Hello everyone,
I’m having a persistent issue with my ASUS Vivobook Pro 15, where it fails to suspend properly. When I close the lid or choose “Suspend” from the menu, the screen turns off, but the fans continue to spin. The laptop never enters a sleep state and often becomes unresponsive, requiring a hard shutdown by holding the power button.
My goal is to get the default s2idle sleep state working.
System Information
Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=a99d8bbc-b8cc-48fc-959e-3901264c7abb rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Laptop System: ASUSTeK product: ASUS Vivobook Pro 15 N6506MV_N6506MV
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: N6506MV v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: N6506MV.311
date: 02/25/2025
ID-1: BAT0 charge: 75.0 Wh (100.0%) condition: 75.0/75.0 Wh (100.0%)
volts: 17.7 min: 15.9 model: S560647 type: Unknown serial: <filter>
status: full cycles: 2
Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x24
Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
st: 10 smt: enabled cache: L1: 1.6 MiB desc: d-10x32 KiB, 6x48 KiB; i-16x64
KiB L2: 18 MiB desc: 9x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4800:5100:3800:2500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
bogomips: 135212
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 0000:00:02.0 chip-ID: 8086:7d55 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 575.64.03 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ ports: active: none
empty: HDMI-A-1,eDP-2 bus-ID: 0000:01:00.0 chip-ID: 10de:28a0
class-ID: 0300
Device-3: Shinetech ASUS 5M WebCam driver: hid-sensor-hub,usbhid,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:3
chip-ID: 3277:0058 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2880x1620 s-dpi: 96 s-size: 762x428mm (30.00x16.85")
s-diag: 874mm (34.41")
Monitor-1: eDP-1 model: Samsung 0x4180 built: 2021 res: mode: 2880x1620
hz: 120 scale: 100% (1) dpi: 213 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 2880x1620
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 53.08 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 575.64.03
device-ID: 10de:28a0 surfaces: N/A
Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 0000:00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
Device-2: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22be
class-ID: 0403
API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:2d:00.0
IF: enp45s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel bus-ID: 0000:2e:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp46s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0032
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
class-ID: 0104
Local Storage: total: 2.75 TiB used: 76.94 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Micron
model: MTFDKBA1T0QFM-1BD1AABGB size: 953.87 GiB block-size: physical: 512 B
fw-rev: V3MA101 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QJXD7 temp: 51.9 C
scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 76.94 GiB (4.1%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 620 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 76.94 GiB (4.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
System Temperatures: cpu: 64.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 56 GiB note: est. available: 54.36 GiB used: 6.01 GiB (11.1%)
Processes: 427 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 21.71 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1432 pm: pacman pkgs: 1422 libs: 435 tools: pamac,yay pm: flatpak
pkgs: 10 Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.38
What I’ve Already Tried
- My system is fully updated via
sudo pacman -Syu. - My BIOS is updated to the latest version from the ASUS website.
- I tried disabling a PCI device (
RP12) as a wakeup source usingecho RP12 > /proc/acpi/wakeup, but it had no effect. - Based on similar issues, I tried preventing the Wi-Fi card from entering a deep power-saving state with
echo 0 > /sys/bus/pci/devices/0000\:2e\:00.0/d3cold_allowed. This also did not solve the problem. - I am aware that switching to
deepsleep might work, but I am specifically looking for a solution to fix thes2idlestate.
Dmesg Log of the Failed Suspend
[ 0.000000] Linux version 6.12.39-1-MANJARO (linux612@manjaro) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Thu, 17 Jul 2025 20:46:35 +0000
[ 0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64 root=UUID=a99d8bbc-b8cc-48fc-959e-3901264c7abb rw rootflags=subvol=@ quiet splash udev.log_priority=3
[ 0.000000] x86/tme: not enabled by BIOS
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000005bd09fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000005bd0a000-0x0000000065ce6fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000065ce7000-0x0000000065e0bfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000065e0c000-0x0000000065f9cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000065f9d000-0x0000000067ffefff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000067fff000-0x0000000067ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000068000000-0x00000000787fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000e7fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] e820: update [mem 0x4f200018-0x4f224c57] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000004f200017] usable
[ 0.000000] reserve setup_data: [mem 0x000000004f200018-0x000000004f224c57] usable
[ 0.000000] reserve setup_data: [mem 0x000000004f224c58-0x000000005bd09fff] usable
[ 0.000000] reserve setup_data: [mem 0x000000005bd0a000-0x0000000065ce6fff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000065ce7000-0x0000000065e0bfff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x0000000065e0c000-0x0000000065f9cfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000065f9d000-0x0000000067ffefff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000067fff000-0x0000000067ffffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000068000000-0x00000000787fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x0000000e7fffffff] usable
[ 0.000000] efi: EFI v2.9 by American Megatrends
[ 0.000000] efi: ACPI=0x65edd000 ACPI 2.0=0x65edd014 TPMFinalLog=0x65eab000 SMBIOS=0x66acf000 SMBIOS 3.0=0x66ace000 MEMATTR=0x50711018 ESRT=0x58214518 INITRD=0x4f330718 RNG=0x65d21018 TPMEventLog=0x65d18018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem75: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xc0000000-0xcfffffff] reserved
[ 0.000000] efi: Not removing mem76: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[ 0.000000] efi: Not removing mem77: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem78: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem80: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem81: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[ 0.000000] SMBIOS 3.6.0 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. ASUS Vivobook Pro 15 N6506MV_N6506MV/N6506MV, BIOS N6506MV.311 02/25/2025
[ 0.000000] DMI: Memory slots populated: 2/2
[ 0.000000] tsc: Detected 3100.000 MHz processor
[ 0.000000] tsc: Detected 3072.000 MHz TSC
[ 0.000007] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000008] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000012] last_pfn = 0xe80000 max_arch_pfn = 0x400000000
[ 0.000017] MTRR map: 8 entries (3 fixed + 5 variable; max 23), built from 10 variable MTRRs
[ 0.000018] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000413] x2apic: enabled by BIOS, switching to x2apic ops
[ 0.000414] last_pfn = 0x68000 max_arch_pfn = 0x400000000
[ 0.004605] esrt: Reserving ESRT space from 0x0000000058214518 to 0x0000000058214668.
[ 0.004610] e820: update [mem 0x58214000-0x58214fff] usable ==> reserved
[ 0.004620] Using GB pages for direct mapping
[ 0.004738] Secure boot disabled
[ 0.004738] RAMDISK: [mem 0x41e98000-0x4682cfff]
[ 0.004816] ACPI: Early table checksum verification disabled
[ 0.004819] ACPI: RSDP 0x0000000065EDD014 000024 (v02 _ASUS_)
[ 0.004822] ACPI: XSDT 0x0000000065EDC728 00019C (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004826] ACPI: FACP 0x0000000065DEE000 000114 (v06 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004830] ACPI: DSDT 0x0000000065D6C000 081403 (v02 _ASUS_ Notebook 01072009 INTL 20210930)
[ 0.004831] ACPI: FACS 0x0000000065F8E000 000040
[ 0.004832] ACPI: SSDT 0x0000000065E09000 0006AA (v02 PmRef Cpu0Ist 00003000 INTL 20210930)
[ 0.004834] ACPI: SSDT 0x0000000065E08000 0005E4 (v02 PmRef Cpu0Hwp 00003000 INTL 20210930)
[ 0.004835] ACPI: SSDT 0x0000000065E07000 0001AB (v02 PmRef Cpu0Psd 00003000 INTL 20210930)
[ 0.004837] ACPI: SSDT 0x0000000065E06000 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20210930)
[ 0.004838] ACPI: SSDT 0x0000000065E04000 001BAF (v02 PmRef ApIst 00003000 INTL 20210930)
[ 0.004840] ACPI: SSDT 0x0000000065E02000 001620 (v02 PmRef ApHwp 00003000 INTL 20210930)
[ 0.004841] ACPI: SSDT 0x0000000065E00000 001349 (v02 PmRef ApPsd 00003000 INTL 20210930)
[ 0.004842] ACPI: SSDT 0x0000000065DFF000 000FBB (v02 PmRef ApCst 00003000 INTL 20210930)
[ 0.004844] ACPI: SSDT 0x0000000065DFB000 003BC8 (v02 CpuRef CpuSsdt 00003000 INTL 20210930)
[ 0.004845] ACPI: DTPR 0x0000000065DFA000 000088 (v01 00000000 00000000)
[ 0.004847] ACPI: SSDT 0x0000000065DF1000 008588 (v02 DptfTb DptfTabl 00001000 INTL 20210930)
[ 0.004848] ACPI: SSDT 0x0000000065DEF000 00108E (v02 INTEL PDatTabl 00001000 INTL 20210930)
[ 0.004850] ACPI: FIDT 0x0000000065D6B000 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.004851] ACPI: ECDT 0x0000000065D6A000 0000C1 (v01 OEM OEM 00000001 OEM. 00000003)
[ 0.004853] ACPI: MSDM 0x0000000065E0B000 000055 (v03 _ASUS_ Notebook 01072009 ASUS 00000001)
[ 0.004854] ACPI: SSDT 0x0000000065E0A000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20210930)
[ 0.004856] ACPI: SSDT 0x0000000065D67000 002494 (v02 INTEL IgfxSsdt 00003000 INTL 20210930)
[ 0.004857] ACPI: SSDT 0x0000000065D5D000 009B64 (v02 INTEL TcssSsdt 00001000 INTL 20210930)
[ 0.004858] ACPI: HPET 0x0000000065D5C000 000038 (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004860] ACPI: APIC 0x0000000065D5B000 000358 (v05 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004861] ACPI: MCFG 0x0000000065D5A000 00003C (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004863] ACPI: SSDT 0x0000000065D4A000 00F3C2 (v02 _ASUS_ MtlP_Rvp 00001000 INTL 20210930)
[ 0.004864] ACPI: SSDT 0x0000000065D48000 00147F (v02 _ASUS_ I2Pm_Rvp 00001000 INTL 20210930)
[ 0.004865] ACPI: SSDT 0x0000000065D44000 00389C (v02 _ASUS_ Ther_Rvp 00001000 INTL 20210930)
