Does “pulseaudio” have a balance control ?
Today (after installing some updates) I notice that my left ch. output is much stronger than the right ch. output. It’s as if the right ch just dropped out. It’s there but at a much lower volume. I reverted back to Kernel 5.4 but that didn’t fix it. Problem does NOT occur when I boot into Win10…then sound is fine (dual boot configuration).
Basic System Config:
KDE Plasma Version: 5.19.5
KDE Frameworks Version: 5.74.0
Qt Version: 5.15.1
Kernel Version: 5.8.11-1-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5-7400 CPU @ 3.00GHz
Memory: 15.3 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 630
Hardware Detect output:
AGP : agpgart intel-gtt
BLOCK : sr_mod xhci-hcd xhci-pci xhci-pci-renesas
CDROM : cdrom
CPUFREQ : acpi-cpufreq pcc-cpufreq
CRYPTO : aesni-intel crc32c-intel crc32-pclmul crct10dif-pclmul ghash-clmulni-intel glue_helper cryptd crypto_simd
DRM : drm_kms_helper drm i915
HWMON : coretemp
I2C : i2c-algo-bit i2c-i801 i2c-smbus
INPUT : evdev input-leds atkbd mousedev psmouse i8042 libps2 serio serio_raw
KVM : kvm-intel kvm
MEDIA : cec rc-core
NET : r8169 fjes libphy
SOUND : pcspkr snd-hwdep snd snd-pcm snd-timer snd-hda-core snd-intel-dspcfg snd-hda-codec-generic snd-hda-codec-hdmi snd-hda-codec snd-hda-codec-realtek snd-hda-intel soundcore
WATCHDOG : iTCO_vendor_support iTCO_wdt
OTHER : intel-cstate intel-uncore rapl ledtrig-audio mac_hid intel_pmc_bxt ee1004 mei_hdcp mei intel_rapl_common intel_rapl_msr intel_powerclamp x86_pkg_temp_thermal fb_sys_fops syscopyarea sysfillrect sysimgblt irqbypass
The audio/KDE interface seems to be “broken”. Here is sample from the log.
I was attempting to test the left/Right speakers after playing a u-tube video.
I am also getting a lot misc Qt/KDE warning messages.
10/3/20 2:21 PM | systemsettings5 | org.kde.plasma.pulseaudio: No object for name “alsa_output.pci-0000_00_1f.3.analog-stereo.monitor” |
10/3/20 2:21 PM | systemsettings5 | file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/DeviceComboBox.qml:59:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … } |
10/3/20 2:21 PM | systemsettings5 | file:///usr/lib/qt/qml/QtQuick/Controls.2/org.kde.desktop/ComboBox.qml:96:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … } |
10/3/20 2:22 PM | systemsettings5 | file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/DeviceComboBox.qml:59:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … } |
10/3/20 2:22 PM | systemsettings5 | file:///usr/lib/qt/qml/QtQuick/Controls.2/org.kde.desktop/ComboBox.qml:96:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … } |
10/3/20 2:22 PM | systemsettings5 | file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:36: TypeError: Cannot read property ‘width’ of null |
