I installed Manjaro KDE today on the new computer I just built and I seem to be having an issue when it comes to getting the case audio jack to be detected by Manjaro. If anyone know’s what is going on that would be appreciated.
Firstly,
Secondly, is the jack connected in the case? There is a cable for HD Audio that would connect to the motherboard header for HD audio. This is what connects the Jack on the case to the Motherboard.
If it is connected, check your audio settings, audio may be being sent to another connection(Like HDMI).
Otherwise, post the information like in the link I provided and someone may see something wrong and know how to fix it.
I think i did this correctly, to answer your questions, Yes the jack is in the case, I believe the Jack is connected as I had to get the device repaired at Microcenter because i originally bent the pin I’ll check after this. Secondly I am not sure how i would check if audio is being sent by HDMI or not as im new to Manjaro and Linux as a whole. (Sorry)
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a0ae95d9-38bb-461b-afbe-dfa7e02d6419 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4
serial: <superuser required> UEFI: American Megatrends v: P3.20
date: 08/11/2020
RAM: total: 31.27 GiB used: 3.14 GiB (10.0%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201005
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2644 high: 3594 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3594 2: 3195
3: 2051 4: 3592 5: 2047 6: 2053 7: 3593 8: 2053 9: 3593 10: 2700 11: 2048
12: 2052 13: 2046 14: 3588 15: 2050 16: 2052 bogomips: 121423
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Hewlett-Packard
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 08:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: f000 bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 24.1 GiB (2.6%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 33.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 24.09 GiB (2.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a0ae95d9-38bb-461b-afbe-dfa7e02d6419
label: NO_LABEL uuid: C9FE-5E87
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Primax HP USB Keyboard type: Keyboard,HID
power: 98mA chip-ID: 0461:4e8e class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-4:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 309 Uptime: 18m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1243 lib: 348
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.11```
Have you tried both front and rear headphone jacks on this system?
If you install package alsa-tools
pamac install alsa-tools
That has hdajacksensetest to check if jack-detection is working
sudo hdajacksensetest --card=1
