Intermittent freezes at suspend with kernel 6.1 and later
Hi all, this problem started happening to my Asus Zenbook UX310QK with kernel 6.1. It also happens with later kernels including 6.7, while it never happens with 5.15 and it didn’t happen with 6.0.
It varies, but on average 1-2 out of 10 times I suspend the laptop it does not make it to actual suspend state, the monitor goes black but the fan continues to spin and the power LED remains on (it should blink in suspend state). Then the laptop will not resume and it doesn’t respond to any keyboard input other than a long power button press for a hard shutdown.
There are no logs of the freezes, as far as the logs are concerned the machine goes to sleep and the next entry is the new (forced) boot. Maybe the disk is already powered off when the machine freezes?
Searching bugzilla.kernel.org I found a bug report which has the exact same symptoms and that’s most likely it.
My laptop has a TPM module but unfortunately no UEFI option to disable it, this is with the last available UEFI version 311.
I’ve tried blacklisting all TPM modules (tpm, tpm_tis, tpm_tis_core and tpm_crb) and bootctl status reports TPM2 Support: firmware only, driver unavailable but I’m still getting the freezes.
I’ve added some notes to the bugzilla.kernel.org report but due to the difficulty of tracking this down I was asked to open a support request with the distro, so I’ve opened this thread.
I normally run kernel 5.15 to avoid the freezes, today I’ve booted kernel 6.6 to trigger a freeze and some logs, which duly happened after a few times I suspended the laptop:
Logs with the laptop freezing on suspend:
Jan 23 15:07:20 zb kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=ff3e61d9-5eaf-4c18-a7a9-493fcf90e01c rw quiet
Jan 23 15:07:20 zb kernel: Linux version 6.6.10-1-MANJARO (builduser@fv-az1496-324) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Fri Jan  5 17:38:36 UTC 2024
Jan 23 15:07:20 zb kernel: microcode: updated early: 0x8e -> 0xf4, date = 2023-02-22
-- Boot b149451ba45d4f518b01d268fae2e804 --
Jan 23 14:25:21 zb kernel: PM: suspend entry (deep)
Jan 23 14:25:21 zb systemd-sleep[10575]: Performing sleep operation 'suspend'...
Jan 23 14:25:21 zb systemd-sleep[10575]: Failed to lock home directories: Unknown object '/org/freedesktop/home1'.
Jan 23 14:25:21 zb wpa_supplicant[626]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jan 23 14:25:21 zb wpa_supplicant[626]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 23 14:25:21 zb systemd[1]: Starting System Suspend...
Jan 23 14:25:21 zb wpa_supplicant[626]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Jan 23 14:25:21 zb wpa_supplicant[626]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 23 14:25:21 zb systemd[1]: Reached target Sleep.
Logs with the laptop NOT freezing on suspend:
Jan 23 15:21:22 zb kernel: ACPI: EC: event unblocked
Jan 23 15:21:22 zb kernel: nvidia 0000:01:00.0: Enabling HDA controller
Jan 23 15:21:22 zb kernel: ACPI: EC: interrupt unblocked
Jan 23 15:21:22 zb kernel: ACPI: PM: Waking up from system sleep state S3
Jan 23 15:21:22 zb kernel: CPU3 is up
Jan 23 15:21:22 zb kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Jan 23 15:21:22 zb kernel: CPU2 is up
Jan 23 15:21:22 zb kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
Jan 23 15:21:22 zb kernel: CPU1 is up
Jan 23 15:21:22 zb kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Jan 23 15:21:22 zb kernel: Enabling non-boot CPUs ...
Jan 23 15:21:22 zb kernel: ACPI: PM: Restoring platform NVS memory
Jan 23 15:21:22 zb kernel: ACPI: EC: EC started
Jan 23 15:21:22 zb kernel: ACPI: PM: Low-level resume complete
Jan 23 15:21:22 zb kernel: [Firmware Bug]: TSC ADJUST differs: CPU0 0 --> -21786836. Restoring
Jan 23 15:21:22 zb kernel: smpboot: CPU 3 is now offline
Jan 23 15:21:22 zb kernel: smpboot: CPU 2 is now offline
Jan 23 15:21:22 zb kernel: smpboot: CPU 1 is now offline
Jan 23 15:21:22 zb kernel: Disabling non-boot CPUs ...
