[ARM Unstable Update] 2024-09-15 - Kernels, Mesa, Plasma, LxQt, LibreOffice
Hi ARM Community,
after a long period of time ALARM managed to sync to a more current toolchain with Arch x86 again. Additionally this sync includes also Python 3.12 updates, Plasma 6.1, KDE Frameworks 6.5, KDE Gear 24.08, Gnome 46.1, LxQT 2.0, Systemd 255.6 to name a few.
A full list of updates can be found here. Based on this nature of this update we expect BROKEN INSTALLs and partly NON-BOOTING. If you need a working system and you are on arm-unstable, switch to arm-testing instead or help us to report issues and missing parts on our end, if you’re brave enough. Especially Plasma Mobile might not work, since we didn’t track development of that for months.
Additional Info
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Hi,
Nice to see an unstable update, thanks to the dev’s, keep the good work :-)
Odroid c2 && Odroid c4 && Odroid m1 && Odroid n2 tested on unstable branch, the devices are working well on wayland && x11
hola
I built an unstable image for the Odroid c4
  1. sudo getarmprofiles -f
  2. sudo buildarmimg -d oc4 -e kde-plasma -v 2024.09.15 -b unstable n
  3. I flashed the image (on emmec module) with an old balenaetcher software => balenaEtcher-1.18.11-x64.AppImage, the newer balenaetcher software don’t flash the images, error during the flash proces…
  4. The Odroid c4 boot, no issue during the setting and install process
Only issue, the keyboard I setted during the install process is not present after the install
Odroid c4 details :
[nls@c4 ~]$ fastfetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    nls@c4
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    ------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    OS: Manjaro ARM Linux aarch64
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Host: Hardkernel ODROID-C4
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Kernel: Linux 6.9.3-3-MANJARO-ARM
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Uptime: 1 min
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Packages: 796 (pacman)[arm-unstable]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Shell: bash 5.2.32
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Display (RTK FHD): 1920x1080 @ 60 Hz in 24β€³ [External]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    DE: KDE Plasma 6.1.5
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    WM: KWin (X11)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    WM Theme: plastik
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Theme: Breeze (Light) [Qt], Breeze [GTK2/3/4]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Icons: breeze [Qt], breeze [GTK2/3/4]
                                Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
                                Cursor: Breeze_Light (24px)
                                Terminal: konsole 24.8.0
                                CPU: Cortex-A55*4 (4) @ 1.91 GHz
                                GPU: Mali-G31 (Panfrost)
                                Memory: 790.93 MiB / 3.58 GiB (22%)
                                Swap: 0 B / 5.37 GiB (0%)
                                Disk (/): 4.90 GiB / 56.79 GiB (9%) - ext4
                                Local IP (eth0): 192.168.1.16/24
                                Locale: en_GB.UTF-8
[nls@c4 ~]$ date -u
dim. 15 sept. 2024 08:48:42 UTC
[nls@c4 ~]$ uname -a
Linux c4 6.9.3-3-MANJARO-ARM #1 SMP PREEMPT Sun Jun  9 20:36:00 UTC 2024 aarch64 GNU/Linux
[nls@c4 ~]$
Right now I test the Odroid c2 ! Report as soon as possible !