[ 0.004867] ACPI: UEFI 0x0000000065E92000 000048 (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004868] ACPI: NHLT 0x0000000065D43000 000960 (v00 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004870] ACPI: LPIT 0x0000000065D42000 0000CC (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004871] ACPI: SSDT 0x0000000065D40000 000CA6 (v02 _ASUS_ PtidDevc 00001000 INTL 20210930)
[ 0.004872] ACPI: SSDT 0x0000000065D3A000 005E42 (v02 _ASUS_ TbtTypeC 00000000 INTL 20210930)
[ 0.004874] ACPI: DBGP 0x0000000065D39000 000034 (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004875] ACPI: DBG2 0x0000000065D38000 000054 (v00 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004877] ACPI: SSDT 0x0000000065D36000 00190E (v02 _ASUS_ UsbCTabl 00001000 INTL 20210930)
[ 0.004878] ACPI: DMAR 0x0000000065D35000 000098 (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.004879] ACPI: FPDT 0x0000000065D34000 000044 (v01 _ASUS_ A M I 01072009 AMI 01000013)
[ 0.004881] ACPI: SSDT 0x0000000065D32000 00104C (v02 INTEL xh_mtlpR 00000000 INTL 20210930)
[ 0.004882] ACPI: SSDT 0x0000000065D2F000 00281A (v02 SocGpe SocGpe 00003000 INTL 20210930)
[ 0.004884] ACPI: SSDT 0x0000000065D2C000 0028D3 (v02 SocCmn SocCmn 00003000 INTL 20210930)
[ 0.004885] ACPI: SDEV 0x0000000065D2B000 0000BA (v01 00000000 00000000)
[ 0.004886] ACPI: BGRT 0x0000000065D2A000 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.004888] ACPI: UEFI 0x0000000065E8E000 00063A (v01 INTEL RstVmdE 00000000 INTL 00000000)
[ 0.004889] ACPI: UEFI 0x0000000065E8D000 00005C (v01 INTEL RstVmdV 00000000 INTL 00000000)
[ 0.004891] ACPI: SSDT 0x0000000065D28000 0011A0 (v02 INTEL St00Ssdt 00001000 INTL 20210930)
[ 0.004892] ACPI: SSDT 0x0000000065D24000 003461 (v02 OptRf1 Opt1Tabl 00001000 INTL 20210930)
[ 0.004893] ACPI: PHAT 0x0000000065D23000 0005C5 (v01 _ASUS_ Notebook 00000005 MSFT 0100000D)
[ 0.004895] ACPI: TPM2 0x0000000065D22000 00004C (v04 _ASUS_ Notebook 00000001 AMI 00000000)
[ 0.004896] ACPI: WSMT 0x0000000065D41000 000028 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.004897] ACPI: Reserving FACP table memory at [mem 0x65dee000-0x65dee113]
[ 0.004898] ACPI: Reserving DSDT table memory at [mem 0x65d6c000-0x65ded402]
[ 0.004898] ACPI: Reserving FACS table memory at [mem 0x65f8e000-0x65f8e03f]
[ 0.004899] ACPI: Reserving SSDT table memory at [mem 0x65e09000-0x65e096a9]
[ 0.004899] ACPI: Reserving SSDT table memory at [mem 0x65e08000-0x65e085e3]
[ 0.004899] ACPI: Reserving SSDT table memory at [mem 0x65e07000-0x65e071aa]
[ 0.004900] ACPI: Reserving SSDT table memory at [mem 0x65e06000-0x65e06393]
[ 0.004900] ACPI: Reserving SSDT table memory at [mem 0x65e04000-0x65e05bae]
[ 0.004901] ACPI: Reserving SSDT table memory at [mem 0x65e02000-0x65e0361f]
[ 0.004901] ACPI: Reserving SSDT table memory at [mem 0x65e00000-0x65e01348]
[ 0.004901] ACPI: Reserving SSDT table memory at [mem 0x65dff000-0x65dfffba]
[ 0.004902] ACPI: Reserving SSDT table memory at [mem 0x65dfb000-0x65dfebc7]
[ 0.004902] ACPI: Reserving DTPR table memory at [mem 0x65dfa000-0x65dfa087]
[ 0.004902] ACPI: Reserving SSDT table memory at [mem 0x65df1000-0x65df9587]
[ 0.004903] ACPI: Reserving SSDT table memory at [mem 0x65def000-0x65df008d]
[ 0.004903] ACPI: Reserving FIDT table memory at [mem 0x65d6b000-0x65d6b09b]
[ 0.004904] ACPI: Reserving ECDT table memory at [mem 0x65d6a000-0x65d6a0c0]
[ 0.004904] ACPI: Reserving MSDM table memory at [mem 0x65e0b000-0x65e0b054]
[ 0.004905] ACPI: Reserving SSDT table memory at [mem 0x65e0a000-0x65e0a38b]
[ 0.004905] ACPI: Reserving SSDT table memory at [mem 0x65d67000-0x65d69493]
[ 0.004906] ACPI: Reserving SSDT table memory at [mem 0x65d5d000-0x65d66b63]
[ 0.004906] ACPI: Reserving HPET table memory at [mem 0x65d5c000-0x65d5c037]
[ 0.004906] ACPI: Reserving APIC table memory at [mem 0x65d5b000-0x65d5b357]
[ 0.004907] ACPI: Reserving MCFG table memory at [mem 0x65d5a000-0x65d5a03b]
[ 0.004907] ACPI: Reserving SSDT table memory at [mem 0x65d4a000-0x65d593c1]
[ 0.004907] ACPI: Reserving SSDT table memory at [mem 0x65d48000-0x65d4947e]
[ 0.004908] ACPI: Reserving SSDT table memory at [mem 0x65d44000-0x65d4789b]
[ 0.004908] ACPI: Reserving UEFI table memory at [mem 0x65e92000-0x65e92047]
[ 0.004908] ACPI: Reserving NHLT table memory at [mem 0x65d43000-0x65d4395f]
[ 0.004909] ACPI: Reserving LPIT table memory at [mem 0x65d42000-0x65d420cb]
[ 0.004909] ACPI: Reserving SSDT table memory at [mem 0x65d40000-0x65d40ca5]
[ 0.004910] ACPI: Reserving SSDT table memory at [mem 0x65d3a000-0x65d3fe41]
[ 0.004910] ACPI: Reserving DBGP table memory at [mem 0x65d39000-0x65d39033]
[ 0.004910] ACPI: Reserving DBG2 table memory at [mem 0x65d38000-0x65d38053]
[ 0.004911] ACPI: Reserving SSDT table memory at [mem 0x65d36000-0x65d3790d]
[ 0.004911] ACPI: Reserving DMAR table memory at [mem 0x65d35000-0x65d35097]
[ 0.004912] ACPI: Reserving FPDT table memory at [mem 0x65d34000-0x65d34043]
[ 0.004912] ACPI: Reserving SSDT table memory at [mem 0x65d32000-0x65d3304b]
[ 0.004912] ACPI: Reserving SSDT table memory at [mem 0x65d2f000-0x65d31819]
[ 0.004913] ACPI: Reserving SSDT table memory at [mem 0x65d2c000-0x65d2e8d2]
[ 0.004913] ACPI: Reserving SDEV table memory at [mem 0x65d2b000-0x65d2b0b9]
[ 0.004914] ACPI: Reserving BGRT table memory at [mem 0x65d2a000-0x65d2a037]
[ 0.004914] ACPI: Reserving UEFI table memory at [mem 0x65e8e000-0x65e8e639]
[ 0.004915] ACPI: Reserving UEFI table memory at [mem 0x65e8d000-0x65e8d05b]
[ 0.004915] ACPI: Reserving SSDT table memory at [mem 0x65d28000-0x65d2919f]
[ 0.004915] ACPI: Reserving SSDT table memory at [mem 0x65d24000-0x65d27460]
[ 0.004916] ACPI: Reserving PHAT table memory at [mem 0x65d23000-0x65d235c4]
[ 0.004916] ACPI: Reserving TPM2 table memory at [mem 0x65d22000-0x65d2204b]
[ 0.004916] ACPI: Reserving WSMT table memory at [mem 0x65d41000-0x65d41027]
[ 0.004952] APIC: Switched APIC routing to: cluster x2apic
[ 0.005148] No NUMA configuration found
[ 0.005149] Faking a node at [mem 0x0000000000000000-0x0000000e7fffffff]
[ 0.005153] NODE_DATA(0) allocated [mem 0xe7ffd52c0-0xe7fffffff]
[ 0.005308] Zone ranges:
[ 0.005309] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.005310] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.005311] Normal [mem 0x0000000100000000-0x0000000e7fffffff]
[ 0.005312] Device empty
[ 0.005312] Movable zone start for each node
[ 0.005313] Early memory node ranges
[ 0.005313] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.005314] node 0: [mem 0x0000000000100000-0x000000005bd09fff]
[ 0.005315] node 0: [mem 0x0000000067fff000-0x0000000067ffffff]
[ 0.005315] node 0: [mem 0x0000000100000000-0x0000000e7fffffff]
[ 0.005319] Initmem setup node 0 [mem 0x0000000000001000-0x0000000e7fffffff]
[ 0.005322] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005340] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.007359] On node 0, zone DMA32: 49909 pages in unavailable ranges
[ 0.079818] ACPI: PM-Timer IO Port: 0x1808
[ 0.079827] ACPI: X2APIC_NMI (uid[0xffffffff] high level lint[0x1])
[ 0.079861] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.079863] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.079864] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.079867] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.079868] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.079876] e820: update [mem 0x504cf000-0x5051bfff] usable ==> reserved
[ 0.079887] TSC deadline timer available
[ 0.079890] CPU topo: Max. logical packages: 1
[ 0.079891] CPU topo: Max. logical dies: 1
[ 0.079891] CPU topo: Max. dies per package: 1
[ 0.079893] CPU topo: Max. threads per core: 2
[ 0.079894] CPU topo: Num. cores per package: 16
[ 0.079895] CPU topo: Num. threads per package: 22
[ 0.079895] CPU topo: Allowing 22 present CPUs plus 0 hotplug CPUs
[ 0.079911] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.079914] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.079916] PM: hibernation: Registered nosave memory: [mem 0x504cf000-0x5051bfff]
[ 0.079917] PM: hibernation: Registered nosave memory: [mem 0x58214000-0x58214fff]
[ 0.079918] PM: hibernation: Registered nosave memory: [mem 0x5bd0a000-0x67ffefff]
[ 0.079920] PM: hibernation: Registered nosave memory: [mem 0x68000000-0xffffffff]
[ 0.079921] [mem 0x78800000-0xfdffffff] available for PCI devices
[ 0.079922] Booting paravirtualized kernel on bare hardware
[ 0.079924] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.083708] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:22 nr_cpu_ids:22 nr_node_ids:1
[ 0.085032] percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
[ 0.085036] pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
[ 0.085037] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[ 0.085040] pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
[ 0.085042] pcpu-alloc: [0] 16 17 18 19 [0] 20 21 -- --
[ 0.085056] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64 root=UUID=a99d8bbc-b8cc-48fc-959e-3901264c7abb rw rootflags=subvol=@ quiet splash udev.log_priority=3
[ 0.085106] Unknown kernel command line parameters "splash BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64", will be passed to user space.
[ 0.085116] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.085117] printk: log_buf_len total cpu_extra contributions: 86016 bytes
[ 0.085117] printk: log_buf_len min size: 131072 bytes
[ 0.085275] printk: log_buf_len: 262144 bytes
[ 0.085276] printk: early log buf free: 113640(86%)
[ 0.090668] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.093369] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.093518] Fallback order for Node 0: 0
[ 0.093522] Built 1 zonelists, mobility grouping on. Total pages: 14531753
[ 0.093523] Policy zone: Normal
[ 0.093726] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.093735] software IO TLB: area num 32.
[ 0.168663] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=22, Nodes=1
[ 0.168712] ftrace: allocating 51430 entries in 201 pages
[ 0.174921] ftrace: allocated 201 pages with 4 groups
[ 0.175000] Dynamic Preempt: full
[ 0.175065] rcu: Preemptible hierarchical RCU implementation.
[ 0.175065] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=22.
[ 0.175066] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.175067] Trampoline variant of Tasks RCU enabled.
[ 0.175067] Rude variant of Tasks RCU enabled.
[ 0.175067] Tracing variant of Tasks RCU enabled.
[ 0.175068] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.175068] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=22
[ 0.175081] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=22.
[ 0.175083] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=22.
[ 0.175085] RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=22.
