0x1d 0x40700001
0x1e 0x411111f0
0x1f 0x411111f0
0x21 0x04211010
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
pa-info from the new kernel:
________________
> pulseaudio_ps_do
ravil       1148  0.0  0.0 1732032 10552 ?       S<sl 10:36   0:00 /usr/bin/pulseaudio --daemonize=no
ravil       3695  0.0  0.0   3076   792 pts/1    S+   10:49   0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1148
________________
pulseaudio 13.0
________________
> pactl info
Is Local: yes
Client Index: 12
Tile Size: 65472
User Name: ravil
Host Name: ravil-pc
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: 79bb:f833
________________
> pactl list
Module #0
	Argument:
	Usage counter: n/a
	Properties:
Module #1
	Argument:
	Usage counter: n/a
	Properties:
Module #2
	Argument:
	Usage counter: n/a
	Properties:
Module #3
	Argument:
	Usage counter: n/a
	Properties:
Module #4
	Argument:
	Usage counter: n/a
	Properties:
Module #5
	Argument:
	Usage counter: n/a
	Properties:
Module #6
	Usage counter: n/a
	Properties:
Module #7
	Argument:
	Usage counter: n/a
	Properties:
Module #8
	Argument:
	Usage counter: n/a
	Properties:
Module #9
	Argument:
	Usage counter: n/a
	Properties:
Module #10
	Argument:
	Usage counter: n/a
	Properties:
Module #11
	Argument:
	Usage counter: n/a
	Properties:
Module #12
	Argument:
	Usage counter: n/a
	Properties:
Module #13
	Argument:
	Usage counter: n/a
	Properties:
Module #14
	Argument:
	Usage counter: n/a
	Properties:
Module #15
	Argument:
	Usage counter: n/a
	Properties:
Module #16
	Argument: sink_name=auto_null sink_properties='device.description="Dummy Output"'
	Usage counter: 0
	Properties:
		module.description = "Clocked NULL sink"
Module #17
	Argument:
	Usage counter: n/a
	Properties:
Module #18
	Argument:
	Usage counter: n/a
	Properties:
Module #19
	Argument:
	Usage counter: n/a
	Properties:
Module #20
	Argument:
	Usage counter: n/a
	Properties:
Module #21
	Argument:
	Usage counter: n/a
	Properties:
Module #22
	Argument:
	Usage counter: n/a
	Properties:
Module #23
	Argument:
	Usage counter: n/a
	Properties:
Module #24
	Argument:
	Usage counter: n/a
	Properties:
Module #25
	Usage counter: n/a
	Properties:
Module #26
	Argument: display=:0 session_manager=local/ravil-pc:@/tmp/.ICE-unix/1101,unix/ravil-pc:/tmp/.ICE-unix/1101
	Usage counter: n/a
	Properties:
Sink #0
	State: SUSPENDED
	Description: Dummy Output
	Driver: module-null-sink.c
	Owner Module: 16
	Mute: no
	        balance 0.00
	Monitor Source: auto_null.monitor
	Properties:
		device.description = "Dummy Output"
		device.class = "abstract"
		device.icon_name = "audio-card"
	Formats:
		pcm
Source #0
	State: SUSPENDED
	Description: Monitor of Dummy Output
	Owner Module: 16
	Mute: no
	        balance 0.00
	Monitor of Sink: auto_null
	Properties:
		device.description = "Monitor of Dummy Output"
	Formats:
		pcm
Client #0
	Owner Module: 20
	Properties:
Client #3
	Owner Module: 26
	Properties:
		application.name = "XSMP Session on KDE as 10de8ee6cc000160070981200000011010004"
		xsmp.vendor = "KDE"
		xsmp.client.id = "10de8ee6cc000160070981200000011010004"
Client #4
	Owner Module: 11
	Properties:
		application.process.id = "1108"
Client #5
	Owner Module: 11
	Properties:
		application.name = "Firefox"
		window.x11.screen = "0"
		application.process.id = "1398"
		application.process.binary = "firefox"
		application.icon_name = "firefox"
Client #6
	Owner Module: 11
	Properties:
Client #7
	Owner Module: 11
	Properties:
		application.version = "80.0.1"
Client #8
	Owner Module: 11
	Properties:
		application.name = "pamac-tray-appindicator"
		application.process.id = "1175"
		application.process.binary = "pamac-tray-appindicator"
Client #9
	Owner Module: 11
	Properties:
		application.name = "Add/Remove Software"
		application.process.id = "2835"
		application.process.binary = "pamac-manager"
		application.icon_name = "system-software-install"
Client #13
	Owner Module: 11
	Properties:
		application.process.id = "3701"
