while using the laptop normally nothing would happen but as soon as i start a video game (or using DRI_PRIME=1 vblank_mode=0 glxgears
for reproducing the problem) the dgpu temperature will go above 100 degrees Celsius and will keep rising until it reaches 110 degrees and at that moment the laptop will forcibly shut itself down in order to prevent hardware damage
this problem does not exist on windows and occurred only on linux
so far i’ve tried switching both cards into amdgpu kernel driver and using amdgpu.dpm=0
kernel parameter which caused the problem but caused the issue of screen flickering at resource intensive programs. so i removed the parameter and started using acpi_call to just disable the dgpu which lowered the system performance down to potato level (update : no longer taking the said approach and using corectrl instead )
specs are :
ASUS K555D
amd fx-8800p cpu
amd radeon r7 graphics as igpu
amd radeon r8 m350 dx as dgpu
kernel 5.15 lts
configs related (updated according to megavolt recommendation) :
/etc/modprobe.d/gpu.conf
options amdgpu si_support=1
#options amdgpu cik_support=1
#options amdgpu dpm=0
options amdgpu ppfeaturemask=0xffffffff
#options amdgpu dc=1
#options amdgpu runpm=0
blacklist radeon
#options radeon cik_support=0
#options radeon si_support=0
options radeon dpm=0
result of inxi -Fazy
(the parts that seemed important):
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=d36e83c1-d5d4-47e1-897f-a454f6305bb7 rw rootflags=subvol=@ quiet
cryptdevice=UUID=cc02c371-7bb0-4b12-91e1-343a8a9bd3dc:luks-cc02c371-7bb0-4b12-91e1-343a8a9bd3dc
root=/dev/mapper/luks-cc02c371-7bb0-4b12-91e1-343a8a9bd3dc splash
resume=UUID=d36e83c1-d5d4-47e1-897f-a454f6305bb7 resume_offset=14984448
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: ASUSTeK product: X555DG v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X555DG v: 1.0 serial: <filter>
UEFI: American Megatrends v: X555DG.605 date: 04/18/2019
Info: model: AMD FX-8800P Radeon R7 12 Compute Cores 4C+8G socket: P0
bits: 64 type: MT MCP arch: Excavator family: 0x15 (21) model-id: 0x60 (96)
stepping: 1 microcode: 0x6006118
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1575 high: 2100 min/max: 1400/2100 boost: enabled
base/boost: 2100/2100 scaling: driver: acpi-cpufreq governor: ondemand
volts: 1.0 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 2100 4: 1400
bogomips: 16775
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: ASUSTeK driver: amdgpu
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:01.0
chip-ID: 1002:9874 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile]
vendor: ASUSTeK driver: amdgpu v: kernel alternate: radeon pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 03:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek USB Camera type: USB driver: N/A bus-ID: 1-1.4:5
chip-ID: 0bda:57b5 class-ID: 0e02 serial: <filter>
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x38ed built: 2014
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon R7 Graphics (CARRIZO DRM 3.42.0
5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
System Temperatures: cpu: 83.0 C mobo: N/A
Fan Speeds (RPM): cpu: 4800
GPU: device: amdgpu temp: 70.0 C device: amdgpu temp: 82.0 C
output of mhwd -l
> 0000:03:00.0 (0380:1002:6660) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:01.0 (0300:1002:9874) Display controller ATI Technologies Inc:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
output of mhwd -li
> Installed PCI configs:
output of journalctl --boot=0 --priority=5 --no-pager
: (warning : LONG) journalctl - Pastebin.com