[ 0.177721] NR_IRQS: 524544, nr_irqs: 2232, preallocated irqs: 16
[ 0.178017] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.178250] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.178290] Console: colour dummy device 80x25
[ 0.178292] printk: legacy console [tty0] enabled
[ 0.178329] ACPI: Core revision 20240827
[ 0.178654] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.178747] APIC: Switch to symmetric I/O mode setup
[ 0.178749] DMAR: Host address width 42
[ 0.178750] DMAR: DRHD base: 0x000000fc800000 flags: 0x0
[ 0.178756] DMAR: dmar0: reg_base_addr fc800000 ver 7:0 cap c9de008cee690462 ecap 12ca9a00f0ef5e
[ 0.178758] DMAR: DRHD base: 0x000000fc801000 flags: 0x1
[ 0.178762] DMAR: dmar1: reg_base_addr fc801000 ver 7:0 cap c9de008cee690462 ecap 12ca9a00f0efde
[ 0.178763] DMAR: SATC flags: 0x1
[ 0.178765] DMAR-IR: IOAPIC id 2 under DRHD base 0xfc801000 IOMMU 1
[ 0.178766] DMAR-IR: HPET id 0 under DRHD base 0xfc801000
[ 0.178766] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.180365] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.184481] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2c47f5688fc, max_idle_ns: 440795305069 ns
[ 0.184488] Calibrating delay loop (skipped), value calculated using timer frequency.. 6146.00 BogoMIPS (lpj=10240000)
[ 0.184537] CPU0: Thermal monitoring enabled (TM1)
[ 0.184538] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.184703] CET detected: Indirect Branch Tracking enabled
[ 0.184704] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.184705] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.184707] process: using mwait in idle threads
[ 0.184709] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.184710] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.184711] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.184713] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.184721] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.184721] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.184722] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.184722] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.184723] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[ 0.184723] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.184724] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.184725] x86/fpu: xstate_offset[11]: 840, xstate_sizes[11]: 16
[ 0.184725] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
[ 0.187819] Freeing SMP alternatives memory: 40K
[ 0.187819] pid_max: default: 32768 minimum: 301
[ 0.187819] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[ 0.187819] landlock: Up and running.
[ 0.187819] Yama: becoming mindful.
[ 0.187819] LSM support for eBPF active
[ 0.187819] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.187819] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.187819] smpboot: CPU0: Intel(R) Core(TM) Ultra 9 185H (family: 0x6, model: 0xaa, stepping: 0x4)
[ 0.187819] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline, AnyThread deprecated, Meteorlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.187819] core: cpu_core PMU driver:
[ 0.187819] ... version: 5
[ 0.187819] ... bit width: 48
[ 0.187819] ... generic registers: 8
[ 0.187819] ... value mask: 0000ffffffffffff
[ 0.187819] ... max period: 00007fffffffffff
[ 0.187819] ... fixed-purpose events: 4
[ 0.187819] ... event mask: 0001000f000000ff
[ 0.187819] signal: max sigframe size: 3632
[ 0.187819] Estimated ratio of average max frequency by base frequency (times 1024): 1684
[ 0.187819] rcu: Hierarchical SRCU implementation.
[ 0.187819] rcu: Max phase no-delay instances is 1000.
[ 0.187819] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[ 0.187819] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.187819] smp: Bringing up secondary CPUs ...
[ 0.187819] smpboot: x86: Booting SMP configuration:
[ 0.187819] .... node #0, CPUs: #1 #3 #6 #8 #10 #12 #13 #14 #15 #16 #17 #18 #19 #20 #21
[ 0.009669] core: cpu_atom PMU driver:
[ 0.009669] ... version: 5
[ 0.009669] ... bit width: 48
[ 0.009669] ... generic registers: 8
[ 0.009669] ... value mask: 0000ffffffffffff
[ 0.009669] ... max period: 00007fffffffffff
[ 0.009669] ... fixed-purpose events: 3
[ 0.009669] ... event mask: 00000007000000ff
[ 0.191253] #2 #4 #5 #7 #9 #11
[ 0.195910] smp: Brought up 1 node, 22 CPUs
[ 0.195910] smpboot: Total of 22 processors activated (135222.00 BogoMIPS)
[ 0.197941] Memory: 56878896K/58127012K available (18432K kernel code, 2672K rwdata, 14348K rodata, 4284K init, 4280K bss, 1213464K reserved, 0K cma-reserved)
[ 0.199117] devtmpfs: initialized
[ 0.199117] x86/mm: Memory block size: 128MB
[ 0.201238] ACPI: PM: Registering ACPI NVS region [mem 0x65e0c000-0x65f9cfff] (1642496 bytes)
[ 0.201238] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.201241] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.201298] pinctrl core: initialized pinctrl subsystem
[ 0.201467] PM: RTC time: 16:09:34, date: 2025-07-25
[ 0.201784] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.202180] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.202487] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.202806] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.202811] audit: initializing netlink subsys (disabled)
[ 0.202816] audit: type=2000 audit(1753459774.000:1): state=initialized audit_enabled=0 res=1
[ 0.202816] thermal_sys: Registered thermal governor 'fair_share'
[ 0.202816] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.202816] thermal_sys: Registered thermal governor 'step_wise'
[ 0.202816] thermal_sys: Registered thermal governor 'user_space'
[ 0.202816] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.202816] cpuidle: using governor ladder
[ 0.202816] cpuidle: using governor menu
[ 0.202816] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.202816] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.202816] PCI: ECAM [mem 0xc0000000-0xcdffffff] (base 0xc0000000) for domain 0000 [bus 00-df]
[ 0.202816] PCI: Using configuration type 1 for base access
[ 0.202816] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.202816] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.202816] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.202816] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.202816] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.202816] ACPI: Added _OSI(Module Device)
[ 0.202816] ACPI: Added _OSI(Processor Device)
[ 0.202816] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.277630] ACPI: 26 ACPI AML tables successfully acquired and loaded
[ 0.279089] ACPI: EC: EC started
[ 0.279091] ACPI: EC: interrupt blocked
[ 0.279695] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.279696] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.308319] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.308322] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.314383] ACPI: Interpreter enabled
[ 0.314445] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.314446] ACPI: Using IOAPIC for interrupt routing
[ 0.315641] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.315642] PCI: Ignoring E820 reservations for host bridge windows
[ 0.318059] ACPI: Enabled 11 GPEs in block 00 to 7F
[ 0.318098] ACPI: Enabled 8 GPEs in block 80 to DF
[ 0.324849] ACPI: \_SB_.PC00.RP06.PXP_: New power resource
[ 0.327892] ACPI: \_SB_.PC00.RP07.PXP_: New power resource
[ 0.328142] ACPI: \_SB_.PC00.RP08.PXP_: New power resource
[ 0.331421] ACPI: \_SB_.PC00.RP08.PXSX.WRST: New power resource
[ 0.331621] ACPI: \_SB_.PC00.RP10.PXP_: New power resource
[ 0.331621] ACPI: \_SB_.PC00.RP11.PXP_: New power resource
[ 0.334712] ACPI: \_SB_.PC00.RP12.PXP_: New power resource
[ 0.353286] ACPI: \_SB_.PC00.XHCI.RHUB.HS10.BTRT: New power resource
[ 0.353337] ACPI: \_SB_.PC00.XHCI.RHUB.HS10.DBTR: New power resource
[ 0.353551] ACPI: \_SB_.PC00.PAUD: New power resource
[ 0.357136] ACPI: \_SB_.PC00.I2C3.PXTC: New power resource
[ 0.380509] ACPI: \_SB_.PC00.TBT0: New power resource
[ 0.380564] ACPI: \_SB_.PC00.TBT1: New power resource
[ 0.380615] ACPI: \_SB_.PC00.D3C_: New power resource
[ 0.395834] ACPI: \_TZ_.FN00: New power resource
[ 0.395888] ACPI: \_TZ_.FN01: New power resource
[ 0.395935] ACPI: \_TZ_.FN02: New power resource
[ 0.395981] ACPI: \_TZ_.FN03: New power resource
[ 0.396027] ACPI: \_TZ_.FN04: New power resource
[ 0.396494] ACPI: \PIN_: New power resource
[ 0.396985] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-df])
[ 0.396991] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.397772] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.399304] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[ 0.399305] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.401099] PCI host bridge to bus 0000:00
[ 0.401102] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.401104] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.401105] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.401106] pci_bus 0000:00: root bus resource [mem 0x80000000-0xbfffffff window]
[ 0.401107] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x3ffbfffffff window]
[ 0.401108] pci_bus 0000:00: root bus resource [bus 00-df]
[ 0.712534] pci 0000:00:00.0: [8086:7d01] type 00 class 0x060000 conventional PCI endpoint
[ 0.712680] pci 0000:00:01.0: [8086:7ecc] type 01 class 0x060400 PCIe Root Port