Jan 23 15:21:22 zb kernel: ACPI: PM: Saving platform NVS memory
Jan 23 15:21:22 zb kernel: ACPI: EC: EC stopped
Jan 23 15:21:22 zb kernel: ACPI: EC: event blocked
Jan 23 15:21:22 zb kernel: ACPI: PM: Preparing to enter system sleep state S3
Jan 23 15:21:22 zb kernel: ACPI: EC: interrupt blocked
Jan 23 15:21:22 zb kernel: ata3.00: Entering standby power mode
Jan 23 15:21:22 zb kernel: sd 2:0:0:0: [sda] Synchronizing SCSI cache
Jan 23 15:21:22 zb kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jan 23 15:21:22 zb kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Jan 23 15:21:22 zb kernel: OOM killer disabled.
Jan 23 15:21:22 zb kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Jan 23 15:19:48 zb bluetoothd[561]: Failed to remove UUID: Failed (0x03)
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/faststream_duplex
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/sbc_xq
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/sbc_xq
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aac
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/aac
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/aptx
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/aptx_hd
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSink/aptx_hd
Jan 23 15:19:48 zb bluetoothd[561]: Endpoint unregistered: sender=:1.36 path=/MediaEndpoint/A2DPSource/ldac
Jan 23 15:19:48 zb kernel: Filesystems sync: 0.012 seconds
Jan 23 15:19:48 zb kernel: PM: suspend entry (deep)
Jan 23 15:19:48 zb systemd-sleep[1618]: Performing sleep operation 'suspend'...
Jan 23 15:19:48 zb systemd-sleep[1618]: Failed to lock home directories: Unknown object '/org/freedesktop/home1'.
Jan 23 15:19:48 zb wpa_supplicant[627]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jan 23 15:19:48 zb wpa_supplicant[627]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 23 15:19:48 zb systemd[1]: Starting System Suspend...
Jan 23 15:19:48 zb wpa_supplicant[627]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Jan 23 15:19:48 zb wpa_supplicant[627]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 23 15:19:48 zb systemd[1]: Reached target Sleep.
inxi --full --admin --filter --width
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel, plank
    wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: UX310UQK v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: UX310UQK v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: UX310UQK.311 date: 04/18/2019
  ID-1: BAT0 charge: 33.2 Wh (100.0%) condition: 33.2/48.0 Wh (69.1%)
    volts: 11.4 min: 11.4 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 879
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  Info: model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 500 high: 800 min/max: 400/3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 800
    bogomips: 23209
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia
    v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2023-11; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
    class-ID: 0302
  Device-3: Realtek USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:58d2
  Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x142d built: 2016 res: 1920x1080
    hz: 60 dpi: 166 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
    device-ID: 8086:5916 memory: 7.47 GiB unified: yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0a2b
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 221.38 GiB (46.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS512G39TND-N210A
    size: 476.94 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
  ID-1: / raw-size: 94.63 GiB size: 92.58 GiB (97.84%) used: 43.72 GiB (47.2%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4
    used: 30.9 MiB (6.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 83.12 GiB size: 81.51 GiB (98.06%)
    used: 60.08 GiB (73.7%) fs: ext4 dev: /dev/sda9 maj-min: 8:9
  ID-1: swap-1 type: partition size: 3 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 45.0 C pch: 28.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2600
  Processes: 216 Uptime: 29m wakeups: 1 Memory: total: 8 GiB
  available: 7.65 GiB used: 3.14 GiB (41.1%) Init: systemd v: 255
  Packages: 1619 pm: pacman pkgs: 1604 libs: 463 tools: octopi,pamac
  pm: flatpak pkgs: 15 Shell: Bash v: 5.2.21 running-in: xfce4-terminal
  inxi: 3.3.31
i have the same problem,except that it sometimes happens also when shutting down… and theres absolutely nothing in logs or dmesg… except these tpm related logs on 6.x kernel:
tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x201] vs fed40080 f80
these logs are not present on the 5.15 kernel… (you could check if you too have these logs on the 6 kernel, and not on the 5.15)
also have an asus laptop…
also no option in bios to turn tpm off…
currently trying the kernel parameter mentioned in the links above, and so far no issues with the 6.6 kernel…
will update back here…
Thanks for the info. I almost never shutdown my laptop, I either suspend or reboot it, so I haven’t seen this bug at shutdown, but with more shutdowns it could well happen to it too.
I’ll re-enable the tpm modules and boot kernel 6.6 to look for that log message, it isn’t on my current logs, I’ve been running 5.15 for months now.
unfortunately, the kernel parameter didnt work, it happened again, so im back with the 5.15 kernel…
I’ve been running 24 hours with kernel 6.6.10 and without blacklisting the TPM modules (bootctl status reporting TPM2 Support: yes).