I built an unstable image for the Odroid c2
  1. sudo buildarmimg -d oc2 -e kde-plasma -v 2024.09.15 -b unstable n
  2. I flashed the image (on emmec module) with the Raspberry Pi Imager
  3. The Odroid c2 boot, no issue during the setting and install process
Odroid c2 details :
[nls@c2 ~]$ fastfetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    nls@c2
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Host: Hardkernel ODROID-C2
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ            β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Kernel: Linux 6.4.3-1-MANJARO-ARM-ODROID
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Uptime: 48 seconds
                                CPU: Cortex-A53*4 (4)
                                GPU: Mali450
                                Memory: 764.09 MiB / 1.88 GiB (40%)
                                Swap: 0 B / 2.81 GiB (0%)
                                Disk (/): 4.76 GiB / 56.78 GiB (8%) - ext4
                                Local IP (end0): 192.168.1.40/24
                                Locale: en_GB.UTF-8
[nls@c2 ~]$ date -u
dim. 15 sept. 2024 09:20:27 UTC
[nls@c2 ~]$ uname -a
Linux c2 6.4.3-1-MANJARO-ARM-ODROID #1 SMP PREEMPT Wed Aug 30 20:04:07 UTC 2023 aarch64 GNU/Linux
[nls@c2 ~]$
I built an unstable image for the Odroid m1
  1. sudo buildarmimg -d om1 -e kde-plasma -v 2024.09.15 -b unstable n
  2. I flashed the image (on emmc module && ssd disc && nvme disc) with the Raspberry Pi Imager
  3. The Odroid m1 boot, no issue during the setting and install process
Odroid m1 details :
[nls@m1s ~]$ fastfetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    nls@m1s
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    -------
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Host: Hardkernel ODROID-M1
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Uptime: 5 mins
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Packages: 947 (pacman)[arm-unstable]
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    WM: KWin (Wayland)
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Theme: Breeze (Classic) [Qt], Breeze [GTK2/3/4]
                                CPU: Cortex-A55*4 (4) @ 1.99 GHz
                                GPU: Mali-G52 r1 (Panfrost)
                                Memory: 1.16 GiB / 7.27 GiB (16%)
                                Swap: 0 B / 10.91 GiB (0%)
                                Disk (/): 7.11 GiB / 457.91 GiB (2%) - ext4
                                Local IP (end0): 192.168.1.7/24
                                Locale: en_GB.UTF-8
[nls@m1s ~]$ uname -a
Linux m1s 6.9.3-3-MANJARO-ARM #1 SMP PREEMPT Sun Jun  9 20:36:00 UTC 2024 aarch64 GNU/Linux
[nls@m1s ~]$ date -u
dim. 15 sept. 2024 13:08:22 UTC
[nls@m1s ~]$
I built an image for the Odroid n2, test report as soon as possible !
I built an unstable image for the Odroid n2
  1. sudo buildarmimg -d on2 -e kde-plasma -v 2024.09.17 -b unstable n
  2. I flashed the image (on emmc module) with the Raspberry Pi Imager
  3. The Odroid n2 boot, no issue during the setting and install process
issue :
  • The keyboard I setted during the install process is not present after the install
  • I set the device with auto login at boot, but no auto login after the first boot, have to set it in the system settings.
Odroid n2 details :
[nls@n2 ~]$ date -u
mer. 18 sept. 2024 08:02:58 UTC
[nls@n2 ~]$ fastfetch
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    nls@n2
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Host: Hardkernel ODROID-N2
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Uptime: 54 seconds
β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ    Packages: 924 (pacman)[arm-unstable]
                                CPU: Cortex-A53*2 + Cortex-A73*4 (6) @ 1.99 GHz
                                GPU: Mali-G52 (Panfrost)
                                Memory: 771.18 MiB / 3.58 GiB (21%)
                                Disk (/): 6.93 GiB / 56.77 GiB (12%) - ext4
                                Local IP (eth0): 192.168.1.50/24
                                Locale: en_GB.UTF-8
[nls@n2 ~]$ uname -a
Linux n2 6.9.3-3-MANJARO-ARM #1 SMP PREEMPT Sun Jun  9 20:36:00 UTC 2024 aarch64 GNU/Linux
[nls@n2 ~]$
GT King Pro - KDE-Plasma Unstable Branch, upgraded to KDE Plasma 6.1.5-1 and other packages successfully yesterday.
Orange-pi5-plus-KDE-Plasma upgraded successfully.
The update on a Pinebook Pro seems to work fine.
The only issue is the ongoing issue about wpa_supplicant. That still needs to be downgraded from currently version 2.11 to 2.10.
To do so:
  • download from Manjaro mirror
  • sudo pacman -U wpa_supplicant-2_2.10-8-aarch64.pkg.tar.xz
However this issue is not related to this update, so all seems to be fine :slight_smile:
GT King Pro-Gnome-Edition-Gnome-46. Was facing some minor visual artifacts on Nautlilus-46.2 on Gnome-Wayland earlier and now found a solution/workaround. It could be related to the new GTK4 which at first I thought was due to mesa.
Solution or workaround for the Nautilus visual artifacts:
Insert GSK_RENDERER=gl into /etc/environment and reboot.
Found a reference reference to new GTK development.
https://blog.gtk.org/2024/01/28/new-renderers-for-gtk/
If you are using GTK on very old hardware, you may be better off with the old GL renderer, since it makes fewer demands on the GPU. You can override the renderer selection using the GSK_RENDERER environment variable:
GSK_RENDERER=gl
Edit: Orange Pi 5 Plus (RK3588) Gnome-46 or Gnome-47 Wayland has NO issue with the new GTK renderer.