[ 0.712699] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.712703] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.712705] pci 0000:00:01.0: bridge window [mem 0x87000000-0x880fffff]
[ 0.712712] pci 0000:00:01.0: bridge window [mem 0x4000000000-0x4201ffffff 64bit pref]
[ 0.712768] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.712799] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[ 0.713580] pci 0000:00:02.0: [8086:7d55] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[ 0.713592] pci 0000:00:02.0: BAR 0 [mem 0x4a20000000-0x4a20ffffff 64bit pref]
[ 0.713600] pci 0000:00:02.0: BAR 2 [mem 0x4210000000-0x421fffffff 64bit pref]
[ 0.713628] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[ 0.713631] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.713663] pci 0000:00:02.0: PME# supported from D0 D3hot
[ 0.713679] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit pref]
[ 0.713680] pci 0000:00:02.0: VF BAR 0 [mem 0x00000000-0x06ffffff 64bit pref]: contains BAR 0 for 7 VFs
[ 0.713874] pci 0000:00:04.0: [8086:7d03] type 00 class 0x118000 conventional PCI endpoint
[ 0.713888] pci 0000:00:04.0: BAR 0 [mem 0x4a33280000-0x4a3329ffff 64bit]
[ 0.714220] pci 0000:00:07.0: [8086:7ec4] type 01 class 0x060400 PCIe Root Port
[ 0.714245] pci 0000:00:07.0: PCI bridge to [bus 02-2b]
[ 0.714250] pci 0000:00:07.0: bridge window [mem 0x80000000-0x85ffffff]
[ 0.714263] pci 0000:00:07.0: bridge window [mem 0x4220000000-0x4a1fffffff 64bit pref]
[ 0.714363] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.714394] pci 0000:00:07.0: PTM enabled (root), 4ns granularity
[ 0.715295] pci 0000:00:08.0: [8086:7e4c] type 00 class 0x088000 conventional PCI endpoint
[ 0.715311] pci 0000:00:08.0: BAR 0 [mem 0x4a332e0000-0x4a332e0fff 64bit]
[ 0.715418] pci 0000:00:0a.0: [8086:7d0d] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
[ 0.715425] pci 0000:00:0a.0: BAR 0 [mem 0x4a33240000-0x4a3327ffff 64bit]
[ 0.715439] pci 0000:00:0a.0: enabling Extended Tags
[ 0.715503] pci 0000:00:0b.0: [8086:7d1d] type 00 class 0x120000 PCIe Root Complex Integrated Endpoint
[ 0.715512] pci 0000:00:0b.0: BAR 0 [mem 0x4a28000000-0x4a2fffffff 64bit]
[ 0.715523] pci 0000:00:0b.0: BAR 4 [mem 0x4a332df000-0x4a332dffff 64bit]
[ 0.715637] pci 0000:00:0d.0: [8086:7ec0] type 00 class 0x0c0330 conventional PCI endpoint
[ 0.715651] pci 0000:00:0d.0: BAR 0 [mem 0x4a332c0000-0x4a332cffff 64bit]
[ 0.715708] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[ 0.716203] pci 0000:00:0d.2: [8086:7ec2] type 00 class 0x0c0340 conventional PCI endpoint
[ 0.716216] pci 0000:00:0d.2: BAR 0 [mem 0x4a33200000-0x4a3323ffff 64bit]
[ 0.716225] pci 0000:00:0d.2: BAR 2 [mem 0x4a332de000-0x4a332defff 64bit]
[ 0.716266] pci 0000:00:0d.2: supports D1 D2
[ 0.716267] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.716412] pci 0000:00:0e.0: [8086:7d0b] type 00 class 0x010400 PCIe Root Complex Integrated Endpoint
[ 0.716427] pci 0000:00:0e.0: BAR 0 [mem 0x4a30000000-0x4a31ffffff 64bit]
[ 0.716434] pci 0000:00:0e.0: BAR 2 [mem 0x86000000-0x86ffffff]
[ 0.716450] pci 0000:00:0e.0: BAR 4 [mem 0x4a32000000-0x4a32ffffff 64bit]
[ 0.716625] pci 0000:00:12.0: [8086:7e45] type 00 class 0x070000 conventional PCI endpoint
[ 0.716637] pci 0000:00:12.0: BAR 0 [mem 0x4a332b0000-0x4a332bffff 64bit]
[ 0.716680] pci 0000:00:12.0: PME# supported from D0 D3hot
[ 0.717417] pci 0000:00:14.0: [8086:7e7d] type 00 class 0x0c0330 conventional PCI endpoint
[ 0.717431] pci 0000:00:14.0: BAR 0 [mem 0x4a332a0000-0x4a332affff 64bit]
[ 0.717486] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.717993] pci 0000:00:14.2: [8086:7e7f] type 00 class 0x050000 conventional PCI endpoint
[ 0.718009] pci 0000:00:14.2: BAR 0 [mem 0x4a332d4000-0x4a332d7fff 64bit]
[ 0.718020] pci 0000:00:14.2: BAR 2 [mem 0x4a332dd000-0x4a332ddfff 64bit]
[ 0.718174] pci 0000:00:15.0: [8086:7e78] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.718198] pci 0000:00:15.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.718595] pci 0000:00:15.1: [8086:7e79] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.718615] pci 0000:00:15.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.718976] pci 0000:00:16.0: [8086:7e70] type 00 class 0x078000 conventional PCI endpoint
[ 0.718999] pci 0000:00:16.0: BAR 0 [mem 0x4a332da000-0x4a332dafff 64bit]
[ 0.719088] pci 0000:00:16.0: PME# supported from D3hot
[ 0.719870] pci 0000:00:19.0: [8086:7e50] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.719889] pci 0000:00:19.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.720259] pci 0000:00:1c.0: [8086:7e3d] type 01 class 0x060400 PCIe Root Port
[ 0.720279] pci 0000:00:1c.0: PCI bridge to [bus 2c]
[ 0.720283] pci 0000:00:1c.0: bridge window [mem 0x88400000-0x884fffff]
[ 0.720345] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.720375] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ 0.721149] pci 0000:00:1c.6: [8086:7e3e] type 01 class 0x060400 PCIe Root Port
[ 0.721168] pci 0000:00:1c.6: PCI bridge to [bus 2d]
[ 0.721171] pci 0000:00:1c.6: bridge window [io 0x3000-0x3fff]
[ 0.721174] pci 0000:00:1c.6: bridge window [mem 0x88300000-0x883fffff]
[ 0.721234] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.721263] pci 0000:00:1c.6: PTM enabled (root), 4ns granularity
[ 0.722014] pci 0000:00:1c.7: [8086:7e3f] type 01 class 0x060400 PCIe Root Port
[ 0.722034] pci 0000:00:1c.7: PCI bridge to [bus 2e]
[ 0.722038] pci 0000:00:1c.7: bridge window [mem 0x88200000-0x882fffff]
[ 0.722098] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 0.722128] pci 0000:00:1c.7: PTM enabled (root), 4ns granularity
[ 0.722894] pci 0000:00:1f.0: [8086:7e02] type 00 class 0x060100 conventional PCI endpoint
[ 0.723328] pci 0000:00:1f.3: [8086:7e28] type 00 class 0x040100 conventional PCI endpoint
[ 0.723351] pci 0000:00:1f.3: BAR 0 [mem 0x4a332d0000-0x4a332d3fff 64bit]
[ 0.723382] pci 0000:00:1f.3: BAR 4 [mem 0x4a33000000-0x4a331fffff 64bit]
[ 0.723457] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.723525] pci 0000:00:1f.4: [8086:7e22] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.723544] pci 0000:00:1f.4: BAR 0 [mem 0x4a332d8000-0x4a332d80ff 64bit]
[ 0.723568] pci 0000:00:1f.4: BAR 4 [io 0xefa0-0xefbf]
[ 0.723839] pci 0000:00:1f.5: [8086:7e23] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.723877] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[ 0.724058] acpiphp: Slot [1] registered
[ 0.724072] pci 0000:01:00.0: [10de:28a0] type 00 class 0x030000 PCIe Legacy Endpoint
[ 0.724082] pci 0000:01:00.0: BAR 0 [mem 0x87000000-0x87ffffff]
[ 0.724090] pci 0000:01:00.0: BAR 1 [mem 0x4000000000-0x41ffffffff 64bit pref]
[ 0.724098] pci 0000:01:00.0: BAR 3 [mem 0x4200000000-0x4201ffffff 64bit pref]
[ 0.724102] pci 0000:01:00.0: BAR 5 [io 0x4000-0x407f]
[ 0.724107] pci 0000:01:00.0: ROM [mem 0x88000000-0x8807ffff pref]
[ 0.724167] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.724539] pci 0000:01:00.1: [10de:22be] type 00 class 0x040300 PCIe Endpoint
[ 0.724549] pci 0000:01:00.1: BAR 0 [mem 0x88080000-0x88083fff]
[ 0.724678] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.724723] pci 0000:00:07.0: PCI bridge to [bus 02-2b]
[ 0.724820] pci 0000:2c:00.0: [17a0:9755] type 00 class 0xff0000 PCIe Endpoint
[ 0.724847] pci 0000:2c:00.0: BAR 0 [mem 0x88400000-0x88400fff]
[ 0.725046] pci 0000:2c:00.0: supports D1 D2
[ 0.725047] pci 0000:2c:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.725371] pci 0000:00:1c.0: PCI bridge to [bus 2c]
[ 0.725426] pci 0000:2d:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 0.725445] pci 0000:2d:00.0: BAR 0 [io 0x3000-0x30ff]
[ 0.725471] pci 0000:2d:00.0: BAR 2 [mem 0x88304000-0x88304fff 64bit]
[ 0.725487] pci 0000:2d:00.0: BAR 4 [mem 0x88300000-0x88303fff 64bit]
[ 0.725593] pci 0000:2d:00.0: supports D1 D2
[ 0.725594] pci 0000:2d:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.725800] pci 0000:00:1c.6: PCI bridge to [bus 2d]
[ 0.726001] pci 0000:2e:00.0: [8086:2725] type 00 class 0x028000 PCIe Endpoint
[ 0.726102] pci 0000:2e:00.0: BAR 0 [mem 0x88200000-0x88203fff 64bit]
[ 0.726305] pci 0000:2e:00.0: PME# supported from D0 D3hot D3cold
[ 0.728445] pci 0000:00:1c.7: PCI bridge to [bus 2e]
[ 0.733552] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.733682] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.733808] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.733934] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.734059] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.734185] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.734311] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.734436] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.735330] ACPI: \_SB_.PEPD: Duplicate LPS0 _DSM functions (mask: 0x1)
[ 0.863429] Low-power S0 idle used by default for system suspend
[ 0.873306] ACPI: EC: interrupt unblocked
[ 0.873308] ACPI: EC: event unblocked
[ 0.873332] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.873333] ACPI: EC: GPE=0x6e
[ 0.873334] ACPI: \_SB_.PC00.LPCB.EC0_: Boot ECDT EC initialization complete
[ 0.873335] ACPI: \_SB_.PC00.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.873424] iommu: Default domain type: Translated
[ 0.873424] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.873424] SCSI subsystem initialized
[ 0.873424] libata version 3.00 loaded.