________________
## commenting.
; daemonize = no
; fail = yes
; allow-exit = yes
; enable-shm = yes
; lock-memory = no
; cpu-limit = no
; nice-level = -11
; log-target = auto
; log-meta = no
; log-time = no
; log-backtrace = 0
flat-volumes = no
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-locks = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
________________
## commenting.
; default-sink =
; default-source =
; default-server =
autospawn = no
; autospawn = yes
; cookie-file =
; enable-shm = yes
________________
.fail
.else
.endif
.nofail
.fail
.endif
.endif
.endif
.endif
### loaded modules.
.nofail
.fail
.endif
### during runtime
.endif
.endif
________________
# mode.
.else
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116,  1 Sep 21 10:36 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Sep 21 10:36 /dev/snd/timer
________________
> lsof /dev/snd/*
________________
> jacks_do
________________
> aplay -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
________________
> alsa_info_do
!!Script ran on: Mon Sep 21 17:49:28 UTC 2020
ID_LIKE=arch
!!DMI Information
Product Name:      81C4
Kernel release:    5.9.0-1-MANJARO
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.9.0-1-MANJARO
Pulseaudio:
  Running - Yes
Jack:
  Running - No
--- no soundcards ---
!!ALSA Device nodes
APLAY
aplay: device_list:274: no soundcards found...
ARECORD
arecord: device_list:274: no soundcards found...
!!Amixer output
!!Alsactl output
--startcollapse--
--endcollapse--
8250_dw
ac
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
hid_sensor_accel_3d
hid_sensor_als
hid_sensor_hub
hid_sensor_trigger
i2c_algo_bit
i2c_hid
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
ideapad_laptop
idma64
industrialio
input_leds
int3400_thermal
int3403_thermal
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
libarc4
libps2
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
nls_cp437
nls_iso8859_1
pcspkr
rapl
rc_core
rfcomm
rfkill
rng_core
roles
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_skl_ssp_clk
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_timer
soundcore
sparse_keymap
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wacom
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
xhci_pci_renesas
!!ALSA/HDA dmesg
Unfortunately 5.7 is EOL now… :sob: Have you tried 5.4 LTS yet?
:thinking:
dmesg data for the v5.7 kernel has this message
but it still respects the setting and audio devices are detected and working in ALSA with snd_hda_intel driver (excluding internal microphone)
kernel v5.4 would probably also work with the dmic detect=0 option
kernel v5.8 is not respecting this old option as it drops snd_hda_intel driver in favour of snd_soc_skl (the same driver shown in OP data)
Uh oh, thanks for pointing this out :sleepy: I haven’t tried 5.4 yet, but I think I should.
I see… So, you mean that sticking to 5.4 kernel is the only viable option to have audio working?
Have you tried options snd-hda-intel snd-intel-dspcfg.dsp_driver=1 instead of options snd-hda-intel dmic_detect=0 on the v5.8 kernel?
Please also try the v5.4 kernel.
Interestingly, even the v5.7 kernel ignores dmic_detect.
Miraculously, it seems like right now the issue resolved itself - the audio is working with the latest kernel. I assume this might be due to the latest system upgrade I did with pacman?
Yup. That’s why I asked to try out 5.4 originally. Next step would have been 5.8, so:
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
:innocent:
P.S. In the future, please mark a solution like this:
Solution
