Attempting to open folders crashes nautilus
Desktop (customised with top, bottom and side bars and various extensions) was working fine until I downloaded a projector user manual from the official Epson site. When I went to open the Downloads folder its window opened momentarily, then the screen crashed and I was presented with a fresh login screen. When I logged back in I’d lost all my desktop settings and was presented with - is it Unity, with the large icons along the bottom of the screen?
Rebooting changes nothing. Trying to open Files always produces the same effect, as does trying to run from the terminal with the ‘nautilus’ command.
Updating the system - overdue as I’ve been away from home for six weeks - has also not solved the problem.
I’m a long time user of Manjaro Gnome, but far from expert. I’ve learned from experience not to mess around too much without expert advice or I’m likely to make matters worse. So far I haven’t found anything online that suggests a diagnosis, let alone a solution. Would be very grateful if someone could suggest a few basic troubleshooting steps. I’m comfortable using the terminal but far from familiar with all its possibilities.
We can begin with some system info;
inxi -Farz
A sort mirrors and sync and upgrade dance couldnt hurt;
sudo pacman-mirrors -f && sudo pacman -Syu
After which we may also look at foreign packages
pacman -Qmq
Of course opening nautilus should not crash things.
Have you tried disabling your extra extensions?
Not sure to what you are referring … but I doubt the system is somehow ‘reverting’ to the defunct ubuntu desktop environment.
    ~  inxi -Farz                                                       ✔
  Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=505a427c-a786-41e4-a4bc-690a3c072cbc rw quiet splash apparmor=1
  Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
    UEFI-[Legacy]: American Megatrends v: 0606 date: 12/12/2017
  Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
    vulnerable
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: none empty: DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nouveau v: kernel
    non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1c82
    class-ID: 0300 temp: 32.0 C
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13.4.3:7
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: nouveau display-ID: 0
  Monitor-1: DVI-D-1 model: NEC 20WGX2 serial: <filter> built: 2007
    res: 1680x1050 dpi: 99 gamma: 1.2 size: 433x270mm (17.05x10.63")
    diag: 510mm (20.1") ratio: 16:10 modes: max: 1680x1050 min: 720x400
  Monitor-2: HDMI-A-1 model: LG (GoldStar) W2243 serial: <filter>
    built: 2009 res: 1920x1080 dpi: 102 gamma: 1.2
    size: 477x269mm (18.78x10.59") diag: 548mm (21.6") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: nouveau wayland: drv: nouveau x11:
    drv: nouveau
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
    direct-render: yes renderer: NV137 device-ID: 10de:1c82 memory: 3.89 GiB
    unified: no display-ID: :0.0
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  API: ALSA v: k6.11.10-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:4 chip-ID: 0b05:190e
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 3.19 TiB used: 1.32 TiB (41.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
    model: MZVKW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: CXA7500Q temp: 35.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 27.9 C
    scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
    used: 51.35 GiB (11.0%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:3
  System Temperatures: cpu: 33.0 C mobo: N/A gpu: nouveau temp: 32.0 C
  Fan Speeds (rpm): N/A
  Packages: 1620 pm: pacman pkgs: 1603 libs: 401 tools: gnome-software,pamac
    pm: flatpak pkgs: 17
    1: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    3: https://manjaro.ynh.ovh/stable/$repo/$arch
  Memory: total: 16 GiB available: 15.48 GiB used: 2.63 GiB (17.0%)
  Processes: 440 Power: uptime: 1h 8m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.16 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.36
Thanks for your speedy response cscs.
Since experiencing an unfixable problem a year or so ago, on advice read on this forum and manjaro help pages I’ve avoided using pacman altogether, sticking entirely to pamac. What are the equivalent pamac commands for the operations you recommend?
I’ve just discovered all extensions are already off - could that be the problem? I’ll post this, switch them back on, and then try logging out and back in.
I didn’t even have to log out: as soon as my extensions were enabled again my familiar desktop reappeared. Still no joy with opening Files though. Would it be worth installing a different file manager and seeing if that works?
CSCS is one of the most proficient people in the forum…
Just one extra note here:
  • Do you have snapshots enabled?
  • Do you have backups enabled?
Resistance is futile. Just follow the instructions and relax.
Run the above to sort your mirrors and do a full update.
(Note - pacman only interacts with repos and local packages)
Afterwards you can also update aur packages using an aur helper like pamac …
pamac upgrade -a
And it wouldn’t hurt to check pacdiff
pacdiff -o
I’m a Plasma user, so I’ll say ‘gnome ore’.
OK Ben, thanks, and here goes:
    ~  sudo pacman-mirrors -f && sudo pacman -Syu                       ✔
[sudo] password for nick:
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.383 France         : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.634 France         : https://mirror.ibakerserver.pt/manjaro/
  0.487 France         : https://manjaro.ynh.ovh/
::INFO Writing mirror list
::France          : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$rep
::France          : https://manjaro.ynh.ovh/stable/$repo/$arch
::France          : https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
 there is nothing to do
    ~  pamac upgrade -a                                         ✔  12s 
Preparing...