[ 0.873424] ACPI: bus type USB registered
[ 0.873424] usbcore: registered new interface driver usbfs
[ 0.873424] usbcore: registered new interface driver hub
[ 0.873424] usbcore: registered new device driver usb
[ 0.873424] EDAC MC: Ver: 3.0.0
[ 0.873424] efivars: Registered efivars operations
[ 0.873424] NetLabel: Initializing
[ 0.873424] NetLabel: domain hash size = 128
[ 0.873424] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.873424] NetLabel: unlabeled traffic allowed by default
[ 0.873424] mctp: management component transport protocol core
[ 0.873424] NET: Registered PF_MCTP protocol family
[ 0.873424] PCI: Using ACPI for IRQ routing
[ 0.884507] PCI: pci_cache_line_size set to 64 bytes
[ 0.884788] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can't claim; no compatible bridge window
[ 0.885061] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.885063] e820: reserve RAM buffer [mem 0x4f200018-0x4fffffff]
[ 0.885064] e820: reserve RAM buffer [mem 0x504cf000-0x53ffffff]
[ 0.885064] e820: reserve RAM buffer [mem 0x58214000-0x5bffffff]
[ 0.885065] e820: reserve RAM buffer [mem 0x5bd0a000-0x5bffffff]
[ 0.885092] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.885092] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.885092] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.885092] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.885092] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.885092] vgaarb: loaded
[ 0.885092] clocksource: Switched to clocksource tsc-early
[ 0.885092] VFS: Disk quotas dquot_6.6.0
[ 0.885092] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.885092] pnp: PnP ACPI init
[ 0.885092] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.885092] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.885092] system 00:01: [io 0x1854-0x1857] has been reserved
[ 0.886097] pnp 00:02: disabling [mem 0x00000000-0x00000fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
[ 0.886100] pnp 00:02: disabling [mem 0x00000000-0x00000fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
[ 0.886121] system 00:02: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.886122] system 00:02: [mem 0xc0000000-0xcfffffff] has been reserved
[ 0.886124] system 00:02: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 0.886125] system 00:02: [mem 0xfc800000-0xfc81ffff] could not be reserved
[ 0.886126] system 00:02: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.886127] system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.887530] system 00:04: [io 0x2000-0x20fe] has been reserved
[ 0.888343] pnp: PnP ACPI: found 6 devices
[ 0.893711] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.893765] NET: Registered PF_INET protocol family
[ 0.893999] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.905895] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.906085] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.906499] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.907071] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.907161] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.907441] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 0.907813] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.908006] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.908112] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.908119] NET: Registered PF_XDP protocol family
[ 0.908125] pci 0000:00:07.0: bridge window [io 0x1000-0x0fff] to [bus 02-2b] add_size 1000
[ 0.908137] pci 0000:00:02.0: VF BAR 0 [mem 0x4202000000-0x4208ffffff 64bit pref]: assigned
[ 0.908142] pci 0000:00:07.0: bridge window [io 0x5000-0x5fff]: assigned
[ 0.908143] pci 0000:00:15.0: BAR 0 [mem 0x4209000000-0x4209000fff 64bit]: assigned
[ 0.908181] pci 0000:00:15.1: BAR 0 [mem 0x4209001000-0x4209001fff 64bit]: assigned
[ 0.908193] pci 0000:00:19.0: BAR 0 [mem 0x4209002000-0x4209002fff 64bit]: assigned
[ 0.908205] pci 0000:00:1f.5: BAR 0 [mem 0x88100000-0x88100fff]: assigned
[ 0.908215] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.908218] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.908221] pci 0000:00:01.0: bridge window [mem 0x87000000-0x880fffff]
[ 0.908223] pci 0000:00:01.0: bridge window [mem 0x4000000000-0x4201ffffff 64bit pref]
[ 0.908227] pci 0000:00:07.0: PCI bridge to [bus 02-2b]
[ 0.908233] pci 0000:00:07.0: bridge window [io 0x5000-0x5fff]
[ 0.908236] pci 0000:00:07.0: bridge window [mem 0x80000000-0x85ffffff]
[ 0.908239] pci 0000:00:07.0: bridge window [mem 0x4220000000-0x4a1fffffff 64bit pref]
[ 0.908244] pci 0000:00:1c.0: PCI bridge to [bus 2c]
[ 0.908247] pci 0000:00:1c.0: bridge window [mem 0x88400000-0x884fffff]
[ 0.908252] pci 0000:00:1c.6: PCI bridge to [bus 2d]
[ 0.908254] pci 0000:00:1c.6: bridge window [io 0x3000-0x3fff]
[ 0.908256] pci 0000:00:1c.6: bridge window [mem 0x88300000-0x883fffff]
[ 0.908262] pci 0000:00:1c.7: PCI bridge to [bus 2e]
[ 0.908265] pci 0000:00:1c.7: bridge window [mem 0x88200000-0x882fffff]
[ 0.908270] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.908271] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.908272] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.908273] pci_bus 0000:00: resource 7 [mem 0x80000000-0xbfffffff window]
[ 0.908274] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x3ffbfffffff window]
[ 0.908276] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.908277] pci_bus 0000:01: resource 1 [mem 0x87000000-0x880fffff]
[ 0.908278] pci_bus 0000:01: resource 2 [mem 0x4000000000-0x4201ffffff 64bit pref]
[ 0.908279] pci_bus 0000:02: resource 0 [io 0x5000-0x5fff]
[ 0.908280] pci_bus 0000:02: resource 1 [mem 0x80000000-0x85ffffff]
[ 0.908281] pci_bus 0000:02: resource 2 [mem 0x4220000000-0x4a1fffffff 64bit pref]
[ 0.908282] pci_bus 0000:2c: resource 1 [mem 0x88400000-0x884fffff]
[ 0.908283] pci_bus 0000:2d: resource 0 [io 0x3000-0x3fff]
[ 0.908284] pci_bus 0000:2d: resource 1 [mem 0x88300000-0x883fffff]
[ 0.908285] pci_bus 0000:2e: resource 1 [mem 0x88200000-0x882fffff]
[ 0.908846] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.908870] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.908910] pci 0000:00:1c.0: mask Replay Timer Timeout Correctable Errors due to 0000:2c:00.0 hardware defect
[ 0.909092] PCI: CLS 64 bytes, default 64
[ 0.909116] DMAR: Intel-IOMMU force enabled due to platform opt in
[ 0.909125] DMAR: No RMRR found
[ 0.909126] DMAR: No ATSR found
[ 0.909127] DMAR: IOMMU feature sc_support inconsistent
[ 0.909128] DMAR: dmar0: Using Queued invalidation
[ 0.909131] DMAR: dmar1: Using Queued invalidation
[ 0.909157] Trying to unpack rootfs image as initramfs...
[ 0.909582] pci 0000:00:02.0: Adding to iommu group 0
[ 0.909612] pci 0000:00:00.0: Adding to iommu group 1
[ 0.909642] pci 0000:00:01.0: Adding to iommu group 2
[ 0.909652] pci 0000:00:04.0: Adding to iommu group 3
[ 0.909668] pci 0000:00:07.0: Adding to iommu group 4
[ 0.909683] pci 0000:00:08.0: Adding to iommu group 5
[ 0.909691] pci 0000:00:0a.0: Adding to iommu group 6
[ 0.909700] pci 0000:00:0b.0: Adding to iommu group 7
[ 0.909715] pci 0000:00:0d.0: Adding to iommu group 8
[ 0.909724] pci 0000:00:0d.2: Adding to iommu group 8
[ 0.909733] pci 0000:00:0e.0: Adding to iommu group 9
[ 0.909746] pci 0000:00:12.0: Adding to iommu group 10
[ 0.909760] pci 0000:00:14.0: Adding to iommu group 11
[ 0.909769] pci 0000:00:14.2: Adding to iommu group 11
[ 0.909783] pci 0000:00:15.0: Adding to iommu group 12
[ 0.909792] pci 0000:00:15.1: Adding to iommu group 12
[ 0.909803] pci 0000:00:16.0: Adding to iommu group 13
[ 0.909815] pci 0000:00:19.0: Adding to iommu group 14
[ 0.909824] pci 0000:00:1c.0: Adding to iommu group 15
[ 0.909834] pci 0000:00:1c.6: Adding to iommu group 16
[ 0.909845] pci 0000:00:1c.7: Adding to iommu group 17
[ 0.909865] pci 0000:00:1f.0: Adding to iommu group 18
[ 0.909875] pci 0000:00:1f.3: Adding to iommu group 18
[ 0.909884] pci 0000:00:1f.4: Adding to iommu group 18
[ 0.909893] pci 0000:00:1f.5: Adding to iommu group 18
[ 0.909926] pci 0000:01:00.0: Adding to iommu group 19
[ 0.909938] pci 0000:01:00.1: Adding to iommu group 19
[ 0.909949] pci 0000:2c:00.0: Adding to iommu group 20
[ 0.909960] pci 0000:2d:00.0: Adding to iommu group 21
[ 0.909970] pci 0000:2e:00.0: Adding to iommu group 22
[ 0.910249] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 0.910250] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.910251] software IO TLB: mapped [mem 0x000000004b200000-0x000000004f200000] (64MB)
[ 0.910287] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c47f5688fc, max_idle_ns: 440795305069 ns
[ 0.910335] clocksource: Switched to clocksource tsc
[ 0.910353] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.924820] Initialise system trusted keyrings
[ 0.924829] Key type blacklist registered
[ 0.924869] workingset: timestamp_bits=36 max_order=24 bucket_order=0
[ 0.924990] fuse: init (API version 7.41)
[ 0.925060] integrity: Platform Keyring initialized
[ 0.925062] integrity: Machine keyring initialized
[ 0.932703] Key type asymmetric registered
[ 0.932705] Asymmetric key parser 'x509' registered
[ 0.932728] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.932779] io scheduler mq-deadline registered
[ 0.932780] io scheduler kyber registered
[ 0.932796] io scheduler bfq registered
[ 0.933108] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.933510] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 0.933718] pcieport 0000:00:07.0: PME: Signaling with IRQ 123
[ 0.933742] pcieport 0000:00:07.0: pciehp: Slot #12 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.934045] pcieport 0000:00:1c.0: PME: Signaling with IRQ 124
[ 0.934230] pcieport 0000:00:1c.6: PME: Signaling with IRQ 125
[ 0.934397] pcieport 0000:00:1c.7: PME: Signaling with IRQ 126
[ 0.934478] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.935385] ACPI: AC: AC Adapter [AC0] (on-line)
[ 0.935438] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.935453] ACPI: button: Power Button [PWRB]
[ 0.935476] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:01/input/input1
[ 0.935486] ACPI: button: Lid Switch [LID]
[ 0.946817] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.946820] ACPI: thermal: Thermal Zone [THRM] (72 C)
[ 0.947061] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.947062] ACPI: thermal: Thermal Zone [THM2] (35 C)
[ 0.947266] thermal LNXTHERM:02: registered as thermal_zone2
[ 0.947267] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.947472] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.948462] serial 0000:00:12.0: enabling device (0000 -> 0002)
[ 0.948821] hpet_acpi_add: no address or irqs in _CRS
[ 0.948877] Non-volatile memory driver v1.3
[ 0.948878] Linux agpgart interface v0.103
[ 0.969622] ACPI: bus type drm_connector registered
[ 0.973726] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.973730] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 0.974812] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 0.975048] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.975049] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 0.975050] xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.975078] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.975080] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.975082] usb usb1: Product: xHCI Host Controller
[ 0.975083] usb usb1: Manufacturer: Linux 6.12.39-1-MANJARO xhci-hcd
[ 0.975084] usb usb1: SerialNumber: 0000:00:0d.0
[ 0.975144] hub 1-0:1.0: USB hub found
[ 0.975150] hub 1-0:1.0: 1 port detected
[ 0.975325] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.975326] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.975327] usb usb2: Product: xHCI Host Controller
[ 0.975327] usb usb2: Manufacturer: Linux 6.12.39-1-MANJARO xhci-hcd
[ 0.975328] usb usb2: SerialNumber: 0000:00:0d.0
[ 0.975361] hub 2-0:1.0: USB hub found
[ 0.975369] hub 2-0:1.0: 4 ports detected
[ 0.976723] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.976725] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.977789] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 0.977989] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.977990] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.977991] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.978004] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 0.978005] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.978006] usb usb3: Product: xHCI Host Controller
[ 0.978006] usb usb3: Manufacturer: Linux 6.12.39-1-MANJARO xhci-hcd
[ 0.978007] usb usb3: SerialNumber: 0000:00:14.0
[ 0.978059] hub 3-0:1.0: USB hub found
[ 0.978070] hub 3-0:1.0: 12 ports detected
[ 0.979310] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 0.979311] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.979312] usb usb4: Product: xHCI Host Controller
[ 0.979312] usb usb4: Manufacturer: Linux 6.12.39-1-MANJARO xhci-hcd
[ 0.979313] usb usb4: SerialNumber: 0000:00:14.0
[ 0.979348] hub 4-0:1.0: USB hub found
[ 0.979353] hub 4-0:1.0: 2 ports detected
[ 0.979554] usbcore: registered new interface driver usbserial_generic
[ 0.979557] usbserial: USB Serial support registered for generic
[ 0.979590] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.980229] rtc_cmos rtc_cmos: registered as rtc0
[ 0.980358] rtc_cmos rtc_cmos: setting system clock to 2025-07-25T16:09:35 UTC (1753459775)
[ 0.980377] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.981933] intel_pstate: Intel P-state driver initializing
[ 0.984130] intel_pstate: HWP enabled
[ 0.984346] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[ 0.984347] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[ 0.986464] Freeing initrd memory: 75348K
[ 0.987372] fbcon: Deferring console take-over
[ 0.987373] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.987420] hid: raw HID events driver (C) Jiri Kosina
[ 0.987465] drop_monitor: Initializing network drop monitor service
[ 0.987530] NET: Registered PF_INET6 protocol family
[ 0.991995] Segment Routing with IPv6
[ 0.991997] RPL Segment Routing with IPv6
[ 0.992009] In-situ OAM (IOAM) with IPv6
[ 0.992036] NET: Registered PF_PACKET protocol family
[ 0.994470] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.995025] microcode: Current revision: 0x00000024
[ 0.995029] microcode: Updated early from: 0x0000001c
[ 0.995491] IPI shorthand broadcast: enabled
[ 0.996314] sched_clock: Marking stable (989129834, 6335930)->(1041788075, -46322311)
[ 0.996506] registered taskstats version 1
[ 0.996865] Loading compiled-in X.509 certificates
[ 0.998168] Loaded X.509 cert 'Build time autogenerated kernel key: 69046061655f891c2ff77cb4e18b0ec87b911ea8'
[ 0.998917] Demotion targets for Node 0: null
[ 0.999038] Key type .fscrypt registered
[ 0.999039] Key type fscrypt-provisioning registered
[ 0.999247] integrity: Loading X.509 certificate: UEFI:db
[ 1.001276] integrity: Loaded X.509 cert 'PegaSW2: 937c088519dcffa941ca83696f244f8c'
[ 1.001278] integrity: Loading X.509 certificate: UEFI:db
[ 1.001288] integrity: Loaded X.509 cert 'Microsoft Corporation: Windows UEFI CA 2023: aefc5fbbbe055d8f8daa585473499417ab5a5272'
[ 1.001288] integrity: Loading X.509 certificate: UEFI:db
[ 1.001294] integrity: Loaded X.509 cert 'Microsoft UEFI CA 2023: 81aa6b3244c935bce0d6628af39827421e32497d'
[ 1.001295] integrity: Loading X.509 certificate: UEFI:db
[ 1.001302] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 1.001303] integrity: Loading X.509 certificate: UEFI:db
[ 1.001309] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 1.002083] PM: Magic number: 1:200:187
[ 1.002127] acpi INT3472:0e: hash matches
[ 1.002164] acpi device:46: hash matches
[ 1.002816] RAS: Correctable Errors collector initialized.
