I’m not on unstable branch but stable. I can test it this week-end…
doesn’t work, I think it’s the raison the dev team don’t push the unstable update for the moment, they have to solve some issue…
[nls@lap ~]$ sudo buildarmimg -d on2 -e kde-plasma -v 2024.03.18 -b unstable n
==> Creating kde-plasma edition rootfs image for on2…
→ Removing old aarch64 rootfs…
→ Extracting aarch64 rootfs…
→ Setting up keyrings…
→ Setting branch to unstable…
==> Installing packages for kde-plasma edition on on2…
core downloading…
extra downloading…
community downloading…
:: Some packages should be upgraded first…
resolving dependencies…
Packages (2) manjaro-arm-keyring-20240211-2 manjaro-keyring-20230719-2
Total Installed Size: 0.11 MiB
Net Upgrade Size: -0.61 MiB
checking keyring…
checking package integrity…
loading package files…
checking for file conflicts…
checking available disk space…
:: Processing package changes…
upgrading manjaro-arm-keyring…
gpg: Warning: using insecure memory!
==> Appending keys from manjaro-arm.gpg…
gpg: error reading key: No public key
==> Locally signing trusted keys in keyring…
→ Locally signed 1 keys.
==> Importing owner trust values…
==> Disabling revoked keys in keyring…
→ Disabled 1 keys.
==> Updating trust database…
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 21 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 21 signed: 2 trust: 0-, 0q, 0n, 21m, 0f, 0u
gpg: depth: 2 valid: 1 signed: 0 trust: 1-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2026-08-21
upgrading manjaro-keyring…
==> Delete expired Key by Jonas Strassel
==> ERROR: The key identified by A44C644D792767CED7941AFEABB2075D5F310CF8 could not be found locally.
error: command failed to execute correctly
==> Appending keys from manjaro.gpg…
→ Locally signed 3 keys.
gpg: setting ownertrust to 4
→ Disabled 8 keys.
gpg: depth: 0 valid: 1 signed: 22 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 22 signed: 2 trust: 0-, 0q, 0n, 22m, 0f, 0u
:: Starting full system upgrade…
:: There are 2 providers available for dbus-units:
:: Repository core
- dbus-broker-units 2) dbus-daemon-units
Enter a number (default=1):
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
- qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
warning: cannot resolve “kjs”, a dependency of “okular”
:: The following package cannot be upgraded due to unresolvable dependencies:
okular
:: Do you want to skip the above package for this upgrade? [y/N]
:: unable to satisfy dependency ‘kjs’ required by okular
==> ERROR: Aborting…
==> Creating kde-plasma edition image for on2…
→ Creating ext4 partitions…
→ Copying files to image…
mv: cannot stat ‘/var/lib/manjaro-arm-tools/tmp/root/boot/*’: No such file or directory
→ Writing the boot loader images…
Boot PARTUUID is 21643652-01…
Root PARTUUID is 21643652-02…
Root UUID is 8afc975e-6db6-4638-afb1-4b216128aecf…
→ Cleaning up image…
→ Compressing Manjaro-ARM-kde-plasma-on2-2024.03.18.img with xz…
Manjaro-ARM-kde-plasma-on2-2024.03.18.img: 2 846,7 KiB / 1 820,0 MiB = 0,002, 205 MiB/s, 0:08
→ Removing rootfs_aarch64…
==> Time elapsed: 1.52 minute(s)
[nls@lap ~]$
