Sometimes (not very often) there is a continuous Not Responding message on the top of current (random) window. It may be browser or document viewer or anything. That happens if I left too many apps opened with less than 20% free RAM. Swap (file) is working as expected.
kernel 6.2.12-1-MANJARO #1 SMP PREEMPT_DYNAMIC
Xorg
Chromebook Flip Asus c302ca
CPU 2 cores (4 threads) Intel® Core™ m3-6Y30
RAM 4Gb
eMMC 64 Gb
On Clear Linux and Fedora there was no such a problem, though in both cases wayland was utilized. Actually under Xorg on Clear Linux there was sometimes Not Responding but for 2-3 seconds. On Artix Linux this behavior not noticed with linux-zen kernel.
Does kernel patches have anything to do with this issue? Thanks.
More likely just coniguration difference in general.
I am pretty sure fedora uses some form of oom-killer or early-oom or whatever, for example.
Also … heres a better way to share system info:
[HowTo] Provide System Information
Kernel: 6.2.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=cf619c44-2151-4b92-bae8-45f216fe48c6 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: Google product: Cave v: 1.0 serial: <filter> Chassis:
type: 9 serial: N/A
Mobo: Google model: Cave v: 1.0 serial: <filter> UEFI: coreboot
v: MrChromebox-4.16 date: 04/09/2022
ID-1: BAT0 charge: 29.2 Wh (100.0%) condition: 29.2/39.0 Wh (75.0%)
volts: 8.5 min: 7.7 model: AS19MZF C302-50 type: Li-ion serial: <filter>
status: charging cycles: 398
RAM: total: 3.73 GiB used: 2.15 GiB (57.6%)
Array-1: capacity: 64 GiB note: check slots: 2 EC: None
Device-1: Channel-0-DIMM-0 type: LPDDR3 detail: N/A size: 2 GiB
speed: 1867 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: Micron part-no: MT52L256M32D1PF-10 serial: N/A
Device-2: Channel-1-DIMM-0 type: LPDDR3 detail: N/A size: 2 GiB
Info: model: Intel Core m3-6Y30 bits: 64 type: MT MCP arch: Skylake level: v3
note: check built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1994 high: 2200 min/max: 400/2200 scaling:
driver: intel_pstate governor: powersave ext-clock: 100 MHz cores: 1: 2200
2: 2124 3: 1500 4: 2155 bogomips: 12007
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 515 driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: eDP-1 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:191e class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 13d3:5679 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x226d built: 2015 res: 1920x1080
dpi: 177 gamma: 1.2 size: 276x155mm (10.87x6.1") diag: 317mm (12.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 515 (SKL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio driver: sof-audio-pci-intel-skl
alternate: snd_hda_intel, snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0401
API: ALSA v: k6.2.12-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-3:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 116.2 GiB used: 13.8 GiB (11.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SD64G
size: 57.95 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/mmcblk1 maj-min: 179:8 vendor: HP model: DF4064 size: 58.24 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: GPT
ID-1: / raw-size: 57.95 GiB size: 56.74 GiB (97.91%) used: 13.8 GiB (24.3%)
fs: ext4 block-size: 4096 B dev: /dev/mmcblk1p2 maj-min: 179:10 label: N/A
uuid: cf619c44-2151-4b92-bae8-45f216fe48c6
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/mmcblk1p1
maj-min: 179:9 label: N/A uuid: 03AA-BA35
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 57.95 GiB fs: exfat label: N/A
uuid: 1F13-383B
ID-2: /dev/mmcblk1boot0 maj-min: 179:16 size: 4 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/mmcblk1boot1 maj-min: 179:24 size: 4 MiB fs: N/A label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-7:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 33.0 C pch: 29.5 C mobo: N/A
Processes: 193 Uptime: 9m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1155 libs: 330 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh (sudo)
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
That is pretty normal behavior, since it swaps RAM to the swapfile. When you open it again, it swaps other Data to swap and swap back the current needed data. Then you experience the “not responding message”.
To improve it a bit, you could decrease the swappiness to 10. That means it will avoid swapping until 10% free RAM. Now it starts swapping at 60% free RAM.
cache-pressure 100 means that it will swap data immediately when it is unused. A lower value result in a higher wait time until it swaps to disk.
You can set both by:
sudo sysctl -w vm.vfs_cache_pressure=50
sudo sysctl -w vm.swappiness=10
That is temporary.
A permanent solution would be:
sudo nano /etc/sysctl.d/99-swap.conf
and add there:
vm.swappiness = 10
vm.vfs_cache_pressure = 50
The values are just examples. You would need to adjust it to your needs and test the behavior.
Sidenote: I would not recommend using KDE with 4GB RAM. It would be much better using a more lightweight environment like i3 or sway, then you have more free RAM available for your applications.
To tag on to what @megavolt suggested … theres a script for that (and some more)
cscs / maxperfwiz · GitLab
(of course you can skip the udev tweaks and/or everything else but the 2 sysctl options above)
It stopped responding for nearly unlimited period of time , while on other Linux distro not. I guess swappiness has nothing to do here. I could understand if there was hdd to blame, but ssd is supposed not to show that behavior. Besides it may Stop Responding when I simply click on the large revealing list with more than a half free RAM. With Wayland window system there were no problems at all except OSK keyboard which is critical for laptop with touchscreen.
Well, I do not against to try another environment. If it is convenient to use with touch screen.
Thanks for the script, I will try that or change DE.
I don’t think I should manually force data to stay on the RAM, though your advice helped. But when I look into the performance script I saw I/O scheduler not set. Thus I’d rather change that setting first and leave swappiness by default. The parameter vm.vfs_cache_pressure=75 I also left as suggested. Other options were already “ideal” and not changed.
$ cat /etc/sysctl.d/99-maxperfwiz.conf
kernel.nmi_watchdog=0
vm.dirty_ratio=10
vm.dirty_writeback_centisecs=150
Just for us to know if I set that thing right for storage type (SSD) on Asus c302ca:
$ cat /etc/udev/rules.d/66-maxperfwiz.rules
ACTION==“add|change”, KERNEL==“sd[a-z]|mmcblk[0-9]*”, ATTR{queue/rotational}==“0”, ATTR{queue/scheduler}=“mq-deadline”
I need a week or so without reboot to estimate if this helped. Thanks.
u2human:
storage type (SSD)
Just a minor correction. An MMC (Multi Media Card) is not a SSD (Solid State Disk).
An MMC can barely compete with a normal HDD and is even slower (not to mention a SSD), but it is cheaper and not so bulky as an HDD. It is used on low-end devices where speed is not the main focus. So please be aware of this when using swap space on such a device.
u2human:
D-1: /dev/mmcblk0
MMCBLK0 → Multi Media Card Block 0
We will see if this cheap ssd will do its job, that’s why I left vm.swappiness=60
The speed test shows that Random Access is low. To my opinion that is the main problem how to optimize Disk I/O
KDE System Monitor Sensors do not see eMMC disk, how to fix? @cscs