[ 1.004844] clk: Disabling unused clocks
[ 1.004845] PM: genpd: Disabling unused power domains
[ 1.006487] ACPI: battery: Slot [BAT0] (battery present)
[ 1.010779] Freeing unused decrypted memory: 2028K
[ 1.011238] Freeing unused kernel image (initmem) memory: 4284K
[ 1.011253] Write protecting the kernel read-only data: 34816k
[ 1.011619] Freeing unused kernel image (rodata/data gap) memory: 2036K
[ 1.015889] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.015892] rodata_test: all tests were successful
[ 1.015895] Run /init as init process
[ 1.015895] with arguments:
[ 1.015896] /init
[ 1.015896] splash
[ 1.015897] with environment:
[ 1.015897] HOME=/
[ 1.015897] TERM=linux
[ 1.015898] BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64
[ 1.118203] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.118207] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.118902] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.123736] vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
[ 1.123740] pci_bus 10000:e0: root bus resource [bus e0-ff]
[ 1.123742] pci_bus 10000:e0: root bus resource [mem 0x86000000-0x86ffffff]
[ 1.123743] pci_bus 10000:e0: root bus resource [mem 0x4a32002000-0x4a32ffffff 64bit]
[ 1.123756] pci 10000:e0:06.0: [8086:09ab] type 00 class 0x088000 conventional PCI endpoint
[ 1.123831] pci 10000:e0:06.0: Adding to iommu group 9
[ 1.123879] pci 10000:e0:06.1: [8086:7eca] type 01 class 0x060400 PCIe Root Port
[ 1.123905] pci 10000:e0:06.1: PCI bridge to [bus e1]
[ 1.123911] pci 10000:e0:06.1: bridge window [io 0x0000-0x0fff]
[ 1.123913] pci 10000:e0:06.1: bridge window [mem 0x86000000-0x860fffff]
[ 1.123985] pci 10000:e0:06.1: PME# supported from D0 D3hot D3cold
[ 1.124026] pci 10000:e0:06.1: PTM enabled (root), 4ns granularity
[ 1.124128] pci 10000:e0:06.1: Adding to iommu group 9
[ 1.124160] pci 10000:e0:06.2: [8086:7ecb] type 01 class 0x060400 PCIe Root Port
[ 1.124186] pci 10000:e0:06.2: PCI bridge to [bus e2]
[ 1.124192] pci 10000:e0:06.2: bridge window [io 0x0000-0x0fff]
[ 1.124194] pci 10000:e0:06.2: bridge window [mem 0x86100000-0x861fffff]
[ 1.124269] pci 10000:e0:06.2: PME# supported from D0 D3hot D3cold
[ 1.124311] pci 10000:e0:06.2: PTM enabled (root), 4ns granularity
[ 1.124410] pci 10000:e0:06.2: Adding to iommu group 9
[ 1.124433] pci 10000:e0:06.1: Primary bus is hard wired to 0
[ 1.124478] pci 10000:e1:00.0: [144d:a80c] type 00 class 0x010802 PCIe Endpoint
[ 1.124504] pci 10000:e1:00.0: BAR 0 [mem 0x86000000-0x86003fff 64bit]
[ 1.124812] pci 10000:e1:00.0: Adding to iommu group 9
[ 1.124883] pci 10000:e0:06.1: PCI bridge to [bus e1]
[ 1.124893] pci 10000:e0:06.2: Primary bus is hard wired to 0
[ 1.124930] pci 10000:e2:00.0: [1344:5413] type 00 class 0x010802 PCIe Endpoint
[ 1.124950] pci 10000:e2:00.0: BAR 0 [mem 0x86100000-0x86103fff 64bit]
[ 1.125349] pci 10000:e2:00.0: Adding to iommu group 9
[ 1.125423] pci 10000:e0:06.2: PCI bridge to [bus e2]
[ 1.125434] pci 10000:e0:06.1: Primary bus is hard wired to 0
[ 1.125439] pci 10000:e0:06.2: Primary bus is hard wired to 0
[ 1.129024] sdhci: Secure Digital Host Controller Interface driver
[ 1.129026] sdhci: Copyright(c) Pierre Ossman
[ 1.136921] sdhci-pci 0000:2c:00.0: SDHCI controller found [17a0:9755] (rev 1)
[ 1.226346] usb 3-4: new full-speed USB device number 2 using xhci_hcd
[ 1.316512] pci 10000:e0:06.1: bridge window [mem 0x86000000-0x860fffff]: assigned
[ 1.316518] pci 10000:e0:06.2: bridge window [mem 0x86100000-0x861fffff]: assigned
[ 1.316520] pci 10000:e0:06.1: bridge window [io size 0x1000]: can't assign; no space
[ 1.316522] pci 10000:e0:06.1: bridge window [io size 0x1000]: failed to assign
[ 1.316524] pci 10000:e0:06.2: bridge window [io size 0x1000]: can't assign; no space
[ 1.316525] pci 10000:e0:06.2: bridge window [io size 0x1000]: failed to assign
[ 1.316528] pci 10000:e1:00.0: BAR 0 [mem 0x86000000-0x86003fff 64bit]: assigned
[ 1.316540] pci 10000:e0:06.1: PCI bridge to [bus e1]
[ 1.316545] pci 10000:e0:06.1: bridge window [mem 0x86000000-0x860fffff]
[ 1.316554] pci 10000:e2:00.0: BAR 0 [mem 0x86100000-0x86103fff 64bit]: assigned
[ 1.316564] pci 10000:e0:06.2: PCI bridge to [bus e2]
[ 1.316568] pci 10000:e0:06.2: bridge window [mem 0x86100000-0x861fffff]
[ 1.316599] pci 10000:e1:00.0: can't override BIOS ASPM; OS doesn't have ASPM control
[ 1.316851] pci 10000:e2:00.0: can't override BIOS ASPM; OS doesn't have ASPM control
[ 1.316891] pcieport 10000:e0:06.1: can't derive routing for PCI INT B
[ 1.316893] pcieport 10000:e0:06.1: PCI INT B: no GSI
[ 1.316975] pcieport 10000:e0:06.1: PME: Signaling with IRQ 163
[ 1.317085] pcieport 10000:e0:06.2: can't derive routing for PCI INT C
[ 1.317086] pcieport 10000:e0:06.2: PCI INT C: no GSI
[ 1.317139] pcieport 10000:e0:06.2: PME: Signaling with IRQ 164
[ 1.317249] vmd 0000:00:0e.0: Bound to PCI domain 10000
[ 1.348799] mmc0: SDHCI controller on PCI [0000:2c:00.0] using ADMA 64-bit
[ 1.360208] i915 0000:00:02.0: [drm] Found METEORLAKE (device ID 7d55) display version 14.00 stepping C0
[ 1.360403] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.361181] i915 0000:00:02.0: [drm] VT-d active for gfx access
[ 1.365672] usb 3-4: New USB device found, idVendor=24ae, idProduct=1870, bcdDevice= 0.00
[ 1.365674] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.365675] usb 3-4: Product: Rapoo Gaming Device
[ 1.365676] usb 3-4: Manufacturer: Rapoo
[ 1.365676] usb 3-4: SerialNumber: 20220811
[ 1.366239] nvme nvme1: pci function 10000:e2:00.0
[ 1.366242] nvme nvme0: pci function 10000:e1:00.0
[ 1.366267] pcieport 10000:e0:06.2: can't derive routing for PCI INT A
[ 1.366268] nvme 10000:e2:00.0: PCI INT A: not connected
[ 1.366272] pcieport 10000:e0:06.1: can't derive routing for PCI INT A
[ 1.366273] nvme 10000:e1:00.0: PCI INT A: no GSI
[ 1.368772] nvme nvme0: D3 entry latency set to 10 seconds
[ 1.371335] nvme nvme0: 16/0/0 default/read/poll queues
[ 1.373693] nvme0n1: p1 p2
[ 1.408351] nvme nvme1: allocated 64 MiB host memory buffer.