All in all today’s monster upgrade on unstable went pretty smooth on my devices here. So far all I had to rebuild is kodi-rpi, kodi-rpi-git and rpi-ffmpeg.
kodi-rpi-21.1-3 and kodi-rpi-git-22.x.66750.994fb30e11-1 packages pushed to the unstable branch when the mirrors sync.
UPDATED:
I decided to put rpi-ffmpeg in the repo so it will be there when the mirrors sync.
limited bandwidth hate huge update, not user friendly, sucks.
GT King Pro - Gnome Edition upgraded successfully and rpi-ffmpeg provide some limited vpu hw acceleration with mpv. Thank you.
Edit:
Hi @Darksky
The rpi-ffmpeg does works with mpv with vpu hw acceleration (may up to h264 1080p/60) on GT King Pro. Thanks.
Hi,
Odroid c2 && n2 && c4 && m1 are up to date, Thanks to the dev’s.
No new kernel during this update ?
GT King Pro - KDE Plasma Edition - Unstable Branch. Upgraded successfully to KDE Plasma 6.2.2.
SDDM login screen complained about cannot assign breath property
Can login into KDE Plasma Desktop and all seems to be working so far.
Thanks for your feedback.
Same issue on x86 in the past, it is a Breath issue solve with an update, more details below from x86 forum ( I don’t use breath but breeze :-)
Edit 1 : The dev’s read your post, the server are now up to date, see below, Enjoy !
[nls@n2 ~]$ date -u
sam. 26 oct. 2024 11:11:53 UTC
[nls@n2 ~]$ sudo pacman -Syu
[sudo] password for nls:
:: Synchronising package databases...
 core                                                       270,0 KiB   250 KiB/s 00:01 [###################################################] 100%
 extra                                                        9,5 MiB  4,78 MiB/s 00:02 [###################################################] 100%
resolving dependencies...
Packages (3) plasma6-themes-breath-24.0.0-4  plasma6-themes-breath-migration-24.0.0-4  sddm-breath-theme-24.0.0-4
Total Download Size:   65,67 MiB
Total Installed Size:  66,16 MiB
Net Upgrade Size:       0,03 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 plasma6-themes-breath-migration-24.0.0-4-aarch64            18,0 KiB  30,0 KiB/s 00:01 [###################################################] 100%
 sddm-breath-theme-24.0.0-4-any                             151,8 KiB   161 KiB/s 00:01 [###################################################] 100%
 plasma6-themes-breath-24.0.0-4-any                          65,5 MiB  16,1 MiB/s 00:04 [###################################################] 100%
 Total (3/3)                                                 65,7 MiB  15,6 MiB/s 00:04 [###################################################] 100%
(3/3) checking keys in keyring                                                          [###################################################] 100%
(3/3) checking package integrity                                                        [###################################################] 100%
(3/3) loading package files                                                             [###################################################] 100%
(3/3) checking for file conflicts                                                       [###################################################] 100%
(3/3) checking available disk space                                                     [###################################################] 100%
(1/3) upgrading plasma6-themes-breath-migration                                         [###################################################] 100%
(2/3) upgrading plasma6-themes-breath                                                   [###################################################] 100%
(3/3) upgrading sddm-breath-theme                                                       [###################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
[nls@n2 ~]$ reboot
Breath theme is now updated to Plasma 6.2.
Thanks @philm. The breath and sddm theme updates resolved the login screen issue on GT King Pro Manjaro-Arm-KDE Edition. All seems well except on GT King Pro KDE Edition 6.2.2 glmark2-es2-wayland score (around 1100+) is much than Gnome Edition 47.1 (1600+)
And KDE Edition Chromium or Firefox performance based on webglsamples.org Aquarium or Lots-O-Images are also lower than Gnome Edition.
Wonder other users had the same or similar experience on KDE Edition.
pacman-7 warring,
warning: config file /etc/pacman.conf, line 19: directive β€˜SyncFirst’ in section β€˜options’ not recognized.
Hi,
Post on the new unstable post => arm-unstable-update-2024-10-27 :-)
The issue look like an issue reported yesterday, see below
Update your device with the last pacman update…
pacman-7.0.0.r10.ga2d0293-1-aarch64
I am thinking your mirrors were not fully synced with the latest packages. The latest removes that outdated line 19 during install.
Xorg-server etc had an big security issue. And has been patched…
https://lists.x.org/archives/xorg-announce/2024-October/003545.html