No freezes yet but I’ve had to reboot the laptop a few times for other reasons, so the “counter” got reset. Also, it’s happened in the past that after a new kernel installation a few days would pass without a freeze, then one happened and after that it became regular.
I still don’t have that tpm_crb error on my logs. According to this link it started happening with kernel 5.1, which doesn’t have the suspend freezes, so it may be unrelated.
I only have one instance of Jan 23 18:45:44 zb kernel: tpm_crb MSFT0101:00: hash matches and that was 3 days ago when I had all the TPM modules blacklisted and kernel 6.6.
I also hadn’t realized that Asus generally doesn’t allow turning off TPM on BIOS/UEFI, I guess I’m not going to buy another Asus laptop.
Edit: as classic as it might sound, as soon as I closed the lid after posting the above the laptop froze :smile: you couldn’t make it up :wink:
Same usual logs, nothing relevant and no TPM related entries:
Jan 26 15:11:36 zb kernel: Linux version 6.6.10-1-MANJARO (builduser@fv-az1496-324) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Fri Jan  5 17:38:36 UTC 2024
Jan 26 15:11:36 zb kernel: microcode: updated early: 0x8e -> 0xf4, date = 2023-02-22
-- Boot b17727637b294f92af207f36b1d8f734 --
Jan 26 15:10:36 zb kernel: PM: suspend entry (deep)
Jan 26 15:10:36 zb systemd-sleep[2595]: Performing sleep operation 'suspend'...
Jan 26 15:10:36 zb systemd-sleep[2595]: Failed to lock home directories: Unknown object '/org/freedesktop/home1'.
Jan 26 15:10:36 zb wpa_supplicant[633]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jan 26 15:10:36 zb wpa_supplicant[633]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 26 15:10:36 zb systemd[1]: Starting System Suspend...
Jan 26 15:10:36 zb wpa_supplicant[633]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Jan 26 15:10:36 zb wpa_supplicant[633]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 26 15:10:36 zb systemd[1]: Reached target Sleep.
Edit 2: I’ve just had another freeze with kernel 6.6. I’ve switched back to kernel 5.15 now.
Jan 29 09:41:50 zb kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=ff3e61d9-5eaf-4c18-a7a9-493fcf90e01c rw quiet
Jan 29 09:41:50 zb kernel: Linux version 5.15.146-1-MANJARO (builduser@fv-az1497-577) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT Fri Jan 5 16:20:43 UTC 2024
Jan 29 09:41:50 zb kernel: microcode: microcode updated early to revision 0xf4, date = 2023-02-22
-- Boot c16d91f46bdc4922828db058ab74a02e --
Jan 29 09:40:47 zb kernel: PM: suspend entry (deep)
Jan 29 09:40:47 zb systemd-sleep[46373]: Performing sleep operation 'suspend'...
Jan 29 09:40:47 zb systemd-sleep[46373]: Failed to lock home directories: Unknown object '/org/freedesktop/home1'.
Jan 29 09:40:47 zb kernel: ata1: SATA link down (SStatus 4 SControl 300)
Jan 29 09:40:46 zb wpa_supplicant[637]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jan 29 09:40:46 zb wpa_supplicant[637]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 29 09:40:46 zb systemd[1]: Starting System Suspend...
Jan 29 09:40:46 zb wpa_supplicant[637]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Jan 29 09:40:46 zb wpa_supplicant[637]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 29 09:40:46 zb systemd[1]: Reached target Sleep.
going to test with the kernel parameter:
tpm.locality_on_suspend=1
which is enabled with the patch mentioned in the bug report, and will report back…
Edit:
it doesnt work, the system froze again…
also the author of the patch says that it doesnt work:
https://lore.kernel.org/all/61067410-5cbe-4b28-a31c-f994933f310d@molgen.mpg.de/T/
so back to 5.15 …
Thank you very much for trying this @brahma, I’ve had a lot of things ongoing in recent weeks and I haven’t had the time or mindset to look into it.
It’s a pity that the patch doesn’t fix it, we’ve really hit a nasty bug.
I’m struggling with the same issue that supend does not work sporadically under kernel 6.6.32. Fortunately the black screen ends after some seconds and the display comes back, so that I can give it a new try to suspend again and this works.