[ 1.432270] nvme nvme1: 16/0/0 default/read/poll queues
[ 1.440581] nvme1n1: p1 p2 p3 p4 p5
[ 1.453844] raid6: skipped pq benchmark and selected avx2x4
[ 1.453846] raid6: using avx2x2 recovery algorithm
[ 1.455520] xor: automatically using best checksumming function avx
[ 1.460214] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.460236] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[ 1.476429] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[ 1.487209] usb 3-9: new high-speed USB device number 3 using xhci_hcd
[ 1.487290] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/mtl_dmc.bin (v2.23)
[ 1.510572] Btrfs loaded, zoned=yes, fsverity=yes
[ 1.552485] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/mtl_guc_70.bin version 70.44.1
[ 1.565484] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[ 1.565489] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[ 1.565697] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[ 1.571097] i915 0000:00:02.0: [drm] GT1: GuC firmware i915/mtl_guc_70.bin version 70.44.1
[ 1.571101] i915 0000:00:02.0: [drm] GT1: HuC firmware i915/mtl_huc_gsc.bin version 8.5.4
[ 1.598153] i915 0000:00:02.0: [drm] GT1: HuC: authenticated for clear media
[ 1.598565] i915 0000:00:02.0: [drm] GT1: GUC: submission enabled
[ 1.598566] i915 0000:00:02.0: [drm] GT1: GUC: SLPC enabled
[ 1.598632] i915 0000:00:02.0: [drm] GT1: GUC: RC enabled
[ 1.600624] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[ 1.605559] [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
[ 1.606014] ACPI: video: Video Device [PXSX] (multi-head: no rom: yes post: no)
[ 1.606049] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:17/LNXVIDEO:00/input/input3
[ 1.607201] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 1.607450] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input4
[ 1.610263] fbcon: i915drmfb (fb0) is primary device
[ 1.610264] fbcon: Deferring console take-over
[ 1.610265] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 1.623055] usb 3-9: New USB device found, idVendor=3277, idProduct=0058, bcdDevice= 0.02
[ 1.623057] usb 3-9: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.623058] usb 3-9: Product: ASUS 5M WebCam
[ 1.623058] usb 3-9: Manufacturer: Shinetech
[ 1.623059] usb 3-9: SerialNumber: 200901010001
[ 1.738977] i915 0000:00:02.0: [drm] GT1: Loaded GSC firmware i915/mtl_gsc_1.bin (cv1.0, r102.1.15.1926, svn 1)
[ 1.743009] usb 3-10: new full-speed USB device number 4 using xhci_hcd
[ 1.759134] i915 0000:00:02.0: [drm] GT1: HuC: authenticated for all workloads
[ 1.877627] usb 3-10: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00
[ 1.877632] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.887872] usbcore: registered new interface driver usbhid
[ 1.887874] usbhid: USB HID core driver
[ 1.890110] input: Rapoo Rapoo Gaming Device as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:24AE:1870.0001/input/input5
[ 1.890151] hid-generic 0003:24AE:1870.0001: input,hidraw0: USB HID v1.11 Mouse [Rapoo Rapoo Gaming Device] on usb-0000:00:14.0-4/input0
[ 1.890257] input: Rapoo Rapoo Gaming Device Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:24AE:1870.0002/input/input6
[ 2.033717] hid-generic 0003:24AE:1870.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Rapoo Rapoo Gaming Device] on usb-0000:00:14.0-4/input1
[ 2.034244] hid-generic 0003:24AE:1870.0003: hiddev97,hidraw2: USB HID v1.11 Device [Rapoo Rapoo Gaming Device] on usb-0000:00:14.0-4/input2
[ 2.034644] hid-generic 0003:3277:0058.0004: hiddev98,hidraw3: USB HID v1.11 Device [Shinetech ASUS 5M WebCam] on usb-0000:00:14.0-9/input4
[ 2.041723] hid-sensor-hub 0003:3277:0058.0004: hiddev98,hidraw3: USB HID v1.11 Device [Shinetech ASUS 5M WebCam] on usb-0000:00:14.0-9/input4
[ 3.147440] BTRFS: device fsid a99d8bbc-b8cc-48fc-959e-3901264c7abb devid 1 transid 2514 /dev/nvme0n1p2 (259:2) scanned by mount (402)
[ 3.147700] BTRFS info (device nvme0n1p2): first mount of filesystem a99d8bbc-b8cc-48fc-959e-3901264c7abb
[ 3.147710] BTRFS info (device nvme0n1p2): using crc32c (crc32c-intel) checksum algorithm
[ 3.147718] BTRFS info (device nvme0n1p2): using free-space-tree
[ 3.248495] systemd[1]: systemd 257.7-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 3.248499] systemd[1]: Detected architecture x86-64.
[ 3.249052] systemd[1]: Hostname set to <ctrlx-x>.
[ 3.493906] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 3.611259] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.684632] systemd[1]: Created slice CUPS Slice.
[ 3.684990] systemd[1]: Created slice Slice /system/dirmngr.
[ 3.685289] systemd[1]: Created slice Slice /system/getty.
[ 3.685587] systemd[1]: Created slice Slice /system/gpg-agent.
[ 3.685848] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 3.686078] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 3.686310] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 3.686565] systemd[1]: Created slice Slice /system/keyboxd.
[ 3.686812] systemd[1]: Created slice Slice /system/modprobe.
[ 3.686990] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 3.687113] systemd[1]: Created slice User and Session Slice.
[ 3.687148] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.687258] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.687273] systemd[1]: Expecting device /dev/disk/by-uuid/2A1E-E02F...
[ 3.687280] systemd[1]: Expecting device /dev/disk/by-uuid/a99d8bbc-b8cc-48fc-959e-3901264c7abb...
[ 3.687289] systemd[1]: Reached target Login Prompts.
[ 3.687296] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 3.687307] systemd[1]: Reached target Remote File Systems.
[ 3.687314] systemd[1]: Reached target Slice Units.
[ 3.687324] systemd[1]: Reached target Swaps.
[ 3.687334] systemd[1]: Reached target Local Verity Protected Volumes.
[ 3.687377] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.687417] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.687869] systemd[1]: Listening on Process Core Dump Socket.
[ 3.688134] systemd[1]: Listening on Credential Encryption/Decryption.
[ 3.688170] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.688196] systemd[1]: Listening on Journal Sockets.
[ 3.688216] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.688225] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.688248] systemd[1]: Listening on udev Control Socket.
[ 3.688266] systemd[1]: Listening on udev Kernel Socket.
[ 3.688285] systemd[1]: Listening on User Database Manager Socket.
[ 3.689538] systemd[1]: Mounting Huge Pages File System...
[ 3.690071] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.690961] systemd[1]: Mounting Kernel Debug File System...
[ 3.691576] systemd[1]: Mounting Kernel Trace File System...
[ 3.692245] systemd[1]: Starting Create List of Static Device Nodes...
[ 3.692822] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.693556] systemd[1]: Starting Load Kernel Module configfs...
[ 3.694273] systemd[1]: Starting Load Kernel Module dm_mod...
[ 3.694918] systemd[1]: Starting Load Kernel Module drm...
[ 3.695672] systemd[1]: Starting Load Kernel Module fuse...
[ 3.696226] systemd[1]: Starting Load Kernel Module loop...
[ 3.696291] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 3.698368] systemd[1]: Starting Journal Service...
[ 3.699030] systemd[1]: Starting Load Kernel Modules...
[ 3.699047] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.699635] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.699678] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 3.700244] systemd[1]: Starting Load udev Rules from Credentials...
[ 3.700780] systemd[1]: Starting Coldplug All udev Devices...
[ 3.701321] systemd[1]: Starting Virtual Console Setup...
[ 3.703045] systemd[1]: Mounted Huge Pages File System.
[ 3.703168] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.703233] systemd[1]: Mounted Kernel Debug File System.
[ 3.703307] systemd[1]: Mounted Kernel Trace File System.
[ 3.703493] systemd[1]: Finished Create List of Static Device Nodes.
[ 3.703708] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 3.703833] systemd[1]: Finished Load Kernel Module configfs.
[ 3.704308] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 3.704435] systemd[1]: Finished Load Kernel Module drm.
[ 3.704626] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 3.704748] systemd[1]: Finished Load Kernel Module fuse.
[ 3.705373] device-mapper: uevent: version 1.0.3
[ 3.705394] loop: module loaded
[ 3.705441] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[ 3.705489] systemd[1]: Mounting FUSE Control File System...
[ 3.705857] systemd[1]: Mounting Kernel Configuration File System...
[ 3.706367] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 3.706491] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 3.706571] systemd[1]: Finished Load Kernel Module dm_mod.
[ 3.706672] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 3.706741] systemd[1]: Finished Load Kernel Module loop.
[ 3.706893] systemd[1]: Finished Load udev Rules from Credentials.
[ 3.707209] systemd[1]: Finished Virtual Console Setup.
[ 3.707298] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 3.707822] i2c_dev: i2c /dev entries driver
[ 3.707972] systemd[1]: Mounted FUSE Control File System.
[ 3.708142] systemd[1]: Mounted Kernel Configuration File System.
[ 3.711213] systemd-journald[474]: Collecting audit messages is disabled.
[ 3.716553] systemd[1]: Starting User Database Manager...
[ 3.735253] nvidia: loading out-of-tree module taints kernel.
[ 3.735259] systemd[1]: Started Journal Service.
[ 3.735261] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 3.760133] BTRFS info (device nvme0n1p2 state M): use zstd compression, level 1
[ 3.781501] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 3.783776] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.783925] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 3.824234] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 575.64.03 Release Build (root@)
[ 3.845355] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 575.64.03 Release Build (root@)
[ 3.849748] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.887054] mousedev: PS/2 mouse device common for all mice
[ 3.888311] Consider using thermal netlink events interface
[ 3.892198] intel_vsec 0000:00:0a.0: enabling device (0000 -> 0002)
[ 3.893051] resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:02 [mem 0xfedc0000-0xfedc7fff]
[ 3.893055] caller igen6_probe+0x158/0x7b0 [igen6_edac] mapping multiple BARs
[ 3.895616] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[ 3.897954] EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
[ 3.897972] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[ 3.897973] EDAC igen6 MC0: ADDR 0x7fffffffe0
[ 3.897984] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[ 3.897985] EDAC igen6 MC1: ADDR 0x7fffffffe0
[ 3.898069] EDAC igen6: v2.5.1
[ 3.898544] intel_vpu 0000:00:0b.0: enabling device (0000 -> 0002)
[ 3.907895] pci 0000:00:08.0: Setting to D3hot
[ 3.914274] mc: Linux media interface: v0.10
[ 3.919701] pci 0000:00:14.2: enabling device (0000 -> 0002)
[ 3.920063] intel_pmc_core INT33A1:00: Assuming a default substate order for this platform
[ 3.920169] intel_pmc_core INT33A1:00: initialized
[ 3.925248] intel_vpu 0000:00:0b.0: [drm] Firmware: intel/vpu/vpu_37xx_v1.bin, version: 20250415*MTL_CLIENT_SILICON-release*1900*ci_tag_ud202518_vpu_rc_20250415_1900*7ef0f3fdb82
[ 3.925252] intel_vpu 0000:00:0b.0: [drm] Scheduler mode: OS
[ 3.933058] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[ 3.933582] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 3.949689] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[ 3.950076] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 3.959887] NVRM: testIfDsmSubFunctionEnabled: GPS ACPI DSM called before _acpiDsmSupportedFuncCacheInit subfunction = 11.