Authenticating as: Nick (nick)
Password:
Refreshing AUR...
Checking ruby-gdk3 dependencies...
Checking ruby-gobject-introspection dependencies...
Checking python-pulsectl dependencies...
Checking ruby-gio2 dependencies...
Checking ruby-glib2 dependencies...
Checking ruby-gtk3 dependencies...
Checking dropbox dependencies...
Checking perl-mojolicious dependencies...
Checking ruby-gdk_pixbuf2 dependencies...
Checking ruby-atk dependencies...
Checking rubyripper dependencies...
Checking ruby-cairo-gobject dependencies...
Checking v86d dependencies...
Checking ruby-pango dependencies...
Checking realvnc-vnc-viewer dependencies...
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- unable to satisfy dependency 'ruby-glib2=4.1.2' required by ruby-atk
- unable to satisfy dependency 'ruby-cairo-gobject=4.1.2' required by ruby-gdk3
- unable to satisfy dependency 'ruby-gdk_pixbuf2=4.1.2' required by ruby-gdk3
- unable to satisfy dependency 'ruby-pango=4.1.2' required by ruby-gdk3
- unable to satisfy dependency 'ruby-gio2=4.1.2' required by ruby-gdk_pixbuf2
- unable to satisfy dependency 'ruby-gobject-introspection=4.1.2' required by ruby-gio2
Edit build files : [e]
Apply transaction ? [e/y/N]
Transaction cancelled.
    ~  pacdiff -o                                             1 ✘  55s 
/etc/passwd.pacnew
/etc/locale.gen.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
/etc/pacman-mirrors.conf.pacnew
/etc/pam.d/polkit-1.pacsave
/etc/default/useradd.pacnew
What should I do about the failed pamac upgrade?
Ok, firstly a comment:
/etc/passwd.pacnew
There should be no output from these, you have not managed your pacdiffs during updates.
I’m curious now if removing ruby-atk would result in a successful update.
    ~  pamac remove ruby-atk                                            ✔
Preparing...
Checking dependencies...
- removing ruby-atk breaks dependency 'ruby-atk' required by ruby-gtk3
Aha, so try pamac remove ruby-gtk3 'cos it’s this AUR thread that’s broken.
Summary
pamac install ruby-gtk3
Warning: ruby-gtk3 is only available from AUR
Preparing...
To install (4):
  ruby-red-colors                0.3.0-4    (Required By: ruby-cairo-gobject)  extra  88.2 kB
  ruby-native-package-installer  1.1.9-1    (Required By: ruby-atk)            extra  35.5 kB
  ruby-pkg-config                1.5.7-1    (Required By: ruby-atk)            extra  21.7 kB
  ruby-cairo                     1.17.13-1  (Required By: ruby-cairo-gobject)  extra  306.4 kB
To build (9):
  ruby-glib2                     4.2.4-1                                       AUR
  ruby-cairo-gobject             4.2.4-1                                       AUR
  ruby-gobject-introspection     4.2.4-1                                       AUR
  ruby-gio2                      4.2.4-1                                       AUR
  ruby-gdk_pixbuf2               4.2.4-1                                       AUR
  ruby-pango                     4.2.4-1                                       AUR
  ruby-gdk3                      4.2.4-1                                       AUR
  ruby-atk                       4.2.4-1                                       AUR
  ruby-gtk3                      4.2.4-1                                       AUR
I’m off to bed now, I hope you can fix it - otherwise no doubt someone else might be around later to help pick up the threads.
    ~  pamac remove ruby-gtk3                                           ✔
Preparing...
- removing ruby-gtk3 breaks dependency 'ruby-gtk3' required by rubyripper
And I use rubyripper regularly for ripping cds so don’t want to break it.
I’ve just installed Nemo, and that’s opening folders fine, so I have a GUI workaround and I assume it indicates that the problem is nautilus specific rather than a deeper problem? Should I try removing nautilus and reinstalling it - or could that cause knock-on problems?
OK, and many thanks for your help, Ben. :slightly_smiling_face:
I think if you first remove rubyripper and get the system sorted it would be better - and also make sure that you get no response when you run padciff -o.
Then you can install it again.