[username@my-pc ~]$ uname -a
Linux fidelis-pc 6.6.32-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon May 27 03:41:25 UTC 2024 x86_64 GNU/Linux
[username@my-pc ~]$ journalctl -b -p3
Jun 10 20:41:43 my-pc pulseaudio[1625]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.Unknow>
Jun 10 20:41:45 my-pc bluetoothd[966]: Failed to set mode: Failed (0x03)
Jun 10 20:41:52 my-pc kernel: ata2: softreset failed (device not ready)
Jun 10 21:12:19 my-pc kernel: Freezing user space processes failed after 20.008 seconds (1 tasks refusing to freeze, wq_busy=0):
Jun 10 21:12:39 my-pc kernel: Freezing user space processes failed after 20.009 seconds (1 tasks refusing to freeze, wq_busy=0):
Jun 10 21:12:39 my-pc systemd-sleep[23796]: Failed to put system to sleep. System resumed again: Device or resource busy
Jun 10 21:12:39 my-pc systemd[1]: Failed to start System Suspend.
Unfortunately I cannot fall back to kernel 5.15 because the boot process hangs with a black screen due to some other kernel or driver issue. This is logged from such a boot process:
username@my-pc ~]$ journalctl -b-3 -p3
Mai 31 12:37:03 my-pc kernel: ACPI Error: Aborting method \_SB.PCI0.GPP1.PTXH.RHUB.POT4._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMEN>
Mai 31 12:37:05 my-pc kernel: kvm: disabled by bios
Mai 31 12:37:05 my-pc kernel: kfd kfd: amdgpu: Failed to resume IOMMU for device 1002:15dd
Mai 31 12:37:05 my-pc kernel: amdgpu 0000:06:00.0: amdgpu: amdgpu_device_ip_init failed
Mai 31 12:37:05 my-pc kernel: amdgpu 0000:06:00.0: amdgpu: Fatal error during GPU init
Mai 31 12:37:05 my-pc kernel: BUG: kernel NULL pointer dereference, address: 0000000000000134
Mai 31 12:37:05 my-pc kernel: #PF: supervisor read access in kernel mode
Mai 31 12:37:05 my-pc kernel: #PF: error_code(0x0000) - not-present page
Mai 31 12:37:08 my-pc bluetoothd[984]: Failed to set mode: Blocked through rfkill (0x12)
If your display comes back after a while it’s probably a different bug, as one of the consistent symptoms of this bug is that the system freezes completely and the only thing that can be done is a long press of the power button for a hard shutdown.
Guys, I’m typing this with my fingers crossed… :wink: but the 2025-03-05 stable update’s kernel (6.12.12-2 → 6.12.17-1) and/or firmware (20250109.7673dffd-1 → 20250210.5bc5868b-1) seem to have fixed this bug!
I almost can’t believe it, it’s been so long since kernel 6.1 came out and at every stable update I tried running a 6.1+ kernel only to have to go back to 5.15, but after this one and 15 days of uptime running 6.12.17 things are looking good.
Very happy, as due to this bug I was planning to get a new laptop this spring, while for the rest this one is still serving me well.
I’ll wait a few more days just in case then I’ll update the kernel.org ticket.
@sergio I have the same impression like you. After upgrading to kernel 6.12.17-1 I have no longer encountered any freeze again. The issue was also discussed in this arch forum thread Issues with Mesa 24.3.x and amdgpu Vega graphics (Page 28) / Pacman & Package Upgrade Issues / Arch Linux Forums . Not sure it was fixed by the kernel upgrade or a newer Mesa driver version. I have been impacted by this bug for several months and experienced the “worst” or most “unstable” Manjaro Linux experience ever since more than 7 years. I already made thoughts of moving to new hardware. Manjaro all in all is too good to abandon it.
Good to hear, hopefully we’re out of the (freezing) woods :wink:
I also would 100% buy new hardware than leaving Manjaro, though probably this bug would have also been present in other distros with our hardware. If it were a Manjaro bug it would have been fixed soon after it’d appeared, though clearly this type of random/niche hardware related kernel bugs can be very hard to track down.
Unfortunately the problem has reappeared following 2 further updates.
After the update on my previous post I was on 21 days of uptime, which had never happened on this machine with a 6.1+ kernel, certainly indicating that the problem was fixed by it.
I then installed the below updates, had no freezes on the 3 days between them and the first one happened on 2025-03-31. 3 days without freezes have happened in the past so the culprit could be either update, with slightly more chances on the second one.
2025-03-27: kernel 6.12.17-1 → 6.12.19-1
2025-03-27: firmware 20250210.5bc5868b-1 → 20250311.b69d4b74-2
2025-03-30: kernel 6.12.19-1  → 6.12.20-2
I’ve already updated the kernel.org ticket with the above info.