[ 3.973049] intel-lpss 0000:00:19.0: enabling device (0004 -> 0006)
[ 3.995933] videodev: Linux video capture interface: v2.00
[ 4.019722] [drm] Initialized intel_vpu 1.0.0 for 0000:00:0b.0 on minor 0
[ 4.025935] ACPI: bus type thunderbolt registered
[ 4.026253] Bluetooth: Core ver 2.22
[ 4.026266] NET: Registered PF_BLUETOOTH protocol family
[ 4.026268] Bluetooth: HCI device and connection manager initialized
[ 4.026271] Bluetooth: HCI socket layer initialized
[ 4.026273] Bluetooth: L2CAP socket layer initialized
[ 4.026277] Bluetooth: SCO socket layer initialized
[ 4.026395] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.026488] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.026562] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 4.029294] Creating 1 MTD partitions on "0000:00:1f.5":
[ 4.029300] 0x000000000000-0x000002000000 : "BIOS"
[ 4.107320] input: ASUP1A04:00 093A:300B Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-15/i2c-ASUP1A04:00/0018:093A:300B.0005/input/input9
[ 4.107374] input: ASUP1A04:00 093A:300B Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-15/i2c-ASUP1A04:00/0018:093A:300B.0005/input/input10
[ 4.107426] hid-generic 0018:093A:300B.0005: input,hidraw4: I2C HID v1.00 Mouse [ASUP1A04:00 093A:300B] on i2c-ASUP1A04:00
[ 4.114539] input: PC Speaker as /devices/platform/pcspkr/input/input11
[ 4.122931] hid-generic 0018:0B05:0220.0006: unsupported Resolution Multiplier 0
[ 4.122962] hid-generic 0018:0B05:0220.0006: hidraw5: I2C HID v1.00 Device [ASUS2020:00 0B05:0220] on i2c-ASUS2020:00
[ 4.130330] proc_thermal_pci 0000:00:04.0: enabling device (0000 -> 0002)
[ 4.130508] intel_rapl_common: Found RAPL domain package
[ 4.130814] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 4.130859] r8169 0000:2d:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 4.130873] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 4.137042] Intel(R) Wireless WiFi driver for Linux
[ 4.137211] iwlwifi 0000:2e:00.0: enabling device (0000 -> 0002)
[ 4.137620] asus_wmi: ASUS WMI generic driver loaded
[ 4.141038] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 4.141041] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 4.141042] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 4.141043] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 4.143168] iwlwifi 0000:2e:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[ 4.143257] iwlwifi 0000:2e:00.0: PCI dev 2725/0024, rev=0x420, rfid=0x10d000
[ 4.143259] iwlwifi 0000:2e:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz
[ 4.143608] cryptd: max_cpu_qlen set to 1000
[ 4.143975] usbcore: registered new interface driver btusb
[ 4.144210] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 4.144263] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 4.144397] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 4.144401] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 4.144941] r8169 0000:2d:00.0 eth0: RTL8168h/8111h, 10:7c:61:c1:dd:1f, XID 541, IRQ 240
[ 4.144944] r8169 0000:2d:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 4.145278] No matching power limits found for this system
[ 4.145280] Could not initialise PPT tunable control 0
[ 4.145362] Bluetooth: hci0: Device revision is 0
[ 4.145365] Bluetooth: hci0: Secure boot is enabled
[ 4.145366] Bluetooth: hci0: OTP lock is enabled
[ 4.145367] Bluetooth: hci0: API lock is enabled
[ 4.145367] Bluetooth: hci0: Debug lock is disabled
[ 4.145368] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 4.145370] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 4.146391] Bluetooth: hci0: DSM reset method type: 0x00
[ 4.152327] AES CTR mode by8 optimization enabled
[ 4.158313] asus_wmi: Initialization: 0x1
[ 4.158398] asus_wmi: SFUN value: 0x21
[ 4.158400] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 4.162801] usb 3-9: Found UVC 1.10 device ASUS 5M WebCam (3277:0058)
[ 4.165321] usb 3-9: Found UVC 1.50 device ASUS 5M WebCam (3277:0058)
[ 4.166022] usbcore: registered new interface driver uvcvideo
[ 4.168349] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input12
[ 4.168390] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input13
[ 4.168430] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input14
[ 4.168455] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0/input15
[ 4.179687] iwlwifi 0000:2e:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[ 4.179935] iwlwifi 0000:2e:00.0: loaded firmware version 89.af655058.0 ty-a0-gf-a0-89.ucode op_mode iwlmvm
[ 4.181628] Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
[ 4.181636] Bluetooth: hci0: Boot Address: 0x100800
[ 4.181637] Bluetooth: hci0: Firmware Version: 88-13.25
[ 4.183542] pps_core: LinuxPPS API ver. 1 registered
[ 4.183543] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.185537] PTP clock support registered
[ 4.334553] sof-audio-pci-intel-mtl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.334647] sof-audio-pci-intel-mtl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 4.334691] sof-audio-pci-intel-mtl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.341680] sof-audio-pci-intel-mtl 0000:00:1f.3: use msi interrupt mode
[ 4.346008] intel_rapl_msr: PL4 support detected.
[ 4.346029] intel_rapl_common: Found RAPL domain package
[ 4.346032] intel_rapl_common: Found RAPL domain core
[ 4.346033] intel_rapl_common: Found RAPL domain uncore
[ 4.352673] mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops i915_gsc_proxy_component_ops [i915])
[ 4.363132] sof-audio-pci-intel-mtl 0000:00:1f.3: hda codecs found, mask 5
[ 4.363135] sof-audio-pci-intel-mtl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 4.363137] sof-audio-pci-intel-mtl 0000:00:1f.3: NHLT device BT(0) detected, ssp_mask 0x4
[ 4.363138] sof-audio-pci-intel-mtl 0000:00:1f.3: BT link detected in NHLT tables: 0x4
[ 4.363138] sof-audio-pci-intel-mtl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 4.366700] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware paths/files for ipc type 1:
[ 4.366703] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware file: intel/sof-ipc4/mtl/sof-mtl.ri
[ 4.366704] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware lib path: intel/sof-ipc4-lib/mtl
[ 4.366705] sof-audio-pci-intel-mtl 0000:00:1f.3: Topology file: intel/sof-ace-tplg/sof-hda-generic-2ch.tplg
[ 4.367254] sof-audio-pci-intel-mtl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.13.0.1
[ 4.380301] iTCO_vendor_support: vendor-support=0
[ 4.383757] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 4.383820] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.477922] sof-audio-pci-intel-mtl 0000:00:1f.3: Booted firmware version: 2.13.0.1
[ 4.503057] iwlwifi 0000:2e:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 4.503096] iwlwifi 0000:2e:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 4.503106] iwlwifi 0000:2e:00.0: WFPM_AUTH_KEY_0: 0x90
[ 4.503119] iwlwifi 0000:2e:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 4.503169] iwlwifi 0000:2e:00.0: Detected RF GF, rfid=0x10d000
[ 4.505433] iwlwifi 0000:2e:00.0: loaded PNVM version 1c1ef094
[ 4.589701] iwlwifi 0000:2e:00.0: base HW address: 80:45:dd:04:09:d4
[ 4.604017] input: ASUP1A04:00 093A:300B Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-15/i2c-ASUP1A04:00/0018:093A:300B.0005/input/input16
[ 4.604088] input: ASUP1A04:00 093A:300B Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-15/i2c-ASUP1A04:00/0018:093A:300B.0005/input/input17
[ 4.604142] hid-multitouch 0018:093A:300B.0005: input,hidraw4: I2C HID v1.00 Mouse [ASUP1A04:00 093A:300B] on i2c-ASUP1A04:00
[ 4.607758] r8169 0000:2d:00.0 enp45s0: renamed from eth0
[ 4.621649] ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
[ 4.623404] hid-sensor-hub 001F:8087:0AC2.0007: hidraw6: SENSOR HUB HID v2.00 Device [hid-ishtp 8087:0AC2] on
[ 4.625181] sof-audio-pci-intel-mtl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:1
[ 4.625341] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 4.652057] iwlwifi 0000:2e:00.0 wlp46s0: renamed from wlan0
[ 4.665670] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 4.665673] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.665674] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.665675] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 4.665675] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 4.665676] snd_hda_codec_realtek ehdaudio0D0: Headset Mic=0x19
[ 4.712964] systemd-journald[474]: Received client request to flush runtime journal.
[ 4.713654] systemd-journald[474]: File /var/log/journal/6193e21dec6b4f59ba7531e9215770ba/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.089936] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 5.106875] input: sof-hda-dsp Headset Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input18
[ 5.107121] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input19
[ 5.107169] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input20
[ 5.107219] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input21
[ 5.107255] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1/input22
[ 5.441114] Bluetooth: hci0: Waiting for firmware download to complete
[ 5.441327] Bluetooth: hci0: Firmware loaded in 1230172 usecs
[ 5.441366] Bluetooth: hci0: Waiting for device to boot
[ 5.466327] Bluetooth: hci0: Device booted in 24387 usecs
[ 5.472700] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0041-0041.ddc
[ 5.474338] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 5.477363] Bluetooth: hci0: Firmware timestamp 2025.13 buildtype 1 build 82008
[ 5.477370] Bluetooth: hci0: Firmware SHA1: 0x47cf9d0e
[ 5.481340] Bluetooth: hci0: Fseq status: Success (0x00)
[ 5.481345] Bluetooth: hci0: Fseq executed: 00.00.02.41
[ 5.481349] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[ 5.565238] NVRM: testIfDsmSubFunctionEnabled: GPS ACPI DSM called before _acpiDsmSupportedFuncCacheInit subfunction = 11.
[ 5.600320] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 0
[ 5.600554] nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
[ 5.702453] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.702456] Bluetooth: BNEP filters: protocol multicast
[ 5.702460] Bluetooth: BNEP socket layer initialized
[ 5.703223] Bluetooth: MGMT ver 1.23
[ 5.706872] NET: Registered PF_ALG protocol family
[ 5.745930] NET: Registered PF_QIPCRTR protocol family
[ 5.769730] Generic FE-GE Realtek PHY r8169-0-2d00:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2d00:00, irq=MAC)
[ 5.960056] r8169 0000:2d:00.0 enp45s0: Link is Down
[ 6.130902] iwlwifi 0000:2e:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 6.130944] iwlwifi 0000:2e:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 6.130954] iwlwifi 0000:2e:00.0: WFPM_AUTH_KEY_0: 0x90
[ 6.130965] iwlwifi 0000:2e:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 6.224842] iwlwifi 0000:2e:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
[ 6.263165] asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
[ 6.274419] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input23
[ 6.286389] asus_wmi: using asus-wmi for asus::kbd_backlight
[ 6.454022] iwlwifi 0000:2e:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 6.454066] iwlwifi 0000:2e:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 6.454108] iwlwifi 0000:2e:00.0: WFPM_AUTH_KEY_0: 0x90
[ 6.454119] iwlwifi 0000:2e:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 6.483074] ACPI: battery: new extension: ASUS Battery Extension
[ 9.319722] ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
[ 9.512882] wlp46s0: authenticate with d8:33:b7:1c:e0:b8 (local address=80:45:dd:04:09:d4)
[ 9.514148] wlp46s0: send auth to d8:33:b7:1c:e0:b8 (try 1/3)
[ 9.551201] wlp46s0: authenticated
[ 9.553049] wlp46s0: associate with d8:33:b7:1c:e0:b8 (try 1/3)
[ 9.555088] wlp46s0: RX AssocResp from d8:33:b7:1c:e0:b8 (capab=0x1011 status=0 aid=8)
[ 9.566791] wlp46s0: associated
[ 9.566834] wlp46s0: Limiting TX power to 23 (23 - 0) dBm as advertised by d8:33:b7:1c:e0:b8
[ 14.349143] systemd-journald[474]: File /var/log/journal/6193e21dec6b4f59ba7531e9215770ba/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 14.794002] nvme nvme0: using unchecked data buffer
[ 14.797458] block nvme1n1: No UUID available providing old NGUID
[ 15.660148] Bluetooth: RFCOMM TTY layer initialized
[ 15.660158] Bluetooth: RFCOMM socket layer initialized
[ 15.660159] Bluetooth: RFCOMM ver 1.11
[ 16.137221] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 179.007163] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[ 179.049841] JFS: nTxBlock = 8192, nTxLock = 65536
Thank you for your help!