There are also other options… I use Strawberry, well maintained:
I would start by removing everything unnecessary and/or problematic.
sudo pacman -Rns ruby-gio2 ruby-gdk_pixbuf2 ruby-gdk3 ruby-atk v86d
Also note that ruby-gtk3 and ruby-gdk3 are different packages.
rubyripper depends on ruby-gtk3
We may also want to see and/or remove orphans
pacman -Qdtq
I dont know why or what would spur a concept of ‘use pamac and avoid pacman’… as evidenced by … all history ever … if anything it should be the other way around. Pamac, like pacman, is an ALPM frontend. Nonetheless pamac uses various pacman resources (like the log and cache).
pacman-mirrors, despite the name, is not part of pacman. There is no pamac equivalent, it is what should be used to sort mirrors.
sudo pacman -Syu would be equal to pamac upgrade --no-aur excepting any possible bugs not shared or similar.
pacman -Qmq would print all foreign packages. I believe the pamac equal is pamac list -imq
Aside from the upgrade command, there would be no option (pacman-mirrors) or no point (the job is only printing) to using a pamac equal.
And, frankly, in the case of upgrades or exchanges I would say pacman is more reliable. The only reason unearthed so far for pamac being considered superior would be the ‘human’ commands, like ‘install’ instead of ‘-S’. But with them being longer, I dont see it as such.
But we do have one again for orphans;
pamac list -o
Thanks so much for the further advice, Ben and CSCS. I’ve ended up removing Rubyripper, as trying to remove selected ruby packages still broke dependencies:
    ~  sudo pacman -Rns ruby-gio2 ruby-gdk_pixbuf2 ruby-gdk3 ruby-atk v86d
checking dependencies...
:: removing ruby-atk breaks dependency 'ruby-atk' required by ruby-gtk3
:: removing ruby-gdk3 breaks dependency 'ruby-gdk3' required by ruby-gtk3
:: removing ruby-gdk_pixbuf2 breaks dependency 'ruby-gdk_pixbuf2' required by ruby-gtk3
:: removing ruby-gio2 breaks dependency 'ruby-gio2' required by ruby-gtk3
I seem to have a lot of orphans:
   ~  pacman -Qdtq                                            1 ✘  7s 
acpica
appstream-glib
blueprint-compiler
box2d
cjson
cmake
dcraw
ddcutil
docker
dvdauthor
gcab
gendesk
go
gradience
intltool
js102
js115
kcmutils5
kfilemetadata5
kitemmodels
knewstuff5
knotifyconfig5
ldns
lib32-libpng12
lib32-libtiff
lib32-libunwind
lib32-libxdamage
libgrss
libsmbios
libutempter
linux-meta
mage
mbedtls2
meson
mkvtoolnix-cli
purpose5
python-async-timeout
python-build
python-future
python-installer
python-ordered-set
python-ply
python-pyaml
python-pycurl
python-pydantic
python-tomli
python-validate-pyproject
qt5-networkauth
sassc
uriparser
v86d
wayland-protocols
web-installer-url-handler
webrtc-audio-processing
wpebackend-fdo
Is it safe to remove them all?
Pamac upgrade now seems to be working; currently downloading files.
How do I sort the pacdiff issue?
If they are orphans (nothing in your system needs them or depends on them) : yes
Here is one thread - the second post (meld) is likely what you want to use.
Support on how to use pacdiff
Meld is definitely the most user friendly of the bunch.
Do not replace the original /etc/passwd file with the /etc/passwd.pacnew file.
Instead, follow these steps:
  1. Review the changes: Open both files in a text editor, side by side, to understand the differences.
  2. Merge the changes: Manually merge the new entries from the pacnew file into your existing /etc/passwd file, preserving your customizations.
  3. Delete the pacnew file: Once you’ve merged the changes, remove the /etc/passwd.pacnew file to avoid any potential issues.
This is the way - you might be able to simply put it back later, or you might find a better alternative…
Add/Remove
Asunder (Official and Flatpak)
Sound Juicer
Heading over to LinuxLinks, searching ‘Asunder’ and then heading to the title Article:
Thanks again, Nachlese and Ben - this is really helpful support. I’m a bit out of my depth with pacdiff but you’ve given me the tools, which I’ll use when I have a bit more time and headspace than right now.
Meanwhile the pamac update has gone through successfully. However, after cleaning up I got this:
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: v86d 0.1.10-13 (lun. 16 déc. 2024 10:51:31)
==> Cleaning up...
Password:
Cancelled
==== AUTHENTICATION FAILED ====
I’m pretty sure I didn’t mistype my password - could this be related to the /etc/passwd.pacnew discrepancies?
Also, I don’t recall ever being asked for authentification after an upgrade. I’m not sure what to do next - clearly the terminal is waiting for something as it’s not returned my normal prompt.
Yes, thanks for those suggestions, Ben. I’ve used Asunder, still have it on my system as a last resort, but I’m a bit of a nerd when it comes to audio and have sought out what are regarded as closest Linux equivalents to EAC. I use whipper primarily, and rubyripper when whipper fails a disc.
v86d was / is one of your orphan packages
remove it instead of trying to build and install it again
The password issue could be (this is speculation on my part) due to one of the not yet merged .pacnew files:
From memory:
one of them adds a new system user (alpm)
(/etc/passwd.pacnew as well if I remember correctly)
and the other may be directly related to the password prompt via polkit
